MartySub Flatpacks - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #901 of 2576 Old 02-27-2014, 06:18 PM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Originally Posted by aaronlinkous View Post
A brewery could be involved.
Aren't you in Seattle ?
chalugadp is offline
post #902 of 2576 Old 02-27-2014, 06:21 PM
Flynnr's Avatar
Quoted: 25 Post(s)
Liked: 43
WAF soon to be at all time high. Current status: all time low.
1st coat of b-I-n shellac based primer/sealer on and is waiting to be sanded -ugh (have to sand it in the garage... It's -10f out right now)
http://t.homedepot.com/p/Zinsser-1-Qt-White-B-I-N-Shellac-Interior-and-Spot-Exterior-Primer-and-Sealer-00904/100398380
I'll do a second coat of primer tonight and sand it and then give it a coat or two of Rustoleum flat black latex paint and call er good.
http://t.homedepot.com/p/Rust-Oleum-Painter-s-Touch-32-oz-Flat-Acrylic-Latex-Black-General-Purpose-Paint-1976502/100172539/
Hopefully this won't look too terrible being applied with a 4" roller on the top/bottom/back/sides and a brush on the front baffle...
Flynnr is offline
post #903 of 2576 Old 02-27-2014, 06:26 PM
aaronlinkous's Avatar
Quoted: 55 Post(s)
Liked: 68
Closer, Bellingham.
aaronlinkous is offline
post #904 of 2576 Old 02-27-2014, 06:30 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Closer, Bellingham.
Take me out for lunch and I could bring it to you. We go to Bellingham every 4-6 weeks. Love the shopping .
post #905 of 2576 Old 02-27-2014, 06:33 PM
Quoted: 55 Post(s)
Liked: 68
Stop buying up all my damn milk! Silly Canadians.
post #906 of 2576 Old 02-27-2014, 06:36 PM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
Originally Posted by randyc1 View Post
The 6000 does'nt do 2 ohm for a pair on 1 channel though ??
certain vega cv5000 would be my choice with that arrangement.
Edit: Who knows how old the post I quoted was...silly mobile. Sorry if I'm addressing something old.
JohnDean is online now
post #907 of 2576 Old 02-27-2014, 06:52 PM
dogger99's Avatar
vega cv5000 = $1000
nu6000dsp = $400
dogger99 is offline
post #908 of 2576 Old 02-27-2014, 06:55 PM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
Cv5k =2ohm stable
Nu6000=not.
The guy was wanting to run two 18D2's on 1 channel. ;-)
post #909 of 2576 Old 02-27-2014, 07:09 PM
carp's Avatar
Quoted: 2486 Post(s)
Liked: 1741
Originally Posted by dogger99 View Post
vega cv5000 = $1000
nu6000dsp = $400
800 not 1000 for the cv5000
carp is online now
post #910 of 2576 Old 02-27-2014, 07:12 PM
asarose247's Avatar
Quoted: 695 Post(s)
Liked: 451
google Duro-med convoluted eggcrate, 33" x 72" 2" about $22 that's a bit over 16 sq. ft. so about $1.40 ish per sq. ft. I haven't priced joannes. AS I've learned, none is necessary for the marty cube but
curious about what the minimum or optimal minimum for a martysub might be
anybody?
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #911 of 2576 Old 02-27-2014, 07:18 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Originally Posted by TekkSki View Post
Can you post a link to the cable? I have the monoprice xlr to rca on the way but it was cheap enough that I won't lose sleep over ordering a better one. Thanks in advance.
I don't know what company Seaton uses for cables. I have 2 of them since I used to own Submersives. A friend of mine bought a cable straight from Mark so you could go that route.
I also bought some from Funky Munky and 2 of them caused hum and 2 did not.
My emotiva preamp only.has one xlr and one rca. I used my.monoprice xlr to rca cable today and no hum.
post #912 of 2576 Old 02-27-2014, 07:20 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
anybody?
None is a.must but the vertical port wall is a minimum to me. I think the rest is just for peace of mind to a degree .
post #913 of 2576 Old 02-27-2014, 07:26 PM
asarose247's Avatar
Quoted: 695 Post(s)
Liked: 451
'None is a.must but the vertical port wall is a minimum to me. I think the rest is just for peace of mind to a degree"
so one sheet for 2 tallmarty's , cheap enough., like less than 2% of total costs
thanks
post #914 of 2576 Old 02-27-2014, 07:48 PM
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
anybody?
If by minimum you mean the amount of eggcrate, I purchased a piece that was 82x32 and I used almost all of it on 1 cube. Had about 15x32 left.
cessna1466u is offline
post #915 of 2576 Old 02-27-2014, 07:50 PM
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
Hunh? Vertical wall is a must, but none is a must??? Confused here.....
Also, Donny, can you tell a difference between the sub with more egg crate than the other? You did one with full egg crate and one only on the vertical port wall right?
My uneducated guess would be that the more egg crate the smoother the response,but again this is very uneducated and a guess..
Claybe is online now
post #916 of 2576 Old 02-27-2014, 07:55 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
without any the sub will sound good. The more you add the smoother ,tighter the sound is but it lowers output (spl). To me you have the air forcing itself to the back of the sub. I would think(don't have proof) that the majority of the air hits the back vertical port. Much more then the side walls. The second cube i built does only have dampening on the vertical port, 1st everywhere. Still waiting for my uxl18 driver to fire it up. I will report out if i hear any difference. One could always add or remove lining and see themselves.
post #917 of 2576 Old 02-27-2014, 07:58 PM
Quoted: 116 Post(s)
Liked: 201
I put it everywhere, making sure to leave enough space up on top for the air to travel to the port with no restriction. The sound is very tight and no "hollow" sound. It sounds great!
post #918 of 2576 Old 02-27-2014, 07:59 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Originally Posted by cessna1466u View Post
Any reason you only want to use 1 channel? Power?
Yes because I only passed one pair of wires behind of my baseboards, going to front stage,,,to 1st SUB then daisy chained (parallel) to the 2nd SUB .
cessna1466u likes this.
randyc1 is offline
post #919 of 2576 Old 02-27-2014, 08:05 PM
Claybe's Avatar
Quoted: 213 Post(s)
Liked: 81
Did you take any pictures of how you rounded the edges? I really like this look.
post #920 of 2576 Old 02-27-2014, 08:23 PM
mhutchins's Avatar
Quoted: 82 Post(s)
Liked: 95
mhutchins is offline
post #921 of 2576 Old 02-27-2014, 08:24 PM
Quoted: 116 Post(s)
Liked: 201
post #922 of 2576 Old 02-27-2014, 08:25 PM
Quoted: 116 Post(s)
Liked: 201
Originally Posted by mhutchins View Post
Is it 1/2? I was looking at possibly doing 3/4 or 1" but I only found them in 1/2" shank and not 1/4" like I have.
post #923 of 2576 Old 02-27-2014, 08:45 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
I thought I'd share a nice bass test video from youtube for all you firs time martys. No crazy dubstep, rap or sine waves, pretty much piano and bass drops. I think a couple are sub 20hz. This shakes my windows and ripples my floors biggrin.gif
Enjoy
http://www.youtube.com/watch?v=S96SguswXY4
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #924 of 2576 Old 02-27-2014, 08:53 PM
Quoted: 116 Post(s)
Liked: 201
Enjoy
How do you play it fr YouTube yo your receiver/amp?
post #925 of 2576 Old 02-27-2014, 08:59 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
Well I use my home theater pc, but one could use airplay with an apple device, most newer receivers have airplay capability and many bluray players have a youtube app I bet.
AlphaPie is offline
post #926 of 2576 Old 02-27-2014, 09:00 PM
Quoted: 116 Post(s)
Liked: 201
post #927 of 2576 Old 02-27-2014, 09:49 PM
TekkSki's Avatar
Chrome Cast works awesome and you can cast any tab up on the TV using chrome as well. Love it esp. for $35
TekkSki is offline
post #928 of 2576 Old 02-27-2014, 10:19 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Haha I was just down picking up a package that arrived from Parts-Express and grab four jugs of milk, plus some cheese biggrin.gif
jbrown15 is offline
post #929 of 2576 Old 02-27-2014, 10:25 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
post #930 of 2576 Old 02-27-2014, 10:37 PM
jbrown15's Avatar
Liked: 1993
I know tell me about it, I was really hoping they would have contacted me today. Hey at least you have one martycube to hold you over, I have nothing!
jbrown15 is offline
Closed Thread DIY Speakers and Subs
