MartySub Flatpacks - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
Closed Thread
post #2521 of 2576 Old 04-22-2014, 04:05 PM
AlphaPie's Avatar
Quoted: 145 Post(s)
Liked: 373
Originally Posted by chalugadp View Post
I was right in his net gain which is 3dbs for alphapie.
Originally Posted by tuxedocivic View Post
I wasn't even sure if you had it mixed up. I just wasn't sure it was clear. SPL addition is confusing and even more confusing when trying to match power cool.gif Hopefully he'll get it one way or the other. smile.gif
If the power stays the same, he will gain 3db only. If the power is cut in half. He will see no gain (in SPL). If he doubles the power somehow and adds the second sub, he'll see 6db gain.
If you have one sub running at max power and you add another sub and feed it max power, then you have increased SPL by 6db (in a perfect world). At that point there is no other way to increase SPL without adding another sub.
an inuke 3000 has to be bridged cuz one channel cant put out 1400 watts
Basically, for it to be worth id need to upgrade to an inuke6000. Hmm.
7.2 w/front wides - Pioneer Elite SC-85 - Polk Audio RTi12/CSi3/RT25i - DIY Dual 12" subs/Behringer Inuke3000 - Monster Power 2500
Sharp Aquos 60" - Xbox One - Sony BRP - Plex Server
AlphaPie is offline
post #2522 of 2576 Old 04-22-2014, 05:16 PM - Thread Starter
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
3 dbs for bass is significant. For a huge increase then yes the inuke 6000 will be a help.
chalugadp is offline
post #2523 of 2576 Old 04-22-2014, 05:25 PM
tuxedocivic's Avatar
Quoted: 1903 Post(s)
Liked: 1724
There are other advantages other than 3db. In general, one sub is never a good idea. Two or more are required for smooth response in room.
Ryan
tuxedocivic is online now
post #2524 of 2576 Old 04-22-2014, 07:40 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Started the curved sealed sub build. Couple of pics
Use flush trim bit to get exact copies. Then tomorrow I will bend 1/8" pieces (six of them) around this mold
Will have pics tomorrow of finished curved sides.
Troglidite likes this.
post #2525 of 2576 Old 04-22-2014, 07:41 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Looked at curvomatic and until I saw the price was pretty excited. Only worth that amount if you are doing a lot of bending.
post #2526 of 2576 Old 04-22-2014, 07:47 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
awesome wood working!  looking forward to seeing the progress!
kevings is offline
post #2527 of 2576 Old 04-22-2014, 09:04 PM
zeus33's Avatar
Quoted: 1328 Post(s)
Liked: 986
? Into 2 ohms it does 1500 per channel.
Delivers 2 x 1500 Watts into 2 Ohms; 2 x 900 Watts into 4 Ohms; 3000 Watts into 4 Ohms (bridge mode)
zeus33 is offline
post #2528 of 2576 Old 04-22-2014, 09:13 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Those are the manufactures specs, I think a iNuke 3000 puts out about 2200watts @ 4ohms bridge. I say that based on the fact that the 6000 version does 2200watts @ 4ohms per channel and the 6000 is basically two 3000's in a single chassis.
jbrown15 is offline
post #2529 of 2576 Old 04-22-2014, 09:13 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Those are not real world specs. its more like 1100 watts instead of 1500 and 4 ohm bridged is 2200 watts. Behinger inflates there specs.
post #2530 of 2576 Old 04-22-2014, 09:17 PM
zeus33's Avatar
Liked: 986
I know they are embellished, but those are the specs that most people use. Based on his post, it sounds like those are the specs he is using. I'm curious, what does the limiter (supposedly) go up to in the 3000?
Originally Posted by AlphaPie View Post
I'm considering building a second and running them both in stereo off of a single inuke3000. Not sure how much of a change in output from running a single 460ho at 1400 watts..
It sounds like he is using one channel now and he wants to add a second using the other channel making it "stereo". So I'm "assuming" he is implying that he gets 1400 per channel. However, realistically, he would get 1100 to each sub if the ohm load is correct to maximize the power.
zeus33 is offline
post #2531 of 2576 Old 04-22-2014, 09:32 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
In stereo with single voice coil he can only get 600 watts per channel out of the inuke 3000. If he had dual voice coils he could wire it to get 1100 watts a side. The limiter for the inuke goes up to right near the full power which is 2200 watts. You could dial it in to get 2000, 1500, 1000, etc. Or 1347 watts if you like. Its very flexible.
post #2532 of 2576 Old 04-22-2014, 09:37 PM
zeus33's Avatar
Liked: 986
Thanks for the info!
zeus33 is offline
post #2533 of 2576 Old 04-22-2014, 09:38 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
No problem, love your username "hail Zeus"
post #2534 of 2576 Old 04-23-2014, 12:33 AM - Thread Starter
chalugadp's Avatar
Liked: 1505
Just so this jig for cutting circles with my laminate router
Going to make this tomorrow. My current jig isn't as precise as this.
post #2535 of 2576 Old 04-23-2014, 11:16 AM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 140
Does anyone know if the limiter on the inuke amps is based off of actual watts? I have the 6000dsp so if I set a limiter for 1 channel for 2200 watts am I actually getting 2200 watts or have I now limited it to 73% of 2200 watts(since that is max. watts it puts out at 4 ohms)? I guess you wouldn't set a limiter if needing 2200 watts at 4 ohms but what about if you needed 1100 watts?
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is offline
post #2536 of 2576 Old 04-23-2014, 12:11 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Mike
93.8Vp is 1099.8 watts in 4ohm bridged mode. Thats the setting you want to use for 1100 watts. cool.gif
post #2537 of 2576 Old 04-23-2014, 01:10 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 140
Gotcha! Thanks
mbw23air is offline
post #2538 of 2576 Old 04-23-2014, 01:21 PM
tgeorge34's Avatar
Quoted: 23 Post(s)
Liked: 24
Thinking of something like this for tower build
Just an initial design. Want something on wide base with sand in it. Like the rounded top.
That would be sweet!...not sure if my skills are to that level, but if you do it, take lots of pics in case I get up the courage to try!
tgeorge34 is offline
post #2539 of 2576 Old 04-23-2014, 05:04 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
^^ thanks. It will be a while before I'm ready to buy. This week has been busy with martycube orders. Five orders in the last few days. Did a little more on the curved build today. Got both curved sides glued.
Tomorrow will router all pieces and should have them ready to assemble Friday.
post #2540 of 2576 Old 04-23-2014, 05:11 PM
jbrown15's Avatar
Liked: 1993
jbrown15 is offline
post #2541 of 2576 Old 04-23-2014, 06:17 PM
Troglidite's Avatar
Some wood working questions on curved sides on cabinets:
1. Did you steam the wood to make plywood panels follow the curved frame?
2. I don't see clamps in the center of the cabinet, how did you keep the center from creating a bubble.
3. How do you keep that round part of the clamp from denting the surface of the wood with all of that pressure on those clamps?
4. And last but now least, where do you get the clamps that are strong enough to handle that much pressure on curved cabinets without braking the clamps?
Man that is a lot of clamps! Your arms & hands must be really sore after clamping all of those clamps down on that curved surface! smile.gif
Troglidite is offline
post #2542 of 2576 Old 04-23-2014, 07:53 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
1) no, six pieces 1/8" thick for a total of 3/4".
2) pulls tight around mold with no bubbles.
3) not that much pressure down on wood. Can easily hold it down with hands.
4) f clamps can tighten down with tremendous pressure. They are heavy duty. I have 30 of them. I was a little tired after putting on the last one tongue.gif
post #2543 of 2576 Old 04-23-2014, 08:17 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
kevings is offline
post #2544 of 2576 Old 04-23-2014, 08:27 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Thanks, will look a lot more like a subs soon.
post #2545 of 2576 Old 04-24-2014, 01:02 AM
Yukichon's Avatar
Quoted: 145 Post(s)
Liked: 59
That's pretty amazing, I wish I had paid more attention in word work classes when I was at school
Yukichon is offline
post #2546 of 2576 Old 04-24-2014, 05:30 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Got the front, bottom, and sides together. Used gorilla glue. Amazing how that stuff expands.
post #2547 of 2576 Old 04-24-2014, 05:42 PM
jbrown15's Avatar
Liked: 1993
Remember how much we were cursing with getting that Gorilla glue all over our hands when we built my first sub, and how it wouldn't wash off because its water proof!....lol
jbrown15 is offline
post #2548 of 2576 Old 04-24-2014, 05:57 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
Had a couple of students give me. A hand. One got some on his thumb. Fills all your mistakes tongue.gif
post #2549 of 2576 Old 04-24-2014, 09:09 PM
Boxozaxu's Avatar
Quoted: 455 Post(s)
Liked: 295
It's really coming together nicely.  I'm intrigued by the idea of using forms myself and I'm wondering how you trimmed up the edges.  I guess I'm curious how you keep the curves symmetrical/same after trimming them.
Boxozaxu is offline
post #2550 of 2576 Old 04-24-2014, 09:43 PM - Thread Starter
chalugadp's Avatar
Liked: 1505
For the front of the curved sides I used a block plane to get a flush fit with it to the front baffle. The curve at the back was a bit more than anticipated and I needed to change the angle by 5 degrees. Tomorrow I put the back on and then the bracing and top. That just leaves the veneer work left.
Closed Thread DIY Speakers and Subs
