FoLLgoTT's build: 18 x Peerless XXLS12 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #181 of 226 Old 03-20-2014, 02:43 AM
rumpeli's Avatar
Hi Nils,
why do you prefer the Klein + Hummel Pro C 28 equalizer for the subwoofers over the in HT applications more popular budget ones. Is it for the use of FIR filters? And if so, then I bet that somewhere you wrote about the pros and cons and how you proved with own measurements but I missed that part.
best regards
rumpeli
rumpeli is offline
post #182 of 226 Old 03-20-2014, 04:22 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
No, I don't use the FIR filter section. In fact it is not possible to use it without a parameter set from Neumann. And I don't need it in the low end. Group delay is so low that it is just not necessary.
The initial reason to use the Pro C 28 was that its IIR parametric equalizer can be configured down to 10 Hz. Beside that this device is extremely flat down to 2 Hz and has a high dynamic range of +26 dBu. So clipping will never occur.
I bought the Pro C 28 second hand for a good price. I would never pay the new price for this application, since I use only 10% of its capabilities. wink.gif
FoLLgoTT is online now
post #183 of 226 Old 03-20-2014, 04:37 AM
rumpeli's Avatar
That confirms my guessing, also since you elaborated elsewhere about the audibility of phase and group delay. However, some say this could be relevant <200 Hz. In case you don't know it already, a google research on the pro C28 lead me to this paper on phase distortion http://forum2.magnetofon.de/bildupload/goosphase.pdf (german content, sorry guys).
rumpeli is offline
post #184 of 226 Old 03-24-2014, 08:32 AM
desertdome's Avatar
Quoted: 1072 Post(s)
Liked: 1160
Originally Posted by markus767 View Post
In the next version REW has a checkbox "Room is sealed".
I see the beta 18 of REW 5 was now released and includes a bunch of room simulation changes. It will be interesting to see how the DBA and SBA model now that you can delay the subs.
Beta 18 changes (23rd March 2014):
Room sim: Added option to show anechoic response
Room sim: Added enclosure type selection (sealed/ported)
Room sim: Added delay and gain adjustments for each speaker/sub
Room sim: Levels are automatically adjusted to maintain 75 dB at main listening position regardless of number of speakers/subs selected
Room sim: Changed response graph range from 45..105 dB to 35..95 dB
Room sim: Added a check box to indicate whether room is well sealed (if room is sealed response is boosted below lowest mode)
Room sim: changed -3 dB defaults for subs to 30 Hz and speakers to 80 Hz
High Impact AV
- Colorimetry Research CR-250 Spectroradiometer & CR-100 Colorimeter
desertdome is offline
post #185 of 226 Old 03-24-2014, 09:04 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
That's great! I posted a sreenshot in the DBA thread. Maybe we can discuss it there.
post #186 of 226 Old 04-07-2014, 11:17 AM
rabident's Avatar
Quoted: 314 Post(s)
Liked: 104
Originally Posted by Adhoc1 View Post
A guy I know actually decreased a problem mode inside his HT by making openings through the walls at the corners towards another rooom / closet which acted as a large Helmholtz resonator. (My opinion:With windows closed, you have a sealed speaker with some losses but there is also some room gain + some pressure gain (less than 12 dB for the ideal fully sealed room). Combined these more or less even out the natural roll off of your sealed speakers.Noah is right about the open windows being perfect absorbers, not for a 6 Hz wave length but for all those close to or smaller than the windows dimensions.
I've always wondered why room designers go to great lengths to contain sound within the room, only to have it bounce around and cause problems, which then takes even more money to fix. Why not have a thin wall and let the low frequency "leak" out into the woods?
rabident is offline
post #187 of 226 Old 04-07-2014, 11:55 AM
markus767's Avatar
Quoted: 3492 Post(s)
Liked: 1243
Why not charge double if you can wink.gif Two better reasons for acoustically isolating a room:
- Don't disturb neighbors
- Keep environmental noise out of the listening room
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #188 of 226 Old 04-07-2014, 06:37 PM
noah katz's Avatar
Quoted: 855 Post(s)
Liked: 299
Missed this until I saw it quoted.
I don't believe the size of the opening relative to a wavelength is related to the wavelength.
A hole is hole; where there was a boundary that would develop pressure and reflect energy, there is now nothing.
Noah
noah katz is online now
post #189 of 226 Old 04-08-2014, 04:12 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Excellent thread! I have some questions regarding your baffle wall & subwoofer configuration.
First, are those subs setup as an IB or do you just use sealed enclosures mounted flush to the baffle wall?
Second, I see that you have your baffle wall angled to toe in the Left & Right mains instead of curving the way you made actual angles. I am curious if those angles in the baffle wall are going to cause any issues with reflections off each wall that each speaker is pointing at?
I would imagine that doing a curved baffle wall would be very difficult, yet, ideal. I plan to start on my baffle wall this coming week as soon as I get moved into our new home. I have never built a baffle wall, but, I want to do something similar to yours with the mains being toed in.
Can you explain how you came up with the proper angle of toe in on each side of the wall? Also, are your subs mounted at the 1/4 point in between each wall?
Martycool007 is offline
post #190 of 226 Old 04-08-2014, 04:59 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
The subwoofer enclosures are mounted on the wall.
I chose the angle which let the speakers point to my reference seat. This was my only criterion.
I investigated a bit toward possible reflections on the baffle wall, but I could not measure any significant effect. I used absorbers to cover the points of possible reflections. But my speakers have waveguides and thus a high directivity. Which means even if there were reflections on the baffle wall they would be attenuated.
1/4 is not possible with 18 drivers. wink.gif
I used the formula I posted here. The distance between the drivers is 1/6 of wall width and 1/3 of wall height. The placement depends on the number of drivers. smile.gif
post #191 of 226 Old 04-08-2014, 05:13 AM
Quoted: 280 Post(s)
Liked: 176
Any particular reason behind using those locations for the subs? Do those positions offer any similar benefits to mounting at the 1/4 points?
I like your baffle wall! I am about to start my baffle wall and would like to do something similar to yours, but, I am limited on carpentry knowledge and have no idea how you can make those angles like you have. Perhaps you could give me some pointers on how to properly construct a baffle wall with curved sides for toeing in your L+R speakers? smile.gif
I have all the tools and have some decent experience with building subwoofer & speaker enclosures, but, I have never tackled a baffle wall, and to be honest, it scare's me!
post #192 of 226 Old 04-08-2014, 01:44 PM
jeno's Avatar
Quoted: 22 Post(s)
Originally Posted by jeno View Post
Hi!
Does the angle on the baffle wall mean that you should delay the outer bass drivers in order to have a planar wave? Or doesn't it matter that much for the lower frequenzies?
I try to post this once more since there has been some discussion on angling.
jeno is offline
post #193 of 226 Old 04-08-2014, 02:02 PM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
Yes. It is just a scaling to more drivers. Even one driver at 1/2 works up to a certain frequency.
To the construction of the angle: I have multiple parts. Two big subwoofers with 6 drivers and two subwoofers with 3 drivers. The columns with 3 drivers are placed in that way that the gap could be closed with the main speakers and with boards. I screwed everything directly into the subwoofer enclosures. The space behind the columns is empty to avoid mold. There is no secret trick in this construction. smile.gif
It doesn't matter. Furthermore there is no big difference at all in frequency response when the outer columns are disconnected.
post #194 of 226 Old 04-08-2014, 02:20 PM
jeno's Avatar
Quoted: 22 Post(s)
jeno is offline
post #195 of 226 Old 04-09-2014, 06:29 AM
Quoted: 280 Post(s)
Liked: 176
And you are sure that by having the baffle walls sides toed in with hard angles rather than a smooth curvature will not take away any of the benefits of having a regular more traditional flat baffle wall?
post #196 of 226 Old 04-09-2014, 06:47 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
I'm sure that listering to the front speakers without angle is the worst case. wink.gif
And a smooth curvature is much harder to build. Of course I would prefer it if I were able to build it.
post #197 of 226 Old 04-09-2014, 07:03 AM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
I work with engineers in Austria quite often. The personality when building things is a bit unique (e.g. over the top) on simple things. I knew you were over the top in a sense. However, over there, over the top has many levels. Seeing that junction/terminal block (lower right) just put you at a 9/10. tongue.gif
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #198 of 226 Old 04-09-2014, 08:06 AM
pnw
pnw's Avatar
Quoted: 47 Post(s)
Liked: 74
Directivity of you mains is not absolute so, rather than firing straight into the room with a lot of inadvertent "splash" from the sidewalls, angled L&Rs direct sound across the listening area. A smooth curved wall would probably be even better, but more difficulty than benefit...better to put the additional effort into the rest of the room.
pnw is offline
post #199 of 226 Old 04-10-2014, 03:36 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
Yes, german/austrian engineers are a bit special. My wife could tell you stories, because I'm a Dipl.-Ing. (M.Eng.) myself! tongue.gif
I love those tiny little bastards. It is so easy to reconfigure all the subwoofer connections. No screwing and no soldering necessary. wink.gif
Btw, my main speakers are connected with the big 8-pole speakON connectors. Together with a multicore cable it feels really big, heavy and solid. No comparison to those cumbersome banana plugs...
post #200 of 226 Old 09-09-2014, 11:45 PM
mikela's Avatar
Quoted: 191 Post(s)
Liked: 221
Any updates?
mikela is offline
post #201 of 226 Old 10-30-2014, 01:28 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
Originally Posted by mikela View Post
Any updates?
Not much. Since my daughter was born there was not much progress.
But I had a bit time to build the second riser.
The next steps are:
- floor covering
- covering the sides with fabric
- speakers on the ceiling (->ATMOS)
- seats/couch
- final adjustment of room acoustics
Time is the biggest problem at the moment...
ID:	339961   Click image for larger version
ID:	339969   Click image for larger version
ID:	339977   Click image for larger version
ID:	339985   Click image for larger version
post #202 of 226 Old 10-30-2014, 11:02 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 107
Does it make any significant difference if you leave the plastic on the rockwool or remove it. Most people on the forums usually recommend wrapping absorber panels with air permeable fabric. You seem to go in the opposite direction leaving the foil on?
splotten is offline
post #203 of 226 Old 10-30-2014, 01:38 PM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
The plastic doesn't make any difference at the low frequencies. In fact it even amplifies the absorption a bit, because it acts like a membrane absorber. But for the mid's and high's the difference is big. The plastic reflects them which doesn't lower the RT60 too much.
I'll decide later if I leave the plastic or if I remove it. It depends on the final measurement when the seatings are installed.
post #204 of 226 Old 10-30-2014, 01:54 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 107
Thanks. Ill remember that. Might come in useful if the room gets too "dead" when putting in a lot of absorption.
splotten is offline
post #205 of 226 Old 10-30-2014, 06:51 PM
mikela's Avatar
Quoted: 191 Post(s)
Liked: 221
I understand completely. I have a daughter that will be 2 on Dec 7th. Very time consuming
I am in the process of building my own SBA using yours as a guideline. I'll soon be posting a build thread in the construction forum. I am guessing from your comments on the insulation bales, that it may be unnecessary to add a Styrofoam diffuser on the back wall? I am using 3 Danley SM60Fs for LCR, 12 Ficar IB315 15" subwoofers on dual manifolds in an IB and 8" coaxes as surrounds and atmos.
Name:	Preliminary Theater Model.png
mikela is offline
post #206 of 226 Old 03-06-2015, 11:52 PM
clausdk's Avatar
Quoted: 204 Post(s)
Liked: 78
Any progress?:-)
clausdk is online now
post #207 of 226 Old 04-06-2015, 12:36 AM
Quoted: 93 Post(s)
Liked: 48
Originally Posted by clausdk View Post
Any progress?:-)
yeah what he said
Doradoguy is offline
post #208 of 226 Old 04-06-2015, 12:43 AM
Quoted: 93 Post(s)
Liked: 48
Fllgott do you have any details on your skyline?
post #209 of 226 Old 04-06-2015, 01:05 AM - Thread Starter
FoLLgoTT's Avatar
Liked: 118
Originally Posted by Doradoguy View Post
yeah what he said
There is not much progress. I installed the floor covering. I used black PVC for the part in front of the screen and vinyl tiles with wooden decor for the riser.
And I bought LED edge profiles for the steps. The profiles for the riser are not installed yet.
I really don't have the time to finish the room soon. In fact I watch one movie every few weeks.
Those are the Vicoustic Multi Fuser DC2. They can be bought in black, grey or white.
mikela and popalock like this.
post #210 of 226 Old 04-06-2015, 04:06 PM
mikela's Avatar
Quoted: 191 Post(s)
Liked: 221
Now that's what i call a MLP!!!
mikela is offline
