Inuke's on sale! - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #541 of 702 Old 04-10-2014, 09:25 AM
LastButNotLeast's Avatar
Quoted: 1497 Post(s)
Liked: 1099
Keep an eye out for a Parts Express coupon, and you can at least save something. I got mine when they had their "Summer" coupon sale, otherwise, SAVE5 almost always works, SAVE10 sometimes works.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #542 of 702 Old 04-10-2014, 10:13 AM
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
Originally Posted by BrutalBodyShots View Post
Anyone know of any 6000dsp deals going on right now that best the standard $399 price across the board?
For those that have been following 6000dsp pricing, what has been the lowest price anyone has come across one for in the last several months?
I probably won't need it for another 4-6 weeks, but would like to know the optimal price point to pull the trigger at should I see it.
I just received mine, ordered directly from a music store price was $321 out the door. It was an open box item but seems to working just fine. Had one little scratch on the top but no biggie. Try calling some of the local music stores. I checked online at Guitar Center and they showed one in PA and had the ability to ship.
On a side note, my 3000dsp had the dreaded hum and this 6000dsp has no hum. Interesting.
cessna1466u is offline
post #543 of 702 Old 04-10-2014, 03:58 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Is the inuke to DIY sub product of choice? Is the DSP version always better to get for the config options?
Blazar!
blazar is offline
post #544 of 702 Old 04-10-2014, 04:45 PM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
I have not been around this forum all too long, but it seems the answer is yes to both of your questions from what I've come to see around here.
BrutalBodyShots is offline
post #545 of 702 Old 04-10-2014, 04:54 PM
dwaleke's Avatar
Quoted: 1114 Post(s)
Liked: 515
It really depends on your subwoofers and whether or not you need the DSP functionality. If you do not have a way to EQ your sub the dsp is nice. Feature wise it is pretty good. It will do an analog to digital and digital to analog conversion to use the DSP. This will add latency and in turn change the phase of your sub slightly. That's usually easily fixed by increasing distance of your sub in your AVR. Auto room eq in an AVR will automatically account for this unless you are running multiple subs with different amplifiers and you used the DSP model on some, but not all the subs.
Some may say the additional signal conversion could reduce quality. True or not is for you to decide. For a subwoofer I'd be surprised if most people could hear the difference. But I've never a/b tested it.
The iNuke is one of the higher value options when it comes to amplifier output.
The previous go to amplifier was the EP2500/EP4000 from Behringer which is a copy of a decent quality qsc amplifier. Still a very good option as well.
Other popular options are the LG clone amps FP10000Q and the FP14000, the IPR2 series from peavey and the sister Crest Prolite models, Cerwin Vega CV-2800 / CV-5000, and some of the Crest CC series (CC4000, CC5500) seem to be popular among forum members.
dwaleke is offline
post #546 of 702 Old 04-10-2014, 09:04 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Awesome, im soaking all this in like a sponge... Thanks!
Blazar!
blazar is offline
post #547 of 702 Old 04-11-2014, 07:57 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
They reign supreme when it comes to bang for buck, especially the 6000DSP when you consider it has the very capable EQ built in.
They are definitely the choice for the budget minded and have performed well regardless.
I would be using them now if it weren't for the dreaded "thump" they emit during shutdown.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #548 of 702 Old 04-11-2014, 08:13 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
How much power RMS does the inuke3000dsp put out per channel, per Ohm rating and in Bridged mode, per ohm rating? Have there been tests done?
Also, what is the hum and or thump at shutdown people are talking about?
04rex is offline
post #549 of 702 Old 04-11-2014, 08:27 AM
Archaea's Avatar
Quoted: 2876 Post(s)
Liked: 2456
Inuke 3000 DSP true power ratings...
about 1100 per channel in 2 ohm
about 600 per channel in 4 ohm
about 280 per channel in 8 ohm
Archaea is online now
post #550 of 702 Old 04-11-2014, 08:28 AM
dwaleke's Avatar
Liked: 515
Peak power 20ms/1000Hz
8 Ohm 2x465
4 Ohm 2x870
2 Ohm 2x1700
RMS (sine wave)
8 Ohm 2x312
4 Ohm 2x600 (2x375 after 3 seconds)
2 Ohm 2x1176 (2x750 after 1 second, protect after 5 seconds)
Behringer says:
NU3000 - approx 580W RMS @ 4 ohms per channel
NU3000 - approx 310W RMS @ 8 ohms per channel
Edit: Archaea beat me to it.
dwaleke is offline
post #551 of 702 Old 04-11-2014, 08:33 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
OK, thanks guys. I am looking for about 1,000 RMS @ 4ohms per channel. Is there any iNuke that does that with DSP?
04rex is offline
post #552 of 702 Old 04-11-2014, 08:34 AM
dwaleke's Avatar
Liked: 515
dwaleke is offline
post #553 of 702 Old 04-11-2014, 08:35 AM
Quoted: 353 Post(s)
Liked: 85
That's the first time I've read of someone referencing a "thump" at shutdown from one of these units. Is it a common problem that just doesn't get talked about or have only a handful of owners experienced it?
post #554 of 702 Old 04-11-2014, 08:39 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
It is very common....Peruse this thread and the 'new sheriff 12000' thread.
The only way to avoid it that I know of is to power it off manually and not use triggers as is common.
Joe = LFE Addict
jpmst3 is offline
post #555 of 702 Old 04-11-2014, 08:40 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
How much does the 6000 put out per channel @ 4 ohms RMS?
04rex is offline
post #556 of 702 Old 04-11-2014, 08:40 AM
dwaleke's Avatar
Liked: 515
A few people have reported it and it appears to happen only with the DSP models. I believe it is when you connect/discount the power without pushing the power switch (triggered by relay).
dwaleke is offline
post #557 of 702 Old 04-11-2014, 08:41 AM
dwaleke's Avatar
Liked: 515
Originally Posted by 04rex View Post
How much does the 6000 put out per channel @ 4 ohms?
~1800->2200 @ 4 ohms per channel.
The 6000 is often referred to as (2) 3000s bridged in one box. So the 4 ohm number per channel what what the 3000 bridged numbers are. When you bridge @ 4 ohms you are essentially adding up the 2 ohm power from both channels and outputing into one channel @ 4 ohms.
dwaleke is offline
post #558 of 702 Old 04-11-2014, 08:41 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Others have reported it on the NU4 as well, a non-DSP model.
Joe = LFE Addict
jpmst3 is offline
post #559 of 702 Old 04-11-2014, 08:43 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Dang, thats too much. Looking for around 1,000 rms.
04rex is offline
post #560 of 702 Old 04-11-2014, 08:44 AM
dwaleke's Avatar
Liked: 515
It's never too much. Just turn the input gain down. Amplifier head room is a good thing.
dwaleke is offline
post #561 of 702 Old 04-11-2014, 08:44 AM
laugsbach's Avatar
Quoted: 135 Post(s)
Liked: 205
You can use the limiter in the DSP model...
laugsbach is online now
post #562 of 702 Old 04-11-2014, 08:44 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Huh?
They have gain knobs...
Is 500hp too much engine for your car? Do you floor it everywhere you go?
You want more than you need. Just don't use all of the available power.
If you are worried about it, get the 3000.
Joe = LFE Addict
jpmst3 is offline
post #563 of 702 Old 04-11-2014, 08:47 AM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Intredasting
04rex is offline
post #564 of 702 Old 04-11-2014, 10:24 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
It's funny that you mention this because I have two iNuke 6000DSP's that I bought back in February and I've never had either of them make the dreaded "thump" sound.
jbrown15 is offline
post #565 of 702 Old 04-11-2014, 10:32 AM
Quoted: 116 Post(s)
Liked: 201
Same here, with both the 3000dsp and the 6000dsp I have had, neither makes the thump. Both have the ground loop hum but not thump. I think I read somewhere that it has something to do with the way you are powering it, but don't remember the specifics.
post #566 of 702 Old 04-11-2014, 10:35 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
I want an amp that i can plug into a trigger system theoretically... As opposed to leaving it on all the time.
Crown xls for example dont thump even if you power them on without the power button. That's because they have powered relays.
Blazar!
blazar is offline
post #567 of 702 Old 04-11-2014, 10:38 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
But, are using a trigger or the built in power button?
The issue arises when used with trigger.
Joe = LFE Addict
jpmst3 is offline
post #568 of 702 Old 04-11-2014, 10:40 AM
jbrown15's Avatar
Liked: 1993
Ah okay, that's why I don't have a thump. I'd rather push the power button on/off myself then have to put up with a thump noise every time I used my subs.
cessna1466u likes this.
jbrown15 is offline
post #569 of 702 Old 04-11-2014, 12:09 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Ya, everyone has a different implementation.
I prefer to hit one button on my remote and have the entire A/V signal chain power down, with HDMI 1.4 and triggers it works wonderfully.
Interestingly, the Behringers seem to be the only amp that I have ever owned that exhibit that behavior.
Joe = LFE Addict
jpmst3 is offline
post #570 of 702 Old 04-11-2014, 01:08 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 220
All of the external pro amps I've used in conjunction with my MiniDSP exhibited this problem. I have a Behringer EPX4000, LG clone FP14K, QSC RMX-5050 and had a Crown (forgot the model number). My solution is to leave the MiniDSP on all the time.
duc135 is online now
