MartySub Flatpacks - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #2431 of 2576 Old 04-13-2014, 03:03 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
Originally Posted by chalugadp View Post
Whatever is easiest will work. I love my remote cuz it has this
On the fly adjustments for all speakers. If your remote doesn't have this then turn gains down a bit. Once you get your mic back you can eq it back.
How do you like that Emotiva pro?
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #2432 of 2576 Old 04-13-2014, 03:16 PM - Thread Starter
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
Love it. Wanted a bit more top end from speakers sore just dialed in peq from 4 to 11 k and gave it a little boost. So many options.
chalugadp is offline
post #2433 of 2576 Old 04-13-2014, 03:50 PM
tgeorge34's Avatar
Quoted: 23 Post(s)
Liked: 24
I know this thread is about the martycube, but I have been following this thread and since I love the performance of my martycube vs previous subs, I trust your guys recommendations.
Is the performance/price similiar with the diy speakers vs commercial speakers?.I see you guys mention the tempest, 1099 , etc. I was in market to buy some aperion audio speakers, but if the performance of diy is better than those, than I would be crazy to not try that route. I read the specs, but those dont always tell the full story of sound quality from a speaker.
for those that have built your own speakers, you think it is well worth it?
Do the kits for the tempest, 1099, include the box, or is it just the baffle and components?
tgeorge34 is offline
post #2434 of 2576 Old 04-13-2014, 03:57 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
None of the kits include the boxes, it's just the baffles. But Erich does offer a flat pack cabinet for the Tempests plus pre-assembled crossovers so that makes putting them together extremely easy.
jbrown15 is offline
post #2435 of 2576 Old 04-13-2014, 03:59 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
The aperion top speaker is 2k for the pair. I have a tough time thinking it's better then the tempest or 1099. I know at reference level aperion would be near it's limit and the diy want to go louder.
Three tempests or 1099 plus two volt 10 or fusion 6 with flatpacks would be similar price to 2k pair. The only area where aperion has real edge is in looks. But that's where my veneer flatpacks come in tongue.gif
If i was going commercial route at cheap price I would go for emptek speakers. Most people find that for movies once you go waveguide, you never go back.
post #2436 of 2576 Old 04-13-2014, 04:40 PM
brian6751's Avatar
Quoted: 861 Post(s)
Liked: 640
totally agree. i have never heard Aperions new Verus speakers but i owned almost every one of their old Intimus line and every Bravus sub. the Tempests or 1099 are in a totally different league. The Aperions are very warm sounding. The SEOS are clear as day.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #2437 of 2576 Old 04-13-2014, 05:21 PM
tgeorge34's Avatar
Quoted: 23 Post(s)
Liked: 24
Ok. So it sounds like the performance difference of these diy speakers are similar to the marty cube vs commercial speakers.
Before I go all out and re-do my whole stereo system and replace something I already have, I think I will try some bookshelf speakers. I need something small, only gonna be able to do 2 channel stereo. Its for our "formal" living room. Had to talk the wife into even letting me do this!
I was looking at the alpha 8 minions. Any reason not to go this route?..any other suggestions? I just picked these cause I watched the video on the website and the clarity and output was insane, even for outdoors like in the video.
Also, the flat pack you can order with it is baltic birch. Not real familiar with wood/stains, but can you stain this to give it a similar look to cherry wood? Just trying to see if I can get close to matching the cabinets that these will be sitting on.
post #2438 of 2576 Old 04-13-2014, 05:42 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
I went the same route. Started with minions. They are great. Then bought fusion mtm. If i was to do it again I think I would buy the fusion 8 instead of minions. A little cheaper and the midrange is a little nicer I think. Jeff is a wizard with his voicing.
The seos or eos are so clear and powerful.
post #2439 of 2576 Old 04-15-2014, 06:22 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Lemans,
Have you finished your sub yet ? How does it sound ? Other people want a sub that size.
post #2440 of 2576 Old 04-15-2014, 06:56 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Received a little gift from kevings today.
I love the address he used
post #2441 of 2576 Old 04-15-2014, 07:04 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Lol!!! Just primered and painted the sub flat black over the weekend. Want to do one more coat over the coming Easter weekend as it is cold again!!
I talked to Mark about ordering a uxl-18 and it looks like they will not be in stock until early June!!
So...no sound until then.
I will post some picks over the weekend once its fully painted to my liking.
I used 3 coats of BIN primer/sealer with sanding 120 grit between coats.
I then painted 2 coats of Tremclad flat black with sanding 220 between.
Came out great and want one more coat to make sure it looks perfect.
I wish I used more wood filler as I can still see some screw heads if I look very closely.
Luckily wont see any of this from a distance. A lot of work but I think it looks much better than Duratex...
lemans24 is offline
post #2442 of 2576 Old 04-15-2014, 07:08 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
I'd die waiting that long. Thanks.
post #2443 of 2576 Old 04-15-2014, 07:17 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
I know but luckily I have lots of patience!!! I really wished I had gotten in on the uxl-18 group by but...such is life!!
I showed my neighbor the sub I was painting in my garage and he was not too happy!!
Can't wait to build the next sub and piss off all the neighbors around me!! Lol
Definitely have plans for more of your services once I am enjoying this sub in my living room.
The veneer that you have designed would look really good on some speakers too.
I also will want some speaker stands too!! This hobby is expensive!!
lemans24 is offline
post #2444 of 2576 Old 04-15-2014, 07:19 PM
jbrown15's Avatar
Liked: 1993
jbrown15 is offline
post #2445 of 2576 Old 04-15-2014, 07:27 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Just working out the kinks with cess. Here's a pic
Shipping out first veneer pack Friday. Once we have it figured out and instruction booklet for people I will be taking orders. I will be redoing my center channel with veneer pack.
Also looks like I will be building a curved subwoofer to match someone's funk audio sub. Looking forward to the challenge.
post #2446 of 2576 Old 04-15-2014, 09:40 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
How will you be selling the veneered flat packs?? The veneer will be attached to the MDF already or they will need to be attached after I build the speaker??
lemans24 is offline
post #2447 of 2576 Old 04-15-2014, 10:11 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Veneer attached after built. Just use proper adhesive and clamps and easiest way is brad nails. A belt sander would be perfect but could get away with orbital sander. Takes about an hour per side. Doing the front baffle would need a router. Could leave the front baffle painted black.
post #2448 of 2576 Old 04-15-2014, 10:15 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
The veneer would come in a small box weighing about 25 lbs ( for a martycube). About 30 bucks to ship. Wood cost depends on what you choose. From 35 to 120 bucks depending on maple ,oak ,or walnut ,etc.
post #2449 of 2576 Old 04-16-2014, 09:45 AM
FireDust58's Avatar
Liked: 30
Wow! I've been gone on business travel, and then had my modem die so I had not been on here for the last few weeks. You guys have been busy!
Still lovin' the cubes. Watched Enders Game earlier this week and there were some pretty sweet scenes where the whole floor was shaking. I definitely think I'm happier with these cubes over something like a VTF-15 or other similarly priced sub that I was looking at and, of course, I built this myself! So, while it may be ugly, its extra cool cool.gif
FireDust58 is offline
post #2450 of 2576 Old 04-16-2014, 10:03 AM
cessna1466u's Avatar
Quoted: 111 Post(s)
Liked: 201
cessna1466u is offline
post #2451 of 2576 Old 04-16-2014, 11:12 AM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 453
hahaa!!!  Glad they got there ok / and that you like them.
I just got back from Canada last night, actually.  I would have got in touch with you but it ended up being a quick trip ( got in Monday, met with Bestbuy's Canadian corporate office on Tues, flew back home right after that, back in CA / orange country by 11pm ).
Vancouver is GORGEOUS ( my 1st time there / now I see why it's often mentioned as one of the world's 10 most beautiful cities )
here's 2 pics i snapped from the hotel room....
kevings is offline
post #2452 of 2576 Old 04-16-2014, 11:14 AM
jbrown15's Avatar
Liked: 1993
jbrown15 is offline
post #2453 of 2576 Old 04-16-2014, 12:00 PM
FireDust58's Avatar
Liked: 30
Originally Posted by cessna1466u View Post
Ugly?eek.gif Them are fighting words. Beauty is in the eye of the beholder. I personally like big boned subs. wink.gif
lol, I was more specifically mentioning mine are ugly. The top is not flush, they haven't been painted, no rounded corners etc. I love em, but mine specifically aren't pretty like the rest of yours smile.gif
cessna1466u likes this.
post #2454 of 2576 Old 04-16-2014, 04:10 PM
Peterc613's Avatar
Quoted: 475 Post(s)
Liked: 669
At home
How is the fan noise from those iNuke's in your theater during quiet passages?
Peterc613 is offline
post #2455 of 2576 Old 04-16-2014, 04:15 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Can't hear fan unless volume off
post #2456 of 2576 Old 04-16-2014, 05:08 PM
jbrown15's Avatar
Liked: 1993
[quote name="Peterc613" url="/t/1516724/martysub-flatpacks/2430#post_24614696
[/quote]
You need to do the fan mod on them otherwise then are fairly loud even at idle. But the fan mod is really easy and once done you can't hear them unless you have your ear within a foot or two of the amp.
jbrown15 is offline
post #2457 of 2576 Old 04-18-2014, 09:14 PM
Claybe's Avatar
Quoted: 211 Post(s)
Liked: 81
How many sheets of mdf does it take to build 2 Marty's ?
Claybe is offline
post #2458 of 2576 Old 04-18-2014, 09:22 PM
Quoted: 111 Post(s)
Liked: 201
post #2459 of 2576 Old 04-18-2014, 09:22 PM
4seahorseman's Avatar
I used four 4x8 sheets based on the one-cut plan of LTD . There was a huge pile of sawdust, mdf cuts like butter but is a mess.
4seahorseman is offline
post #2460 of 2576 Old 04-18-2014, 09:24 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
It takes 1.25 sheets to make one Marty cube.
Closed Thread DIY Speakers and Subs
