MartySub Flatpacks - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #181 of 2576 Old 02-11-2014, 10:38 AM
Ryan Flynn's Avatar
Liked: 24
Originally Posted by dogger99 View Post
What type of cables would be needed to connect the 3000 to a pioneer sc 37 receiver?
Assuming you just have a normal sub precut like my pioneer receiver you will just need this cable.
http://www.monoprice.com/Product?seq=1&format=2&p_id=4777&CAWELAID=1329450499&catargetid=320013720000011014&cadevice=t&cagpspn=pla&gclid=CKH2sbnOxLwCFaZAMgodGFAAKg
dogger99 likes this.
Ryan Flynn is offline
post #182 of 2576 Old 02-11-2014, 12:07 PM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
I started cutting out the pieces for my first martycube. Couldn't finish because I actually have to do some teaching. Damn students mad.gifsmile.gif
I will start a seperate build thread and include some of it in the first post here.
The question today is how much is the martycube flatpack going to weigh ?
I brought my scale and will let you know later.
How about some guesses and see who gets the closest ? 45lbs,50... 55 ???biggrin.gif
chalugadp is offline
post #183 of 2576 Old 02-11-2014, 12:13 PM
aaronlinkous's Avatar
Quoted: 55 Post(s)
Liked: 68
aaronlinkous is offline
post #184 of 2576 Old 02-11-2014, 12:24 PM
Ryan Flynn's Avatar
Liked: 24
Actually now that I think about it we are using different wood.
Mine is coming along nicely - only one hiccup last night (cut a board too short... Damn!)... Everything is cut minus the 1x1's to brace the box as I will just do that when the time comes.
post #185 of 2576 Old 02-11-2014, 01:53 PM
mbw23air's Avatar
Quoted: 158 Post(s)
Liked: 149
68lbs
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Oppo BDP-93 blu-ray player Panasonic UB-900 UHD blu-ray player
mbw23air is offline
post #186 of 2576 Old 02-11-2014, 02:01 PM
atabea's Avatar
Quoted: 561 Post(s)
Liked: 362
Chaluga, are you still using Birch? If your are, then I would say 60 lbs. BTW, is there any chance you can specifically identify exactly which Birch Ply you are using and which store you bought it from? I am in the Toronto/GTA area and if it's at any of the Stores I have access to I can pick up the same product. Unless, of course, MDF is the better choice.
thanks
atabea is online now
post #187 of 2576 Old 02-11-2014, 02:12 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
thanks
Birch ply from rona. Plywood is easier to work with and cheaper here. Accepts nails and screws better.
post #188 of 2576 Old 02-11-2014, 02:19 PM
atabea's Avatar
Quoted: 561 Post(s)
Liked: 362
Thanks very much Chaluga, I will be visiting Rona either tonight or tomorrow. Is there a specific product number I should be looking for?
thanks
Rick
post #189 of 2576 Old 02-11-2014, 02:37 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
60 lbs sounds like a great guess. i'll take the "under" on that...59. :-)
Listen. It's All Good.
LTD02 is online now
post #190 of 2576 Old 02-11-2014, 02:40 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
thanks
Rick
In BC here they only carry one model of 3/4" by 4' by 8' . The piece is exactly 48" wide so I had to make some small changes to my sizes of the sub (1/8"). If someone is using a 4 by 8 sheet that is 49" wide they will be fine.
post #191 of 2576 Old 02-11-2014, 02:44 PM
atabea's Avatar
Quoted: 561 Post(s)
Liked: 362
Thanks, Chaluga!!!
post #192 of 2576 Old 02-11-2014, 02:52 PM
steve nn's Avatar
Liked: 433
lol.. That’s a union issue and arbitration is called for here before things get out of hand.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #193 of 2576 Old 02-11-2014, 03:08 PM
Quoted: 55 Post(s)
Liked: 68
Originally Posted by aaronlinkous View Post
67lbs
Originally Posted by mbw23air View Post
68lbs
You are terrible, terrible person!
post #194 of 2576 Old 02-11-2014, 03:19 PM
Ryan Flynn's Avatar
Liked: 24
75lbs
post #195 of 2576 Old 02-11-2014, 04:08 PM
fr8doggr's Avatar
Quoted: 16 Post(s)
Liked: 66
71.3 lbs.
fr8doggr is offline
post #196 of 2576 Old 02-11-2014, 04:31 PM
mbw23air's Avatar
Quoted: 158 Post(s)
Liked: 149
mbw23air is offline
post #197 of 2576 Old 02-11-2014, 04:52 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Rebel975 is offline
post #198 of 2576 Old 02-11-2014, 04:54 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
The official weight is ................................................
71.4 lbs
post #199 of 2576 Old 02-11-2014, 05:02 PM
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Originally Posted by Rebel975 View Post
pi^pi * 2
My guess was approximately 72.92 lbs. Pretty close...
Rebel975 is offline
post #200 of 2576 Old 02-11-2014, 05:13 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1775
71.4 lbs
Hey, didn't you think the bigger 9cuft Mini Marty was going to be 85lbs?? wink.gifwink.gifbiggrin.gif
Did you decide to not do the 9 cubic footer?
The smaller ported Cube is pretty much identical to the ported model I was working on for some of the 15" drivers. LTD02 helped figure the volume needed for them last year, but we never discussed dropping an 18" inside of it.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #201 of 2576 Old 02-11-2014, 05:14 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
post #202 of 2576 Old 02-11-2014, 05:16 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
71.4 lbs
Hey go fix that upside down 1099 picture wink.giftongue.gif:eek:
post #203 of 2576 Old 02-11-2014, 05:22 PM
atabea's Avatar
Quoted: 561 Post(s)
Liked: 362
So, in view of the now finalized cube (2x2x2), are you able to offer a flat pack for this little beast?
post #204 of 2576 Old 02-11-2014, 05:24 PM
Erich H's Avatar
Liked: 1775
I was hoping the Cube would come in under 70lbs with plywood. Once you go over 70, you might as well break the kit into 2 packages because 2 smaller ones will cost the same as one that weighs over the 70lb mark. I'd figure a good 5lbs for packaging material for each of the 2 boxes. Ideally you can get all the big pieces in one box and be around 50lbs, then put the smaller ones in their own box. But finding a perfect shipping box might not be so easy.
Erich H is offline
post #205 of 2576 Old 02-11-2014, 05:31 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
I will once I have finished my two. Hope to be able to take orders Feb 18th. Have three people already signed up. You the fourth atabea ?
post #206 of 2576 Old 02-11-2014, 05:36 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
The fact that I am not the guru of packaging like u means one box. You.should see me with xmas presents. Also I have to drive these across the border for some people and ship from usa side. Can't tape box completely , they want to look in at the border. I will give a ballpark figure for shipping but the final amount will be per person . I might be asking you some questions.
post #207 of 2576 Old 02-11-2014, 05:41 PM
atabea's Avatar
Quoted: 561 Post(s)
Liked: 362
I was trying to prompt Erich into making flat packs available for the long term since you (as I understand it) will only be doing them for a limited time. I really think the cube will be very popular for a long time due to its WAF friendly size and the performance it offers. I might order a couple flat packs from you since I just found out Rona Ontario does not carry the Birch Ply you found in BC. I have a call out to a couple of places. Once I find out, I will let you know either way.
Rick
post #208 of 2576 Old 02-11-2014, 05:54 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
I see myself making marty flatpacks till the end of the school year ( end of June) or till erich makes them way cheaper and puts me out of business cool.gif
If I make six or 16 doesn't matter. I just need six to make my front speakers and everything after that is gravy.
post #209 of 2576 Old 02-11-2014, 06:07 PM
Erich H's Avatar
Liked: 1775
I wish there was a way to let you use my FedEx shipping account to get lower rates. But when I asked about a year ago to help someone else out, I was told that I'd be liable for any damages or anything like that. And with these being bigger boxes, that might be an issue.
Not sure what shipping company you plan on using, but that 70lb figure is the magic weight for FedEx. Once you go over the shippers weight ceiling, rates jump very fast and it does end up being cheaper or the same price to ship in 2 smaller packages. Plus it would be safer. 75+lb packages get rolled and flipped a lot versus picking them up. And if they are picked up, most won't be sitting them down lightly, they just drop them.
I've been lucky to have no damages on those big boys, and some people send me photos of the package when it arrives.....looks like it went through a war zone. But they still made it okay. The secret is pallet protectors on the corners and foam! biggrin.gif
Erich H is offline
post #210 of 2576 Old 02-11-2014, 06:09 PM
Erich H's Avatar
Liked: 1775
Rick
I can convert the ported 15's over to an 18" model with a little work if there is demand. But I don't want to steal Mr. Chalugadp's thunder right now.
Erich H is offline
Closed Thread DIY Speakers and Subs
