UXL-18 Subwoofer driver Group Buy (is now closed out/over/done/fini) !!!! - Page 29 - AVS Forum | Home Theater Discussions And Reviews
post #841 of 1399 Old 03-04-2014, 04:23 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Originally Posted by fuzz092888 View Post
What's the output look like after adding the filter?
Here ya go.............
doublewing11 is offline
post #842 of 1399 Old 03-04-2014, 04:32 PM
Quoted: 229 Post(s)
Liked: 968
Originally Posted by steve nn View Post
Yeah way back when I bought a kit that they didn't have lined up right and it turned out to be a real pain in the arss! They also said nothing about gluing which would have been nice if lined up correctly. rolleyes.gif
Rafter squares and glue works well!  ;)
If you have the tools, the insert with glue whether Gorilla, Titebond II, or pig fat...............is the cleaner, better looking alternative.  Screws in MDF I'd avoid at all cost.  That doesn't leave too many options...............
post #843 of 1399 Old 03-04-2014, 04:42 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1669 Post(s)
Liked: 1490
The concern with tee nuts or inserts like Double showed is the potential for them to come undone when trying to remove the screws, which is why I'd go with the glue route using some epoxy. If an insert or tee nut comes undone, you'll have to cut a hole in the enclosure to remove the insert. But even with that danger, I'd still recommend some sort of insert instead of a screw in bare wood.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is online now
post #844 of 1399 Old 03-04-2014, 04:59 PM
steve nn's Avatar
Liked: 433
Screws though MDF into 3/4 ply backing works just fine when mounting ring covers (you can't tell me different) 65 pounds is very heavy though, so I would suggest something like this http://www.parts-express.com/cast-frame-1-4-20-speaker-mounting-kit--260-778 with straight MDF.
doublewing11 likes this.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #845 of 1399 Old 03-04-2014, 05:13 PM
Quoted: 229 Post(s)
Liked: 968
I have no problem with that..................but if you're like me, when you change out drivers every 6 months, then my method just might be more convenient........................:D
BTW, those t-nuts in plywood would be fine............but NOT in MDF.....................  shrugs
post #846 of 1399 Old 03-04-2014, 05:21 PM
steve nn's Avatar
Liked: 433
I have no problem with that..................but if you're like me, when you change out drivers every 6 months, then my method just might be more convenient........................biggrin.gif
That's why I like the ply backing route, but without the mounting ring it wouldn't look good. I've maybe had one or two get loose over the years and just break off 2-4 wooden toothpicks in the hole and no problemo. Whatever a guy wants though, just so it works.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #847 of 1399 Old 03-04-2014, 06:05 PM
Quoted: 229 Post(s)
Liked: 968
Makes perfect sense...........if you like to screw.
I like to bolt!  :D
post #848 of 1399 Old 03-04-2014, 08:32 PM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1217
I just make all my mounting panels out of 1" ply. Use any screws you want and never worry about them coming loose.
N8DOGG is offline
post #849 of 1399 Old 03-05-2014, 06:04 AM
Spiderm0n's Avatar
Wow, lots of mounting strategies. Thanks guys!
My Gear: Sony VPL-HW40ES, 130" Spandex Screen, Onkyo TX-NR818, Fusion 12 Tempests (LCR), Axiom M3 & M2 Surrounds, Mach 5 UXL 18 Subwoofer
My theater: Escape from New York theater build
Spiderm0n is offline
post #850 of 1399 Old 03-05-2014, 10:24 AM
Rebel975's Avatar
Quoted: 21 Post(s)
Liked: 127
Mine should be delivered tomorrow... along with a pair of Fusion-12's. biggrin.gif
Monkey_Man likes this.
Rebel975 is offline
post #851 of 1399 Old 03-05-2014, 10:45 AM
steve nn's Avatar
Liked: 433
Spid> Wow, lots of mounting strategies. Thanks guys!
You will notice some of the dumb things we get going over here. There can five methods that work very well and some guy will post this is the only way to do it rolleyes.gif lol We all have our ways including some bad ways that might need tweaking? Or you have to do it this way because it's 2% better than your 95% when only 50% is required.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #852 of 1399 Old 03-05-2014, 12:27 PM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
Here at the avs forum, massive overkill is minimum code of practice.
steve nn likes this.
Monkey_Man is offline
post #853 of 1399 Old 03-05-2014, 12:46 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Touchdown!
jbrown15 is offline
post #854 of 1399 Old 03-05-2014, 02:07 PM - Thread Starter
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
blah450 is offline
post #855 of 1399 Old 03-05-2014, 03:02 PM
Quoted: 229 Post(s)
Liked: 968
Originally Posted by jbrown15 View Post
Touchdown!
Ok......
I googled 7951 Surrey, BC........and this is what I got!
post #856 of 1399 Old 03-05-2014, 05:38 PM - Thread Starter
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
Selling my miniDSP 2x4 Balanced kit revision B (latest). Like new, no-smoke, no pet environment. All original/factory packaging...about 20 hours of use.
Will include 12V power supply speced exactly for hardware. Power supply comes with a tinned whip for connection to Phoenix blocks.
This power supply has not been cannabalized...was matched to and used only with DSP.
$100 shipped CONUS with supply.
edit: it appears that one of our fine AVSers is already all over this...will post again if there is a problem.
blah450 is offline
post #857 of 1399 Old 03-05-2014, 06:20 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
There's some additional venting that I haven't seen in previous pics.
gpmbc is offline
post #858 of 1399 Old 03-05-2014, 06:25 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Here's before
gpmbc is offline
post #859 of 1399 Old 03-05-2014, 06:44 PM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
I have those too but Mark installed miniature tailpipe whistles on mine for a little wooo woooooooo! True story.
popalock likes this.
post #860 of 1399 Old 03-05-2014, 07:03 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Pics?
gpmbc is offline
post #861 of 1399 Old 03-05-2014, 07:20 PM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
post #862 of 1399 Old 03-05-2014, 07:37 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Lol
gpmbc is offline
post #863 of 1399 Old 03-05-2014, 08:04 PM
wvu80's Avatar
Quoted: 329 Post(s)
Liked: 293
Originally Posted by Monkey_Man View Post
http://youtu.be/JZD-ADArwXo
Nice. There is NOBODY pictured on that vid except the TV host who could pass a drug screen, I guarantee you.
Could we go back to the "screw mount" topic for a minute? (man, there is NO way to say that without it sounding X-rated)
I am ready to pull the trigger on some screws or bolts to mount my 15" woofers in MDF (3/4" inner baffle plus 3/4" outer baffle). I went to my local Lowes tonight and the Tee nuts were more than $3 each. I have been looking at the PE offerings, and this is what I think I need, a mounting kit with 8 screws/t-nuts:
http://www.parts-express.com/cast-frame-10-32-speaker-mounting-kit--260-776
My problem is how this will work with MDF. Some of you say this is exactly the thing, some of you say "never in MDF." Some of the review have the same mixed message.
I don't need 50 tee nuts, but for $6 this product has 6 teeth and the feedback says "works with MDF." Opinions?
http://www.parts-express.com/10-32-deluxe-6-prong-t-nuts-50-pcs--081-1088
And of course, 4 prong, with a course thread.
http://www.parts-express.com/10-24-t-nuts-50-pcs--081-1073
wvu80 is offline
post #864 of 1399 Old 03-06-2014, 03:10 AM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
post #865 of 1399 Old 03-06-2014, 03:46 AM
popalock's Avatar
Quoted: 1311 Post(s)
Liked: 1813
Ahhh fond memories of ol Bubb Rubb and the Woooo woooooooo clan...lol
popalock is offline
post #866 of 1399 Old 03-06-2014, 04:42 AM - Thread Starter
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
Monkey...they worked well, right?
They seem ideal...coarse thread for the MDF/wood...wide head and flat underneath to prevent pull-through.
Choose the length that is appropriate for project (longer is available if anyone is using plywood backer pieces, which is a great idea)...pre-drill some small holes...and good to go! biggrin.gif
blah450 is offline
post #867 of 1399 Old 03-06-2014, 05:02 AM
Monkey_Man's Avatar
Quoted: 93 Post(s)
Liked: 51
Yeah I went with 1-1/2" for my application. my baffle is 3/4 MDF and 3/4 birch plywood. I know the coarse thread isn't ideal with the birch (hardwood), but we will see how it goes. I like the square drive, black coated, and flat washer head which is hard to find in a wood screw. I just wish there was more thread. Since its a pocket screw so the thread length makes sense.
post #868 of 1399 Old 03-06-2014, 05:56 AM
Deep Sea Sound
dgage's Avatar
Liked: 1490
The concern with tee nuts is that they might loosen over time or destroy the surrounding wood if tightened too much. I think MDF is even more concerning for that. If the tee nut gets loose, your only real option is to cut a hole in your enclosure. This is why I made custom mounts for my big LMS 5400s.
Here is what I'd recommend for you but I'd glue some plywood in first so the screws could have something to mount to.
http://www.rockler.com/screw-on-tee-nuts-choose-size-thread
Or you could just use a coarse screw as others have suggested and screw into a glued plywood block.
If you do use regular tee nuts on MDF or plywood, epoxy them in place to reduce the chances of them loosening. And tighten your screws snug but don't overdo it or you could twist the tee nuts inside which would be bad.
David Gage
Deep Sea Sound
dgage is online now
post #869 of 1399 Old 03-06-2014, 03:36 PM
Spiderm0n's Avatar
I'm proud to announce the arrival of my UXL-18 by UPS. Arrival time was 6:20 pm, and he weighs 50.4 pounds. Both daddy and baby are sleeping well. biggrin.gif
post #870 of 1399 Old 03-06-2014, 04:16 PM - Thread Starter
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
Thanks, Spider. I guess that definitively nails the weight of the driver question!
blah450 is offline
