MartySub Flatpacks - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
Old 02-17-2014, 05:58 PM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Originally Posted by Erich H View Post
How much does it weigh?
Didn't get a chance , had to run my daughter to art class . I am going to do like you said and package it in two boxes. I think it will be about 50lbs in one and 30 or so in the other.
chalugadp is offline
Old 02-17-2014, 06:05 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
I was thinking of buying a Kreg Jig kit that makes it real easy to join wood together. I figured that I would only need one clamp, glue, a drill and the Kreg Jig kit. Did you also use silicone to seal or any sealant to make sure no leaks??
lemans24 is offline
Old 02-17-2014, 06:10 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
If you want to make it easier for the same cost buy a small compressor and brad gun from harbor freight tools. I will run a bead of silicone in the joints tomorrow , add some bracing , dampening , and attach the top. Then paint and wait for that uxl18 driver.
Old 02-17-2014, 06:45 PM
WarrenBerry's Avatar
Quoted: 40 Post(s)
Liked: 48
Looks really good chaluga. Makes me kinda homesick smile.gif whats the shipping cost from your house anyhow? wink.gif
WarrenBerry is offline
Old 02-17-2014, 06:53 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
To where ?
Old 02-17-2014, 06:56 PM
Quoted: 40 Post(s)
Liked: 48
I was just messin around knowing full well i could just drive.
Old 02-17-2014, 07:16 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Old 02-18-2014, 01:28 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Couldn't sleep so I created the instruction booklet tonight. I used sketchup pics to try to make it easier. I am sure their could be edits made but I am not going to make them. This method worked great for me and i hope it helps anyone who builds the cube. In the booklet I mention glueing and using screws. I like the added strength of screws as well as the convenience of speeding up the process. If you want to just use glue then go ahead. I will also put this in post one.
I hope this helps people. Building the full or mini-marty would follow very similar steps. cool.gif
LTD02, fr8doggr, dogger99 and 14 others like this.
Old 02-18-2014, 02:23 AM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
^^^^^^^^^^^^THIS is freakin' impressive, Donny!!!
chalugadp likes this.
blah450 is offline
Old 02-18-2014, 07:32 AM
FireDust58's Avatar
Liked: 30
Well, I pulled the trigger and bought some 3/4" MDF and made all my cuts last night!
FireDust58 is offline
Old 02-18-2014, 08:32 AM
mhutchins's Avatar
Quoted: 82 Post(s)
Liked: 95
Awesome job, Donny!!!
One minor suggestion for the bracing, the corner braces are already in the strongest area of the enclosure. You would derive much more benefit if you move these adjacent to the speaker cutout hole.
I hope you sell a ton of these and build some 15" SEOS mains with the money earned!!
Mike
mhutchins is offline
Old 02-18-2014, 08:39 AM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Excellent instructions!!!
a few additions would be nice for the flat packs you are making:
- add dado cuts for all of the port rails (outer back/bottom & port back/bottom)
- add dado cut for large brace on port bottom
- need to glue front double baffle before mounting to box
lemans24 is offline
Old 02-18-2014, 09:04 AM
FireDust58's Avatar
Liked: 30
Question: Is the acoustic foam better / worse than pillows or other polly fill for the cube? On a ported box, do you typically still add stuffing like a sealed?
Old 02-18-2014, 10:31 AM
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
This is great, Thank you. Just what we needed to understand some of the stuff that isn't seen in the finished product. BTW most people that can't sleep watch a movie or read, they don't put sit down and put out an awesome manual. Looks like you have subwoofer-itus.
cessna1466u is offline
Old 02-18-2014, 12:41 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
In all the building that I have done dado cuts are helpful when glueing together several pieces (6-10) at once. The dadoes prevent the pieces from sliding around. FOr this cube the pieces fit snug and once in place don't move much. You are only putting together two pieces at once so you will have to take my word that its very easy. If someone wants dadoes it makes it more time consuming for me to cut out. It would be faster for me just to assemble it together without glueing the top down. I could do that and round corners for a small fee. smile.gif
Old 02-18-2014, 12:42 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
I don't think it makes a difference. Polyfill is cheaper.
Old 02-18-2014, 12:43 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
thanks,
it actually is pretty easy. Just text boxes in word and insert pics.
Old 02-18-2014, 01:22 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Can you post a picture of where you put the connectors on the box and how you got the wires there?  Through the port wall?  through the port itself???
Claybe is offline
Old 02-18-2014, 01:43 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Drill through the back , and the port. I will be doing it In awhile and will take a pic
Old 02-18-2014, 02:59 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Here it is
fr8doggr and Rebel975 like this.
Old 02-18-2014, 07:49 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Here it is
Thanks! One other question, does the hole through the port need to be sealed? Wouldn't the hole through the port affect the tuning or not?
Claybe is offline
Old 02-18-2014, 07:53 PM
Flynnr's Avatar
Quoted: 25 Post(s)
Liked: 43
This Sucker is heavy. I can barely lift mine (but I'm a wimp)...
Flynnr is offline
Old 02-18-2014, 08:47 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Do you have pics?
Claybe is offline
Old 02-18-2014, 08:50 PM
mhutchins's Avatar
Quoted: 82 Post(s)
Liked: 95
This Sucker is heavy. I can barely lift mine ...
Just imagine the weight of a full-size Marty....
Old 02-18-2014, 08:52 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
nice instructions! thumbs up!
Listen. It's All Good.
LTD02 is offline
Old 02-18-2014, 08:53 PM
dtsdig's Avatar
Quoted: 829 Post(s)
Liked: 921
Haha! That rocks!
dtsdig is online now
Old 02-18-2014, 09:22 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Mine was 91 pounds
Old 02-18-2014, 09:40 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Mine was 91 pounds
The one made out of plywood or MDF?
jbrown15 is offline
Old 02-18-2014, 09:51 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Mine was 91 pounds
Mdf , plywood was 71
Old 02-18-2014, 10:00 PM
notnyt's Avatar
Quoted: 2165 Post(s)
Liked: 1986
pffffft.
notnyt is offline
