SEOS waveguide - deadening? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-02-2014, 01:02 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
I have read that covering the backside of horns with rope caulk helps reduce unwanted vibrations. Is this recommended for the SEOS kits? Is there a product out there that is more clean/self contained? I don't like the idea of having rope caulk crumble/droop/whatever off inside the speaker.
Rebel975 is online now
post #2 of 14 Old 02-02-2014, 01:10 PM
Bill Fitzmaurice's Avatar
Liked: 4628
Most of the recommendations for the need to damp the rear of horns are unfounded. Their shape and construction makes them naturally very resistant to vibration.
Scott Simonian and Rebel975 like this.
Bill Fitzmaurice is online now
post #3 of 14 Old 02-02-2014, 09:17 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
I measured before and after applying deadening material to the back of a SEOS-12 WG and saw no difference in FR or distortion. They're thick enough that additional deadening isn't required.
Face2 is offline
post #4 of 14 Old 02-02-2014, 09:32 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Exactly what I needed to hear. I am prepping for 3 Alpha-12 kits, and wanted to know if I should throw anything extra in to my Amazon cart. I'm relieved to hear that I don't need to.
post #5 of 14 Old 02-03-2014, 11:55 AM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
post #6 of 14 Old 02-03-2014, 12:00 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5282 Post(s)
Liked: 4166
Nice!
Rebel975 likes this.
Scott Simonian is online now
post #7 of 14 Old 02-03-2014, 01:07 PM
Liked: 4628
Couple more questions:
Is this good for lining the walls of the speakers? Is one layer enough? (It's 2" thick, apparently)
http://www.homedepot.com/p/UltraTouch-16-in-x-48-in-Denim-Insulation-Multi-Purpose-Roll-60301-16482/202709974
I've never tried it but it should work OK.
post #8 of 14 Old 02-03-2014, 01:40 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
post #9 of 14 Old 02-03-2014, 01:52 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
FYI I used about three layers of duct tape on my 12" SEOS waveguides for no scientific reason whatsoever, except that what I tapped on it with a drum stick, the duct tape deadened the sound, and I determined that was a good thing. smile.gif
To the point of the thread, Mr. Rebel; did you replace the wiring?
wvu80 is offline
post #10 of 14 Old 02-03-2014, 02:04 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
This works well, from what I've read, almost or better than fiberglass of equal thickness. I've purchased a few cases already.
Face2 is offline
post #11 of 14 Old 02-03-2014, 02:50 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
post #12 of 14 Old 02-03-2014, 03:13 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
I'm not sure, but I think two threads were run into one on my browser! I could swear I was replying to a thread on wiring subs with a long run of wire! Sorry about that.
At least I got PART of the thread responded to properly with my duct tape answer. rolleyes.gif
wvu80 is offline
post #13 of 14 Old 02-03-2014, 03:19 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
I know what thread you are talking about. "Wire size for passive subs.... did I mess this up?"
But if it makes you feel any better, I ordered this in preparation for this build: https://www.parts-express.com/wired-home-skrl-10-100-10-awg-ofc-speaker-wire-100-ft--100-029 biggrin.gif
post #14 of 14 Old 02-03-2014, 03:23 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
wvu80 is offline
