Inuke's on sale! - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
Old 05-03-2014, 12:53 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Originally Posted by cessna1466u View Post
The display itself has a dimmer in the menu functions and I did this for the orange ring around the level knobs. They are from Lowes. $1.89
Another thanks on making this amp
disappear when the lights go dark.
Via Mikes brain/thumb interface, LLAP
mtbdudex is offline
Old 05-03-2014, 05:27 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 141
I had a hum/buzz coming from my subs and I have a inuke 6000dsp and I finally tracked it down to my Directv receiver. I checked the dish to make sure it was grounded and it was. I bought this ground loop isolator for $8.99 + shipping and buzz/hum is gone in all subs. Hope this helps someone.
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is offline
Old 05-03-2014, 05:38 PM
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
Mike
I see it looks like a inline coax, where did you put it in the directv install. I have coax going from the dish to an amplifier to another thing with an ethernet cable to it and then to the box.
cessna1466u is offline
Old 05-04-2014, 11:45 AM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
My inuke3000dsp emitted some serious static during normal use twice today for about 10 secs, then all limiter lights lit up and the amp stopped responding until I turned it off and back on again. Cant find anything on google about this. Below is a video with the static.
https://www.youtube.com/watch?v=ezpVEqNiF20
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
Old 05-04-2014, 12:00 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Can someone help me with wiring my sub for the 3000? I have 2 SI 18 dual 4 ohm speakers and have no idea how to wire the subs to the speakon connectors.
Claybe is offline
Old 05-04-2014, 12:10 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
I used a two-conductor speaker wire, positive into +1 and negative into -1, then the coils are wired in parallel for a nominal 2 ohm load. Repeat for the other channel.
cessna1466u likes this.
moosifee is offline
Old 05-04-2014, 12:12 PM
Quoted: 116 Post(s)
Liked: 201
I am assuming you are going to run each sub at a 2ohm load and then just wire one to each channel in the amp? This is the wiring for the subwoofer itself. I have the standard 2 pole speakon cnnectors, is that what you have or the 4 pole?
Old 05-04-2014, 12:22 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
I have the 4 pole speakon connectors. So would it be positive to 1+ and negative to 1- ???
Claybe is offline
Old 05-04-2014, 12:25 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
I thought that's what I said.
moosifee is offline
Old 05-04-2014, 12:29 PM
Quoted: 116 Post(s)
Liked: 201
Yes as long as you are not bridging your amplifier or anything fancy like that then yes you wire it like that.
Old 05-04-2014, 12:30 PM
Quoted: 116 Post(s)
Liked: 201
Also make sure you do the same on the speakon connector you are going to use to plug into that female on the box.
moosifee likes this.
Old 05-04-2014, 12:52 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Thanks. Now if I am not using a computer, what are the recommended settings?
Claybe is offline
Old 05-04-2014, 01:21 PM
Quoted: 116 Post(s)
Liked: 201
The EQ settings are room specific so no one can really tell you what to set that too but the crossover I set the high pass to 20hz, Butterworth, 12DB slope. The low pass I leave off since my receiver takes care of that.
The Config, I set to Stereo so that I only have to deal with one set of settings (EQ, Crossover, Etc) If you are going to have to set different setting for each sub then you would use Dual Mono. No limiter needed for this Amp and sub combo.
Old 05-04-2014, 01:54 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Got everything wired up and nothing works. No sound to the sub at all. Any suggestions where to start? I did hook up the computer to it so I can adjust as necessary.
Claybe is offline
Old 05-04-2014, 02:29 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 141
I put it after the SWM box coax, which is right before the coax going into my Sat receiver.
Mike
mbw23air is offline
Old 05-04-2014, 03:12 PM
Quoted: 116 Post(s)
Liked: 201
Don't know if you got it figured out yet but here is an example of how to wire speakons. I think we had it wrong with the 1+ and 1-. I remember someone else having this issue. Hope it helps.
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 95
Old 05-04-2014, 05:15 PM
Quoted: 116 Post(s)
Liked: 201
Mike
Thanks Mike, just ordered one. Will be glad to remove the cheater plug. biggrin.gif
Old 05-04-2014, 05:29 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Mike
Let me know if it works. I should get rid of my cheater plug soon.
chalugadp is offline
Old 05-04-2014, 05:31 PM
Quoted: 116 Post(s)
Liked: 201
Old 05-04-2014, 05:52 PM
chalugadp's Avatar
Liked: 1505
Will do do you have to direcTV or satellite also? Wondering if that's been the problem for everyone?
I have Motorola cable box. My hum noise comes from my parasound amp. Inukes didn't create any.
Old 05-04-2014, 06:22 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
I had a ground loop a year ago, turns out it was the HDMI cable from the cable box, I connected the coax cable to my power conditioner and that re-grounded it and made the hum go away.
BassThatHz is offline
Old 05-04-2014, 06:57 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
Ditched my receiver and got a prepro. All my ground loop buzz problems ended immediately. God bless xlr outputs.
Swolephile is offline
Old 05-04-2014, 07:58 PM
raynist's Avatar
Quoted: 1257 Post(s)
Liked: 1196
Same here!!
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
Old 05-04-2014, 10:19 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
I got out my flashlight and glasses, and then I pulled mine apart and had a look, and it's definitely 1+ and 1-. This is on a four-pole connector at the amp end.
moosifee is offline
Old 05-05-2014, 12:10 AM
Quoted: 116 Post(s)
Liked: 201
Ok so it might be a receiver issue then. I can't help but feel like we have had this issue before with someone else. Hopefully that person can chime in. You need to make sure you have your subwoofer output on the receiver turned on and at least on 0 to test. What kind of AVR are you using?
Old 05-12-2014, 02:47 PM
Quoted: 116 Post(s)
Liked: 201
Mike
IT WORKS!!! Thank you. I received this isolator over the weekend and finally got around to installing it. The hum is gone, no need for a cheater plug and I don't see any change in the picture quality. Thank you for the advice on this.
Old 05-17-2014, 10:53 PM
tgeorge34's Avatar
Quoted: 23 Post(s)
Liked: 24
So how does this part work?..or better yet how do I install it? This hum is driving me crazy!
tgeorge34 is offline
Old 05-18-2014, 01:29 AM
raynist's Avatar
Liked: 1196
These didn't work for me. I upgraded to an avr with XLR inputs which are silent.
Old 05-18-2014, 01:50 AM
notnyt's Avatar
Quoted: 2155 Post(s)
Liked: 1983
Don't the level lights still blind you?
I just ended up covering all the lights with masking tape. It's still bright enough through the tape.
notnyt is offline
Old 05-18-2014, 06:32 AM
raynist's Avatar
Liked: 1196
I cover them with black felt, otherwise they are crazy bright.
