IPR2 Amplifiers Group Buy - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 285 Old 02-27-2014, 04:27 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 153 Post(s)
Liked: 154
Originally Posted by cookieattk View Post
just cut the end of the wire off slap a regular old 15A plug and use any old extension cord and lets say some day u need to send it in b/c it dies Well just dont include the power cord :P
Not such a good idea when all you have to do is build a 20 amp extension cord OR get an adaptor
Option 1 -
http://www.homedepot.com/p/RIDGID-20-Amp-T-Blade-Adapter-612-TADAPT20R/202070815
Option two
http://www.homedepot.com/p/Pass-Seymour-20-Amp-125-Volt-Straight-Plug-PS5366XCCV4/100189052
http://www.homedepot.com/p/Pass-Seymour-20-Amp-125-Volt-Connector-PS5369XCCV4/100162451
I couldn't find it online but they have cut to length 12 gauge/3 strand extension cord wire. Make your own custom length cord.
pdxrealtor is offline
post #272 of 285 Old 02-27-2014, 04:31 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 961
Originally Posted by tsloms View Post
Make sure that you use a heavy duty preferably 20a extension cord but simply add onto the existing cord. Don't overthink this!
The goal is not to use extension cord but to find a power cord replacement that will work and be 6-7 foot long.
I'm very comfortable and experienced with building cables..........but I'm looking for a replacement cable that will go from amp to wall plug. I may have to build my own cord, but I don't want to and will try to avoid at all cost.
One would think something is out there.........
doublewing11 is offline
post #273 of 285 Old 02-27-2014, 04:47 PM
tsloms's Avatar
Quoted: 55 Post(s)
Liked: 60
Do a google search for Nema 5-20P to C19 cords and you will find quite a few of them. They are for sure more rare than standard cords but not too tough to find if you search for that.
doublewing11 likes this.
tsloms is offline
post #274 of 285 Old 02-27-2014, 04:57 PM
Quoted: 229 Post(s)
Liked: 961
BINGO!!!!!!!!
Thank you very, very much!  Just what I was looking for!
post #275 of 285 Old 02-27-2014, 05:08 PM
tsloms's Avatar
Quoted: 55 Post(s)
Liked: 60
Originally Posted by doublewing11 View Post
BINGO!!!!!!!!
tsloms is offline
post #276 of 285 Old 02-27-2014, 05:25 PM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
Ok......the freaking power cord on 7500 is way, way too short! lol
The cord is only three feet at most and I need at least 6-7 feet!
Damn.....the Middle Atlantic AXS-R is a great rack but have to pull rack out 42 inches on guides to get access!
Where in the world do I get matching power cord 7 ft long to fit the thing? Have a call into local Guitar Center but they haven't called back!
The reason for the short power cable is that these amps are designed for professional usage and mounted in amplifier racks that have a power distro in them.
Longer cables get to be a problem to deal with in those cases.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #277 of 285 Old 02-27-2014, 05:32 PM
Quoted: 16 Post(s)
Liked: 59
Originally Posted by Martycool007 View Post
I know that the DSP in these amps are very limited in what they can do. I would opt for a non-dsp model and then pick up a MiniDsp.
It depends on how you describe "very limited"
There are high and low pass filters with selectable rolloffs and I think a couple of filter types) There are limits on how much range (high and low) that they have.
I don't have one in front of me right now to look at.
There are 5 bands of eq per channel-however the resolution is not as fine as others-they only go as narrow as 1/3 octave-but that is good enough for most cases.
The delays have both ms and us adjustments.
The limiters are only in 1dB steps-but that is usually good enough for most people.
There are only 4 memory presets-do you need more?
So yes they are "limited", but good enough for most people applications.
Danley Sound Labs
Physics-not fads
post #278 of 285 Old 02-27-2014, 05:35 PM
Quoted: 229 Post(s)
Liked: 961
Well that gave me some relief!
I have an AXS-R rack and moving rack in and out of cabinet requires a long cord.  Due to moving rack in and out to service, it makes sense to have locking receptacle so I don't pull plug.  Thinking this may be the ticket.
http://www.customavrack.com/products/1023-l5-20-to-c19-power-cord.aspx
For my rack.............
Makes perfect sense............I have dedicated homerun circuits for these amps..........feeling better now that I can purchase the chord without having splices and such. One solid cord was my goal!
post #279 of 285 Old 04-01-2014, 09:07 AM
traider79's Avatar
I am in for the next GB if someone organizes one.
traider79 is offline
post #280 of 285 Old 04-01-2014, 09:41 AM
04rex's Avatar
Quoted: 132 Post(s)
Hey guys, is this amp noisy? Does it have fans for colling down or heat sinks?
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 300, Apple TV Gen 3, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v.5 L/R, CC-690 v.5 C, Studio 10 v.5 x4 Surround Side and Backs, 4x DIY 15" Ultimax Subwoofers in 3.0 Cu Ft sealed boxes, Cerwin Vega CV-5000 for Subs, Anthem MRX 720, Outlaw Audio 7700, HTPC, Apple TV Gen 4, X-Box One, Harmony Ultimate Remote, Ben-Q W1070, 92" screen
04rex is offline
post #281 of 285 Old 04-01-2014, 10:54 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yes and fans.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #282 of 285 Old 04-01-2014, 05:30 PM
Quoted: 229 Post(s)
Liked: 961
Yes, has cooling fans....
As for noise, I will NOT be using a fan mod since amps will be outside of room. Fans are nowhere near as loud as iNukes......noise is relative........
post #283 of 285 Old 05-29-2014, 03:07 PM
Archaea's Avatar
Quoted: 3071 Post(s)
Liked: 2680
pdxrealator may have an extra or two - he is selling them in his sig for about the same price as the group buy.
pdxrealator - do you have any 7500 DSP models left to sell or would that require another group buy?
Archaea is offline
post #284 of 285 Old 05-29-2014, 03:32 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 153 Post(s)
Liked: 154
No DSP models. The DSP in the IPRs is not that great, and from I can remember is not the same as the Crest.
If you want DSP in an amp get the inukes.
I can get any peavey or crest product with a minimum order of six. Once six are spoken for the final number could be 7 or 700.
EDIT to add -- it's all about the shipping to my supplier. Once six are ordered to him the shipping is waived which allows for the lower cost.
BLAH was pushing the Crests pretty hard for a while. If he can get those he should be able to get the IPRs also. Something to keep in mind.
Another thing to keep in mind is, as I just posted in another thread, 99% of the setups here will be served great by the IPRs- no need to spend the extra coin on the Pro lites.
post #285 of 285 Old 05-29-2014, 10:53 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 153 Post(s)
Liked: 154
