DIY Speaker designs to rival B&W 802 or Salk Soundscape - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 01-02-2014, 10:56 AM
Rick Craig's Avatar
Quoted: 80 Post(s)
Liked: 77
Originally Posted by Porthos01 View Post
Finally found some MDF that isn't swollen and bought it. Tomorrow I plan to start on the cabinets. Anyone have opinions on open back mids? I like the idea of an increased sound stage but am concerned that it will make it sound more like a smiley curved speaker.
I've built both open back and dipole mids. If I had a choice I would go with dipole for the best effect.
Selah Audio
Thinking Inside the Box...
Rick Craig is offline
post #32 of 37 Old 01-02-2014, 12:37 PM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
Why not go with a SEOS design such as the SEOS18 with Radian B450BePB Beryllium Diaphragm CD? TD15M's for the midwoofers and either use multiple subs for the distributed bass effect or employ a couple of TD18's to fill in the bass.
Use overkill construction with CLD for the cabinets to make sure they're absolutely dead.
An alternative would be with the RAAL 140 15D.
rajacat is offline
post #33 of 37 Old 01-03-2014, 04:14 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
I would love to see a RAAL waveguide build! I would try it out myself, but I don't think my RAAL 70-20xr's would fit on that particular waveguide as mine are a custom round design that came with my Ascend Acoustics Sierra's, and I am pretty sure that the waveguide for the RAAL requires the rectangular version.
But, for the sale of discussion and fantasizing...what would be a good mid to use with the RAAL + waveguide? I would love to see a nice 3-way build like this! I wonder how Wayne's mid-horn with the Eminence Delta-10a and a single AE TD15 or TD12 would work out?
Martycool007 is offline
post #34 of 37 Old 01-03-2014, 07:32 AM
Face2's Avatar
Quoted: 341 Post(s)
Liked: 206
As far as which mid to use, something small such as the C90 or 12M/15M would be the best directivity match.
Face2 is offline
post #35 of 37 Old 01-03-2014, 09:05 AM
noah katz's Avatar
Quoted: 1032 Post(s)
Liked: 364
I don't believe that's correct; in general a driver is about the same width as the horn it's mated with to match directivity.
Noah
noah katz is online now
post #36 of 37 Old 01-03-2014, 09:35 AM
Face2's Avatar
Quoted: 341 Post(s)
Liked: 206
This is the correct WG: http://www.diysoundgroup.com/waveguides/ha25.html
Face2 is offline
post #37 of 37 Old 01-04-2014, 11:23 AM
noah katz's Avatar
Liked: 364
Ah, I see, that's a match
Noah
