Sub line array wiring - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-01-2014, 11:46 AM - Thread Starter
Noxdowne's Avatar
My head hurts. One I those situations where the answer is there but I'm so overloaded I can't see it anymore frown.gif
I have four boxes that house two 4ohm dvc subs. I have a choice of wiring them for either 1ohm or 4ohm coming out of each as you can see here:
In the end there will be four of these boxes and I need to be at 4-8 Ohms for the combined resistance on the four boxes.
I hope I said that right.
Should I wire them as 1 ohm or 4 ohm to make the easiest final resistance?
That being asked could someone show/explain to me how to net a final resistance in my range?
Each box of two drivers will end with just one +- wire out. I need to then take the four wires and wire them for 4-8ohms.
Again, sorry for the wording. I'm flustered.
Jeff
Whether you think you can or think you can't...you're correct!
Henry Ford
Noxdowne is offline
post #2 of 6 Old 01-01-2014, 11:50 AM - Thread Starter
Noxdowne's Avatar
I think what I'm seeing is if I duplicate the 4ohm choice as shown imagining the 4ohm outputs as wires from the boxes I can net 4ohms.
Henry Ford
Noxdowne is offline
post #3 of 6 Old 01-01-2014, 12:10 PM - Thread Starter
Noxdowne's Avatar
Better picture
Henry Ford
Noxdowne is offline
post #4 of 6 Old 01-01-2014, 01:47 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Jeff,
Originally Posted by Noxdowne View Post
My head hurts.
That's not unexpected after last night . . .
You have two decent choices, both giving you a final impedance of 4 ohms:
1) Wire each box as 1 ohm, and then wire all of the boxes in series.
2) Wire each box as 4 ohms, and then wire each pair of boxes in series, and the two pairs in parallel.
I would prefer the latter myself, as each box is 4 ohms if used stand-alone, but wiring the former is simpler.
MarkHotchkiss is offline
post #5 of 6 Old 01-01-2014, 06:42 PM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1562
If your amp is dual 2-ohm or mono 4-ohm bridgeable, then wire it that way.
Otherwise, wire it as dual 8-ohm.
Or, if the amp only does dual 4-ohm, you can connect just one coil from each, with the understanding that you'd want to get another amp, for quad 4-ohm operation.
Assuming your box is not limiting you in some way.
BassThatHz is online now
post #6 of 6 Old 01-01-2014, 08:23 PM - Thread Starter
Noxdowne's Avatar
Mark choice 2 is the way to go. Took me a bit to filter this.
Thanks for the replies guys. Much appreciated.
Funny part is I hardly drank last night. Info overload haha
Jeff
Henry Ford
Noxdowne is offline
