Suggestion on dampening 15" Dayton Ultimax 3 sq ft - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 02-01-2014, 09:22 PM - Thread Starter
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 61
I bought the 3 ft kit and and I"m about to start building it. What do you suggest for dampening if anything?
Line 4 sides with foam?
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #2 of 19 Old 02-01-2014, 11:54 PM
steve nn's Avatar
Liked: 433
.5 to a pound per cu ft is what most guys go with including more and none. Here is a good link to Data that refers to it. Be sure to read the summery at the bottom though. Insulation works but some don’t like that option. A pillow or two works depending on size of course to name a few.
http://www.data-bass.com/data?page=content&id=79
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #3 of 19 Old 02-02-2014, 12:10 AM
LastButNotLeast's Avatar
Quoted: 1472 Post(s)
Liked: 1066
LastButNotLeast is offline
post #4 of 19 Old 02-02-2014, 12:23 AM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1037
If using the cheap wal-mart pillows, they are almost exactly .5 cf of fill. I put 1 pillow per CF of box space and it's perfect. The pillows are $4.99 each (in Canada anyways)
N8DOGG is online now
post #5 of 19 Old 02-02-2014, 08:56 AM - Thread Starter
Quoted: 167 Post(s)
Liked: 61
I was told by a speaker designer that with a plate amp, I should avoid the polyfil type of material. Do you use the fil with an plate amp on yours?
If I do go with fil, I'll definitely go with the Walmart pillow idea.
Theater Build
post #6 of 19 Old 02-02-2014, 09:29 AM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1037
I don't use polly with plate amps no. You don't take the fill out of the pillows (though I'm sure you knew that but just saying), just stuff the whole thing in there.
I only have one amp that uses a plate amp, the rest are passive and the passives are half and half, pillows and fill (because I got a giant bag for super cheap and used it on 4 of them)
post #7 of 19 Old 02-02-2014, 09:43 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Polyfill does nothing for damping the enclosure, it only lowers the Fb. You should adhere rigid fiberglass or Acoust-X to the cabinet walls. http://store.acrytech.com/Speaker-Cabinet-Coating-Acoust-X-Sound-Damping-Coating.html
http://www.bobgolds.com/AbsorptionCoefficients.htm
Face2 is online now
post #8 of 19 Old 02-02-2014, 10:04 AM
Bill Fitzmaurice's Avatar
Liked: 4628
Type 700 fiberglass damps, but so does polyfill, or any one of a dozen alternatives. Type 700 is a good material in terms of damping per inch thickness, but other materials work equally well if you use enough of it. Fb can be lowered with any damping material, if you use enough of it. If you significantly lower a vented box Fb you used too much.
FWIW I prefer to line a cab, rather than just tossing in a pillow, which will leave a lot of panel area exposed, and the purpose of damping is to cover the panels, rendering them non-reflective. With a sub you need that property to extend to 300Hz or so, which will take a couple of inches of damping to realize. One especially good material for subs is felt carpet padding, due to its high density it takes less of it to work well in the lower mids/midbass.
Acoust-X is too thin to do much of anything below 10kHz or so.
Bill Fitzmaurice is online now
post #9 of 19 Old 02-02-2014, 10:19 AM - Thread Starter
Quoted: 167 Post(s)
Liked: 61
For a sub?
Theater Build
post #10 of 19 Old 02-02-2014, 10:40 AM
Liked: 4628
For a sub?
Subwoofer drivers create above bandwidth harmonics that must be damped. And crossovers aren't exactly brick wall either, so the program material is another source of above bandwidth content. Standing waves are another issue. Modern sub cabs tend to be too small for them to arise within the subwoofer passband, but they will arise in the mids, so they need damping as well.
post #11 of 19 Old 02-03-2014, 10:55 AM - Thread Starter
Quoted: 167 Post(s)
Liked: 61
What thickness / brand is suggest? I'm looking at Parts-Express but it looks like they are a fair bit.
Would 1" Paper faced OC703 work well? Glue the paper side to the inside of the box?
Theater Build
post #12 of 19 Old 02-03-2014, 11:32 AM
Liked: 4628
I like to use two inches of foam in subs. Mattress topper open cell foam is cheap and readily available locally.
post #13 of 19 Old 02-03-2014, 12:54 PM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
rajacat is offline
post #14 of 19 Old 02-03-2014, 01:04 PM
Liked: 4628
Originally Posted by rajacat View Post
+1
Spectrum Sludge looks good too.
http://store.secondskinaudio.com/spectrum-sludge-1-gallon/
In a car door maybe, but not a subwoofer.
post #15 of 19 Old 02-03-2014, 01:33 PM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
Why not ?
rajacat is offline
post #16 of 19 Old 02-03-2014, 02:47 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I had this leftover 2" thick recycled cotton based material, and used it to line my recent subwoofer 4 cu ft ported box for resonance control.
top lined also
mtbdudex is offline
post #17 of 19 Old 02-03-2014, 04:15 PM
SeekingNirvana's Avatar
Quoted: 233 Post(s)
Liked: 123
Does using the foam change the internal volume? And just lining it with this is better then pillows?
My dual sealed LMS 5400 Ultra build
http://www.avsforum.com/forum/155-di...0-build-4.html
SeekingNirvana is offline
post #18 of 19 Old 02-03-2014, 06:48 PM - Thread Starter
Quoted: 167 Post(s)
Liked: 61
I'm still not hearing a consistent answer.
Sealed and ported subs are treated the same with regard to lining?
Theater Build
post #19 of 19 Old 02-03-2014, 08:19 PM
Liked: 4628
They are not, read this, which was already linked near the top of the thread:
