Inuke's on sale! - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
Old 05-18-2014, 12:23 PM
cessna1466u's Avatar
Quoted: 111 Post(s)
Liked: 201
Originally Posted by tgeorge34 View Post
So how does this part work?..or better yet how do I install it? This hum is driving me crazy!
It installs inline from the wall to my Directv receiver. Make sure you have an extra piece of coax cable to go from the out of this to the directv receiver. I just removed the coax from the back of the receiver, plugged this in and then to the receiver. It works for me but might not work for others, don't know for sure but it was worth the $15 shipped.
cessna1466u is offline
Old 05-18-2014, 12:41 PM
raynist's Avatar
Quoted: 1062 Post(s)
Liked: 993
Originally Posted by notnyt View Post
Don't the level lights still blind you?
I just ended up covering all the lights with masking tape. It's still bright enough through the tape.
I still see them a bit through the felt, I may put electrical tape over them.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's)
DIY Sound Group (4 Volt 8's in Slanted boxes, 3 Volt 8's in Ported boxes)
SVS (2 SB13+ and one SB12-NSD)
raynist is online now
Old 05-18-2014, 01:27 PM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1496
I guess I'm the only one who doesn't mind the orange
chalugadp is offline
Old 05-18-2014, 01:51 PM
notnyt's Avatar
Quoted: 1593 Post(s)
Liked: 1590
I used blue masking tape, and I still see them, but it darkens it enough it isn't annoying. I still want to be able to see what it's doing, I just don't want to be blinded by it.
notnyt is offline
Old 05-19-2014, 08:53 AM
McStyvie's Avatar
Liked: 78
Can anyone tell me what CFM the stock fans push on the inuke 1000? I am about to do the mod, but want to make sure it is getting enough air.
Also, I assume it voids the warranty to do that? I am giving up a 3 year warranty in Germany if I go that route, so want to make sure I don't jip it of air flow...
Or a black permanent marker?
McStyvie is offline
Old 05-19-2014, 08:59 AM
LastButNotLeast's Avatar
Quoted: 1240 Post(s)
Liked: 888
If you do the mod carefully, you won't damage anything, so un-doing it in the future is possible if you need to.
Just go with any of the fans recommended here (or check their specs and at least meet them) and you should be fine.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 05-20-2014, 07:13 PM
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
Anyone have issues with their inuke shutting down periodically? Didn't have problem a while ago, but it's starting to get hotter here (and by hot, I mean 70deg :P). Wondering if the fan mod is causing low flow resulting in thermal shut-off. I swapped stock for 2x http://www.amazon.com/gp/product/B005ZF64TQ/
may need higher flow without the super loud stock.
Anthony_Gomez is offline
Old 05-20-2014, 08:25 PM
raynist's Avatar
Liked: 993
I use those same fans. Are you sure the fans are still running? The connection comes loose easily.
PSA (4 Triax's)
Old 05-20-2014, 08:48 PM
Quoted: 61 Post(s)
Liked: 184
Actually, I think the problem is something else. The amp felt cool under load, and the fans were blowing. Trying to think of what else will cause the amp to shut down into protection for a second then restart (happened at loud and quiet times).
Old 05-21-2014, 09:35 AM
AlphaPie's Avatar
Quoted: 133 Post(s)
Liked: 367
Mine did that once, then exhibited other odd behavior. Now it's dead going on 2 weeks sent out for RMA. I did not mod mine either.
Marantz SR5008 | Polk RTi12 | Polk CSi 3 | Morel surrounds | 3 DIY 12" subs | Inuke 3000 | Crown xls1000 | Onkyo M-282
Monster HTS-2600 | HTPC/Gaming PC | Xbox One | RoKu 3 | Sony BDP-S1100 | Sharp Aquos 60"
2 Channel | Polk RTi12 | Realistic STA-2100 | Marantz AT-6 | Ipod 5th gen classic
AlphaPie is offline
Old 11-10-2014, 11:59 AM
Archaea's Avatar
Quoted: 2524 Post(s)
Liked: 2166
The inuke DSP 12,000 is on sale at <$800 at amazon. (new price?)
http://www.amazon.com/Behringer-NU12...inuke+dsp+6000
Did the issue on these with the wrong firmware ever get ironed out?
I will not hoard audio gear
Archaea's FS Thread
Archaea is offline
Old 11-11-2014, 05:14 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
@Mfusick pointed that out to me last night. According to a amazon price tracking site its the cheapest price every listed.
http://camelcamelcamel.com/Behringer...uct/B00HRKWS0Q
Do they use a 220 volt plug? Anyone remember?
This is almost the same price as a clone amp, for the reliability factor alone that would make me want to go with a behringer over it. Its still no 14,000 watt rms but this does have 4000rms per channel @ 2 ohms with DSP.
lemonslush is offline
Old 11-11-2014, 06:41 AM
Archaea's Avatar
Liked: 2166
Did you find a site that tested output? The results that Brian, from speakerpower returned were a little disappointing right, unless you do need 2 ohm operation, you're just as well off to buy the dsp 6000 right? Now that it's basically double the 6000 in price it makes more sense though.
Archaea's FS Thread
Archaea is offline
Old 11-11-2014, 08:20 AM
Quoted: 595 Post(s)
Liked: 258
That's how I understand it. Just a 6000 that is 2 ohm stable. Not worth double the price.
I'd much rather have a clone amp.
dwaleke is online now
Old 11-27-2014, 07:26 PM
Archaea's Avatar
Liked: 2166
Anyone know of a better deal on these amps then parts express coupon for up to 10% off right now for Black Friday?
Archaea's FS Thread
Archaea is offline
Old 11-27-2014, 10:25 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 345
These didn't work for me. I upgraded to an avr with XLR inputs which are silent.
The final solution.
Swolephile is offline
Old 11-29-2014, 09:42 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
SamAsh had a $50 off deal and free shipping. My inuke 6k dsp was $350 shipped no sales tax. Its the best deal I have found thus far. The parts express coupon they had was only $25 off.
Samash has returned or open box inuke 6ks dps for $350 shipped now (its less but they charge you shipping) still a decent deal for a great amp.
Sam ash give you a free tshirt parts express give you a hat... I have 3 hats.
Archaea and sickboy013 like this.
Old 11-29-2014, 10:03 AM
Archaea's Avatar
Liked: 2166
@lemonslush ,
What coupon code did you use at SamAsh?
Archaea's FS Thread
Archaea is offline
Old 11-29-2014, 10:13 AM
rhodesj's Avatar
Quoted: 804 Post(s)
Liked: 449
I needed some wire and other odds and ends from PE, so I was able to use the $50 off of $500 coupon.
rhodesj is online now
Old 11-29-2014, 10:15 AM
Archaea's Avatar
Liked: 2166
I chatted with Sam Ash CSR. They would honor the current $50 off $399 or greater coupon available on line, if the iNuke DSP 6000 was in stock. Since it is out of stock - no go. I'd never even heard of Sam Ash before, but I went ahead and registered an account there.
Archaea's FS Thread
Archaea is offline
Old 11-29-2014, 11:40 AM
lemonslush's Avatar
Quoted: 823 Post(s)
Liked: 402
It was a deal of the day and I had to call to get it.
Old 11-29-2014, 03:24 PM
Jawbone311's Avatar
Just got off the phone with sam ash, picked up a 6000 DSP for 350$ shipped.
Call 800-472-6274, then option 3.
The guy on the other end just changed the price of the amp in my shopping cart.
He also said there are 4 more in stock even though it says they are out.
LTD02, sickboy013 and wvu80 like this.
Jawbone311 is offline
Old 11-29-2014, 04:15 PM
Aundudel25's Avatar
I chatted with Sam Ash and got a inuke 6000DSP for 340 shipped. Best deal i found so far. But i live in CA so plus sales tax . Does anyone that lives outside CA want to help?....lol j/k But at least cash back sites help a bit
Edit: 330 shipped with new customer coupon!
sickboy013 likes this.
Aundudel25 is offline
Old 11-29-2014, 06:31 PM
sickboy013's Avatar
Quoted: 33 Post(s)
I just did the online chat with a rep from SamAsh and got $50 off a $299 purchase. I picked up an inuke 3000dsp, some speakon connectors, and an rca to 1/4 adapter for $250.
sickboy013 is offline
Old 12-01-2014, 08:13 PM
juiceblrc's Avatar
Quoted: 20 Post(s)
Sickboy,
I just got the same deal. thanks for the info.
juiceblrc is offline
Old 12-02-2014, 04:22 AM
Plagen's Avatar
I called Sam Ash yesterday and bought one for $340. Thanks everyone for the tips!
Plagen is offline
Old 12-02-2014, 01:05 PM
XLBrad's Avatar
Liked: 1
SamAsh also has 15% off right now so I got the inuke 3000dsp for 237.99 free shipping, no tax. You can get the price by using the chat feature when you order and they will add the discount.
XLBrad is offline
Old 12-03-2014, 03:48 PM
likelinus's Avatar
Quoted: 101 Post(s)
Liked: 46
Glad i Found this thread. I ended up getting a 3000DSP for $227.99 with free shipping and no tax. Which really surprised me cause there is a Sam Ash about 10 miles from me. Not that I'm complaining!
Plan is to add two more SI 18s. I was going to get a 6000, but then I'd have a 3000 left over and have to sell it or find so,etching to do with it. Just easier to have (2) 3000dSP. One running the two up front and the other running the two rear!
likelinus is offline
Old 12-06-2014, 06:57 PM
sickboy013's Avatar
Quoted: 33 Post(s)
Originally Posted by juiceblrc View Post
Sickboy,
Awesome! You're welcome. Mine was delivered today!
Old 12-09-2014, 05:56 AM
dman918's Avatar
Quoted: 309 Post(s)
Liked: 100
Originally Posted by cessna1466u View Post
The display itself has a dimmer in the menu functions and I did this for the orange ring around the level knobs. They are from Lowes. $1.89
Great idea! I went over to Menards and they have them for 59 cents apiece.
dman918 is offline
