8x 18" LMS 5400 Ultras Sealed to 27 Cube 15hz Ported Build - Page 10 - AVS Forum
 5Likes
post #271 of 512 Old 03-10-2014, 11:27 PM
steve nn's Avatar
Liked: 425
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #272 of 512 Old 03-10-2014, 11:28 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
Originally Posted by steve nn View Post
XT32 doing its thing nicely =]
notnyt is offline
post #273 of 512 Old 03-10-2014, 11:33 PM
steve nn's Avatar
Liked: 425
No seriously it looks totally awesome response wise and looks wise. It's a really out there system you have there.
Scott Simonian likes this.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #274 of 512 Old 03-10-2014, 11:33 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 139 Post(s)
Liked: 638
Totally! +1
My Dual 18" LLT subs 120dB down to 10hz
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is offline
post #275 of 512 Old 03-10-2014, 11:34 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
notnyt is offline
post #276 of 512 Old 03-10-2014, 11:38 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
and a big +1 to Herb at CSL. (or csa now?) Calibration for the umik1 is great. Much easier than my emm6. I think I'll sell it with the amp soon.
notnyt is offline
post #277 of 512 Old 03-10-2014, 11:46 PM
LTD02's Avatar
Quoted: 117 Post(s)
Liked: 841
"nu1000dsp powering transducers"
ah!
looks like you might be getting some compression in the 125db sweep...any concern about that? LOLOL.
perhaps surprisingly, the ports don't seem to be compressing even at that ridiculous level. good design there.
Listen. It's All Good.
LTD02 is offline
post #278 of 512 Old 03-10-2014, 11:55 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
ah!
Hard to say for sure, the walls ... move... a lot.... look at the lower frequencies there, you can see its actually gaining output.. also the mid level sweep gained output over the first sweep... Either way, there were no port noises. When I ran sine waves through them one at a time at max levels I was able to hear them them being not so happy, so there's still some room left.
I'm wondering if the mic is compressing there. Keep in mind the calibration at those frequencies is boosted.
notnyt is offline
post #279 of 512 Old 03-11-2014, 12:08 AM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
Aaaaaaand, updated compression graphs so you can see in more detail. Look at the low frequency on the high level sweep....
notnyt is offline
post #280 of 512 Old 03-11-2014, 03:08 AM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
and if flaming skulls are simply too much...yeah, that had to go. :-)
flaming skulls were awesome.
notnyt is offline
post #281 of 512 Old 03-11-2014, 03:16 AM
Decadent_Spectre's Avatar
Awesome.
Graphs only go so far, hearing is believing, wish I could listen...
I probably missed this, what is the final size/length of the port?
Decadent_Spectre is offline
post #282 of 512 Old 03-11-2014, 03:22 AM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
Originally Posted by Decadent_Spectre View Post
Awesome.
effective port length of 55". Tune came in at 14.7hz or so. If you come to NY you can have a listen =]
notnyt is offline
post #283 of 512 Old 03-11-2014, 03:31 AM
What was the height/width of the port?
post #284 of 512 Old 03-11-2014, 07:58 AM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
notnyt is offline
post #285 of 512 Old 03-11-2014, 08:55 AM
Senior Writer @ AVS
imagic's Avatar
Quoted: 672 Post(s)
Liked: 1692
I need to stop by.
Find out more about Mark Henninger at www.imagicdigital.com
imagic is online now
post #286 of 512 Old 03-11-2014, 08:55 AM
MKtheater's Avatar
Quoted: 93 Post(s)
Liked: 403
What frequency were those distortion measurements produced?
MKtheater is offline
post #287 of 512 Old 03-11-2014, 08:58 AM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
Originally Posted by imagic View Post
I need to stop by.
Hah, feel free. I warn you, the urge to upgrade things after will be strong =]
notnyt is offline
post #288 of 512 Old 03-11-2014, 10:57 AM
gpmbc's Avatar
Quoted: 23 Post(s)
Liked: 69
Notnyt, are you running a high pass? Also, are your crowsons being effected by Audyssey or do you have them on a separate feed?
gpmbc is offline
post #289 of 512 Old 03-11-2014, 12:26 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
They're on the transducer output from my avr, so not affected.
I highpass the subs at 13hz 3rd order, who knows what it actually is as minidsp 2x8 is a bit mental down there. I've measured loopbacks and took the one that looked best in that area.
notnyt is offline
post #290 of 512 Old 03-11-2014, 12:37 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
Here's a bunch of different filters from the minidsp at low frequencies to show how erratic it can be. These are from REW, so you will need to load in there.
download measurements
notnyt is offline
post #291 of 512 Old 03-11-2014, 01:55 PM
gpmbc's Avatar
Quoted: 23 Post(s)
Liked: 69
Great build man, can only imagine what that feels like.
gpmbc is offline
post #292 of 512 Old 03-11-2014, 03:32 PM
Is the port length actually 55"? I ask because you use the word effective and because there was some talk of corrections on the port length in the old thread as I recall. I wanted to know the actual physical port length to see how it differs from WinISD numbers.
post #293 of 512 Old 03-11-2014, 04:58 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
If you want to measure center line down the port, its 53.25.
The actual effective length requires the addition of half of the port height since the back wall continues, so its 55".
notnyt is offline
post #294 of 512 Old 03-11-2014, 05:32 PM
So it would seem the WinISD numbers were correct.
post #295 of 512 Old 03-11-2014, 05:38 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
They were close. The tuning actually came in at about 14.7hz, so it was a little long.
notnyt is offline
post #296 of 512 Old 03-11-2014, 07:25 PM
LTD02's Avatar
Quoted: 117 Post(s)
Liked: 841
"flaming skulls were awesome."
didn't know if they were mucking up your thread. since they are 'awesome', i put them back up there. :-)
notnyt likes this.
LTD02 is offline
post #297 of 512 Old 03-11-2014, 07:30 PM
LTD02's Avatar
Quoted: 117 Post(s)
Liked: 841
regarding the cancellation at 80hz. i'm sure you know, 1/4 distance cancellation correlates to about 3.5 feet to boundary. i'm guessing your picking up cancellation of both the side and rear walls?
LTD02 is offline
post #298 of 512 Old 03-11-2014, 07:44 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
It's an tangential mode followed by an oblique mode.... Using a room sim, as well as taking measurements, the dropout shrinks as i move it forward or backwards. However, other areas get worse, which matches my measurements. I'll take a small part of an octave dropout over something much larger. It's not really noticeable as it is. Not much I can really do given the space.
notnyt is offline
post #299 of 512 Old 03-11-2014, 08:10 PM
LTD02's Avatar
Quoted: 117 Post(s)
Liked: 841
"It's an tangential mode followed by an oblique mode...."
that is kind of surprising, given how pronounced it is.
LTD02 is offline
post #300 of 512 Old 03-11-2014, 08:16 PM - Thread Starter
notnyt's Avatar
Quoted: 74 Post(s)
Liked: 333
It's in about the center of a 24x25ish room. Got some weird interactions too from not having a wall on the back rear part. If there was an easy way to treat it or move the lp without making something else I'm all ears.
notnyt is offline
Tc Sounds Lms Ultra 5400
User Tag List
