MartySub Flatpacks - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #961 of 2576 Old 03-02-2014, 07:59 AM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
So it looks like the old monster cable is 16 gauge so I guess I will order some 12 gauge wire. Any recommendations on what kind???
Claybe is offline
post #962 of 2576 Old 03-02-2014, 08:44 AM
fr8doggr's Avatar
Quoted: 16 Post(s)
Liked: 66
fr8doggr is offline
post #963 of 2576 Old 03-02-2014, 08:53 AM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Yep, seems like this is the way to go! Thanks.
Claybe is offline
post #964 of 2576 Old 03-02-2014, 09:35 AM
cessna1466u's Avatar
Quoted: 117 Post(s)
Liked: 204
That is a good deal, I picked up 50 feet of speaker wire but it does not have have the white surround like that and it was almost $20. Go with that wire it looks perfect for it.
cessna1466u is offline
post #965 of 2576 Old 03-02-2014, 03:50 PM - Thread Starter
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Jbrown and Warren popped by and we got 2 full martycubes packed up and three more ready to be packaged. Those two went off to Jbrowns house to make out ! tongue.gif (listening to jbrowns setup)
Routing the recess has chewed up my cheapie router bit. Time to go buy another 12 buck jobbie. Will be done everything but packaging tomorrow. Feel like a kid waiting for xmas with my uxl18 driver. eek.gif
chalugadp is offline
post #966 of 2576 Old 03-02-2014, 04:06 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Don't send me my flat pack until you have checked that the baffle recess fits a uxl-18 when you get yours
I so regret not getting a couple of uxl18 in the group buy but so happy that Donny is making marty sub flat packs!!
I finally downloaded the latest version of winisd and will be checking to see if the uxl18 will be ok with 2800 watts from a cv2800 amp.
I feel more safe with an old style heavy ass amp that has a high damping factor. Don't think I can get a full 2800 watts rms from standard 15 amp wall socket anyways!!
When I looked at the in depth review of the inuke 6000, they basically said that it puts around 1800 watts rms each channel @ 31hz. I want think the uxl-18 can handle way more than that but I will make sure the excursion is kept in check with 2nd order butterworth high pass @ 20hz...
Building this sub will almost be as much fun as building racing go karts for 2 boys!!
lemans24 is offline
post #967 of 2576 Old 03-02-2014, 04:10 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Yours has everything done but the recess . Once I get my uxl18 I will measure it. I think my template will work but we will see. Crazy how we can ship to Florida faster then to Winnipeg .
post #968 of 2576 Old 03-02-2014, 05:00 PM
bluer101's Avatar
Quoted: 375 Post(s)
Liked: 295
After I'm done with my new media center then I can do my Marty cubes. :-).
This is from today, still need vertical dividers and face frame.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #969 of 2576 Old 03-02-2014, 07:26 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
a friend of mine just finished building some down firing variants of the marty cube.
Here are some pics. Not painted yet...still deciding on finish. Hope this is ok to post here.
LTD02 likes this.
basshead81 is offline
post #970 of 2576 Old 03-02-2014, 07:29 PM
Quoted: 117 Post(s)
Liked: 204
post #971 of 2576 Old 03-02-2014, 07:31 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Nice! Will be very interested to see results on the sound of this "one upper cube". smile.gif
Claybe is offline
post #972 of 2576 Old 03-02-2014, 07:36 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
Very nice cube cousin :thumbup:
post #973 of 2576 Old 03-02-2014, 07:45 PM
N8DOGG's Avatar
Quoted: 1117 Post(s)
Liked: 1218
UXL's are not the best driver for bottom firing, it will sag over time (for anyone thinking about it)
N8DOGG is online now
post #974 of 2576 Old 03-02-2014, 08:12 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
You mean I am going to have to get a sub lift for my cube ? tongue.giftongue.giftongue.gif
post #975 of 2576 Old 03-02-2014, 09:01 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
good to know!! Fwiw SI HT D2's are being used in the down firing MC's. smile.gif
post #976 of 2576 Old 03-02-2014, 11:16 PM
blah450's Avatar
Quoted: 142 Post(s)
Liked: 171
Clearance distance between floor and port affect anything with a down-firing Marty design as above?
blah450 is offline
post #977 of 2576 Old 03-03-2014, 04:38 AM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
I get a first port resonance of around 108hz with a port length of 62". Since winisd calculates the port length as too long, my port length will be around 51". Does the first port resonance change to with port length shortened? I assume so as the actual tuning should really be 20hz now instead of lower as calculated by winisd.
Can anyone confirm the new port resonance?? Design is for 6.3cf Marty cube with 2.75" x 22.5" x 51" port @ 20hz tuning
lemans24 is offline
post #978 of 2576 Old 03-03-2014, 05:30 AM
splotten's Avatar
Quoted: 290 Post(s)
Liked: 138
Its the actual length of the port that decides the port resonance. I dont know if you measured the port resonance at 108Hz or calculated it, but if fits perfectly with calculation. I calculate 131Hz for the new shorter port.
splotten is offline
post #979 of 2576 Old 03-03-2014, 06:00 AM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Thanks...looks like I will need to implement a 4th order low pass filter around 80hz to make sure that resonance will not be audible...
I also checked excursion limits and port velocity for uxl-18 @ 2800 watts rms and I should be well within limits with a 2nd order high pass filter @ 20hz.
My only concern is the voice coil but I think I am within thermal limits...love all this audio techno theory!!!
lemans24 is offline
post #980 of 2576 Old 03-03-2014, 06:30 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
No it should not long as there is a few inches of clearence. Not different then placing a rear ported sub next to a wall. Boundries are just that, does not matter if they are walls, floors, or ceilings.
post #981 of 2576 Old 03-03-2014, 06:55 AM
steve nn's Avatar
Liked: 433
I once went a little to far and felt it affected the performance but didn't keep it long enough. It's going to depend on the driver and xmax. I would give a 18" a good 3" - 3.5 minimum myself. http://www.diyaudio.com/forums/subwoofers/101549-how-far-can-driver-down-firing-sub-floor.html
Here is a post by Bill F regarding the subject also. http://www.avsforum.com/t/1466683/distance-to-floor-for-downfiring-sub
The distance to the floor will affect the loading of the driver. If you're skilled enough with speaker modeling software you can calculate how the distance will impact the result. Otherwise it's a matter of trial and error, measuring the response with various height legs.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #982 of 2576 Old 03-03-2014, 08:53 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
post #983 of 2576 Old 03-03-2014, 09:04 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
So the real question is Bass, when are you going to come over to the darkside and build something?
jbrown15 is offline
post #984 of 2576 Old 03-03-2014, 09:17 AM
steve nn's Avatar
Liked: 433
LOL.. I guess it would have been better to put your 2" quote in that reply rather than blahs question. Anyway yeah I'm with jb wondering when you might make the move?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #985 of 2576 Old 03-03-2014, 09:27 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
Not for a while...my current room will not handle anymore bass. I need a dedicated theatre, that has no windows, with dedicated circuits, and is completely sealed. Then DIY will probably be a go. Although the Passive Captivators look pretty tempting too. Still not the value vs performance of DIY, but the gap is closer. smile.gif
post #986 of 2576 Old 03-03-2014, 09:34 AM
steve nn's Avatar
Liked: 433
Well it's good to see you over here. I certainly understand a guy only needs so much!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #987 of 2576 Old 03-03-2014, 09:37 AM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
I like it over here...getting tired of the same ol "what sub for 500.00" threads in the turn key section. If I had DIY subs I would probably just camp here. smile.gif
NWCgrad likes this.
post #988 of 2576 Old 03-03-2014, 05:25 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Are you referring to my once "Greek God" body which has morphed into something else?  Sounds all too familiar..............................:D
Age tends to be the great "Equalizer"....................... ;)
doublewing11 is offline
post #989 of 2576 Old 03-03-2014, 07:05 PM - Thread Starter
chalugadp's Avatar
Liked: 1532
My pc computer crapped out today. Either motherboard or hard drive done. Had it almost 5 years. I stream everything so it's a nightmare . Using my daughter's laptop but now I have to go get another tower. Grrrrr
post #990 of 2576 Old 03-03-2014, 07:26 PM
wvu80's Avatar
Quoted: 329 Post(s)
Liked: 293
Rule of thumb is your computer is outdated about every 3 years. You got five good years, so it's all good. FYI I am a PC guy so if I can help you troubleshoot your problem, shoot me a PM or email, wvu80 at msn dot com. You might be able to simply plug in a few new parts and get some more mileage out of the old girl.
If it's the HDD that crashed, a Samsung EVO Solid State Drive will give your computer new life, but your motherboard must be able to support it. The 120 GB's are under a hundred bucks, and the 250's are about $160 from Newegg. Just like subs, bigger is better. cool.gif
wvu80 is offline
Closed Thread DIY Speakers and Subs
