Coaxials: Another DIY Group Project. - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 300Likes
post #391 of 1403 Old 07-20-2014, 07:11 AM
Sibuna's Avatar
Quoted: 372 Post(s)
Liked: 425
While this doesnt matter to most what are the maximum SPL levels you can achieve with the 8" Coax? 10"?
Just trying to see if I can use an 8". Again this will be used outside. Most likely the 8 will be fine for my app. Just curious of the answer is all. Has anyone done any "MTG90," like videos of the coaxials?
Ive been meaning to with the Volt-8 but Ive been super busy and every time i think i have time its raining
Sibuna is offline
post #392 of 1403 Old 07-20-2014, 07:35 AM
chrapladm's Avatar
Quoted: 788 Post(s)
Liked: 278
You people with your busy schedule, things in your life and 24" subwoofers always have excuses
When ever you get a chance that would be great, thanks.
chrapladm is online now
post #393 of 1403 Old 07-20-2014, 02:14 PM
noah katz's Avatar
Quoted: 858 Post(s)
Liked: 300
It's the 8". The compression driver is built into the back and shares the magnet with the woofer. It does test better than the B&C and FaitalPro.
I imagine you mean freq resp.
It would be interesting to see the polars, which for the B&C's aren't half bad and I believe part of the reason Danley uses them.
RickD1225 likes this.
Noah
noah katz is offline
post #394 of 1403 Old 07-20-2014, 03:49 PM
mtg90's Avatar
Quoted: 397 Post(s)
Liked: 763
Here is the off axis response of the 8" model (1/6th oct smoothing), the crossover is not done yet but it's close.
Also attached one at 10 degrees with 1/24th smoothing, you can see phase is not too bad either.
Name:	0-90 degrees off axis.png
ID:	172170   Click image for larger version
Name:	10 degrees fr+phase.png
NicksHitachi and Nate Hansen like this.
mtg90 is offline
post #395 of 1403 Old 07-20-2014, 04:34 PM
Nate Hansen's Avatar
Quoted: 252 Post(s)
Liked: 162
How consistent are the polars with a higher resolution plot? That 1/6 smoothed set looks really good for a coax. Thanks for posting that I don't think I've ever seen a full set of polars for a coax like that.
Does anyone have any for the volt models?
Nate Hansen is offline
post #396 of 1403 Old 07-20-2014, 08:28 PM
noah katz's Avatar
Quoted: 858 Post(s)
Liked: 300
Thanks, pretty nice!
Do you have polars for an 8" B&C?
Noah
post #397 of 1403 Old 07-21-2014, 06:57 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
That looks pretty nice..... Whats going on at 700Hz? Is that noticeable to your ears? Too low to be breakup right? Maybe some resonance on speaker or enclosure?
NicksHitachi is offline
post #398 of 1403 Old 07-22-2014, 02:22 AM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
So this model
Appears to be this one
https://www.parts-express.com/faital...-ohm--294-1192
Driver is $215 so full kit in the 260-280 range I'm guessing. Looks like it would fit in a small box too. Perfect for what I want. Would make a great addition to your lineup
chalugadp is offline
post #399 of 1403 Old 07-22-2014, 06:08 AM
Sibuna's Avatar
Quoted: 372 Post(s)
Liked: 425
yea that little guy looks like it would be perfect for a set of computer speakers in a small space
Sibuna is offline
post #400 of 1403 Old 07-22-2014, 06:10 AM - Thread Starter
Erich H's Avatar
Quoted: 1386 Post(s)
Liked: 1713
There's a design already done with the FaitalPro 6" coaxial, but that's not the one used in that small box.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #401 of 1403 Old 07-27-2014, 09:46 PM
dragonleepenn's Avatar
Quoted: 192 Post(s)
Liked: 85
Can't wait to see one,hope the dimensions are for a sealed box.
PeterV
dragonleepenn is offline
post #402 of 1403 Old 07-28-2014, 05:08 PM
Quoted: 192 Post(s)
Liked: 85
Originally Posted by chalugadp View Post
So this model
This is the one I need as far as size I want 4, what driver and cd is it?
What is the size of this box?
PeterV
post #403 of 1403 Old 07-28-2014, 05:44 PM - Thread Starter
Erich H's Avatar
Liked: 1713
We need to come up with a box design that works for Atmos, then we can adjust dimensions. Angled, square, wide but shallow, etc. The box size in the picture you posted is something like 8" wide, 10.5" tall and around 7 or 7.5" deep.
Maklar and pgwalsh like this.
Erich H is offline
post #404 of 1403 Old 07-28-2014, 06:01 PM
Quoted: 192 Post(s)
Liked: 85
That's what i was thinking to use these for atmos, why not .
Also what coaxial is that in the picture, who makes it.
PeterV
post #405 of 1403 Old 08-03-2014, 04:39 PM - Thread Starter
Erich H's Avatar
Liked: 1713
High end coaxials need high end enclosures. Here's some experimenting:
8" model:
I do have some other experimental stuff, but haven't taken pictures of that yet.
ID:	195169   Click image for larger version
mtg90 likes this.
Erich H is offline
post #406 of 1403 Old 08-03-2014, 04:40 PM - Thread Starter
Erich H's Avatar
Liked: 1713
6" model: Not sure I like the non circular frame as much as the 8" model.
This one is sort of like a marble style material and getting a good photo of it is not very easy for me. It looks much better in person.
Back side:
ID:	195193   Click image for larger version
ID:	195201   Click image for larger version
mtg90 likes this.
Erich H is offline
post #407 of 1403 Old 08-03-2014, 05:58 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
I pray to baby Jesus that you're going to offer both of those sizes in the ported slanted box style for these high end coax's.
jbrown15 is offline
post #408 of 1403 Old 08-03-2014, 06:09 PM
chrapladm's Avatar
Quoted: 788 Post(s)
Liked: 278
I am not much of a fan of the non-circular frames myself. That being said if it performs then I could look past that.
post #409 of 1403 Old 08-03-2014, 06:49 PM - Thread Starter
Erich H's Avatar
Liked: 1713
My problem is a speaker grill. Seems kind of stupid to cover up such a nice looking baffle! But I can't seem to think of anything right now.
Jbrown15, these actually get down to around 80hz in sealed boxes, so no need for porting. They can even be run full range for music in a tower speaker!
I can't recall the exact internal volume on the 8" model, but I think it was about .5cuft. Not very big, but in Corian, it weighs around 30lbs! Obviously that wouldn't make much sense for an angled surround sound box.
People that have heard these 8" type coaxials are always surprised at how much volume they can put out. So it seems to me these would make for the perfect 'sleeper' system in a nice living room where you wouldn't want huge speakers. Small, nice looking with a high WAF, and louder than most would ever need.
The more I looked at the boxes, the more I was wondering about getting them made up, but still being a DIY speaker kit that came with an assembled box as well.
Erich H is offline
post #410 of 1403 Old 08-03-2014, 07:07 PM
mmarki's Avatar
Quoted: 18 Post(s)
Liked: 26
I'm happy to see some progress with these. I'm really interested in the 6" for surrounds and I'm hoping they can be used in a low profile/slanted box. Unfortunately the wife doesn't want "big speakers hanging on the wall."
chalugadp likes this.
mmarki is offline
post #411 of 1403 Old 08-03-2014, 07:47 PM
jbrown15's Avatar
Liked: 1993
What about the smaller one? How low can they play? My room is smaller so I'm more interested in a slanted style box for the 6" to use as surrounds. Those ones really have my attention!
jbrown15 is offline
post #412 of 1403 Old 08-03-2014, 07:50 PM
chalugadp's Avatar
Liked: 1505
Yeah me and Joe don't listen at +10 reference like the crazies here
post #413 of 1403 Old 08-03-2014, 08:20 PM
NWCgrad's Avatar
Quoted: 1208 Post(s)
Liked: 1178
How about +18 like at Andrew's yesterday? All I can say is it was fantastic, but it will be years before my system is up to the challenge due to living in a townhouse (I think the police would be involved).
Looking forward to more of the 8" coaxial designs, I am in need of new surrounds in the next few months.
NWCgrad is online now
post #414 of 1403 Old 08-03-2014, 10:50 PM
Quoted: 192 Post(s)
Liked: 85
Hi Erich H,
What are the box dimensions for both the 6" and 8" coaxials. They look great.
PeterV
post #415 of 1403 Old 08-14-2014, 03:09 PM
rlhaudio's Avatar
Quoted: 293 Post(s)
Liked: 83
So I am ready to build some DIY rear speakers. I know this thread directed on some new upcoming projects but been kida stagnant for a few. So I figured I would ask here rather that the Sound Group Forum. My front speakers are 100db QSC 2150 with my sides being 97db Q!SC 8101 which leaves me deciding which to use for my rears. My last from of seat will be on a riser approx. 4 feet from my rear wall. I was thinking of building the Volt 10 with the slanted box. @ at price of $338.00 for drivers and box. OR I could build the Fusion 6 for $240.00 that's a difference of $98.00. Im just curious what I am giving up my building the Fusion 6 for rears? I thought perhaps the horn driver in the fusion would help with the seating distance for rear speakers. However the Volts would match closer as they are 95db.
I will defer to your expert opinions to those who have already built these speakers as to your opinionated recommendations. I am not looking to save $100.00 at the loss of sound quality and then end up replacing them with the Volts anyway. I'll still be keeping an eye of this page for Atmos speakers IF I decide to go that route In the future. Once these are placed into my theater, Ill be adding Wide speakers next. I'll wait of the height speakers until I decide on Atmos unless I build Volt 10 in the flat box and use them in my ceiling. Still waiting to see what the scientists come up with at S.G.
Marantz 7702mk2, Panasonic 8000 w/ 130" AT Screen HTPC w/30 tb
DIY QSC SC-2150 L,C,R (10) QSC SR-8101 sides, rears & atmos/dst-x
DIY (4) Fusion Tempest
DIY (2) UM 15 "Sub's (4) SI 18's (2) PA460 mbm
Dayton Titanic MK4 & B&W ASW 855 both subs for sale
rlhaudio is offline
post #416 of 1403 Old 08-15-2014, 07:37 AM
Bassment's Avatar
Quoted: 899 Post(s)
Liked: 362
for surrounds it's more about dispersion pattern than sound quality. Coaxials have a wide dispersion to cover lots of seats, horn's have controlled directivity. It depends on your speaker location/angle/seats but you will probably be better off with the volts.
Bassment is offline
post #417 of 1403 Old 08-15-2014, 07:53 AM
Sibuna's Avatar
Quoted: 372 Post(s)
Liked: 425
I'm gonna try my hardest to get an outdoor vid of one of the 8s playing this weekend
Sent from my LG G3 using Tapatalk
Sibuna is offline
post #418 of 1403 Old 08-15-2014, 08:28 AM
chrapladm's Avatar
Quoted: 788 Post(s)
Liked: 278
That would be awesome.
post #419 of 1403 Old 08-16-2014, 02:07 PM
Sibuna's Avatar
Quoted: 372 Post(s)
Liked: 425
ok so first vid, be warned the mic on my camera is not amazing, + it picks up everything thats going on in the world. the crackling you hear at the end of the first vid and on the 2nd vid (not uploaded yet) is the camera mic being maxed out (it is NOT the speakers), you also hear the focus motor which makes a grinding sound.
Vids should give you an idea, of what these can do. remember not designed for outdoor PA use.
Source is my phone running a stereo to RCA adapter to a Yamaha RX-A3000 running the volume at 0 in Pure direct mode
fumoffu, Erich H and Gorilla83 like this.
Sibuna is offline
post #420 of 1403 Old 08-16-2014, 03:06 PM
Sibuna's Avatar
Quoted: 372 Post(s)
Liked: 425
2nd vid
you can hear my cameras mic getting maxed out in this when im close its not the speaker
Erich H likes this.
Sibuna is offline
