Coaxials: Another DIY Group Project. - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 306Likes
post #331 of 1425 Old 07-05-2014, 04:23 PM
Linh27's Avatar
Erich, which high end coaxial is going to be offer? B&C, your custom one?
Linh27 is offline
post #332 of 1425 Old 07-09-2014, 07:32 AM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
Anymore info on the new high end coaxials?
And Erich can the DNA150's be used with the Eminence 8" coaxial speaker?
chrapladm is online now
post #333 of 1425 Old 07-09-2014, 01:01 PM
desertdome's Avatar
Quoted: 1303 Post(s)
Liked: 1513
The DNA-150 and the Eminence 8" coaxial are both in the V-8 Volt kit so I would assume they can be used together.
desertdome is offline
post #334 of 1425 Old 07-09-2014, 07:39 PM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
I assumed but had to ask. Thanks DD. I have been looking at trying to build a cheap SM100 but using an 8". So owning the DNA150 already I figured I might try and just use this 8" or possibly 10" coaxial in my clone.
Erich can you buy the 8/10" coaxial speaker without the baffle?
post #335 of 1425 Old 07-10-2014, 04:15 AM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 532
rhodesj is offline
post #336 of 1425 Old 07-10-2014, 04:47 AM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
The 8 is more expensive than the 10. LOL Good option but I would still have to buy more 150's and crossover parts. So the volt is an all in one place. I could use my 150's I have already but I would rather just buy the whole package in one place. Either way I will do what I have to.
post #337 of 1425 Old 07-10-2014, 05:21 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 191
There was talk in the SEOS thread about getting higher end completed boxes made up for some of the nicer designs. I've been looking into that over the past month or two. So we can cross that road when we get there.
I saw your post on completed boxes in the rallying thread. Just a suggestion:
Look into developing boxes that use either kerfing or channels to assemble. This makes construction of non square enclosures possible and actually enhances the performance of the speaker. I don't mean curved enclosures you can cnc channels in the mdf and the box just folds together without any seams to contend with. You can also veneer the entire back panel and fold the box together without any seams to do and makes the box assembly cost low and product value very very high.
Seaton posted a demo on how their boxes were made sometime back somewhere, the whole box was one piece with channel kerfs. You just veneer back, cnc the channels, insert bracing, fold and glue together, done. It was pretty impressive and I don't think it was proprietary.
Just a thought.
NicksHitachi is offline
post #338 of 1425 Old 07-10-2014, 05:37 AM - Thread Starter
Erich H's Avatar
Quoted: 1478 Post(s)
Liked: 1895
The panel normally comes with veneer already installed. The cabinet company simply cuts V-grooves down to the veneer without cutting all the way through. Then you just miter fold the box and you have no seams.
It works great, but they can't be shipped unassembled.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #339 of 1425 Old 07-10-2014, 05:48 AM
Quoted: 182 Post(s)
Liked: 191
Yep thats it, I meant for your assembled boxes/speakers.
post #340 of 1425 Old 07-10-2014, 11:59 AM
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
Are we considering different speaker designs or the use of different drivers. There were quite a few different discussions going on here.
rlhaudio is offline
post #341 of 1425 Old 07-10-2014, 01:50 PM
beastaudio's Avatar
Quoted: 4121 Post(s)
Liked: 3458
So there are drivers, but no pics... We need some meat here...
Willie likes this.
beastaudio is offline
post #342 of 1425 Old 07-10-2014, 02:53 PM - Thread Starter
Erich H's Avatar
Liked: 1895
I'll try to get some photos posted in the next day or so. I must have 15 different models here that I tested.
Erich H is offline
post #343 of 1425 Old 07-10-2014, 03:51 PM
ClemsonJeeper's Avatar
Quoted: 233 Post(s)
Liked: 145
Anyone have any idea what the smallest enclosure one would want to go to using a Volt 8? I ask because I'm thinking about using Volt 8's for in-ceiling (with backer box) speakers for Atmos. Think this would be a decent fit for this application? (My surrounds are angled Volt 10s)
November 2015 HT of the Month: The Vortex Theater
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
post #344 of 1425 Old 07-10-2014, 04:30 PM
beastaudio's Avatar
Liked: 3458
The 10's can get to 100hz pretty comfortable in a box the size of .75 cuft. I would guess the 8's at a little less sensitivity will get there in slightly less, say .6 cuft. I wouldn't go much less than that sealed....
post #345 of 1425 Old 07-10-2014, 06:26 PM
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
Are you staying with the standard Volt Coax design using the slanted box?
Is it possible to build a HT speaker as a bi-pole for surround sound use perhaps using a switch for mono vs. bi-pole use? Or is that a pain with XO work?
I already own a few waveguide speakers including 3 Tempests. I was going to purchase the Volt 10 for surround use but if your thinking of making a new HT speaker to match the waveguides I can wait another month.
rlhaudio is offline
post #346 of 1425 Old 07-11-2014, 11:30 AM
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
I was curious about Atmos speakers myself. I wish they had better papers concerning speaker placement. Distance from viewer, etc. Not sure if I want to place my speakers facing straight down (cube box) or use the angled boxes to allow some directivity. Also the pros/cons between 2 and 4 atmos speakers. I guess in time all will be answered.
rlhaudio is offline
post #347 of 1425 Old 07-12-2014, 12:11 PM - Thread Starter
Erich H's Avatar
Liked: 1895
Here's a picture with most of the different coaxial samples in it.
Maklar and EarlK like this.
Erich H is offline
post #348 of 1425 Old 07-12-2014, 12:17 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1531
I like the bottom left one for my surrounds. Is that a 5 or 6" ?
chalugadp is offline
post #349 of 1425 Old 07-12-2014, 12:19 PM
Maklar's Avatar
Quoted: 42 Post(s)
Love the octagon shaped ones.
Maklar is offline
post #350 of 1425 Old 07-12-2014, 12:35 PM - Thread Starter
Erich H's Avatar
Liked: 1895
Bottom left models are 6". The 2nd one over tested good and I did order some, but not many. They get louder than you would think and have a full sized compression driver that shares the magnet with the woofer. The one right next to it on the right is the nice custom 8" model. But I was hoping the dust cap would be slightly different than it is. Next one is FaitalPro, next is B&C.
Top row 2nd over is the 12" Eminence with a screw on BA-750. It's kind of interesting.
I do like the larger octagon models. Those horns sound okay with certain compression drivers, but not all compression drivers. The bolt on BA-750 sounds okay on that octagon 12". I'm going to eventually try to get that larger one made without that type of horn sticking too far out the front. It is a beefy model, but not sure there's a reason to go with a 12" for home use.
Erich H is offline
post #351 of 1425 Old 07-12-2014, 01:18 PM
chalugadp's Avatar
Liked: 1531
Is that 6" one that tested well the one that can go in a small box ? I want a.small coaxial for surround in my living room. Like .4 to .5 cuft box
post #352 of 1425 Old 07-12-2014, 02:19 PM
beastaudio's Avatar
Liked: 3458
The 8" should still do sufficiently well in a .6 cuft box after bracing and displacement. That small, bracing isn't really that necessary anyways....
post #353 of 1425 Old 07-12-2014, 08:52 PM
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
+1 on the 8" with the .6 flat pack. you already have an angled and cube flat pack. Besides, its better to have too much speaker and turn down the volume than not have enough and distort.
rlhaudio is offline
post #354 of 1425 Old 07-12-2014, 08:55 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
All I know is that I want some high end units that will work well with my JTR's and will fit in the 14" slanted flat pack, point me in that direction and I'm in!
jbrown15 is offline
post #355 of 1425 Old 07-13-2014, 02:11 AM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
What is the far right corner monster?
From the basket it reminds me of the Venezuela 6 spoke on 18's but after you described the 12 next to it I figured it must be a 15?
I will be going with coax 8's and 10's. BUT turning down the volume is a good thing. So maybe one of Erichs 12's would be nice.
post #356 of 1425 Old 07-13-2014, 06:24 AM - Thread Starter
Erich H's Avatar
Liked: 1895
Far upper right is a 15". They didn't make it with the cone I asked for though because it didn't fit the frame right. That one hasn't been tested yet.
The best testing one so far is the third one from the left on the bottom.
Erich H is offline
post #357 of 1425 Old 07-13-2014, 06:30 AM
Maklar's Avatar
Quoted: 42 Post(s)
Ditto
Maklar is offline
post #358 of 1425 Old 07-13-2014, 06:59 AM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
Is that the 10"? How did it do and what CD used?
post #359 of 1425 Old 07-13-2014, 07:40 PM - Thread Starter
Erich H's Avatar
Liked: 1895
It's the 8". The compression driver is built into the back and shares the magnet with the woofer. It does test better than the B&C and FaitalPro.
Erich H is offline
post #360 of 1425 Old 07-13-2014, 08:06 PM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
These are all custom made ones Erich?
Either way I hope to hear more about these 8" models and also 10" models.
