Inuke's on sale! - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #451 of 702 Old 03-13-2014, 07:55 PM
loopaddiction's Avatar
I'm guessing that's like 70%? That should work, give it a go.
loopaddiction is offline
post #452 of 702 Old 03-13-2014, 08:00 PM
dtsdig's Avatar
Quoted: 829 Post(s)
Liked: 921
Originally Posted by jbrown15 View Post
What if I don't have isopropyl alcohol?
Do you have access to a hair dryer? That's what I used to soften the factory glue for a few seconds and remove the header. Easy peasy.
dtsdig is online now
post #453 of 702 Old 03-13-2014, 08:01 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
what about a small dab of nail polish remover?
jbrown15 is offline
post #454 of 702 Old 03-13-2014, 08:03 PM
I wouldn't risk it. The hair dryer method should work too.
post #455 of 702 Old 03-13-2014, 08:04 PM
dtsdig's Avatar
Quoted: 829 Post(s)
Liked: 921
You don't want acetone on the pcb. Bad idea.
post #456 of 702 Old 03-13-2014, 08:15 PM
jbrown15's Avatar
Liked: 1993
Okay, so I got the connector and collar off with the hair dryer no problem. So is the general consensus that the middle wire with my fans in the positive?
jbrown15 is offline
post #457 of 702 Old 03-13-2014, 08:16 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Just try , won't damage if your wrong.
chalugadp is offline
post #458 of 702 Old 03-13-2014, 08:17 PM
Yeah how I connected it is consistent with Archaea's explanation. The 2 holes that align with the molex adapter's wires are the ones you need to connect. Middle is power, edge is ground.
post #459 of 702 Old 03-13-2014, 08:21 PM
jbrown15's Avatar
Liked: 1993
Okay so in the picture I posted a little while ago it had a secondary connector with two wires, is it safe to assume that those two wires are the + & -? and I already know that the middle wire in the +, so if that's the case the wire in the second connector is the -?
jbrown15 is offline
post #460 of 702 Old 03-13-2014, 08:23 PM
Yesh
post #461 of 702 Old 03-13-2014, 08:35 PM
jbrown15's Avatar
Liked: 1993
Well thanks everyone for answering my dumb questions, got the fans switched out. Holy cow what a difference. smile.gif
jbrown15 is offline
post #462 of 702 Old 03-13-2014, 08:41 PM
laugsbach's Avatar
Quoted: 134 Post(s)
Liked: 202
laugsbach is online now
post #463 of 702 Old 03-13-2014, 09:27 PM
brian6751's Avatar
Quoted: 886 Post(s)
Liked: 680
Originally Posted by zeus33 View Post
Isn't that counter intuitive? Won't the Audyssey just override your settings and try to flatten out the frequency response? I understood that you should set your DSP after the Audyssey calibration so that your settings in the DSP remain intact.
It's usually best to EQ it best you can then Let Audyssey do its thing. Then Go back and EQ to taste.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #464 of 702 Old 03-14-2014, 12:25 AM
jbrown15's Avatar
Liked: 1993
Wow, these fans are so quite that I'm almost wondering if they'll provide enough cooling. Someone tell me I'm worrying about nothing please?
jbrown15 is offline
post #465 of 702 Old 03-14-2014, 02:27 AM
I'm wondering the same thing, the airflow is noticeably less than the stock fans. I'm unable to put my modded iNuke through the paces since my DIY subwoofer won't be done until the end of the month. Someone have any experience and can chime in?
post #466 of 702 Old 03-14-2014, 06:29 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Unless you are doing sine wave testing there will be plenty of cooling.
These things are designed for rack dense areas that are not necessarily climate controlled. A home theater is about the easiest life these things could have with typical short bursts and close to idle most of the time in a cozy temperature.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #467 of 702 Old 03-14-2014, 07:11 AM
Bstloukal1's Avatar
I received both my 3000dsp and 6000dsp did the fan swaps on both but have to say to me the original fans aren't really that loud for me. I have a PS3 as my blu ray and the fan on that is about the same as the original on the 3000dsp. My question is I have set up the 3000dsp in bridged mono to one of my subs and have played around some with the setting. not thinking far enough in advance I did not pic up a separate mic to use REW yet. Since I have the velodyne SMS-1 has anyone used this setup to fine tune the DSP. I pulled the SMS-1 out of the box yesterday to get started but wanted to see if any one has gone this route. It appears I have to run the sub through the SMS-1 and then adjust the 3000DSP separately. Let me know your thoughts on this is this will work ok versus the REW way or if I should just pony up for a new mic.
Bstloukal1 is offline
post #468 of 702 Old 03-14-2014, 10:57 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 690
Fan mod one EP2500, iNuke 3000dsp and 6000dsp no issues.
EP2500 5 years now, 6000 1 year, 3000 3 months.
Via my iPhone 5s & Tapatalk, LLAP
mtbdudex is offline
post #469 of 702 Old 03-14-2014, 12:18 PM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
There is no reason to use the SMS-1 if you have a DSP iNuke. Unless I am missing something?
Martycool007 is offline
post #470 of 702 Old 03-14-2014, 12:29 PM
Bstloukal1's Avatar
my question was more for the viewing of a graph to see the actual response of the sub. I have adjusted the 3000dsp only from a listening perspective. So what I want to do is see how the frequency response actual turns out to see what else I can play with. I do not have a mic to use the for the REW setup so I figured I see if I could use the sms-1 as it has a mic and all the goodies. so I was just picking some ideas. figured I could set up the sms-1 and do the sound waves as it will graph it and I can adjust the dsp separately and resweep for any other adjustments Tis a lot of setup and work though. this may be a moot point as I think just sold the sms-1 I have listed in the classifieds.
post #471 of 702 Old 03-21-2014, 06:48 AM
Bstloukal1's Avatar
i have hooked up my 3000dsp and is running strong in bridged mono. I am working on the 6000dsp now. what is the best way to hook up 1 sub to it. sub is wired to 4ohm. currently have the speakon +1 , -1. any thing I should considered in the configureation on the dsp screen
post #472 of 702 Old 03-21-2014, 07:47 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Your easiest solution is to simply use one channel on the 6000.
Joe = LFE Addict
jpmst3 is offline
post #473 of 702 Old 03-21-2014, 07:54 AM
Bstloukal1's Avatar
Yeah I am running channel a in stereo right now but was wondering how the dual mono would work even though only using 1 channel
post #474 of 702 Old 03-21-2014, 08:01 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I am not sure what you mean by dual mono in relation to the way you have it hooked up. But, you could also run one channel to each voice coil but there would be no benefit that I could think of.
Joe = LFE Addict
jpmst3 is offline
post #475 of 702 Old 03-21-2014, 08:17 AM
Bstloukal1's Avatar
yeah I thought so also. I will be playing around with it this weekend with it. the only difference I see with the way I am running this versus the 3000dsp in bridged mono is the peak limiter. right now I think it is at like 188. I haven't adjusted anything other than the HPF and HS12 to deal with my low end.
post #476 of 702 Old 03-21-2014, 08:17 AM
JohnDean's Avatar
Quoted: 433 Post(s)
Liked: 183
I just thought I'd throw this out there....
Yesterday I was at Guitar Center and they price matched/beat sweetwater on a dsp/crossover. Total price shipped to my door was $16 cheaper. I know that's not a lot but it also gives me a local place for returns & exchanges. I also know their customer service can do the same. Maybe worth a try on amps too.
JohnDean is offline
post #477 of 702 Old 03-21-2014, 08:32 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Joe = LFE Addict
jpmst3 is offline
post #478 of 702 Old 03-21-2014, 09:27 AM
Quoted: 280 Post(s)
Liked: 176
I wish that there were some sort of write up, article, or reference post that walks a person through the iNukeDsp setup. I still don't have the used iNuke1000dsp's and the single iNuke3000dsp that I ordered from an eBay seller, but, I would really like to be able to read up on how to properly set it up as far as EQ'ing my left & right speakers, and subs & mid- bass cabs!
post #479 of 702 Old 03-21-2014, 07:25 PM
gworrel's Avatar
Quoted: 288 Post(s)
Liked: 255
You can download the software and try it out. Then ask any specific questions you may have. I have a DBX Driverack PA and the Inuke DSP is much easier to configure. You will probably want to use some measurement software like REW to monitor the changes that you make. http://www.behringerdownload.de/iNuke/iNuke_Remote_Connect_V01-1.zip
gworrel is online now
post #480 of 702 Old 03-22-2014, 06:32 AM
raynist's Avatar
Quoted: 1266 Post(s)
Liked: 1201
I am looking to pick up a couple 1000dsp's or 3000dsp's.
Out of curiosity, doesn't anyone know if I could split the signal coming out of my AVR and run it to the L/R of the inuke and have one channel be 150 and up and the other be 150 and below for a midbass module?
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
