18" ultimax pair + iNuke 6000 custom build w/ pics - AVS Forum | Home Theater Discussions And Reviews
 28Likes
Old 01-26-2014, 09:44 AM - Thread Starter
jhgkak's Avatar
Quoted: 27 Post(s)
Liked: 32
I'm going to document my first build project after years of reading about others'. Any and all comments or advice welcomed.
I'll keep this thread updated with pictures of the entire process.
I've read a ton of posts and this seems like the best time to be building a couple subs! I'm finally moving into a house we built and my old faithful MFW-15 won't fit in my built-in cabinet.
And of course I need more bass! The new room is 32'x30'x9'.
My cabinet depth is only 17" deep but plenty wide to get a 4.35 cu ft sealed box in it. In the picture below, they would go on each side of the mains.
I put in two dedicated 20a circuits, but could add more as needed.
The guts:
1x Behringer NU6000DSP iNUKE 6000W (change the fans out with these).
2x Dayton Audio UM18-22 18" Ultimax subwoofer
Based on my built in theater built-in cabinets, I'm looking at the subwoofer cabinets being 26"W x 24"H x 15"D = 4.35 cu ft.
My questions if you have advice:
-Does this make sense?
-How does the wiring work with the DVC and ohms back to the amp?
-Do I have everything I need on the parts express cart? I already have 14 gauge speaker wire.
-Do I need the CLEANBoxPro?
Also- I don't have the woodworking tools to build the cabinet- any ideas on where to I could get the custom cabinet?
Resources:
Cut list generator: http://www.optimalon.com/PanelCutOptimizer.aspx
box volume calculator http://www.diyaudioandvideo.com/Calculator/Volume/
parts express:
http://www.parts-express.com/behringer-nu6000dsp-inuke-6000w-lightweight-power-amplifier-with-dsp--248-6710
https://www.parts-express.com/dayton-audio-um18-22-18-ultimax-dvc-subwoofer-2-ohms-per-coil--295-518
https://www.parts-express.com/bi-amp-speaker-terminal-cup-gold-banana-binding-post--260-281
https://www.parts-express.com/art-cleanboxpro-stereo-balanced-unbalanced-converter--245-868
https://www.parts-express.com/speaker-gasketing-tape-1-8-x-3-8-x-50-ft-roll--260-540
https://www.parts-express.com/neutrik-nl4fx-speakon-spx-cable-connector-4p--092-190
https://www.parts-express.com/6-x-3-4-deep-thread-pan-head-screws-black-100-pcs--081-435
https://www.parts-express.com/banana-plug-pair-compression-type--091-330
jhgkak is offline
Old 01-26-2014, 01:40 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Enclosure looks ok, after bracing and driver displacement it should come to 4cu ft. You should also brace the rear of the cabinet and the front if possible. You'll need polyfill (walmart pillows) or fiberglass for the inside of the enclosure.
http://www.the12volt.com/caraudio/woofer_configurations.asp
What receiver do you have? Most people are fine without a boost box. You can also measure how many volts the LFE can output using a test tone and multimeter.
jhgkak likes this.
Mrkazador is offline
Old 01-26-2014, 07:53 PM
BassThatHz's Avatar
Quoted: 2029 Post(s)
Liked: 1546
should thump good.
BassThatHz is offline
Old 01-27-2014, 09:38 AM - Thread Starter
jhgkak's Avatar
Quoted: 27 Post(s)
Liked: 32
Thanks guys, both good suggestions.
Thank you for that diagram, that's what I was thinking but wasn't sure.
The current receiver is a Yamaha HTR-5990, but I'll probably upgrade that too. biggrin.gif
Ordered the speaker today, back ordered until 2/12.
jhgkak is offline
Old 01-27-2014, 10:14 AM
imagez's Avatar
Ah buddy,get in line lol,i pre-ordered one as well a couple of weeks ago. I would build my sealed enclosure but givin that this sub is a air moving monster,ima have it built at my local stereo shop.im running a iNuke 3000 with a miniDSP. Lets see who gets their build up first lol
imagez is offline
Old 01-27-2014, 10:32 AM - Thread Starter
jhgkak's Avatar
Quoted: 27 Post(s)
Liked: 32
One more question- does anyone know how many DB I might expect at 20hz?
jhgkak is offline
Old 01-27-2014, 01:37 PM
Bill Fitzmaurice's Avatar
Liked: 4628
Your box modeling software program, such as WinISD, will tell you that. I can't see anywhere that you used one.
Bill Fitzmaurice is online now
Old 01-27-2014, 04:17 PM
Archaea's Avatar
Quoted: 2825 Post(s)
Liked: 2413
two notes:
1) You don't need the art cleanbox pro with the iNuke amps in most situations.
2) You can get the iNuke DSP amps cheaper on ebay by at least $100 than parts-direct if you are comfortable with ebay.
jhgkak likes this.
Archaea is online now
Old 01-27-2014, 05:59 PM
steve nn's Avatar
Liked: 433
18 UM 4cf 1500w.. This is what the driver comes in at taking xmax into account with no dsp driver plopped in 4cf.
jhgkak likes this.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 01-27-2014, 07:30 PM
steve nn's Avatar
Liked: 433
^^ One thing to remember at that much power it doesn't give you any room to add any dsp down lower although it’s been suggested it has more to give. You’re in a large room so your room gain wont come in like a sealed up 1000-1500cf room.. but then your building two. Sounds like a great build though. Congrats!
jhgkak likes this.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 01-27-2014, 07:37 PM
BassThatHz's Avatar
Liked: 1546
Without the Cleanbox you won't need xlr,
just RCA to TRS.
jhgkak likes this.
Old 01-27-2014, 07:39 PM - Thread Starter
jhgkak's Avatar
Quoted: 27 Post(s)
Liked: 32
Thanks steve nn! I can never get winISD to output anything useful. I'm researching that now, but based on your graph, I'm excited to get this project done!
I'm about 95% music and the 30-80hz range seems to be where it hits the hardest in rock.
I figure this amp is only $400-$500 and it will hopefully last forever.
That and under powered amps can kill a driver if they start clipping?
jhgkak is offline
Old 01-27-2014, 08:02 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 36
That cutlist panel optimizer is not making it easy on you...check this layout out...much much simpler as you only have to adjust the table-saw (assuming you are using one) 4 times....first at 26, then set it to 13.56, then 22.56, then set it to 24.
My solution is not as efficient, but it is much easier.
urapnes1 is offline
Old 01-27-2014, 08:21 PM
schmidtwi's Avatar
Quoted: 166 Post(s)
Liked: 121
I'm thinking you'll like these for music! I have 2 UM 15's in 4 cu/ft. boxes - they're awesome for music & movies. Now thinking about adding 2 UM 18's, so I'll be interested in hearing your experience. Subbed.
Archaea mentioned EBAY as a source to save on the iNuke, make sure you search the Web for deals. smile.gif
Have fun!
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
Old 01-27-2014, 08:44 PM
Ryan Flynn's Avatar
Liked: 24
Go to Home depot, grab your 4'x8' sheet of 3/4" thick mdf (or better yet have the guy in the wood department help you) and ask him to make cuts for you.  They do this for free!  YES - FREE!  No need to buy a table saw / etc.  All you will need is maybe a handheld jigsaw , orbital sander, glue, and some clamps.  This is my local Home depot dude helping me out with my Marty sub box.
bombertodd likes this.
Ryan Flynn is offline
Old 01-28-2014, 06:58 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
You sub modelers need to unionize!
This is what Scotty came up with using 1200 watts.............
Since I'll be using a Peavey ipr2 7500 for two temporarily...............I need a ski slope downhill from 10hz! Guess I'll be using all reserve power...........or be buying more drivers........ie. can you say bottoms out? biggrin.gif
doublewing11 is offline
Old 01-28-2014, 07:42 PM - Thread Starter
jhgkak's Avatar
Quoted: 27 Post(s)
Liked: 32
I put this into the webISD and seems like i really should be building a 14.25 cu ft ported box, no?
Just kidding, I don't have the space.
jhgkak is offline
Old 01-28-2014, 08:29 PM
Archaea's Avatar
Liked: 2413
If you are 95% music you should care much more about max output at 70hz instead of 10hz. I think a massive ported box is not the right end result. You might even prefer the previously released 18 HO dayton driver for a few more dB in the kick drum wheelhouse. I'd consider sealed boxes with the HO driver for 95% music.
Old 01-28-2014, 08:32 PM - Thread Starter
jhgkak's Avatar
Quoted: 27 Post(s)
Liked: 32
Agreed. I can't wait to get these drivers in!
jhgkak is offline
Old 01-29-2014, 06:56 AM
steve nn's Avatar
Liked: 433
double> You sub modelers need to unionize!
Lol, I bet you’re wondering. I see what's going on. I have mine in a 4cf enclosure single driver (no dsp) and he has his sim in a 8cf enclosure dual drivers. It’s against our union contract to check each others work though. smile.gifwink.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 03-06-2014, 07:52 AM
blackhawk95's Avatar
If one was to build a dual driver setup in a single cabinet. Do you simply double the volume used for a single driver?
Bombelman likes this.
blackhawk95 is offline
Old 03-06-2014, 05:20 PM
steve nn's Avatar
Liked: 433
If you want to keep the same response. If you were to put two UM drivers in 6cf it would only be a difference of basically 1dB from 30hz down which you could address with dsp if needed.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 03-06-2014, 06:24 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
jhgkak,
I'm looking forward to watching this thread. The cabinetry looks great already, so it will be fun to watch things progress. Good luck with your build.
Subscribed!
kevings is offline
Old 03-06-2014, 06:43 PM
Steve NN,   thank you.
Jerid
Old 05-31-2014, 10:55 AM - Thread Starter
jhgkak's Avatar
Quoted: 27 Post(s)
Liked: 32
Had the cabinets built. Really disappointing on the release date getting pushed again. Any ideas for another driver that would fit a 17" cutout?
Name:	home theater.JPG
jhgkak is offline
Old 05-31-2014, 11:43 AM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
Stereo Integrity HT 18" will fit ! (they require 16,70")
$100 less expensive each, sans the shipping.... I've got 2, ordered two more.... Get them (pre order for July)
Bombelman is offline
Old 05-31-2014, 10:33 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Are the SI 18's going to be available before the UM18-22's?
jbrown15 is offline
Old 05-31-2014, 10:38 PM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
SI website states first weeks of July...
Most of their items are made by themselves, some made to order. Not in a far far away factory...
So I trust them when they call a date, they know how their inventory moves, I think.
I have also placed a pre-order so I do also hope my subs will ship early July :-)
As for the UM, great subs, I have an Ultimax 15 also... but just not sure when I'll se an UM 18.....
Best of luck buddy !
(ps Some guys here are selling SI HT 18's)
Old 05-31-2014, 11:04 PM
jbrown15's Avatar
Liked: 1993
As for the UM, great subs,mI have an Ultimax 15 also... but just not sure when I'll se an UM 18.....
My understanding is that Nick doesn't do any assembling for the SI 18's, they come in from the factory ready to go out to the customers. That's also the reason he's able to sell them for so cheap.
jbrown15 is offline
Old 05-31-2014, 11:13 PM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
ah yes, says on the box where they are made 😁 well, let's hope his suppliers are reliable hehe
