8x 18" LMS 5400 Ultras Sealed to 27 Cube 15hz Ported Build - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #61 of 614 Old 02-17-2014, 03:59 PM
carp's Avatar
Quoted: 2630 Post(s)
Liked: 1897
OCD is not my problem.... lack of tools, experience, and intelligence is. redface.gif
carp is offline
post #62 of 614 Old 02-17-2014, 04:03 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Remember, you can always have the home store rip your wood to widths and lengths you need for free. Then it is just a matter or assembly or at least only a couple rudimentary cuts.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #63 of 614 Old 02-17-2014, 04:14 PM
carp's Avatar
Liked: 1897
Yeah you are right. Still... you should have seen my flat pack assembly, it was bad enough. Maybe it wouldn't have been so bad if there weren't 8 of them..... I still have nightmares about PL glue. biggrin.gif
carp is offline
post #64 of 614 Old 02-17-2014, 04:23 PM - Thread Starter
notnyt's Avatar
Quoted: 2394 Post(s)
Liked: 2196
I've been using regular tite-bond on these builds. I used titebond 2 on the front baffle (gluing the two boards together) since I didn't want it to tack too fast.
Anywhere there will be a large gap or you're not sure on the seal, then I used PL. Trick is keeping plenty of paper towels and gloves handy. Wear clothes you don't care about, too.
The only places in this build to get PL were the front baffle and the top since I had to make sure any gaps were sealed.
Has anyone worked with the new PL fast grab? It has my curiosity, but didn't want to try something new on this build.
Bob7145 likes this.
notnyt is offline
post #65 of 614 Old 02-17-2014, 04:24 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
biggrin.gif PL is evil!
It usually takes it a week to wear off my hands even after doing most of with gloves...
Joe = LFE Addict
jpmst3 is offline
post #66 of 614 Old 02-17-2014, 04:27 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 441
I hear ya, PL is the devil. I have a few extra "work rags" after messing with that stuff.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #67 of 614 Old 02-17-2014, 04:37 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Yep! ...and work clothes!
Joe = LFE Addict
jpmst3 is offline
post #68 of 614 Old 02-17-2014, 04:38 PM
Quoted: 360 Post(s)
Liked: 441
post #69 of 614 Old 02-17-2014, 04:42 PM
N8DOGG's Avatar
Quoted: 1040 Post(s)
Liked: 1120
Yup, although I use it for household stuff, it gets tacky and hard to remove anything in under 1 minute. I'll use it on my next build since I have 4 tubes I got for free.
N8DOGG is online now
post #70 of 614 Old 02-17-2014, 04:44 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I figured! But, I thought it was worth saying literally. OMG! That stuff eventually gets on everything!
Joe = LFE Addict
jpmst3 is offline
post #71 of 614 Old 02-17-2014, 04:44 PM - Thread Starter
notnyt's Avatar
Liked: 2196
Sounds like it might be too quick for some box building. I'll probably pass on it, thanks for the info =]
notnyt is offline
post #72 of 614 Old 02-17-2014, 04:44 PM
BadmanSound's Avatar
cool trick I learned is to wrape a couple strips of duct tape around the tube before opening. this stop it from bowing out/spurting after you release pressure on the gun.
BadmanSound is offline
post #73 of 614 Old 02-17-2014, 04:46 PM
N8DOGG's Avatar
Liked: 1120
OK, no more ported talk. I've had my sealed setup running less than 8 months and I don't want to rebuild everything yet. cool.gif
I'd still not personally trade my sealed subs for ported ones. The hit of the horn is harder than any ported design I've ever seen. I like to have both in the HT personally.
post #74 of 614 Old 02-17-2014, 04:50 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1994
I know I'm pretty excited to try out the large ported cabinets that I'm building, now I just need my damn UXL-18's to show up rolleyes.gif
jbrown15 is offline
post #75 of 614 Old 02-17-2014, 05:04 PM - Thread Starter
notnyt's Avatar
Liked: 2196
Or just spend $5 instead of $3 on a gun and get one that pulls back wink.gif
notnyt is offline
post #76 of 614 Old 02-18-2014, 03:16 AM - Thread Starter
notnyt's Avatar
Liked: 2196
notnyt is offline
post #77 of 614 Old 02-18-2014, 04:57 AM
gpmbc's Avatar
Quoted: 314 Post(s)
Liked: 197
Nice! One more to go.
gpmbc is online now
post #78 of 614 Old 02-19-2014, 01:54 AM - Thread Starter
notnyt's Avatar
Liked: 2196
Almost, just put on coat of paint #2, need to flip it again and put one more on the top, then bring it inside and install the drivers and stuff... but soon... this build will not end frown.gif
notnyt is offline
post #79 of 614 Old 02-19-2014, 04:34 AM
steve nn's Avatar
Liked: 433
Your project definitely tips to the scale to the right considering size and work involved. You're doing it though, and of course it's looking really nice . At least with the ones you're building now you know how good they perform.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #80 of 614 Old 02-19-2014, 05:31 AM
MKtheater's Avatar
Quoted: 1657 Post(s)
Liked: 1172
How is one of these compared to a GH?
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- TBD
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #81 of 614 Old 02-19-2014, 05:37 AM
LTD02's Avatar
Quoted: 2370 Post(s)
Liked: 2621
same ballpark. of course, smidgen more extension with the ~15hz ported cabs vs the ~17hz tuned tapped horn. excursion limited max spl is about the same in both cases. right around 126db +/- in the low 20's. gh is a little more sensitive compared to a dual ported cab, 3-5db depending where you measure. gh requires a little eq to smooth horn resonances. overall, pretty close.
Listen. It's All Good.
LTD02 is offline
post #82 of 614 Old 02-19-2014, 06:55 AM - Thread Starter
notnyt's Avatar
Liked: 2196
http://www.data-bass.com/data?page=system&id=45&mset=42 for the GH, unfortunately I don't have similar measurements frown.gif
unfortunately I cant move 400+lb enclosures around to take gp measurements.
As for the simulations I posted, these subs were at least 3db more sensitive than my sealed. With the Denon subwoofer cal signal, I had to drop the gain on my amps by 3db to get it to match up, but this might be from less EQ needed in the MiniDSP. Once I get all 4 rolling, I'll have more/better info.
notnyt is offline
post #83 of 614 Old 02-19-2014, 07:48 AM
MKtheater's Avatar
Liked: 1172
So these are more expensive with two drivers for similar performance BUT easier to build and less EQ required.
Marantz 7702 Atmos
Speakers- TBD
post #84 of 614 Old 02-19-2014, 08:01 AM - Thread Starter
notnyt's Avatar
Liked: 2196
They dig a bit deeper as well, looking at the gjallerhorn measurements you can see it rolls off around 21-22hz. They can also be run to a higher frequency without horn issues. They'll require more power, but you'll get a bit more max output out of them as well I reckon.
notnyt is offline
post #85 of 614 Old 02-19-2014, 08:11 AM
MKtheater's Avatar
Liked: 1172
Yes extension as well.
Marantz 7702 Atmos
Speakers- TBD
post #86 of 614 Old 02-19-2014, 12:03 PM
dtsdig's Avatar
Quoted: 888 Post(s)
Liked: 987
Uh oh... sounds like the seed is planted...
HAHA, I know! It's around the bend we go again. It's fascinating how the trends come and go in this arena we're in. Less than 6 months ago, tapped horns and folded horns were all of the rage. 6 months before that, major sealed builds were happening. Before that, LLT, etc. (all round-about time frames, of course). Now between Notnyt's progress and the gobs of Marty Subs cropping up, ported is now king for a day. It's awesome. The constant change here is really great. biggrin.gif
For me, I am good with my curvy sealed builds and wouldn't have room for anything large and ported anyway. cool.gif
dtsdig is online now
post #87 of 614 Old 02-19-2014, 01:01 PM
Trepidati0n's Avatar
Quoted: 39 Post(s)
Liked: 107
I must be guilty because people say I am guilty because they chose to call me guilty because they refuse to see the truth. Much easier to be part of the mob..
Trepidati0n is offline
post #88 of 614 Old 02-19-2014, 01:06 PM
Stumbo's Avatar
Quoted: 55 Post(s)
Liked: 88
It's a classic "grass is always greener " situation.
I'm skipping the ported and going from horns to infinite baffle, to stay ahead of the curve.
Oppo 103D
Samsung pn64f8500
Pioneer vsx-82txs
And a bunch of DIY speakers and subs.
Coming soon: Dirac Room Correction
Stumbo is offline
post #89 of 614 Old 02-19-2014, 01:07 PM
dtsdig's Avatar
Quoted: 888 Post(s)
Liked: 987
Originally Posted by Trepidati0n View Post
Lol! Yeah, you can bet that I've spent more than a few minutes pondering the placement possibilities of a couple of Marty Subs.
post #90 of 614 Old 02-19-2014, 01:12 PM
jbrown15's Avatar
Liked: 1994
I think the Martycube would really interest a lot of guys. Forum member chalugado has a good post directly comparing the output of his full sized Marty sub to his martycube. It makes the cube very appealing, oh and with an SI driver with a inuke 3000 amp his marty cube crushed his HSU VTF-15V by almost 10dB @ 20hz from his measurements that he took. Not bad for about $600. smile.gif
jbrown15 is offline
Tc Sounds Lms Ultra 5400
