MartySub Flatpacks - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #271 of 2576 Old 02-13-2014, 11:52 AM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Originally Posted by aaronlinkous View Post
Wait... Im confused on what those pictures are showing? Did you just put veneer on the face and not the exposed edges?
Also, why is that circle so janky?! I thought you teach woodworking?! I give you a C+.... learn to apply yourself (see what I did there.... apply... veneer... zing!)
Circle doesn't need to be perfect when you are covering it with a driver. Might want to put in some smileys next time eek.giftongue.gif:cool:
Paxonator likes this.
chalugadp is offline
post #272 of 2576 Old 02-13-2014, 11:55 AM
aaronlinkous's Avatar
Quoted: 55 Post(s)
Liked: 68
Sorry.. have all of the smileys to emphasize the sarcastic tone  :D
aaronlinkous is offline
post #273 of 2576 Old 02-13-2014, 11:58 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Well its been a frustrating morning. Spent lots of time last night and this morning getting wood ready to be stained . Had it looking nice, tested stain on a sample piece and it looked good. Put a coat on the cube and *&%^^(. Ended up being blotchy. Never had stain go like that. It wasn't glue stains. I am not sure if it was residue from contact cement or oils from my hands. I sanded well but it just went crazy.
Going to just paint it black over top. Will still look good but just frustrating spending all that time. Will be taking home tonight and seeing what the cube can do. cool.gif
post #274 of 2576 Old 02-13-2014, 11:59 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
I'm just in a bad mood from my above post about the stain. Knew you were joking biggrin.gif
post #275 of 2576 Old 02-13-2014, 12:02 PM
Paxonator's Avatar
Really looking forward for your thoughts on the sub tonight. I've been following the marty subs the whole time but couldn't pull the trigger due to the size. I will eagerly wait for your test now!
Paxonator is offline
post #276 of 2576 Old 02-13-2014, 12:03 PM
Quoted: 55 Post(s)
Liked: 68
Originally Posted by chalugadp View Post
Well its been a frustrating morning. Spent lots of time last night and this morning getting wood ready to be stained . Had it looking nice, tested stain on a sample piece and it looked good. Put a coat on the cube and *&%^&#^(. Ended up being blotchy. Never had stain go like that. It wasn't glue stains. I am not sure if it was residue from contact cement or oils from my hands. I sanded well but it just went crazy.
That is quite a ****** turn of events..... what would you normally use to clean the veneer before applying in case there was contact cement or oil? Would a spray gun have helped prevent this (if the area was clean of course)
post #277 of 2576 Old 02-13-2014, 12:09 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
I almost always use watco oil to finish my projects. Never have problems. Tried a varathane stain I used years ago (new can for today)and i am not sure what happened. Not going to worry about it too much since I know it will fine painted and I really want to know how it sounds. Lesson learned was stick to my watco oils. cool.gif
post #278 of 2576 Old 02-13-2014, 12:21 PM
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
I read some where that you need to use some kind of oil/cleaner first on veneers because if not it will be blotchy when stained. Something about the glue they use to adhere the paper backing. Could be on certain brands maybe.
cessna1466u is offline
post #279 of 2576 Old 02-13-2014, 12:31 PM
steve nn's Avatar
Liked: 433
If you paint the top I beg you to be sure to seal it first. I had a bad experience painting the top of my last project. Thing is I pretty much knew better but had to learn the hard way. That being that, I’m not sure if I would paint the top even if I did seal it. I would test mixing some black paint with stain and test it out on scrap.. just a suggestion
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #280 of 2576 Old 02-13-2014, 01:02 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
I am going to give it a quick sanding with 80 grit orbital to rough up surface. THen paint black. Then its coming home. I need to test this baby. If I am not happy with the black paint job I can always paint again at home. Before I invest too much more time I need to try it out. rolleyes.gif
post #281 of 2576 Old 02-13-2014, 01:15 PM
Quoted: 116 Post(s)
Liked: 201
I agree you need to try it out so that we can get the okay to start building our own. :)We appreciate you being the guinea pig.smile.gif
post #282 of 2576 Old 02-13-2014, 01:21 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
For my testing tonight I am first going to play certain music tracks/movie (I know these very well)and set volume to 50 on my preamp.(thats loud). Then use my spl meter and measure certain points in the song/movie. Say at 30 seconds bass hits 105dbs. I will measure 6-8 demo spots with full marty and then swap driver out to the cube. I will place the cube in the exact same spot as full marty. With volume at same level and all eq settings the same I will measure the 6-8 spots again. My hope is that the measurements should be very similar other then around 15-20 hz. THere I will lose 2-4dbs I am guessing. cool.gif
Will also play a heavy bass song really loud on cube to see if their is any chuffing.
post #283 of 2576 Old 02-13-2014, 01:33 PM
atabea's Avatar
Quoted: 554 Post(s)
Liked: 348
I am really looking forward to your tests and comments.
atabea is online now
post #284 of 2576 Old 02-13-2014, 01:35 PM
Quoted: 116 Post(s)
Liked: 201
Those all sound like great tests and real life situations. Can I put in a request? When you get mystery salt can you please put it in layman terms. Graphs might explain a lot to some of the people but I know to myself personally the "it sounded bad ass and the walls were shaking. Compared to the regular Marty this was as good or better" goes a lot further than the graphs. I know the graphs are important and they say a lot and one day when I learn all about them I will appreciate them but for right now they scare me.
Flynnr likes this.
post #285 of 2576 Old 02-13-2014, 01:36 PM
fr8doggr's Avatar
Quoted: 16 Post(s)
Liked: 66
Yeah, I am too. I bet there are quite a few guys that currently have, or are thinking about building a Marty or Mini-Marty, and would like to know how the cube compares at half the real estate.
fr8doggr is offline
post #286 of 2576 Old 02-13-2014, 01:44 PM
steve nn's Avatar
Liked: 433
Painting over the top of veneer can cause the veneer to bubble, no second chance to redo. tongue.gif If painting just the ply then you're good. Maybe your veneer wont, mine was paper backed Bandit.
EDIT> I thought you had paper backed veneer but now see it's not. This is good!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #287 of 2576 Old 02-13-2014, 02:28 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
No graphs,
For example
Star wars pod racing scene full marty 114dbs and cube 113.5 dbs
My songs are :
Metallica enter sandman
Ozzy mama I'm coming home
Bruno mars just the way you are
Black eyed peas boom
Couple of hip hop songs (can't remember the names)
Pod scene
WOTW ground scene
last is tv show justified. THe opening music starts with four beats that are classic midbass.
post #288 of 2576 Old 02-13-2014, 03:19 PM
Quoted: 116 Post(s)
Liked: 201
"Star wars pod racing scene full marty 114dbs and cube 113.5 dbs"
Are these actual numbers already., if so HD is still open, I can pick up MDF and maybe get a few cuts in tonight.
Either way with all jokes aside, thank you for testing this and putting the results out to everyone. We do appreciate it and always look forward to your projects and comments.
post #289 of 2576 Old 02-13-2014, 03:23 PM
Quoted: 116 Post(s)
Liked: 201
"Mystery Salt"? I guess that is what happens when you type on a cell phone with auto correct. These Results is what it should say.
post #290 of 2576 Old 02-13-2014, 07:09 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
We need the Mystery Salt!
_______________________
The SEOS Waveguide Project
Erich H is offline
post #291 of 2576 Old 02-13-2014, 07:11 PM
Quoted: 116 Post(s)
Liked: 201
Man, why do you have to scare us Erich. I saw my phone beep that I had a new email, and I could see that it was from AVS. I almost knocked my kid down trying to get to the computer to check. I was wondering if Donny had results for us. Makes me wonder if he is enjoying himself too much or throw the whole thing out the window and doesn't want to tell us the bad news.
post #292 of 2576 Old 02-13-2014, 07:13 PM
Paxonator's Avatar
Yes I saw that as well and had to quickly refresh. Hope Donny gets back to us tonight with good news smile.gif
post #293 of 2576 Old 02-13-2014, 07:19 PM
atabea's Avatar
Quoted: 554 Post(s)
Liked: 348
I am three hours ahead here in the GTA and I can't go to bed before I read what Chaluga has to say.
post #294 of 2576 Old 02-13-2014, 07:24 PM
Quoted: 116 Post(s)
Liked: 201
post #295 of 2576 Old 02-13-2014, 09:25 PM
Flynnr's Avatar
Quoted: 25 Post(s)
Liked: 43
Anxious!
Flynnr is offline
post #296 of 2576 Old 02-13-2014, 09:27 PM
Quoted: 116 Post(s)
Liked: 201
post #297 of 2576 Old 02-13-2014, 09:48 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Man what a crowd. Well I just spent four hours helping jbrown build one of his big subs. Warren gave us a hand . Bringing the cube home right now but I am bagged. Will test it out tomorrow morning and have results up before noon Pacific .
post #298 of 2576 Old 02-13-2014, 09:52 PM
Quoted: 116 Post(s)
Liked: 201
No worries man. We are only kind-of kidding with you. I am sure jbrown appreciates your help and that is how it should be. (Helping each other out) I wish there where people around here that needed help, I could offer up my garage and tools (lots of woodworking tools) in exchange for knowledge. Either way, get some rest. I assume school is out tomorrow like it is here in Seattle area. Thanks for the heads up. We can all go to sleep know.
post #299 of 2576 Old 02-13-2014, 09:55 PM
Quoted: 55 Post(s)
Liked: 68
Donny, if there wasnt a border between us... oh the sub boxes we would make. My wallet is thankful that there is.
cessna1466u likes this.
post #300 of 2576 Old 02-13-2014, 10:04 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Its got a little bro
Thanks to Warren for helping me get it home.
Closed Thread DIY Speakers and Subs
