Considering building a sub... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-02-2014, 06:06 PM - Thread Starter
MIDOC's Avatar
Hi everyone,
I had decided on an SVS SB-2000, but I want to make sure I'd not be better off building my own and save some $.  Can anyone recommend a kit that might fall into the spec range of the SB-2000 (or slightly better)?  I'm looking for mostly music, no real interest in super hard-hitting HT stuff, although I'd like to be able to know there's a sub in the room when I watch an action flick.
Thanks, in advance for the help!
System:
Marantz NR1504 (AVR)
Sib XL (F,C,R)
Sib (rears)
Budget: around $500-$600
MIDOC is offline
post #2 of 6 Old 02-02-2014, 09:53 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
http://www.parts-express.com/dayton-audio-15-ultimax-subwoofer-and-cabinet-package--300-7097
Find a iNUKE 1000 with DSP for around $200 on ebay. If you want a plate amp instead, http://www.parts-express.com/dayton-audio-spa1000-1000w-subwoofer-plate-amplifier--300-809
Add some glue, paint, acessories, and it should come to around $550-$600.
Mrkazador is offline
post #3 of 6 Old 02-02-2014, 10:08 PM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1566
BassThatHz is offline
post #4 of 6 Old 02-02-2014, 10:34 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
i would suggest something that can play up to at least 150hz or so, as there are no woofers in your speakers.
Listen. It's All Good.
LTD02 is offline
post #5 of 6 Old 02-12-2014, 06:41 PM
rlcoopmsu's Avatar
I figured I would try out SVS's subs and ordered dual pb-1000.
After exploring, I am now contemplating building something simple like what you posted above.
I currently have polk audio CS2 and Monitor 70s II.  Would this be a better alternative?
Dayton Audio 15" Ultimax Subwoofer $262.00
Dayton Audio SPA1000 1000W $271
I'm assuming putting this together is pretty straight forward?
rlcoopmsu is offline
post #6 of 6 Old 02-13-2014, 12:22 AM
steve nn's Avatar
Liked: 433
Off the top of my head I would recommend 2 15” MK 4’s http://www.parts-express.com/dayton-audio-ts400d-4-15-titanic-mk-4-subwoofer-4-ohm--295-405 or 2 SI 15"s and 1 amp http://www.parts-express.com/behringer-nu3000-inuke-3000-watt-power-amplifier--248-6704 or a $100 more if you want the dsp version which I would suggest especially if building sealed. Add wood and miscellaneous that puts you in at $150-$250 under the dual option you’re speaking of with conservatively a few dB ahead. wink.gif You always have the option of going a more budget friendly route also.. and a cheaper source for your amp.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
