FoLLgoTT's build: 18 x Peerless XXLS12 - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #211 of 226 Old 05-21-2015, 12:37 PM
Flaesh's Avatar
Liked: 2
Originally Posted by FoLLgoTT View Post
.. This means that an open window is definitely not the same as an equivalent-sized absorber in the same place.
Agree. As I measured 5 years ago opening\closing door in back wall makes about nothing with room length modes.
(I was hoping that would help )
Flaesh is offline
post #212 of 226 Old 11-13-2015, 07:12 AM
Tenson's Avatar
Liked: 0
Hello,
I'm desperately trying to find one pair or even a single unit of Tang Band 75-1558se mid dome. Can anybody help me, please?
Solen have one unit in stock so if I can find one more I'll get my pair.
Simon
Tenson is offline
post #213 of 226 Old 11-13-2015, 09:04 AM
Tenson's Avatar
Liked: 0
Thank you Nils.
I can not sent PM becasue my post count is too low.
I have contacted the shop you suggested.
If they don't have stock, do you have any you are willing to sell?
Simon
Tenson is offline
post #214 of 226 Old 01-07-2017, 03:55 AM
dkelly60's Avatar
A question about DBA and SBA, is the rigidity of the wall essential to operation? If you use sound insulation like double drywall & green glue, will it cause problems?
dkelly60 is offline
post #215 of 226 Old 01-07-2017, 08:31 AM
mikela's Avatar
Quoted: 195 Post(s)
Liked: 231
Use of DD, GG and hat channel will assist in reducing low frequency resonant modes. This is due to the flex in the wall. It works fine in my SBA.
mikela is online now
post #216 of 226 Old 01-09-2017, 05:48 AM
dkelly60's Avatar
I have sub'd your thread will read more when I get a chance. And yeah hat channel+ thanks for the reminder.
One reason I am thinking DBA over SBA is I want a dual purpose room an audio lounge (for 2 channel listening and chatting) at one end and theater at the other. It seemed to me that it would be simple to have the DBA reversible so the bass can come from either end. Do you think a DBA would also be Ok with the walls?
Can you tell me how much effect the rows of seating have on your SBA? Also what level of bass do you get from your array? I would need to use 32 drivers (DBA) to match yours
dkelly60 is offline
post #217 of 226 Old 01-09-2017, 11:21 AM
Viperoni's Avatar
I never said this thread when it was first created, just wanted to say I've always loved the Peerless XLS/XXLS drivers and thus love this install
Viperoni is offline
post #218 of 226 Old 01-10-2017, 12:41 AM
mikela's Avatar
Quoted: 195 Post(s)
Liked: 231
SBA or DBA should not matter. The resiliency of DD, GG + hat channel walls will add some "free" absorption (also known as invisible alpha on Gearslutz) of the low frequency modes.
I could not detect any effect.
I only have 12 15" Ficar IB subs in my array.
post #219 of 226 Old 01-10-2017, 01:33 AM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
Ahhh, only on DIY @ AVS!
mikela and jlpowell84 like this.
GIEGAR is online now
post #220 of 226 Old 01-10-2017, 11:55 AM
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
jlpowell84 is offline
post #221 of 226 Old 01-10-2017, 03:28 PM
gworrel's Avatar
Quoted: 278 Post(s)
Liked: 248
Were they out of 18s?
gworrel is online now
post #222 of 226 Old 01-10-2017, 09:08 PM
mikela's Avatar
Quoted: 195 Post(s)
Liked: 231
Here is the reason. In retrospect, I'm sure the 18s would have worked out fine despite a very low Vas and besides they don't make the 15s anymore.
edit: I see Ficar has a new version of the IB subs which includes 12", 15" & 18".
post #223 of 226 Old 01-10-2017, 11:30 PM
dkelly60's Avatar
Seriously did you measure the output level you get at seating?
If I used the approach you did I would need 8 output points on the array i.e. 16 drivers each array.
dkelly60 is offline
post #224 of 226 Old 01-10-2017, 11:46 PM
mikela's Avatar
Quoted: 195 Post(s)
Liked: 231
post #225 of 226 Old 01-11-2017, 08:44 AM
gworrel's Avatar
Quoted: 278 Post(s)
Liked: 248
I was mostly kidding based on the idea that only on AVS would 12 15s be questioned as inadequate. But interesting to see the logic behind it. Where does that formula (speed of sound/2*distance between drivers) come from? The 18s are only $20 more than the 15s so for most purposes 18s make more sense. I have 8 x 15" in two vertical arrays at the front of my theater. I used 15s because I got them for a steal. I am considering upgrading to 18s.
Great job with the layout and planning!
post #226 of 226 Old 01-11-2017, 08:59 AM
mikela's Avatar
Quoted: 195 Post(s)
Liked: 231
From the OP's DBA thread. Also check out the 1:59 mark of this youtube
