Inuke's on sale! - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #571 of 702 Old 04-11-2014, 01:09 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Originally Posted by duc135 View Post
All of the external pro amps I've used in conjunction with my MiniDSP exhibited this problem. I have a Behringer EPX4000, LG clone FP14K, QSC RMX-5050 and had a Crown (forgot the model number). My solution is to leave the MiniDSP on all the time.
Then I think you can safely say that the mini-DSP is the problem and not the amps.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #572 of 702 Old 04-11-2014, 01:11 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
You are 99.999% correct.
duc135 is online now
post #573 of 702 Old 04-11-2014, 01:16 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Just ordered a lab gruppen product with full EQ finally so this should alleviate all these issues and only use 2u rack space for 4 channels of superclean amplification...
Cant wait to get to work on this project
Blazar!
blazar is offline
post #574 of 702 Old 04-11-2014, 01:27 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
http://www.ebay.com/itm/Lab-Gruppen-PLM20000Q-SP-PLM-20000Q-Powered-Management-System-XCaseProAudio-/221330926678?pt=US_Pro_Audio_Amplifiers&hash=item338859ec56
Joe = LFE Addict
jpmst3 is offline
post #575 of 702 Old 04-11-2014, 02:10 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
Originally Posted by BrutalBodyShots View Post
That's the first time I've read of someone referencing a "thump" at shutdown from one of these units. Is it a common problem that just doesn't get talked about or have only a handful of owners experienced it?
They don't all do it. I use an NU3000DSP plugged into a triggered outlet on an APC AV H15; the outlet is triggered by the Emotiva UMC-200 when it powers on and off, and there is never any thump from the sub.
moosifee is offline
post #576 of 702 Old 04-11-2014, 02:20 PM
raynist's Avatar
Quoted: 1256 Post(s)
Liked: 1194
I am about to hook up 2 inuke 3000dsp's this weekend to my LCR JTR 228's. I hope to use these to boost the mid bass a bit.
I read in this thread I think that the DSP versions do a analog-digital-analog conversion and could cause phase issues with subs. Could this cause any issue with mains? The plan is to hook these up and then run Audyssey, after I will tweak the DSP for a mid bass bump. What setting should I start the 3000DSP's gain at?
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #577 of 702 Old 04-11-2014, 02:45 PM
dwaleke's Avatar
Quoted: 1114 Post(s)
Liked: 515
As long as you run your auto room EQ setup after hooking up the amplifier you will be good to go.
dwaleke is offline
post #578 of 702 Old 04-11-2014, 03:33 PM
laugsbach's Avatar
Quoted: 130 Post(s)
Liked: 199
laugsbach is online now
post #579 of 702 Old 04-11-2014, 05:06 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Originally Posted by laugsbach View Post
I did and cannot understand why they won't take $1500!??! I tried!tongue.gif
dwaleke likes this.
Joe = LFE Addict
jpmst3 is offline
post #580 of 702 Old 04-12-2014, 08:09 AM
jherring69's Avatar
Can anybody recommend a good place to buy from in Canada. I,m looking to pick up a 1000DSP $235.00 or a 3000DSP $335.00. A few options are LA Music, FleetSound, AV Shop.ca, PA Shop. All of the prices are similar, so I'm wondering about customer service, etc.
Thanks in advance for any input.
Jason
jherring69 is offline
post #581 of 702 Old 04-12-2014, 09:05 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Just wanted to throw out there that I have a buddy, (non-forum member) that is also looking to purchase an iNuke1000dsp and/or possibly an iNuke3000dsp.
If anyone of you guys might happen do have one of the 1000dsp units or 3000dsp units that you might willing to part with, please hit me up and I will give you his contact info!
Martycool007 is offline
post #582 of 702 Old 04-13-2014, 12:39 PM
raynist's Avatar
Liked: 1194
I finally hooked up my 2 iNuke 3000 DSP's. I am running an RCA to xlr cable from my 4311 to the 3000's. I just wanted to see if they work.
What should the inukes gain be set at? If I set it any more than 55-60% I get a hum coming through the speakers. Have tried both inukes and they are the same for both outputs. I also tried a cheater plug and plugging them into their own 20A outlet and still the same.
Ray.
post #583 of 702 Old 04-13-2014, 12:52 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
I have mine full or 3 clicks back from full.
chalugadp is offline
post #584 of 702 Old 04-13-2014, 01:20 PM
raynist's Avatar
Liked: 1194
About 4 clicks back the buzz is not noticeable. If I unplug the input it goes away so it mus be coming from my receiver.
I guess I can back off the gain and Audyssey will compensate right?
post #585 of 702 Old 04-13-2014, 04:41 PM
raynist's Avatar
Liked: 1194
Actually had to set it back 9 clicks to remove the hiss. Audyssey set the speakers for LCR around -2db but have a phase issue between L/R.
Now I need to change the fans!!
Would love if I could dim the lights on the front, very distracting. Put a piece of black felt over it for now.
post #586 of 702 Old 04-13-2014, 05:04 PM
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
The display itself has a dimmer in the menu functions and I did this for the orange ring around the level knobs. They are from Lowes. $1.89
jpmst3, Bob7145 and laugsbach like this.
cessna1466u is offline
post #587 of 702 Old 04-13-2014, 06:25 PM
raynist's Avatar
Liked: 1194
Thanks, great idea with the o-rings!! I see a contrast setting but not a dimmer.
I replaced the fans with ones I ordered online but they are still too loud. What is the quietest fan people have found that still has good cooling?
Also, when I replaced the fans, only one of the 3000DSP's had the shroud/air deflector on it. Neither appears to have been opened. Anyone else not have a shroud?
post #588 of 702 Old 04-13-2014, 06:46 PM
Quoted: 116 Post(s)
Liked: 201
Thanks, this is the fan I used for the 3000dsp. I assume that is the one you have? Mine had a shroud but my 6000dsp does not. I had great success with this fan and never had any issues at all. I will check on the dimmer/contrast and let you know.
http://www.sidewindercomputers.com/no80nf34cfm.html
post #589 of 702 Old 04-13-2014, 06:50 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 42
Arctic cooling f8 . just bought 2 for 4.50 CAD. Has a good cfm to DBA rating.
Noctua's are the best computer fans you can get IMO, but also way more expensive.
Thatsnasty is offline
post #590 of 702 Old 04-13-2014, 06:51 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Joe = LFE Addict
jpmst3 is offline
post #591 of 702 Old 04-13-2014, 08:48 PM
Quoted: 116 Post(s)
Liked: 201
Thanks Joe, and yes your right it's just contrast not dimmer. Thought I saw dimmer when I was going through the settings, sorry.
post #592 of 702 Old 04-14-2014, 05:50 AM
Quoted: 280 Post(s)
Liked: 176
Ray.
What you need to do is setup everything to what makes the hum most noticeable, then go by each component in your setup unplugging their cables from your AVR-4311 one at a time, and then if you unplug a component and the hum persist, plug it back in as it would not be the source of the hum. You have to go through this with each component as one of them are causing a hum. When you figure out where the hum is coming from, deal with that component individually. For most people the source of the hum is the cable box. Unplug the cable from the wall and the cable connecting it to your signal chain. Hope this helps!
post #593 of 702 Old 04-14-2014, 06:35 AM
raynist's Avatar
Liked: 1194
Thanks! I will try this!
post #594 of 702 Old 04-14-2014, 09:40 PM
joebuddyguy's Avatar
Quoted: 50 Post(s)
Liked: 92
Ray.
I had a similar issue Ray....I found my XLR to RCA cable to be mostly to blame. My cable was from monoprice and has the shield/ground wired to pin 1 of the XLR cable....I took the cable apart and snipped the ground connection to pin 1 and I no longer have a hum. Followed the advice in this thread: http://www.avsforum.com/t/1525117/can-onkyos-run-pro-amps-without-voltage-step-up/30#post_24600157
joebuddyguy is online now
post #595 of 702 Old 04-15-2014, 02:35 PM
Bob7145's Avatar
Liked: 36
I use that same Monoprice cable from AVR to the INuke3000dsp and I can crank the gains to max and not hear any noise at all when driving my mains. The cable isn't the problem...
Bob7145 is offline
post #596 of 702 Old 04-15-2014, 03:27 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Correct.
The cable was only transmitting the hum which was caused by another component.
Joe = LFE Addict
jpmst3 is offline
post #597 of 702 Old 04-20-2014, 06:22 PM
Peteybob35's Avatar
Quoted: 12 Post(s)
Anyone have experience with restocked items from Parts Express?
Peteybob35 is offline
post #598 of 702 Old 04-29-2014, 03:45 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Should be fine, i am sure they will honor warranties and whatnot
Blazar!
blazar is offline
post #599 of 702 Old 05-02-2014, 07:19 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
Is there a way to dim the lights on the dials and limiter lights on these inukes?
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #600 of 702 Old 05-02-2014, 08:21 PM
Quoted: 116 Post(s)
Liked: 201
No dimmer just contrast. Look back about 6 posts or so, some genius came up with the idea of using o-rings to hide the bright lights around the gain knobs.biggrin.gif
