SEOS-24? brutal dual 18" three-way LCR build - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1 of 164 Old 01-30-2014, 03:02 PM - Thread Starter
erwinfrombelgium's Avatar
Quoted: 438 Post(s)
Liked: 237
Erwin's SEOS-24 + BMS 4594ND + dual Beyma 18P80Nd LCR and much more
Thanks to the help and suggestions from several guys here, all the drivers are selected so it is the moment to start a build thread. Over the years, I have been all over the place deciding this!
For a semi-dedicated homecinema in a new house build, I want to build all the speakers starting with the center and then the left and right front speakers. Each LCR uses the same drivers, but since the center is put behind the 330 x 140 cm (130 x 55") 2.35/1 acoustic transparent XD screen from Seymour, which is visually floating, the box shape will be different. It is easier to make, so I want to have a go at that one before making the towers.
The room is about 22.8 x 28.4 x 8.7 feet hence more than 5,000 cubic feet. It is a box-in-box construction on top of a floating concrete floor to keep the noise sound inside. I checked the room ratio at Salford University website and it rates among the "best". Not my merit, just pure luck. I have also been consulting an acoustician to implement room treatments. I fancy diffusion elements which will be used behind the AT screen (flanking the center speaker), on the side walls, the back wall and the ceiling. Then a reverberation measurement will be executed which will enable us to decide on extra absorption, most likely in the bass region.
Two subs are long ready using 18" Maelströms. 550 liters each, "LLT" tuned to 13 Hz. I might add two more (sonotubes) if necessary.
The parts:
  • SEOS-24™ waveguide
  • BMS 4594ND coaxial 1.4"
  • EighteenSound 15ND930 [2] / or Beyma 18P80Nd [2]
The idea is to use a passive x-over between the BMS tweeter and mid (@6,300 Hz) and use a miniDSP 10x10 HD as an active x-over between the bass and mid @ 450 Hz since that is where ChopShop has it. The 15ND930 was suggested to me because it is suitable for a lower tune than most pro 15 inches. It is still 98 dB / Watt sensitive which theoretically gets me 125 dB @ 1 meter using the Emotiva XPR-5 (600 Watt @ 4 ohm). That should be enough for our 12 feet listening distance... Acoustic Energy, although specced great, was not a viable option since these do not seem to be represented in EU. Woofers are expensive to ship! The 15ND930 can be had for less than €250 including delivery.
Edit: it will be triple active using the 10x10 HD.
Edit: as there are only 8 analog outputs on a 10x10 HD, I need 2 miniDSP 4x10HD to do 3 three-way speakers.
The recommended enclosure volume is 60 - 140 liters (2.12 - 4.95 cu-ft). I made the exercise and I can actually stretch to 140 liter net volume for each woofer (320 liter gross internal with braces before the volume of the drivers and ports are counted for).
Now I have to figure out which tune and what size the ports have to be. Is there Mac-usable software out there? Or is there a good soul who could do the math for me? i would like to try to set the x-over to the subs as low as 45 Hz, the threshold of directivity. Maybe I end up higher, but it would be cool to have the option.
The two L+R towers would be MTM which puts the SEOS-24™ centered @ 1 m height (yes, you guessed it, they are 2 m height). This leaves two options for the center:
  1. MTM layout which puts the SEOS-24™ @ 1.25 m height. I guess I can tilt it downwards a bit to aim at MLP.
  2. MMT layout with both woofers on top, which puts the SEOS-24™ @ the same height as the L+R. Is that good practice? If the woofers would have been crossed higher, then I guess not, but I presume I am okay up to 450 Hz? This would be my preferred option.
I would use 30 mm MDF and apply more than enough bracing.
Any suggestions very much appreciated.
Latest picture:
Floor plan as of 2015/09/03
Edit: I managed to hook up the test center using a miniDSP 4x10HD. But I realize I simply lack the skills to implement a workable active crossover. so I decided to give this up and build 3 DIYSG Titan LX. The kit is only $520 each, which is cheaper than a BMS coaxial.
ID:	919042   Click image for larger version
filtor1 likes this.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #2 of 164 Old 01-30-2014, 03:07 PM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
The subs:
P2161237.jpg 35k .jpg file
filtor1 likes this.
post #3 of 164 Old 01-30-2014, 03:15 PM
bass addict's Avatar
Quoted: 366 Post(s)
Liked: 442
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #4 of 164 Old 01-30-2014, 03:22 PM
gpmbc's Avatar
Quoted: 336 Post(s)
Liked: 206
Ironically, I have 6 of the eighteen sound 15ND930 since having the Yorkville u215s and 3 seos 24s just missing the bms compression drivers if I ever decided to tinker.
gpmbc is offline
post #5 of 164 Old 01-30-2014, 11:16 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
How does the 18sound XT1464 compare to the SEOS-24 waveguides?
jbrown15 is offline
post #6 of 164 Old 01-31-2014, 05:36 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 180
I think the Seos-24 will hold patern down lower than the XT1464, allowing for a lower crossover point between the compression driver and woofer. The Seos-24 is a lot bigger, physically, as well.
Martycool007 is offline
post #7 of 164 Old 01-31-2014, 08:23 AM
AudioJosh's Avatar
Quoted: 281 Post(s)
Liked: 255
Some comments/questions,
So I didn't really follow the other super big SEOS builds but is there any measurements and distortion measurements of the BMS on the SEOS24? I am really surprised by the 450hz xo point. Given that a SEOS WG doesn't really provide much loading, unlike a horn, I would think the distortion would be through the roof below say 600-700hz. I would have guessed (without data) that this would be the ideal xo point. Again, I haven't see the data but given what I know about the waveguide design, that would be what I thought.
Second, are you considering doing a 2.5 way setup? The center to center distance using a massive waveguide and 15" woofers in MTM means a huge amount of combing and small forward lobe. Given your seating position is 12' away, I'd think a 2.5 way config might be more ideal. Since you are using a miniDSP 10x10 you have plenty of channels available to make that much easier.
It would just suck to expect way better results by building bigger and better and actually get worse results because of poor execution, which is why I ask the question.
I think the MMT upside down would be just fine if you properly orient the front lobe and do it 2.5 way again.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
post #8 of 164 Old 01-31-2014, 08:46 AM
mtg90's Avatar
Quoted: 462 Post(s)
Liked: 885
Distortion of the 4594 on the SEOS-24 starts to rise below 500hz or so, a 450hz crossover keeps it well tamed.
I was just playing around with the driver for this measurement, I don't know what distance I used or if the levels were calibrated but it gives you an idea of what the distortion does in the SEOS-24.
Flaesh likes this.
mtg90 is offline
post #9 of 164 Old 01-31-2014, 08:47 AM
jbrown15's Avatar
Liked: 1995
How the heck does Jeff from JTR get away with using the even smaller XR1464 and crossing over the BMS 4593 so low in his 212HT's confused.gif
jbrown15 is offline
post #10 of 164 Old 01-31-2014, 08:48 AM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
ChopShop's build with the same horn and coaxial:
http://www.avsforum.com/t/1457166/s-e-o-s-r-mega-build/1350#post_24251859
Isn't the combing frequency dependent? The center to center distance of the dual 15" will be like 80 cm (31,5") but they will only be used up to 450 Hz.
I can also swap the dual 15" for one 18".
post #11 of 164 Old 01-31-2014, 08:53 AM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
That and the XT1464 is designed as a 60° horizontal dispersion where the SEOS-24™ is 90° if I remember correctly. I suppose the XT1464 is aimed at higher SPL also. The only real downside is that the SEOS-24™ is bloody wide!
post #12 of 164 Old 01-31-2014, 08:55 AM
mtg90's Avatar
Quoted: 462 Post(s)
Liked: 885
Because at the lower crossover both woofer and horn are mostly omnidirectional therefore dispersion patterns still match up.
mtg90 is offline
post #13 of 164 Old 01-31-2014, 08:58 AM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
And to know that the recommended min x-over is 800 Hz...
http://www.eighteensound.com/index.aspx?mainMenu=view_product_simple&pid=268
post #14 of 164 Old 01-31-2014, 08:59 AM
Face2's Avatar
Quoted: 341 Post(s)
Liked: 205
Here's my distortion measurement of the SEOS-24(1.4" entrance) at 1m.
Face2 is offline
post #15 of 164 Old 01-31-2014, 09:22 AM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
You are aware that the BMS4594ND coaxial is already a 2 way, right? So if I divide the dual 15" again that would make it a 3,5 way, not?
post #16 of 164 Old 01-31-2014, 10:13 AM
AudioJosh's Avatar
Quoted: 281 Post(s)
Liked: 255
I'd say that looks ok at 500hz xo, given those measurements, *I* personally wouldn't go lower than 500hz, probably 550 to be safe. Yeah, sorry forgot about the coax driver, I was merely commenting on the .5.
Yes, combing is freq dependent, but a 450hz wave is ~24" long, so waveguide's to outer woofer space will still cause combing at 450hz. Its one of the reasons why when we designed the SEOS we made the vertical shorter than the horizontal to widen the vertical lobe between the waveguide and the woofer. When you add the second woofer the distance is a whole driver diameter further away.
post #17 of 164 Old 01-31-2014, 11:53 AM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 354
Oh this looks like a delicious large speaker build. Love it!
Swolephile is offline
post #18 of 164 Old 01-31-2014, 03:23 PM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
There is no substitute for cubic inches!
Anyone care to comment on the size? I can go to up 140 liter per 15" woofer. I believe ChopShop did 5 cuft per woofer (135 liter). OR I can do 270-280 for a single 18".
post #19 of 164 Old 01-31-2014, 06:16 PM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
What about two 18" from Beyma: 18P80Nd. Specs seem great, wide frequency range and 100dB/watt. Ofcourse in MTM (more WTW) the distance between the center would be 86 cm (34"). 18" looks nicer with the SEOS-24™.
Price is reasonable when purchased in Spain: about €320 incl delivery.
Beyma_18P80NdE.pdf 334k .pdf file
BEF-NO initially used two 15P80Nd in his inConcert Miles LCR:
http://www.avsforum.com/t/1416004/bef-from-norway-diy-uncompromising-theater/30#post_22161723
Then he added a third 15" plus a dedicated midrange:
http://www.avsforum.com/t/1416004/bef-from-norway-diy-uncompromising-theater/120#post_23278790
As you will notice, I was all set to build that one, but the dispersion issues put me off. It is really only a 40° horizontal dispersion, not 80° as claimed for the TPL150H by Beyma.
Here's another fine example of a threeway version of the inCincert Miles:
http://www.hifisentralen.no/forumet/mitt-hi-fi-anlegg/71117-ntligen-hemma.html
He uses two x-over points to the woofers which he chooses from: 150 Hz (vocal) or 250 Hz (metal)
post #20 of 164 Old 01-31-2014, 06:22 PM
Quoted: 280 Post(s)
Liked: 180
So would using a single 15" or even a single 18" woofer solve the center to center issues with lobbing on the Seos-24 with a compression driver, (be it a BMS-4594, or even a Radian 950BePB), that is crossed at 500hz or even 450hz?
post #21 of 164 Old 01-31-2014, 06:48 PM
tuxedocivic's Avatar
Quoted: 2139 Post(s)
Liked: 1996
That would "solve" the "problem". But I don't think its a problem at that frequency. The vertical spreads is probably a bigger advantage than the negative of lobing.
I'd go with 18s myself. As long as its free of any break up until 800hz and nothing to crazy until 1000hz or higher.
My youtube channel: Impulse Audio
tuxedocivic is offline
post #22 of 164 Old 01-31-2014, 08:13 PM
Face2's Avatar
Quoted: 341 Post(s)
Liked: 205
The AE TD-15S works well in 5ft^3 sealed. I believe the AE TD-18H works well in 5ft^3 ported, and is more efficient.
Face2 is offline
post #23 of 164 Old 02-01-2014, 04:54 AM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
AE is not on the European market hence the shipping, duties and VAT make it too expensive vs the EU brands. I guess they would cost about €500 each to me. Beyma, a Spanish brand are like €320 if bought at a Spanish webshop. And the 18P80Nd is certainly not the cheapest Beyma 18", but maybe the best for my goal.
post #24 of 164 Old 02-01-2014, 05:01 AM - Thread Starter
Quoted: 438 Post(s)
Liked: 237
I think the Beyma 18P80Nd is excellent. Frequency range is 25-4000 Hz and fs = 30 Hz. And 100 dB / 1 Watt efficient. So it goes both lower and louder than the already excellent 18Sound 15ND930 as far as I can tell.
Which tune would you recommend in a 5 cuft (135 liter) net volume for each of the drivers?
post #25 of 164 Old 02-01-2014, 09:01 AM
Liked: 1996
The specs might say 4000hz but I wouldn't let that thing make a whisper above 1khz. Looks good though.
post #26 of 164 Old 02-02-2014, 06:46 AM
coctostan's Avatar
Liked: 142
First we don't know (at least I've not seen it posted) what Jeff is doing with the crossover. The spec is fairly vague.
With that said, the BMS mid in home use is easily used down to 450hz. The rising distortion right at 450hz is basically nil once a filter is applied. Whether it is better crossed at 450 or up by 600 is a design choice with many factors.
I agree that the concerns about comb filtering are overblown in this case especially with a 450hz cross. It also depends on how steep the transfer function is at in this region.
Now if it were up to me, I'd use 4 12" woofers with two side by side above and two side by side below. This has multiple benefits. First it will control directivity a bit lower. Second, the CTC spacing is better which widens the vertical lobe a bit and further reduces MTM comb filtering. Finally, This should further reduce excursion versus equivalent 15s. This reduces IMD.
Of course the differences between a single 15, MTM 15s, quad 12s or MTM 18s are small especially in a home where none of the drivers will be taxed. What I'm saying is that it would be hard to tell them apart assuming equal implementation.
coctostan is offline
post #27 of 164 Old 02-02-2014, 07:52 AM
Quoted: 280 Post(s)
Liked: 180
I saw a thread on the Klipsch forum a while back where a guy used four Dayton Pro-10's in a CornScala build that he did. It looked like an awesome speaker!
So you are saying that any differences between a single 18", a MTM with 15" drivers or a quad 12" driver configuration would be small in a typical small room in a home theater environment?
I really like Scott's design with the quad JBL-2226's in each of his LCR's. That is probably huge overkill, but cool, none the less!
post #28 of 164 Old 02-02-2014, 11:34 AM
coctostan's Avatar
Liked: 142
Yep, diminishing returns. Look at the shootout that included the Danley, Seaton, CBT and Noesis. Four very well designed speakers and nobody could even figure out which was which. There were even big design differences.
Adding woofer capacity is cool but frankly a single pro 15 isn't breaking a sweat from 80-400hz in even the craziest home setup. Two is nice, but the difference is so small because you are really only buying headroom. Yes, there is less excursion but you are going from maybe 1mm to .5mm.
Of course there are other potential benefits (and downfalls) to more midwoofers.
Much of this is like a guy with a 1000hp drag car fighting for 2hp. That might make sense because it is a competitive environment but with speakers we are strictly subjective and these tiny differences get overshadowed by larger factors like room interaction.
Of course it isn't an either or proposition, but once you get capability in the range of dual high end pro 15" mid basses the only way to improve is by working on the room. It is like that 1000hp guy adding 200hp but he just spins the tires and runs the same time (and probably no quicker than when he was at 500hp).
post #29 of 164 Old 02-02-2014, 12:20 PM
Bill Fitzmaurice's Avatar
Liked: 5625
+1. If there is a way to improve the overall result it's not with a larger woofer, it's by using multiple smaller woofers, vertically stacked, for wider horizontal dispersion where you want it, narrower vertical dispersion where you don't. The main thing you accomplish with going larger is to require a lower crossover. The same applies to using multiple woofers that aren't vertically aligned.
Bill Fitzmaurice is offline
post #30 of 164 Old 02-02-2014, 03:04 PM
Quoted: 280 Post(s)
Liked: 180
Bill, would you mind explaining a little bit about where you would want narrower vertices dispersion? Also, would duel woofers that are side by side not help with both horizontal dispersion and reduce some of the lobbing associated with vertically stacked woofers?
