MartySub Flatpacks - Page 81 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #2401 of 2576 Old 04-10-2014, 09:49 PM
tgeorge34's Avatar
Quoted: 25 Post(s)
Liked: 24
^^^^^ I will be!
tgeorge34 is offline
post #2402 of 2576 Old 04-11-2014, 11:58 AM - Thread Starter
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1509
Finished
Taking it home once paint drys. I only get 8 this building faze for about 2 months every 3 to 4 years. Then I hibernate.
Troglidite and cessna1466u like this.
chalugadp is offline
post #2403 of 2576 Old 04-11-2014, 12:01 PM
cessna1466u's Avatar
Quoted: 117 Post(s)
Liked: 203
Wow, do you have a flat pack price for this yet? biggrin.gif Did you post what kind of woods you used? Is that ply with banding on the front?
cessna1466u is offline
post #2404 of 2576 Old 04-11-2014, 12:18 PM
scstockwell's Avatar
Nice! You might even be able to sell a matching flat pack bundle (sub/cabinet) now wink.gif
scstockwell is offline
post #2405 of 2576 Old 04-11-2014, 12:52 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
Kind of used up the woods I had in shop. Sides are maple and oak. Top is oak and mahogany. Front is strips of oak I cut. Shelves are plywood.
Since I don't have a 24" planer it's a lot easier attaching these 3/8" veneer strips.
I will be offering a flatpack of veneer strips in about a month. Cost would be around 150 bucks for martycube, and around the same for a pair of tempests.
cessna1466u likes this.
post #2406 of 2576 Old 04-11-2014, 01:52 PM
uopdrmark's Avatar
Quoted: 62 Post(s)
I am trying to figure out a new build with some modified martysubs to be only 15'' deep if possible behind a screen. Maybe 15"x40"x48'' with a port tune around 15. So first question is: Are those dimensions possible? Also, would it be ok to have the driver pushed up into a corner of the box vs in the center?
My room is 20'x21'x10' and I am planning on 4 of them built into a baffle wall at 1/4 spacing for best room response as suggested by others here. After get winisd setup I was thinking 4 UXL-18's or even 4 daytons would be way more than enough with the UXL's having 130dbs at 20hz. Then I realized my seat is about 4 meters back from the screen so I adjusted this in winisd and now I'm wondering if 4 will really be enough. So, I went back and looked at the AVS ULF thread and I'm even more confused. It says it is measured at 4m and when you put in 4 sealed UXL-18's it says they'll do 110dbs at 10hz. On winisd it shows more like 99dbs at 10hz if LP is at 4m. So which one is right? If I change the LP in winisd to 1m they seem to match the ULF thread much better so I'm just not sure which one is a better predictor of what kind of headroom to expect in my actual room.
uopdrmark is offline
post #2407 of 2576 Old 04-11-2014, 02:22 PM
tuxedocivic's Avatar
Quoted: 1926 Post(s)
Liked: 1750
If you're looking at WinISD it's talking about half space anechoic response. Down at 10hz there's so much constructive intereference (room gain) that you're often more than 10db in excess of the WinISD prediction. If you want ULF, the martysub isn't an effective choice. If you want SPL, it's a good choice. The UXL-18 is a great sealed sub. Really really good. Should get you near reference levels down to 5hz if you have a good room gain profile.
Ryan
tuxedocivic is online now
post #2408 of 2576 Old 04-11-2014, 04:03 PM
uopdrmark's Avatar
Quoted: 62 Post(s)
I'm not really too concerned about getting to 5hz but I was hoping to build something big enough to get the port tune down to 15hz. Below that I'm not really too concerned. I will definitely be going with 4 subs and it just looks like you loose so much spl going sealed just to get those single digits. I want to be able to hit 120dbs at 15hz if possible and I'm not too worried about anything lower.
Do you think that is possible with 4 UXL's in 15''x40''x42 ported boxs with a 15hz tune?
post #2409 of 2576 Old 04-11-2014, 04:43 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
At home
tgeorge34 likes this.
post #2410 of 2576 Old 04-11-2014, 04:59 PM
bluer101's Avatar
Quoted: 353 Post(s)
Liked: 285
Very nice. I like the 2 tone. I contemplated on doing black and natural oak on my stand.
I wish I had more of a workshop here at home. Right now I use a garage/office for shop. After the office gets closed my dedicated theater gets started, yippee.
If anyone is interested I posted new photos and build today for my projector screen valance.
http://www.avsforum.com/t/1526213/tv-projector-screen-console-build/0_60#post_24597723
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #2411 of 2576 Old 04-11-2014, 05:27 PM
Quoted: 117 Post(s)
Liked: 203
Looks awesome Donny, great work. Take the weekend off and watch some movies. Then on Monday you can start on the next project that will wow us. Maybe you can paint the inukes?smile.gif I will have the pictures and thread up this evening/tomorrow morning. It came out really nice.
post #2412 of 2576 Old 04-11-2014, 05:42 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
Thanks ,
Look forward to your thread. My right rear Polk speaker is partially blown. Thinking of getting the fusion 6. Then later might move them to my computer lab if I want to get some coaxials for surrounds.
post #2413 of 2576 Old 04-11-2014, 05:57 PM
Quoted: 117 Post(s)
Liked: 203
I am in love with the MTMs. I placed it on top of the marty cube yesterday and it looked very menacing in all black Duratex with the flat black speakers. I set it down where its going now and it ain't moving. This thing is a beast. I ran YPAO on my Yamaha receiver to set up the levels and distance and such and it set the center channel at -10 which is the lowers it can go. It set the front mains at +3 this is just to get them to be close enough in levels. The sound is beautiful and sounds like you are there. Played some Blink 182 and some Passenger and the guitar solos are amazing. Felt as if they were playing in my living room. I will be doing 2 more MTM for the fronts running vertical on top of the cubes, or if I get brave AKA (Wife gives me permission) I might consider the Fusion-12 Tempest. I will then do the coaxial for the surrounds. Can't wait to get it all dialed in. Here is a shot of the MTM I have the waveguide blocked because I am not proud of it at the moment. I messed it up and have another on order.
post #2414 of 2576 Old 04-11-2014, 06:07 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
C'mon cess , let us see it !!!!
Yeah I love.my mtm as well.
post #2415 of 2576 Old 04-11-2014, 06:12 PM
Quoted: 117 Post(s)
Liked: 203
Keep in mind that I tried Dura text on it to make it blend in and I talk to you and realized it was a bad idea so I tried removing it. It wouldn't come off with just water or sandpaper so I used paint remover which of course started to melt the plastic. LOL I threw it away and ordered a new one but wanted to try it so I took it out of the trash and plugged it in.
post #2416 of 2576 Old 04-11-2014, 06:16 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
I thought it would have a big gouge. Right now my mtm is vertical and I didn't finish the bottom cuz I thought it was going to stay horizontal. It looks real ugly.
Hold tight until the GTG like. And use it to audition the tempests and others.
post #2417 of 2576 Old 04-11-2014, 06:20 PM
Quoted: 117 Post(s)
Liked: 203
I did the same with my Marty cubes I left the bottom unfinished so it would slide better on the carpet. I don't think I'm going to have a choice but to wait five show up with any more new speakers I'm going to be sleeping on the sofa for a while.
post #2418 of 2576 Old 04-11-2014, 06:32 PM
kevings's Avatar
Quoted: 294 Post(s)
Liked: 457
Donny,
This turned out GORGEOUS!  You could probably flatpack something like that, and make yourself some $$$.
You know what else......Im starting not to like this thread, because i want to just relax for a bit now and just watch some movies  / enjoy the new subs, but every time i come in here, i feel myself saying "  I'd love to give something like that a try" or im looking at cessna's pics, and saying to myself..."i bet that new center he's got sounds amazing....i think i want one"
whats the next thing to be produced by the donny wood co.?  End tables, new wall unit, sofa table? : )
kevings is offline
post #2419 of 2576 Old 04-11-2014, 06:33 PM
Sibuna's Avatar
Quoted: 375 Post(s)
Liked: 429
http://www.amazon.com/Waxman-4602295N-Self-Stick-Sliders-Oatmeal/dp/B000SL3SEG/ref=sr_1_6?s=hardware&ie=UTF8&qid=1397266379&sr=1-6
Sibuna is offline
post #2420 of 2576 Old 04-11-2014, 06:51 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
Originally Posted by kevings View Post
Donny,
You have contributed a few of your own nice pieces. smile.gif:sly:cool.gif
post #2421 of 2576 Old 04-11-2014, 09:37 PM
Quoted: 117 Post(s)
Liked: 203
Watching a movie tonight with the 6000 and dare I say it, it's too much bass. I know I need to eq it but as far as levels you guys think it's best to lower the gains on the amplifier or lower the sub level on the receiver?
post #2422 of 2576 Old 04-11-2014, 09:48 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
I use the bass trims on my preamp to turn the bass up or.down a bit. Don't know if your yammy can do that easily.
post #2423 of 2576 Old 04-11-2014, 09:56 PM
Quoted: 117 Post(s)
Liked: 203
I have a couple options, the subwoofer level which is set to 0 right now and then this but the "bass" on here is only for the mains I think, not the sub.
post #2424 of 2576 Old 04-11-2014, 10:05 PM
RexST's Avatar
Liked: 25
I tried to adjust the sub trim on my Sherwood R972 by turning Trinnov off and boosting it by 5 and it was a disaster. Martycube started making popping sounds with only the first light on, on the Berry. Took the driver off and peeled the sealing foam off thinking it was an air leak. Turns out after re-engaging Trinnov problem was fixed even at 3 lights on. Wonder what the hell is going on...
RexST is offline
post #2425 of 2576 Old 04-11-2014, 10:05 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
Whatever is easiest will work. I love my remote cuz it has this
On the fly adjustments for all speakers. If your remote doesn't have this then turn gains down a bit. Once you get your mic back you can eq it back.
post #2426 of 2576 Old 04-11-2014, 10:09 PM
Quoted: 117 Post(s)
Liked: 203
post #2427 of 2576 Old 04-11-2014, 11:22 PM
Quoted: 117 Post(s)
Liked: 203
Maybe Kevings will chime in soon, I know he has a Sherwood as well. I don't know anything about that brand.
post #2428 of 2576 Old 04-12-2014, 12:34 AM
kevings's Avatar
Quoted: 294 Post(s)
Liked: 457
kevings is offline
post #2429 of 2576 Old 04-13-2014, 12:15 PM
RexST's Avatar
Liked: 25
Not a huge deal as it works perfect with Trinnov on. I just thought I'd mess with trims for fun. I can always turn gain up in amp I guess.
RexST is offline
post #2430 of 2576 Old 04-13-2014, 12:28 PM - Thread Starter
chalugadp's Avatar
Liked: 1509
Just a bit of an update.
I am still offering marty flatpacks but I understand people waiting for Erich's Stonehenge. I am really loving my hardwood additions to my living room. Equally important is my wife really likes the look of wood over painted black boxes. She says it much more warm and beautiful.
I am currently working with cessna1466u on an 3/8" veneer for his new fusion mtm. Will be shipping him the first veneer flatpack. He is my guinea pig and we will try to work out and kinks to this process.
I will be putting a mahogany veneer on my mtm as well. What I found with the Stereo cabinet project is that the lexel along with a few well placed 1" brad nails works fast and well. The brad nails can be filled easily and are not noticeable if you do it right.
Since shipping will be a fraction of what the subs are I can offer these flat packs for a real good price. People can pick their desired wood. I get a good price from a local place. Doesn't take me long to prepare the wood or box them either.
Closed Thread DIY Speakers and Subs
