Inuke's on sale! - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #481 of 702 Old 03-22-2014, 07:30 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Originally Posted by Martycool007 View Post
I wish that there were some sort of write up, article, or reference post that walks a person through the iNukeDsp setup. I still don't have the used iNuke1000dsp's and the single iNuke3000dsp that I ordered from an eBay seller, but, I would really like to be able to read up on how to properly set it up as far as EQ'ing my left & right speakers, and subs & mid- bass cabs!
There are various threads regarding the DCX-2496. The DSP in the Behringer amps works the same way.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #482 of 702 Old 03-23-2014, 07:29 PM
raynist's Avatar
Quoted: 1280 Post(s)
Liked: 1211
Originally Posted by raynist View Post
I am looking to pick up a couple 1000dsp's or 3000dsp's.
Out of curiosity, doesn't anyone know if I could split the signal coming out of my AVR and run it to the L/R of the inuke and have one channel be 150 and up and the other be 150 and below for a midbass module?
Anyone know?
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #483 of 702 Old 03-23-2014, 07:42 PM
Bstloukal1's Avatar
Yes. You should be able to accomplish what your looking to do. I have not tried it yet but using the biamp mode you should be able to have the low end to the sub and the high end go to another driver. The link here should show you the biamp and how to hook it up
http://www.behringer.com/assets/NU6000DSP_NU3000DSP_NU1000DSP_M_EN.pdf
Bstloukal1 is offline
post #484 of 702 Old 03-23-2014, 07:52 PM
whitey019's Avatar
Quoted: 90 Post(s)
Liked: 55
Yes you can do that. Run the output from your AVR to each Ch A input of two inukes and use either modes Bi-amp 1 or 2 and run corresponding output to the correct speaker (one amp for the left and one for the right). You can also do this with the non-dsp version, but would be limited to the 150Hz hi/lo-pass filter. The DSP version provides a lot more flexibility.
Too slow: Bstloukal1 beat me to it, while I checked the software settings on my laptop.
whitey019 is offline
post #485 of 702 Old 03-23-2014, 08:16 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Sorry how would you do this exactly? I was thinking about it early and I'm running two subs off of a iNuke 6000DSP in stereo more, one sub per channel. And when I EQ'd them a little in the PEQ settings to lower and boost certain frequency's it doesn't give me the option for either the A or B channel. It only lets you do them together.
jbrown15 is offline
post #486 of 702 Old 03-24-2014, 07:24 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
It sounds like you have the channels "linked". Try unlinking them and the settings should be independent for each channel. From there you should be able to set your crossovers to achieve what you desire.
Joe = LFE Addict
jpmst3 is offline
post #487 of 702 Old 03-24-2014, 07:46 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
So with the iNuke3000dsp it is possible to go from the subwoofer out of an AVR and have one channel on this iNuke3000dsp go to a sub covering from say...20hz to 80hz and then the other channel going to a mid-bass cabinet covering say...60hz to 150hz?
What would be the ideal way to do this if you have two mid-bass cabinets and two subs, and two iNuke3000dsp's? Could you split the signal coming from your AVR into two iNuke's for this purpose?
Martycool007 is offline
post #488 of 702 Old 03-24-2014, 08:25 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yes and yes.
This was answered above. You can set the crossovers on each channel independently, that is why they are there.
You can split the output to either multiple channels and/or multiple amps.
Joe = LFE Addict
jpmst3 is offline
post #489 of 702 Old 03-24-2014, 03:01 PM
LastButNotLeast's Avatar
Quoted: 1493 Post(s)
Liked: 1095
Last day of the PE Spring sale.
I couldn't see buying the 1000 for $190 when I could get the 3000 for $255.
So I'm getting an NU3000DSP when they're back in stock.
I don't even know what I'm doing with it, yet!
:D
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #490 of 702 Old 03-24-2014, 05:03 PM
whitey019's Avatar
Quoted: 90 Post(s)
Liked: 55
You need to use Dual-Mono Mode rather than Stereo Mode and then you will have separate Filter/PEQ/DEQ/Delay/Limit settings for each channel.
post #491 of 702 Old 03-24-2014, 06:55 PM
raynist's Avatar
Liked: 1211
I bought two also!
post #492 of 702 Old 03-24-2014, 08:18 PM
Quoted: 280 Post(s)
Liked: 176
So would this be the optimal way to integrate and power some mid-bass cabinets along with subs? This would probably work up to the LP point that my AVR has on the LFE channel. I wonder how I could setup two subs powered by a single iNuke3000 and two mid-bass cabs powered by a single iNuke1000dsp? Split the LFE out with a Y cable at the output on my AVR? What if I want to have the mid-bass cabs go up higher than the highest LP option on my AVR? Ie, if the LP on my AVR only goes up to say..120hz or 150hz, and If I wanted go cross my mid-bass cabs at 200hz, how would that work?
post #493 of 702 Old 03-24-2014, 08:29 PM
dwaleke's Avatar
Quoted: 1114 Post(s)
Liked: 515
You want to split your left/right preamp output to your midbass units. Leave your LFE alone. That's how I would do it. Are you driving your left/right with a separate amp currently?
dwaleke is offline
post #494 of 702 Old 03-24-2014, 08:39 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yes, this is what these amps and EQs were designed to do.
Joe = LFE Addict
jpmst3 is offline
post #495 of 702 Old 03-24-2014, 09:01 PM
tential's Avatar
Quoted: 40 Post(s)
Liked: 50
Parts Express won't charge my CC until the product is instock right?
tential is offline
post #496 of 702 Old 03-24-2014, 09:08 PM
Liked: 1095
No, they won't charge it until it ships.
Theoretically. ;)
post #497 of 702 Old 03-25-2014, 05:50 AM
Quoted: 280 Post(s)
Liked: 176
Thanks for the reply! I believe others have told me to use the Left & Right speaker pre-outs as well, but, I never fully grasped how that would work. Will my Denon AVR-3310 send a signal to the Left & Right speaker pre-outs while also sending a signal to the Left & Right speaker binding post? So would I just hook up the iNuke1000dsp to the pre-outs as you described and set the LPF, HPF, and EQ in the iNuke? Then leave the speakers alone on the binding post?
Currently I don't have my mains hooked up to a separate amp, but, at some point I do plan to add an additional iNuke1000dsp to power the Left & Right speakers. When I do this, how would the other iNuke1000dsp that would be powering my mid-bass cabinets need to be hooked up since both would need to share the same pre-out?
Being that I would then need connections to two iNuke1000dsp amps to the same pre-out for the Left & Right speakers, and my duel mid-bass cabs, would I then just use a Y splitter out of each L+R pre-out, or should I just hook up one iNuke to each Left & Right speaker pre-out and have one channel power, EQ, and HPF/LPF the mid-bass cab on that channel, and have the other channel on the iNuke power the corresponding speaker that is also on that pre-out?
post #498 of 702 Old 03-25-2014, 02:38 PM
scotsman8's Avatar
Quoted: 12 Post(s)
so what fans are recommended for the inuke6000dsp?
scotsman8 is offline
post #499 of 702 Old 03-25-2014, 03:24 PM
laugsbach's Avatar
Quoted: 135 Post(s)
Liked: 202
There are plenty to pick from but I just installed this one:
http://www.amazon.com/gp/product/B000234W0E/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
laugsbach is online now
post #500 of 702 Old 03-25-2014, 04:30 PM
dwaleke's Avatar
Liked: 515
Yes that is what I would do. The preamp outputs always output a signal.
I would use a Y cable, but your second method might work. I don't have a dsp inuke so I cannot say for certain.
dwaleke is offline
post #501 of 702 Old 03-25-2014, 06:58 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
I bought two also!
same here... stock due on 4/4... with the spring sale, and AMEX's generous 150 off 500 offer... works out to $360 shipped for a pair of 3000dsp's. smile.gif
mods, can we have a 'dislike' button ?
wlhungdude is online now
post #502 of 702 Old 03-25-2014, 07:02 PM
Boomassiv's Avatar
Quoted: 118 Post(s)
Liked: 50
?AMEX 150 off?  Didn't know about this.
Boomassiv is offline
post #503 of 702 Old 03-25-2014, 07:25 PM
BadmanSound's Avatar
Yes please expand on the offer. Was looking to snag a pair of inuke dsps. Initially a 6k and 1k, but additional savings might sway me towards a 3k
BadmanSound is offline
post #504 of 702 Old 03-25-2014, 07:26 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
targeted offer for the 150, but there is an available 100 off 500 purchase offer available when opening a new Blue Cash Everyday card. quick google search brings it up. sorry for the off topic discussion, but ************** finance forum has this and many, many more ways to save, and even make $, in very clever ways.... moral or ethical ways, different story wink.gif
post #505 of 702 Old 03-25-2014, 07:34 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
sorry for the censored website, but apparently it's not ok to discuss having a FAT, as in not thin, WALLET, when visiting a favored (dot) COM. and promoting them would probably earn another infraction point. rolleyes.gif
so consider yourself warned...
post #506 of 702 Old 03-25-2014, 08:05 PM
jbrown15's Avatar
Liked: 1993
I used this that were recommended by another member
http://www.newegg.com/Product/Product.aspx?Item=N82E16835226034&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6155355&SID=1co6hpjgq7bh7
No wire cutting or soldiering required, so the fan swap out went pretty easy.
jbrown15 is offline
post #507 of 702 Old 03-25-2014, 09:05 PM
Liked: 1095
One red and one yellow?
:eek:
:D
post #508 of 702 Old 03-26-2014, 05:49 AM
noysboy's Avatar
Im using the red version of these on 5 inukes and everything is great. Even with reduced airflow, the amps never get too hot, even after long bass sessions.
noysboy is offline
post #509 of 702 Old 03-27-2014, 10:32 AM
raynist's Avatar
Liked: 1211
I just got a notification that my 2 inuke 3000dsp's have shipped from PE, thought it wouldn't be for another week or so.
I have never used a pro amp. How do I connect these to my JTR speakers? Is there an adapter I can buy/order that will allow me to connect?
post #510 of 702 Old 03-27-2014, 11:33 AM
Liked: 1095
Mine, too. Can't wait for the free baseball cap.
