UXL Group Buy Builds............post your pics! - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 01-02-2014, 04:36 PM - Thread Starter
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
I'll start off with a few of my pics of enclosures................still have to paint last two coats of Truck bed liner.................
Would be interesting to see pictures of varying builds using UXL-18 group buy drivers.................BTW, this is not my idea................Blah450 is responsible!!! biggrin.gif
doublewing11 is offline
Old 01-02-2014, 05:11 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
Have you double checked to make sure the woofer fits in that box?
Rebel975 likes this.
_______________________
The SEOS Waveguide Project
Erich H is offline
Old 01-02-2014, 05:15 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
We know for a fact it fits in the 4cu ft box with the cutout for the Dayton 18", and have been advised that it should fit even better in the 4cu ft with the cutout for the SI 18. smile.gif
Rebel975 is online now
Old 01-02-2014, 05:19 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Originally Posted by Rebel975 View Post
We know for a fact it fits in the 4cu ft box with the cutout for the Dayton 18", and have been advised that it should fit even better with the 4cu ft with the cutout for the SI 18. smile.gif
Since you just completed your UXL build..................I took your advise and ordered SI version of flat pack........................
Old 01-02-2014, 05:21 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Well, I do have picture evidence of it fitting in the 4cu ft box with the Dayton cutout (after I took off the thick rubber gasket that is on the outside). If the SI 18 cutout is just a tiny bit bigger then it should be perfect. smile.gif
According to Sibuna: "the SI is larger. prob really close to 1/2 an inch in diam larger
should fit the UXL close to perfectly"
Old 01-02-2014, 05:23 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
I agree.........................the diameter of the SI flat pack is 18.5 inches.......................perfect! wink.gif
Old 01-02-2014, 05:42 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
jbrown15 is offline
Old 01-02-2014, 05:46 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Originally Posted by jbrown15 View Post
How deep is the cab?
I've been thinking of doing something similar down the road................problem is, my facade wall is only 25 inches deep minus 3.5 inches for floor plate..................21.5 inches.........
Old 01-02-2014, 05:47 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
^HUGE dual sub ported cab? What are the outer dimensions?
Old 01-02-2014, 05:50 PM
jbrown15's Avatar
Liked: 1993
Right now the dimensions are 34" wide, 22" deep and 76" high, with a port tune of 15hz. if you only had a depth of 21.5" you could make them a little wider or higher. You want to try to have a cabinet size of around 22cu/ft.
jbrown15 is offline
Old 01-02-2014, 05:51 PM
jbrown15's Avatar
Liked: 1993
The info on my build can be found here
http://www.avsforum.com/t/1506201/unnamed-sub-build
jbrown15 is offline
Old 01-02-2014, 05:59 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Old 01-02-2014, 06:02 PM
jbrown15's Avatar
Liked: 1993
I'm honestly a little worried that they might be a little too much for my room, which is just over 1800cubic/ft.
jbrown15 is offline
Old 01-02-2014, 06:10 PM
Ryan Flynn's Avatar
Liked: 24
Said nobody, ever ;)
Ryan Flynn is offline
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Here's my modified martysub designed by ltd02 .
He added a rear port to lower the tuning to 16hz. I wanted the length of the box down to 40" to fit in my living room. Will come up with a name for this build later.
Two questions ...
The wiring for this sub will be 4 ohm bridged to my inuke3000dsp for 2200 watts
1) will I need the 4 pole speakon cable going to output a ? Do I just use two wires , pos to pos neg to neg ?
2) my emo umc200 has a xlr already being used with my martysub. That leaves a rca input. So I need this
http://www.monoprice.com/mobile/Product/Details/4776?mainCategoryId=115&categoryId=11509&subCategoryId=1150902
chalugadp is offline
Old 01-02-2014, 06:14 PM
chalugadp's Avatar
Liked: 1505
I'm sure 95% of the time two big subs like i will have will do it.. but for those deep down 15-20hz rumbles an extra two won't hurt. Now how long before you say I need another two for the rear tongue.gif
Old 01-02-2014, 06:26 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
"1) will I need the 4 pole speakon cable going to output a ? Do I just use two wires , pos to pos neg to neg ?"
you'll have to double check, but iirc, for bridged it is + to + and amp set for "bridged mode" (which flips the polarity of one of the channels).
yes. 4 pole speakon.
I think an xlr splitter would work. something like this:http://www.amazon.com/Hosa-YXM121-Female-Dual-Cable/dp/B000068O59
but check to make sure the correct male/female ends are on the one that you get.
Listen. It's All Good.
LTD02 is offline
Old 01-02-2014, 06:58 PM
chalugadp's Avatar
Liked: 1505
Is xlr splitter better because it reduces the chance of noise compared to xlr to rca cable ?
Old 01-02-2014, 07:19 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
XLR cables are better for longer runs........................and sometimes can litigate ground loops.........for example:
i have two different amps for my surrounds.............my black ATI1807 with rca connects gives out a low 60 hz hum...............my Silver Krell S-1507 with XLR connects is dead silent. I've done a switch, but I can't stand silver in my rack so living with ATI and slight hum!!!
Old 01-02-2014, 07:22 PM
chalugadp's Avatar
Liked: 1505
Will only.be a three foot run. Probably get both since their cheap and I hate hum noise as well.
Old 01-02-2014, 07:27 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
If you can use XLR cables......................do so, you wont regret it! wink.gif
Old 01-02-2014, 07:35 PM
chalugadp's Avatar
Liked: 1505
found a diagram on another thread for 4ohm bridged
as usual ltd02 was right. I will keep the photo to help the next dude who asks this question.smile.gif
Old 01-02-2014, 07:42 PM
steve nn's Avatar
Liked: 433
Just finished my first UXZinger and cant decide if I like the tape or not?? wink.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 01-02-2014, 08:21 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Here's mine. x 4
Steve- I like the blue tape. Leave it.....
pdxrealtor is offline
Old 01-02-2014, 08:26 PM
fr8doggr's Avatar
Quoted: 16 Post(s)
Liked: 66
Steve,
That looks really nice!
fr8doggr is offline
Old 01-02-2014, 08:35 PM
jbrown15's Avatar
Liked: 1993
jbrown15 is offline
Old 01-02-2014, 08:36 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 938
Impressive....................................Great job! You're now part of the "Bassaholics" club..........but with class! wink.gif
Glad mine will be hidden behind second row!
Old 01-02-2014, 08:41 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
In the group buy thread, huskeromaha asked "anyone have photos of the earlier version like mine vs the new? I don't remember what changed but don't think it was noticeable visually or even measurable?"
Does anyone know what he was talking about? pdx and steve- are those really UXL-18's? Mine looks very different?
Old 01-02-2014, 08:55 PM
jbrown15's Avatar
Liked: 1993
I believe his had a black carbon fiber cone with black paper dust cap, the ones in the group buy are all black carbon fiber. Much sexier looking IMO biggrin.gif
I believe it would just be a visual thing, no performance difference.
steve nn likes this.
jbrown15 is offline
Old 01-02-2014, 09:01 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
So the only difference is the dust cap being carbon fiber vs paper? Mine is black but looks slightly purple if you look at it at the right angle. It also has a matching carbon fiber dust cap.
I guess I already have the 'newer' version, which is a relief. I'd prefer to have matching subs. smile.gif
