Inuke's on sale! - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1 of 702 Old 01-31-2014, 08:50 PM - Thread Starter
ozziedog's Avatar
Liked: 24
If anyone is needing an amp Sweetwater is having a sale right now.
Inuke3000dsp. $279
Inuke6000dsp. $399
Inuke NU4-6000. $349
And so on. All Inuke's on sale.
LTD02 and laugsbach like this.
ozziedog is offline
post #2 of 702 Old 01-31-2014, 08:57 PM
bass addict's Avatar
Quoted: 370 Post(s)
Liked: 446
Inuke3000dsp. $279
Inuke6000dsp. $399
Nice. Thanks for the heads up. I was just about ready to order another EP4000 but this direction will work just fine.
Does anyone remember if the Inukes have a roll off?
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 702 Old 01-31-2014, 09:10 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5927 Post(s)
Liked: 4967
Sssshhhhiiiiiittttt!!
Bombelman likes this.
Scott Simonian is online now
post #4 of 702 Old 01-31-2014, 09:11 PM
chalugadp's Avatar
Quoted: 1673 Post(s)
Liked: 1531
chalugadp is offline
post #5 of 702 Old 01-31-2014, 09:42 PM
Bass Enabler
Liked: 4967
Sheesh! It figures! The only one I am interested in is not in stock. rolleyes.gif
post #6 of 702 Old 01-31-2014, 09:47 PM
MrMky's Avatar
Can these be used with an AVR, or do you need to use a pre amp?
MrMky is offline
post #7 of 702 Old 01-31-2014, 10:04 PM
chalugadp's Avatar
Liked: 1531
If your avr has preouts then yes
post #8 of 702 Old 01-31-2014, 10:10 PM
Quoted: 370 Post(s)
Liked: 446
I'm assuming you're using this as a sub amp? If so than any ol receiver with a sub out will work just fine.
post #9 of 702 Old 02-01-2014, 05:10 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Does anyone know if the iNuke1000dsp is on sale, and if so, how much does it cost? I am trying to find a good deal on an iNuke1000dso and would definitely be open to buying used in case anyone has one to get rid of!
Martycool007 is offline
post #10 of 702 Old 02-01-2014, 06:56 AM
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Amazon has the 3000dsp and 6000dsp for the same prices. Nu4-6000 is apparently not on sale.
cmryan821 is offline
post #11 of 702 Old 02-01-2014, 07:59 AM - Thread Starter
ozziedog's Avatar
Liked: 24
Marty,
They have the 1000 dsp for $199
ozziedog is offline
post #12 of 702 Old 02-01-2014, 09:06 AM
laeriq's Avatar
Quoted: 72 Post(s)
Liked: 91
So I have 4 SI D2's that will be going into two boxes two drivers each. Between the 6400 and the 6000, which is the better option for my setup? I've used the DSP in the inuke before and like it but I also have a mic2200 and anti mode along with xt32 in the receiver so I feel covered in the eq region. So I guess it comes down to this-
6000 doing 8 ohm stereo at ~1100W per channel so ~550W per driver if they are wired together for an 8 ohm load.
6400 4X 620W RMS 820W Peak at 4ohm to each individual driver.
I'm assuming that the 6000 won't do 2 ohm stereo so this seems to be the best guess for my case. All opinions and corrections appreciated!
laeriq is offline
post #13 of 702 Old 02-01-2014, 09:39 AM
BassThatHz's Avatar
Quoted: 2313 Post(s)
Liked: 2062
BassThatHz is offline
post #14 of 702 Old 02-01-2014, 10:09 AM
Quoted: 370 Post(s)
Liked: 446
I was ready to order the Inuke and I noticed the EP4000 on Amazon has dropped back down a bit. It's been 375 for quite some time now and it's been lowered to 330.00.
post #15 of 702 Old 02-01-2014, 11:20 AM
rr14's Avatar
Quoted: 46 Post(s)
How do you guys like the dsp on these? Is it possible to set a subsonic filter?
rr14 is offline
post #16 of 702 Old 02-01-2014, 11:38 AM
corradizo's Avatar
Quoted: 1137 Post(s)
Liked: 843
corradizo is online now
post #17 of 702 Old 02-01-2014, 11:54 AM
andy497's Avatar
Quoted: 16 Post(s)
Awesome! Can't believe I'm getting an Nu4-6000 for just tree-fiddy.
^Above: Yes, nu6000dsp is perfect for 4 SI 18s. I have D4s so wired series to yield four 8-ohm loads, then paralleled two per speakon so the amp sees two 4-ohm loads. Thats ~1000 real RMS watts per driver give or take, and seems to be about a perfect match.
^Above: I find the built in dsp to be awesome. I have a plain dsp1124p as well, but a nice usb interface with software on computer is cool, as is the ability to do more fancy stuff than just eq, like for example simulate a Linkwitz Transform via shelf filter + PEQ. What exactly do you mean by "subsonic" filter? High pass and/or low pass? Yes for sure, 12 db/octave and 24 db/octave, with the caveat that 20hz is as low as you can go. (You can however push that lower with filter combinations: search the post by LTD to find out how).
andy497 is offline
post #18 of 702 Old 02-01-2014, 12:04 PM
rr14's Avatar
Quoted: 46 Post(s)
yes, I currently have a crown, but the crossover on that one only goes down to 50hz. For my infinite baffle speakers the roll off of the amp is fine. But I did want to know for a ported 13.av.2 ED speaker I built.
I'm thinking about pulling the trigger on the 6000dsp. That's a pretty awesome deal. I'm guessing about 2000 watts rms times 2 for the 6000 @ 4 ohms?
rr14 is offline
post #19 of 702 Old 02-01-2014, 12:54 PM
gworrel's Avatar
Quoted: 367 Post(s)
Liked: 315
I just bought an NU1000dsp on eBay for $190 shipped just yesterday. Uniquesquared has them listed for $224.99. I made a best offer of $165.00. They counteroffered with $199.00. I countered with $190 and they accepted. They might have taken even less. Ebay also had a 10% coupon for my account (not sure if everyone gets one), so my net cost was $171.00. I also had eBay bucks based on prior purchases so it was even cheaper.
gworrel is offline
post #20 of 702 Old 02-01-2014, 12:55 PM
mbw23air's Avatar
Quoted: 166 Post(s)
Liked: 155
I think I read that it measured around 2100 watts x 2 @ 4 ohms. Ordered this amp last night.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is online now
post #21 of 702 Old 02-01-2014, 01:03 PM
filtor1's Avatar
Quoted: 189 Post(s)
Liked: 150
Does anyone know if PE will price match these?
filtor1 is offline
post #22 of 702 Old 02-01-2014, 01:14 PM
gworrel's Avatar
Quoted: 367 Post(s)
Liked: 315
Is anyone aware of any issues using the Inuke series into 2 ohm loads? Or using bridged into 4 ohms? I am doing a dipole array of 8 RS225-8 per side that will give me 4 ohms net. I was thinking one Inuke NU1000 bridged per side for 1000 watts each array. I was also going to use an NU1000dsp to power a single Dayton Ultimax 18 (when they get here) in a Velodyne ULD-18 enclosure of 6 cubic feet. That would be 2 x 500 into the 2 ohm voicecoils.
I have looked but cannot find any actual third party measurements of the NU1000. Has anyone seen any somewhere? Thanks.
gworrel is offline
post #23 of 702 Old 02-01-2014, 01:16 PM
HopefulFred's Avatar
Quoted: 521 Post(s)
Liked: 477
Looks like amazon has matched sweetwater.
http://camelcamelcamel.com/Behringer-EP4000-Professional-Accelerated-Technology/product/B001U5JFNM?context=browse
HopefulFred is online now
post #24 of 702 Old 02-01-2014, 02:02 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Inuke3000dsp. $279
Inuke6000dsp. $399
OK. I am at a lost where do you get these sale prices?
Questions.
I currently have an EP2500 powering 4 sealed subs, which iNuke would be the ideal replacement?
I see that the iNukes are using speak-on connection? Do I need to get some sort of conversion cables?
smokarz is offline
post #25 of 702 Old 02-01-2014, 02:13 PM
rr14's Avatar
Quoted: 46 Post(s)
just joined the party! I ordered an inuke 6000 dsp. I'm moving from a crown xls 1500 which is currently powering my 2 Elemental designs 18" infinite baffle subs. I'm going to power those off one channel and I may have to buy 2 more 18's to join them on the other channel!
rr14 is offline
post #26 of 702 Old 02-01-2014, 02:15 PM
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Just get some speakon connectors. A little bit of a pain if you're using 12awg or 10awg wire, but still really simple.
post #27 of 702 Old 02-01-2014, 02:32 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Straight from their website.
ozziedog is offline
post #28 of 702 Old 02-01-2014, 04:26 PM
Quoted: 280 Post(s)
Liked: 181
The iNuke1000 is likely a little small for the UM18. I would go with the iNuke3000dsp for the price that they are going for ATM, can't be beat! Also, have you modeled the UM18 in the UDL-18 enclosure to make sure it's a suitable habitat for the UM18? That might be a problem that could easily be fixed with a 4cufy flat pack from DIYSG!
post #29 of 702 Old 02-01-2014, 04:51 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
+1
Once you make the switch to the Speakon connectors you will never go back. So sweet!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is online now
post #30 of 702 Old 02-01-2014, 04:58 PM
gworrel's Avatar
Quoted: 367 Post(s)
Liked: 315
I think you are right about the NU1000. I am considering the NU-4-6000 which seems to be two NU3000s in one chassis. But no DSP version, which would come in handy for the standalone sub.
The Velo ULD-18 enclosure is about 6.3 cubic feet. It is 1" mdf all around. In WinIsd I get about 2 dB more output at 10Hz in 6.3 cubic feet than in a 4 cubic foot box. So it should work great.
Interestingly, the original Velodyne woofer, no slouch in its day, had a volume displacement of 2.1 liters. The UM18-22 has a vd of 6 liters. At first I didn't see how that was possible given similar cone areas. But the Velodyne literature says 3/4" of linear cone travel. Parts Express says over 2" of total cone travel. "Over 2"" is about 3 times .75", so triple the volume displacement. The Velodyne woofer must have had an xmax of about 7-9mm.
gworrel is offline
