8x 18" LMS 5400 Ultras Sealed to 27 Cube 15hz Ported Build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 51Likes
post #31 of 585 Old 02-12-2014, 02:33 AM - Thread Starter
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1981
notnyt is offline
post #32 of 585 Old 02-12-2014, 08:38 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Go not!
You are on a roll now!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #33 of 585 Old 02-12-2014, 09:12 AM
Shan87's Avatar
Quoted: 16 Post(s)
Liked: 27
Originally Posted by notnyt View Post
2SrCUwM.jpg?1
#3 all cut and ready for assembly
Random Opitma... usually equals drag car/toy that doesn't get used in the winter sitting some where also.
How does 4 of the ported subs sound compared to the all 8 sealed you were used to?
Shan87 is offline
post #34 of 585 Old 02-12-2014, 09:14 AM - Thread Starter
notnyt's Avatar
Liked: 1981
better, more visceral/tactile, feel it in the chest more.
notnyt is offline
post #35 of 585 Old 02-13-2014, 02:18 PM
BeerParty's Avatar
Quick question...
Since the ported boxes are so much larger and heavier, why not build singles and stack them up instead? I know it would use more wood, but moving and lifting a 400 pound box sounds dangerous. I realize that you will only have to move then a couple of times, and that you have help, but still.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #36 of 585 Old 02-13-2014, 09:11 PM - Thread Starter
notnyt's Avatar
Liked: 1981
Originally Posted by BeerParty View Post
Quick question...
Because you're not going to shave that much weight, what's 50 lbs out of 400? Stacking that high I'd rather have only two for stability as well.
notnyt is offline
post #37 of 585 Old 02-14-2014, 04:15 AM - Thread Starter
notnyt's Avatar
Liked: 1981
notnyt is offline
post #38 of 585 Old 02-14-2014, 05:45 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Not long now!
Joe = LFE Addict
jpmst3 is offline
post #39 of 585 Old 02-16-2014, 06:46 AM - Thread Starter
notnyt's Avatar
Liked: 1981
been busy, slow progress, only got an hour or two tonight.. cut the woofer holes and some bracing
notnyt is offline
post #40 of 585 Old 02-16-2014, 07:55 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
I know how painful that must be...
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #41 of 585 Old 02-16-2014, 11:59 PM - Thread Starter
notnyt's Avatar
Liked: 1981
progress...
bracing
yay warped wood
and assembled
notnyt is offline
post #42 of 585 Old 02-17-2014, 01:09 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Great progress!
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #43 of 585 Old 02-17-2014, 08:11 AM
BlindSet's Avatar
What's your strategy with the bracing? More specifically I see that you have full length members that seem to be resting on 1 inch blocks. Are you just gluing everything at the end points and the blocks are for more surface area?
BlindSet is offline
post #44 of 585 Old 02-17-2014, 10:30 AM
carp's Avatar
Quoted: 2486 Post(s)
Liked: 1741
Not,
I've been thinking about your subjective impressions of the ported box and the fact that it's more punchy in the chest etc. Could it be that the fact that you only have subs on one side of the room have caused a change in the frequency response and this could be responsible for your impressions? Possibly a boost in the 60-80 hz range or something?
I'm asking because I have been getting curious myself about all these marty sub (ported) builds and may decide to make a change myself at some point.
I have owned ported JTR Captivators in the past and when I made the switch to the sealed Seaton Submersives the differences I noticed were that the Seaton's were tighter punchier for music and the JTR's had more low end couch shake with movies - makes sense because they would have had more output around the 20hz tuning. Having subs that do both would be ideal, and you have that! cool.gif
When you get them all built and in the same spots as the sealed setup you'll find out for sure. Did you take measurements of the first box from the main LP to see if maybe it had a peak around 60-80 hz or something?
I have a feeling that a change in the response is NOT responsible for what you are experiencing - I just wanted to make sure since I'm thinking about making a change myself. If you already posted graphs that show the response is similar up top between ported and sealed and I missed it I apologize.
carp is online now
post #45 of 585 Old 02-17-2014, 02:27 PM - Thread Starter
notnyt's Avatar
Liked: 1981
The blocks provide a surface for me to nail the braces to. It also provides more surface area for glue and helps keep the bracing in place when installing. Just gluing the end of the strip to the box isn't very secure, as I found out in the first build.
notnyt is offline
post #46 of 585 Old 02-17-2014, 02:40 PM - Thread Starter
notnyt's Avatar
Liked: 1981
Not,
I tested with the subs side-by-side after eq. Sealed units by their nature will have more of a peak around 50-60hz. Not sure how you were testing or what was done.
notnyt is offline
post #47 of 585 Old 02-17-2014, 02:46 PM
carp's Avatar
Liked: 1741
Similar, I stacked one on top of another. Haha, that's not an option in your case. biggrin.gifcool.gif
I didn't have an omnimic back then so I couldn't compare frequency responses.
Like I said, I don't think diferent freq response what's going on here. I think it's more related to what Dom has been talking about in his thread with ported vs. sealed.
I get the feeling that the increased punchiness/feel/whatever is quite obvious for you and not just from one point in the room - I think you said your wife noticed it too. I'm just kind of thinking aloud here as I think of maybe going back to ported like you have... and want to explore all possibilities for the perceived differences.
carp is online now
post #48 of 585 Old 02-17-2014, 02:50 PM - Thread Starter
notnyt's Avatar
Liked: 1981
I wouldn't go ported without transducers, but with transducers... oh my.. its seriously awesome.
If you want to experiment, it's not too pricey, just some wood. Build one of the design you like setup and EQ for it, and swap back and forth with sealed.
notnyt is offline
post #49 of 585 Old 02-17-2014, 03:02 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Carp, I've shared this with notnyt, but I believe its a product of greater wavelaunch coherence, more ideal acoustic summation ... yielding less smeared higher peak energy packet.
I've yet to read the thread you referenced, sounds interesting.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #50 of 585 Old 02-17-2014, 03:09 PM
carp's Avatar
Liked: 1741
I believe it's on Dom's ULF score thread let me look.
carp is online now
post #51 of 585 Old 02-17-2014, 03:14 PM
carp's Avatar
Liked: 1741
Here is an example.
http://www.avsforum.com/t/1488059/your-home-theater-ulf-score/1530#post_24269289
There is a lot more discussion here and there throughout the last half of the thread, lots of other stuff to wade through but one of the topics is why ported gave so much more tactile feel than sealed and also why nearfield does the same as a sub across the room even though both could be calibrated to the same spl at the seats. Interesting thread for sure.
carp is online now
post #52 of 585 Old 02-17-2014, 04:25 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
With my G-horns and sealed 21's, EQ to be very close to the same, the horns hit you like a freight train and the sealed subs are more like standing a foot away from the train. It's quite different. I have everything running down low and the G-horns cutoff at 50hz.
N8DOGG is offline
post #53 of 585 Old 02-17-2014, 04:35 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
OK, no more ported talk. I've had my sealed setup running less than 8 months and I don't want to rebuild everything yet. cool.gif
azz7686 likes this.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #54 of 585 Old 02-17-2014, 04:41 PM - Thread Starter
notnyt's Avatar
Liked: 1981
Uh oh... sounds like the seed is planted...
notnyt is offline
post #55 of 585 Old 02-17-2014, 04:47 PM
Quoted: 360 Post(s)
Liked: 437
The funny part is; I have my screen down and whole front stage disassembled at the moment waiting on the mad scientist to do a little tweaking on my xovers. Now would be the perfect time to do another box build. Must................resist.......................... biggrin.gif
post #56 of 585 Old 02-17-2014, 04:48 PM - Thread Starter
notnyt's Avatar
Liked: 1981
Build a quick box to a/b test, see which you like. wink.gif
notnyt is offline
post #57 of 585 Old 02-17-2014, 04:49 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
It is just about time to update your avatar. Those sealed boxes are so last week! tongue.gif
Joe = LFE Addict
jpmst3 is offline
post #58 of 585 Old 02-17-2014, 04:51 PM
Quoted: 360 Post(s)
Liked: 437
Quick box, lol. I've never built anything in my theater that's been quick.
post #59 of 585 Old 02-17-2014, 04:53 PM - Thread Starter
notnyt's Avatar
Liked: 1981
Originally Posted by jpmst3 View Post
It is just about time to update your avatar. Those sealed boxes are so last wee! tongue.gif
notnyt is offline
post #60 of 585 Old 02-17-2014, 04:58 PM
Quoted: 360 Post(s)
Liked: 437
Tc Sounds Lms Ultra 5400
