Someone hold my hand - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 128 Old 01-18-2014, 09:02 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
I was referred to you guys for my subwoofer needs. I have a basement theater (roughly 2500 cu ft) that needs proper bass. Right now I'm limping along with a crappy 10" sub I bought for $125. Well, after some quick research I decided I could afford 2 SVS PB-2000's. However, I'm quite handy with my tools. As such, I was told to come to you guys for my needs.
See my signature for my theater build thread. You can get a quick look at the pics to see how it's laid out. I have about 26" from the back wall to my screen (moleskin spandex). Basically I'm looking for a 2-sub setup that can give me the performance of 2 PB-2000's for less money.
Can anyone help me? I'm looking for someone to essentially tell me step-by-step what to build. Also, keep in mind that I am by no means an audiophile, but I do appreciate good bass that doesn't drown out all other sounds.
Crash11 is offline
post #2 of 128 Old 01-19-2014, 12:12 AM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 42
Amp - inuke 3000dsp ($375)to power 2
Marty subs (ported 18" Dayton or Si subs)($200 each)
Each sub is the equivalent to a pb13ultra.
So you are looking at $800+wood+glue+100 for the performance of 4 pb2000.
http://www.avsforum.com/t/1489541/large-ported-dayton-ho18s#post_23711347
LTD02 likes this.
datranz is offline
post #3 of 128 Old 01-19-2014, 04:13 AM
steve nn's Avatar
Liked: 433
Yeah what you do is come up with a design by copying to a degree (same size enclosure and tune) or one of your own in a thread like you’re doing. One or a few of us will sim it up for you and figure things out to a degree and you then hop at it at your own pace. You can post your questions as you move forward with rewarding us with your pics. Sometimes a guy starts off with asking what would be a good driver in a box no bigger than??? Some guys have no limit in enclosure size.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 128 Old 01-19-2014, 07:32 AM
eXa
eXa's Avatar
I dont think a PB13 Ultra can keep up with a Martysub...
eXa is offline
post #5 of 128 Old 01-19-2014, 07:43 AM
atabea's Avatar
Quoted: 609 Post(s)
Liked: 430
Agreed. If you look at the measurements at data bass (sealed enclosure), it's significant enough. Pretty sure the differences will be even greater poreted
atabea is offline
post #6 of 128 Old 01-19-2014, 08:05 AM
steve nn's Avatar
Liked: 433
When you do compare, you need to be sure to add 6dB to Data's numbers on account they're 2m g p versus 1m g p in winisd though.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #7 of 128 Old 01-19-2014, 08:27 AM
Bill Fitzmaurice's Avatar
Liked: 5684
Aren't they normalized to 1m? Measuring is done at 2m, because any closer and the result is corrupted by the presence of the box. Some places, notably Danley, measure at 10m/100w for more of a real world result. 10m/100w is the same as 1m/1w. It's a bit vague exactly what data-bass does, though there could be a footnote that I just haven't seen.
Bill Fitzmaurice is offline
post #8 of 128 Old 01-19-2014, 09:20 AM
steve nn's Avatar
Liked: 433
Yeah it's 6 dB Bill. A guy needs to add 9dB bassicly from the HSU site.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #9 of 128 Old 01-19-2014, 09:55 AM
Liked: 5684
Again, data-bass is confusing, SPL charts are vaguely labeled. For instance, the VTF 15H Basic Response chart shows a bit over 100dB, and that's certainly not 1w/1m, nor 1w/2m. Typical charts say right on them the conditions under which they were measured.
post #10 of 128 Old 01-19-2014, 10:57 AM
steve nn's Avatar
Liked: 433
Yeah HSU is 3m. (9dB from other posts I've seen. I don't know the details but if you go 9dB you will see they pretty much match. 1m for winisd of course unless changed and 2m over at Data.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #11 of 128 Old 01-19-2014, 03:36 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
Ok, before I start measuring my constraints, I guess I need to know all of my constraints.
1 - Is it preferred to orient the driver such that it faces the people?
2 - How close to my screen fabric can I place the driver or port?
3 - I have cabinet doors running across the bottom of my screen hiding my equipment. Can I place the subs down on the ground behind these cabinet doors or is it preferred to elevate them up to screen level?
Some constraints I've already placed on myself.....
A - I will only place the subs behind the false wall. No wiring in place for a sub anywhere else in the room.
B - I have a dedicated 20 amp circuit wired to my room for the subwoofer(s).
C - Has to fit behind the false wall, which is nominally 23.5" deep, but there are places that have more depth (e.g. behind any fabric components, or between studs).
D - If I'm going to do this myself, I'd like to keep the budget at $1000.
E - I really don't need any more performance than what would be attained from a couple PB-2000's. Remember, I'm not an audiophile.
So does anyone have an opinions on 1-3? I'm excited to take this on.
Crash11 is offline
post #12 of 128 Old 01-19-2014, 03:48 PM
LTD02's Avatar
Quoted: 2527 Post(s)
Liked: 2869
"It's a bit vague exactly what data-bass does, though there could be a footnote that I just haven't seen."
i'm pretty sure that all the measurements are at 2m except where it is specifically noted as 1m or 10m.
the sweeps correlate with winisd predictions (which as you know is 2pi 1m) with 6db added to the db numbers for the low bass. the upper bass is a little more tricky because some of the larger cabs provide a little bit of their own boundary gain.
steve nn likes this.
Listen. It's All Good.
LTD02 is offline
post #13 of 128 Old 01-19-2014, 03:57 PM
LTD02's Avatar
Liked: 2869
"1 - Is it preferred to orient the driver such that it faces the people?"
doesn't really matter. lots of good subs fire sideways or up/down.
" 2 - How close to my screen fabric can I place the driver or port?"
that is a great unknown and depends of course on the port velocity of the sub. best would be to just port it up or sideways so it isn't blowing on the screen in the first place.
" 3 - I have cabinet doors running across the bottom of my screen hiding my equipment. Can I place the subs down on the ground behind these cabinet doors or is it preferred to elevate them up to screen level?"
they don't have to be up at screen level unless you are going for the 1/4 distance spacing idea.
suggest 1/4 distance array with at least 4 units then.
that should be fine.
a minimum of two martys as described above would be in that budget and pound pretty hard. four drivers would give a little more flexibility for placement and mode killing.
who cares what you need? :-)
"I'm excited to take this on."
yahoo!
LTD02 is offline
post #14 of 128 Old 01-19-2014, 04:05 PM
steve nn's Avatar
Liked: 433
yahoo!
Thank God somebody finally said that. It reminds me of a guy I was helping out yesterday. Like we're gaining something or it’s such a XXXX privilege! rolleyes.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #15 of 128 Old 01-19-2014, 04:08 PM
Liked: 5684
I'm not sure. Look at the Basic Response chart here:
http://www.data-bass.com/data?page=system&id=100&mset=109
What is it supposed to represent? 1m/1w? Halfspace? Nothing I can find on that page says, and IMO one shouldn't have to search the entire website to figure it out. And where taking measurements at more than 2m is SOP it's also SOP to normalize the result to 1m/1w or 1m/2.83v. They may be doing that, they may not. I may be old and not as sharp as I once was, but I haven't totally lost touch yet, and I can't find a succinct explanation.
post #16 of 128 Old 01-19-2014, 04:14 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
What's a 1/4 array? I'm assuming if I just have 2 subs that I'd place them 1/4 of the way from each side wall at the same height, but what happens if I have 4 subs?
Crash11 is offline
post #17 of 128 Old 01-19-2014, 05:21 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
I'm not sure I'm getting your meaning?
Crash11 is offline
post #18 of 128 Old 01-19-2014, 05:43 PM
wvu80's Avatar
Quoted: 329 Post(s)
Liked: 293
I think someone was taking Mr. Steve's help for granted, and was being a bit of a poo-poo head about it. wink.gif
wvu80 is offline
post #19 of 128 Old 01-19-2014, 07:14 PM
steve nn's Avatar
Liked: 433
I’m sure it was some kid (maybe not) that didn’t know the meaning of common curtsies that I better not catch my kids (even though they’re grown) lacking in. Imo It’s the principle of the matter albeit little stevie needs to take a break now and then. smile.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #20 of 128 Old 01-19-2014, 10:13 PM
steve nn's Avatar
Liked: 433
Since you want all four up front (that would be quite the rig) you would divide the distance of the two walls by 1/4 and place in a line accordingly. Another option if you were to build 4, and since they’re going to be hid, is to go the sono route. Building 4 of the Marty's would be quite a chore, building 4 sono’s would be much easier. It would basically be the same sub performance wise. Just a thought..
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #21 of 128 Old 01-20-2014, 10:29 AM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 42
You can build a tht from bill as a coffee table. It's also pretty wicked for less money but much more difficult. But 2 Si and a 3000dsp has the most value.
datranz is offline
post #22 of 128 Old 01-20-2014, 11:48 AM
WVSyd's Avatar
Liked: 47
What's a 1/4 array? ...
Well since an array is 2 or more elements sharing a passband.
a 1/4 array does not exist - except as a misunderstanding smile.gif
"Beware of Salesmen: They are the modern Svengali, immune to Science and Reality"
WVSyd is offline
post #23 of 128 Old 01-20-2014, 12:06 PM
sdaddy's Avatar
4 subs. 1 sub 1/4 in from the left wall and 1/4 up from the floor. One sub 1/4 in from the right wall and 1/4 up from the floor. One sub 1/4 in from the left wall and 1/4 down from the ceiling. One sub 1/4 in from the right wall and 1/4 down from the ceiling. I'm sure LTD will post a pic when he checks back in.
sdaddy is offline
post #24 of 128 Old 01-20-2014, 01:43 PM
WVSyd's Avatar
Liked: 47
Ah...
I tend to start with fractions like 1/3, 1/5 etc
But whatever gets the task accomplished
WVSyd is offline
post #25 of 128 Old 01-20-2014, 03:05 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
What's an SI?
Crash11 is offline
post #26 of 128 Old 01-20-2014, 03:46 PM
LTD02's Avatar
Liked: 2869
Stereo Integrity HT 18" Subwoofer
http://stereointegrity.com/index.php?id=60
LTD02 is offline
post #27 of 128 Old 01-20-2014, 06:27 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
Ok, let's try to narrow down this design some. Here's a shot of my screenwall:
My plan for now is to just build 2 subs. I know more is always better, but this is my first attempt at making a speaker so let's just take baby steps. With that in mind, I have the ability to place them both at 1/4 (44.5") from each side wall. That's about 14" from the edges of the velvet screen border. This is also ideal for depth behind my false wall. I have 27.5" of room between the back wall and the screen material. Also, I want to keep the boxes elevated above the cabinet door to leave room for storage and more equipment. So that leaves about 50" of height to work with. So in this position, will a Martysub work with the driver being at the long end? Can I stand them up vertical and face the driver and port up? Also, keep in mind that the panel I built above the screen is not acoustically transparent. It's a solid 1x10 piece of pine wrapped in fabric. How would you guys orient a couple subs with this setup?
Another issue.....where to place the amp. I originally planned to build an IB so I actually wired my 20 amp plug behind the theater. My plan was to have all of the wiring and power in my utility room behind the theater, and the only run going through the wall was going to be the pre-out from the receiver. Check out these pictures:
Narrow angle shot of the back of my theater:
Closer shot showing the lone outlet for my subwoofer in the bottom right:
Close up of my open box for passing cables through:
I was thinking about placing the amp back in this room because I saw a few complaints about fan noise. I'd have to run the pre-out line through my "hole" as well as the speaker wire runs. Is this a bad idea?
Crash11 is offline
post #28 of 128 Old 01-20-2014, 06:43 PM
pdxrealtor's Avatar
Quoted: 154 Post(s)
Liked: 154
pdxrealtor is offline
post #29 of 128 Old 01-20-2014, 07:01 PM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
Originally Posted by pdxrealtor View Post
^^ nice room..... Good job
Thank you.
Crash11 is offline
post #30 of 128 Old 01-23-2014, 08:12 AM - Thread Starter
Crash11's Avatar
Quoted: 23 Post(s)
Crash11 is offline
