AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   DIY Speakers and Subs (http://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   8x 18" LMS 5400 Ultras Sealed to 27 Cube 15hz Ported Build (http://www.avsforum.com/forum/155-diy-speakers-subs/1516234-8x-18-lms-5400-ultras-sealed-27-cube-15hz-ported-build.html)
notnyt 02-05-2014 06:45 PM
222 Attachment(s)
http://i.imgur.com/MCAONW1.jpg
This is a continuation of the discussion in this thread. There was some further discussion here as well. My current low end setup, chronicled here, consists of 8x LMS Ultra 5400s in sealed enclosures with 4x FP14000 powering them, pictured below. Kind of absurd to upgrade, but that's what this project is about. I feel the sealed enclosures I built left a lot on the table under 40hz that I can pick up by going with a vented alignment. A full build gallery is available here.
The outer dimensions of the new enclosures measure 48" long, 46" high, and 30" deep. Ports will be oriented on the sides as I will be stacking these. These dimensions were chosen mainly to fit in the current space that I have, stacked two high.
I've got two of these built, and I consider it a great success. It output as modeled, though the tuning ended up around 14.7hz, with an effective port length of about 55". I'm going to pick up some more lumber once the roads here are dry. The output from these down low is just so much greater than the sealed boxes. It would take four of them to equal one of these at 15hz. The bass from the ported boxes also feels like it has more impact. You feel it a great deal more in your chest. To make up for the lack of ULF I decided to get some Crowson transducers for my couch, which also add a great deal of tactile feel. Since this setup is on a slab, the ULF from the subs basically does nothing aside from causing my walls to flex an doors to bounce around. I can listen at lower bass levels now with more feel while having more headroom in reserve. Watching previous demo scenes and listening to various bass heavy music so far have me convinced this was the right move.
Since completing all four of these, I am incredibly happy with the results. EQ'd the same the bass is far more visceral and I have a lot more headroom where I needed it.
Bracing was accomplished with strips of left over ply from the build. Handy since it was almost all cut to size already. The boxes are painted with Duratex. Holes filled with spackle.
Sketchup file: download
Cut list: download
Original setup. The new enclosures will be stacked in the same place as the old.
http://i.imgur.com/z0w2Ezd.jpg?1
Here is the project half-way through. Can't wait to finish. I can't describe how imposing these are, they still look kind of like toys in the picture, but those are 8' ceilings.
http://i.imgur.com/tpvaI7gl.jpg
Modeled at 6200w with 13.5hz 3rd order butterworth highpass. I ended up using a 14hz 4th order filter. Very similar results.
Compared to the sealed subs with 8000w input and 11hz 3rd order filter (I have massive room gain in this area, filter prevents over excursion below 7hz). Both of these signal levels push the subs to almost identical excursion levels.
http://i.imgur.com/uzHHFx0.png
Excursion:
http://i.imgur.com/wTXz0BN.png
Port Velocity:
http://i.imgur.com/bU47pI7.png
Enclosure:
It weighs about 400lbs with the drivers in it. This was built from maple ply, which was excessive, but the selection was poor when I went out to get the lumber for this. The second was built out of some not-so-good 6 ply soft wood sort of like arauco, but worse. It warped really bad and made my life miserable. Thankfully I have a lot of clamps. I found some nice Baltic Birch for $40/sheet that I'll be using for the last two.
http://i.imgur.com/XwN5YG3.png?1
http://i.imgur.com/zhnXSIN.jpg?1
http://i.imgur.com/dxlkaNCl.jpg
http://i.imgur.com/wwje7pMl.jpg
http://i.imgur.com/M3Eg5ER.jpg?1
http://i.imgur.com/bUPBUVDl.jpg
Results, as modeled. Huge gains. It's hard to move these things. This was back-to-back with a sealed enclosure in the same location. No changes otherwise. This measurement was taken with a faulty mic. Apparently I shocked it one too many times or something and it was rolling off way sooner than expected. The gains are the same, but the slope is all wrong.
http://i.imgur.com/wOdI6Tz.png
impedance
http://i.imgur.com/bgKvI7u.png
And in room results. There's a null at 80hz where the mic is placed. What's crazy is I still have headroom.
http://i.imgur.com/qwwHhUq.png
And full system results with XT32
http://i.imgur.com/9S0i6yE.png
3 Sweeps to determine compression... I can't measure louder with the umik1. http://files.avsforum.com/images/smilies/cool.gif
100db to 126db. Interesting how the walls react
Unstacked
http://i.imgur.com/n2Zqazc.png
Stacked
http://i.imgur.com/0pX50Ip.png
THD @ reference level. Mic is compressing/clipping
http://i.imgur.com/jHA9m2m.png
THD @ OMGWTF level. I think I might be am definitely reaching the ceiling of the mic's limits. I'm afraid to test louder for fear of damaging something in my house.
http://i.imgur.com/nOkSimG.png
jpmst3 02-05-2014 06:54 PM
Nice to find everything in one place.
Fatshaft 02-05-2014 07:08 PM
164 Attachment(s)
Not
I know I keep repeating myself but I am really looking forward to the finished results
Thanks for sharing/documenting this whole process
notnyt 02-05-2014 07:18 PM
222 Attachment(s)
Originally Posted by Fatshaft View Post
Not
Fatshaft 02-05-2014 07:33 PM
164 Attachment(s)
Originally Posted by notnyt View Post
Oh I am!
I guarantee it !!!
I can't before the summer. I don't have a garage.
I'll meet you on the dark side then
Reserve me a spot .
notnyt 02-05-2014 07:40 PM
222 Attachment(s)
Oh I am!
I guarantee it !!!
Reserve me a spot .
Excellent!
The transducers are awesome as well if you need something to hold you over until it's warm smile.gif
BassThatHz 02-05-2014 09:20 PM
SeekingNirvana 02-05-2014 10:10 PM
42 Attachment(s)
BOOM BOOM!!
LTD02 02-05-2014 10:47 PM
great plan. great work. great post.
how did you get sub 2 on top of sub 1?
notnyt 02-05-2014 11:23 PM
222 Attachment(s)
Lifted it wink.gif I had the help of 3 friends.
The fun part was inserting some foam rubber draw liners between the subs after they were up there. Duratex on Duratex makes an awful noise. I had to lift the top sub solo for that.
Bigus 02-06-2014 12:02 AM
I have to ask... since you have what I presume is enough swept volume and power to listen to any audible frequency at more than sane levels, did you ever consider playing with a linkwitz transform on your sealed system? You could have emulate your modeled ported response curve easily enough, which should give the same "feel" changes you describe. Drawbacks being more input power required (you have plenty of this in reserve), and lower max possible spl (does that really matter in this case?).
I guess I don't understand unless it is for max spl bragging rights. The benefit of massive sealed displacement is that your final output response can be user adjusted to taste electrically while remaining louder than tolerable. You had that, but sacrificed it for an option that locked in one response and with significant size penalty. Do you really intend to listen now to 20Hz at 160dB instead of 150dB?
notnyt 02-06-2014 12:19 AM
222 Attachment(s)
You might be pulling some of these numbers from your nether regions, or possibly just exaggerating to try to make a point. I'm not sure which. My sealed setup was EQ'd flat, with the -3db point at 7hz. I was bottoming out the subs during movie and music playback somewhere in the 15-20hz region. My ported setup is EQ'd flat down to around 14hz, but I have the headroom now to not worry about bottoming out my subs. I don't have any room gain in that area and there's 10,000 cubic feet of open air space to deal with. I wouldn't be busting my ass building these just for bragging rights, there are plenty of other ways to get louder output.
Also, level matched and EQ'd the same, the ported subs have a different feel to them. Can't quite explain it, but it's there, and I like it.
Bigus 02-06-2014 12:50 AM
Exaggerated, not to make a point but as a tip of the hat. I don't recall exactly what your max levels were, but I know it was loud. Really loud.
Man, hard to believe you were bottoming 15-20Hz in real world usage, but I'll take your word for it. Not sure if that is due to the large space or insane listening habits (both), but I suppose that is a legitimate reason to go chasing more headroom in that range. I would have never guessed that... figured it was just a response curve preference kind of thing.
Bigus 02-06-2014 12:51 AM
notnyt 02-06-2014 01:00 AM
222 Attachment(s)
Ah, somewhere around 130db at 20hz depending on position in the room was what I was peaking at iirc. Less under there as excursion starts skyrocketing. They'd bottom out during WOTW and HTTYD pretty bad without pushing it to insane levels. If I pushed it in some movies with not as deep bass, they'd still bottom. Pushing it listening to electronic music with sweeps down to a bit under 20hz also bottomed out before being able to reach the levels I wanted. Giving up content under 14hz to have the extra output is definitely worth it to me. The transducers I added deal w/ that pretty well anyway, since I'm still feeling it. In fact, more so than previously. Granted, I won't feel the room pressurize with a 10hz sine wave like I did before, but that was only something I'd ever notice when testing with signal generators anyway, or starting the Xbox.
It's really worrying to hear the LMS drivers bottom out, especially after seeing pictures of what happens. Things like that can keep you awake at night wink.gif
I basically had the choice to double up on drivers for 3db, or to redo the enclosures for 10-12db where it mattered. I went with the bigger enclosures. At least I'm not losing any more floor space =]
Fatshaft 02-06-2014 05:05 AM
164 Attachment(s)
Wow, that's very interesting to hear that you're bottoming them around the 15-20HZ region.
My 21's bottom at around 20HZ region too...one of my 21's makes a knocking noise (pretty bad!) when it's close to bottoming. that's when I know it's at their limit.
The other 3 don't make that noise.
OTOH, my SI18's can take a hell of a beating and have problems bottoming them out.
Can't wait to start on my end too.
I'm just gonna have to beg someone to tell me what size a cab I need for my 21's... redface.gif
Martycool007 02-06-2014 05:38 AM
How are you guys bottoming out these massive 18" & 21" subs at just 20hz? Something isn't right with your enclosures or system setup because those drivers should be able to do 15hz to 20hz with ease!
Fatshaft 02-06-2014 05:58 AM
164 Attachment(s)
Very easy...by applying MAJOR power
Sorry...don't know what else to tell you.
My 21's are getting roughly 2100Watts per sub
My 18's are getting roughly 1250Watts per sub
I believe that's a lot of juice and I know it's way more than they are rated for.
Someone correct me if I'm wrong.
I DO NOT blast sinewaves loud at them.
This is during movies ONLY that they bottom out! Never on music!
Examples:
Monument scene in OLF
Rocket launch (Ender's Game...this one really bottoms HARD!) at approx 1:05:00 mark.
dominguez1 02-06-2014 06:11 AM
Subscribed.
notnyt 02-06-2014 10:26 AM
222 Attachment(s)
The EQ necessary to get a sealed enclosure to play flat causes massive excursion increases, not much else to it.
Scott Simonian 02-06-2014 10:38 AM
135 Attachment(s)
No. Not at all, actually. The 15-25hz is the region where excursion is always at it's greatest, even with little drive power (subject to alignment). Almost every system has non-trivial rolloff below 10hz so most of us have more protection down there than in the 15-25hz region.
Lol! I got this thread mixed up with the other one. I guess since you're back now ya might as well. wink.gif
BassThatHz 02-06-2014 04:51 PM
The Ultra is only down 30% motorforce at 66mm (of 80mm), where as the SI-18 probably has no motor force at all at 66mm (of a "claimed" 86mm). That has a lot to do with it,
the LMS is more linear that nearly ANY other subwoofer at the extremes.
Scott Simonian 02-06-2014 05:44 PM
135 Attachment(s)
Yup. It still has that HUGE motor at nearly full force at the very end of the mechanical throw. It will be easier to bottom the LMS-Ultra driver compared to most other 'conventional' drivers.
edoggrc51 02-06-2014 06:13 PM
notnyt 02-06-2014 08:00 PM
222 Attachment(s)
Originally Posted by edoggrc51 View Post
maxmercy 02-06-2014 08:33 PM
So is the thread at d-b dead?
JSS
notnyt 02-06-2014 08:36 PM
222 Attachment(s)
JSS
Nobody is posting, but I've been updating it as well. I haven't had anything new to add for a bit, so it's just been conversational replies mostly. I should be able to get some lumber tomorrow morning or Saturday. I'd like to have two more built within 2 weeks. Then I can get into posting some interesting stuff like high level distortion tests and sweeps.
Between the new setup and the Crowson transducers, I can't even describe how awesome it is right now. Totally brought an already over the top system to the next level.
Scott Simonian 02-06-2014 08:44 PM
135 Attachment(s)
JSS
I've been watching. Just don't have anything useful to add usually. Still waiting for the other pair. tongue.gif
maxmercy 02-06-2014 08:48 PM
Crowson makes a great product. Folgott may have figured out how to do a semi-Crowson setup using existing subs....
Good to hear you will still update the d-b thread.
JSS
notnyt 02-06-2014 08:58 PM
222 Attachment(s)
JSS
Yeah, I saw with the springs. I'll take the actual crowson setup smile.gif Running some dynamic eq on the inuke with it now too. I put a 2'x6' piece of ply under the couch and it makes a big difference. Less energy lost.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
