3 Danley DTS-10 Modded (TC Sounds LMSR 12 ) plus 2 Othorn - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 90 Old 03-09-2014, 06:28 PM
notnyt's Avatar
Quoted: 2791 Post(s)
Liked: 2575
Originally Posted by kutlow View Post
according to REW hdmi is supposed to be the easiest. This is a case of bad software design. It should work when you download the required stuff. Plus whats up with a mic you have to smash to get to plug into. Im just not use to junk
Sounds like a driver issue on your laptop if HDMI audio output is not listed under playback devices. This isn't REW's fault. See this thread.
http://h30434.www3.hp.com/t5/Notebook-Display-and-Video/No-HDMI-audio-out-in-playback-devices-HP-G60-234DX/td-p/181276
notnyt is offline
post #62 of 90 Old 03-09-2014, 07:17 PM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
Ok I was able to get it using the microphone jack and rca cable. Now I need to figure out how to post the graph.
kutlow is offline
post #63 of 90 Old 03-09-2014, 07:49 PM
BadmanSound's Avatar
press prntscreen button. open microsoft past. ctrl v. pos screenshot (crop if necessary)
BadmanSound is offline
post #64 of 90 Old 03-09-2014, 08:28 PM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
kutlow is offline
post #65 of 90 Old 03-09-2014, 08:29 PM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
how do I fix that huge suck out 25-50? I cant move my subs . What should I do now?
kutlow is offline
post #66 of 90 Old 03-09-2014, 10:04 PM
notnyt's Avatar
Liked: 2575
btw, theres a little picture of a camera at the top left of the graph window, you can use that for getting a capture.
As for the dropout, what are the dimensions of your room? Where are the subs located? Where is the listening position?
notnyt is offline
post #67 of 90 Old 03-10-2014, 04:20 AM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
my room is 15 foot wide 21 foot deep and the listening position is 14 foot back from the front wall. My 3 danleys are at the front of the room facing the sitting position. I have them behind the screen with the ports firing under the bottom of the screen. I cant move them because no room. I just need to apply filters to make it the best I can.
kutlow is offline
post #68 of 90 Old 03-10-2014, 04:23 AM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
this graph is with none of Tom Danleys required filters and everything bypassed including the highpass filter.
kutlow is offline
post #69 of 90 Old 03-10-2014, 04:29 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Have you done the reverse math type thing to see if you have a reflection due to some sort of boundary? I can't remember for the life of me how to do the math to see if you are dealing with a boundary induced reflection....
Martycool007 is offline
post #70 of 90 Old 03-10-2014, 04:42 AM
notnyt's Avatar
Liked: 2575
I'd say make sure all of your subs are wired in phase, but it seems your couch is positioned right at a room node due to the length of the room.
Try measuring 3.5' closer, see if it's smoother.
notnyt is offline
post #71 of 90 Old 03-10-2014, 07:36 AM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
Here is a graph after applying REW filters . We selected a max of 9db on the filters. Audessey is also ran after the filters from REW. Maybe we should set the filters up to say +-12 db and retry to try to get it flatter?
rewminiaudessey.jpg 68k .jpg file
kutlow is offline
post #72 of 90 Old 03-10-2014, 07:52 AM
MKtheater's Avatar
Quoted: 1757 Post(s)
Liked: 1350
I bet his HDMI cable is directional and it is backwards, if not then it is a computer problem. HDMI allows you to run each channel without moving, 8 individual channels rather than just the right or left plus sub. Now if all you want is to measure the sub than ASIO is not needed. The HDMI also bypasses the sound card in the computer so no cal files needed. That suck out is room or phase related and the reason you feel bass maybe lacking. Does it sound better after the EQ?
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is offline
post #73 of 90 Old 03-10-2014, 07:59 AM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
overlay3micpositions.jpg 60k .jpg file
Here is an overlay with the mic in 3 different positions.
The purple is the current ear/chair position
The Green is the mic moved 1 foot closer to the subs
the Yellow Is the mic moved 2 foot closer to the front of the room closer to subs
kutlow is offline
post #74 of 90 Old 03-10-2014, 08:29 AM
MKtheater's Avatar
Liked: 1350
You just solved your problem, move your seats 1 foot closer.
Marantz 7704
2 Outlaw 7140s
post #75 of 90 Old 03-10-2014, 08:46 PM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
This is with the seats moved up 1 foot and with Tom Danleys filters vs Tom Danley filters plus audessey. This is with no rew
newseat.jpg 68k .jpg file
kutlow is offline
post #76 of 90 Old 03-10-2014, 10:04 PM
notnyt's Avatar
Liked: 2575
move it up another foot =]
notnyt is offline
post #77 of 90 Old 03-10-2014, 10:18 PM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
Originally Posted by Martycool007 View Post
Is there an easier way of doing measurements, (not counting the Omni-Mic)? I was under the impression that a USB mic and a laptop connected via HDMI was the simplest way if doing this??
Yes, OmniMic
Noah
noah katz is offline
post #78 of 90 Old 03-10-2014, 10:20 PM
MKtheater's Avatar
Liked: 1350
Nevermind EQ for now, just move the seats where the best response is before any EQ and go from there. Try audyssey first and I not flat then turn off audyssey and then let REW set the EQ filters for you. That should be enough without Audyssey or Audyssey will be enough.
Marantz 7704
2 Outlaw 7140s
post #79 of 90 Old 03-10-2014, 10:26 PM
MKtheater's Avatar
Liked: 1350
Buying a umik and plugging the computer into the AVR is using REW is just about as easy. The hard part of REW is using analog and external sound cards which you bypass. One just needs to make sure the computer is right. Omni mic uses a disc through your system so you don't have to connect the computer to the AVR.
Marantz 7704
2 Outlaw 7140s
post #80 of 90 Old 03-11-2014, 09:27 AM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
I just had a umik come from Cross Spectrum yesterday. I can't wait to try it out and have more confidence than using the audyssey mic.
JohnDean is offline
post #81 of 90 Old 03-11-2014, 12:22 PM
notnyt's Avatar
Liked: 2575
Take some back-to-back measurements so you can see how close they are wink.gif
notnyt is offline
post #82 of 90 Old 03-11-2014, 01:43 PM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
That's exactly what im doing tonight. REW on my last seating position had my amps clipping. Hopefully this will be better.
kutlow is offline
post #83 of 90 Old 03-13-2014, 07:56 AM - Thread Starter
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
I got a question for you guys who know REW. hOW MANY DB do you allow for corrections? I have mine set for 6 but think I need alittle more.
kutlow is offline
post #84 of 90 Old 03-13-2014, 09:33 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
Kutlow,
I'd suggest you use the same graph standards for all measurements, ... as your submitted graphs are wildly different each time (one being 50dB per vertical division eek.gif. )
Typically subwoofer measuring standards for submitted freq response graphs are; 45dB-105dB, 10hz-200hz, this enables others to quickly and easily compare visually.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #85 of 90 Old 03-13-2014, 12:19 PM
notnyt's Avatar
Liked: 2575
Depends on what's causing the issue and where it is in the fr band.
notnyt is offline
post #86 of 90 Old 03-13-2014, 01:28 PM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
What are you trying to say? ;-)
Should I just go ahead and send this one back? Naaa. It's gotta be better than the old style(flat/puck) mic I'm using.
JohnDean is offline
post #87 of 90 Old 03-13-2014, 01:31 PM
notnyt's Avatar
Liked: 2575
umik is great, love mine, just saying, would be interesting to take measurements using both mics in the same location/settings. I think they will both be real close =]
notnyt is offline
post #88 of 90 Old 03-13-2014, 04:49 PM
MKtheater's Avatar
Liked: 1350
How does the lilmike compare?
Marantz 7704
2 Outlaw 7140s
post #89 of 90 Old 03-13-2014, 10:18 PM
notnyt's Avatar
Liked: 2575
The linkwitz wm61a design (lilmike) It's much flatter, requires less adjustment on the low end. Possibly good to higher spl levels as well. I shocked the one I had a calibration file for and broke it =[
If I'm measuring in REW I'll just use the umik since I have calibration, but for stuff like speclab which doesn't take a calibration file, the wm61a mic is way better. The older audyssey mics are good too. Something I've noticed is my XT32 mic is much more sensitive than the older XT mic. I'll have to update my measurement mic shootout thread sooner or later.
notnyt is offline
post #90 of 90 Old 03-14-2014, 06:58 AM
MKtheater's Avatar
Liked: 1350
Yes, keep it going for the new stuff. You should have it link in your signature as well. As always good stuff!
Marantz 7704
2 Outlaw 7140s
