The Corinthians - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 03-01-2014, 12:49 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Originally Posted by beastaudio View Post
Ok, the wiring has finally sunk in. I get it now biggrin.gif thanks for everyone's patience! Haha It dawned on me finally to wire each pair to the 8 ohm as suggested, and then wire each "Pair" in parallel to achieve an end 2 ohm final load.
Great
Tell me if this hookup diagram is any more helpful than the line diagram I sent you.
If this confuses you in any way, pitch it and use what you do like.
Each subwoofer is a dual (2ohm) coil. In this diagram, each driver is config'd with the internal coils in series.
Thus, each driver represents a 4ohm load.
Each pair of drivers are in series, representing an 8ohm load.
There are four 8ohm loads, all connected in parallel, thus totaling a 2ohm load ... all on one channel of the amp.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
Old 03-01-2014, 01:03 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
it has the positive and negative from the amp coming into opposite drivers, at each end of the circuit, but on the 12 volt calc, it has the positive and negative coming into the same driver, different VC's and series-ing the coils from there to a loop from + to - on the final two VC's of the second driver. Any reason one works better than the other? Like this:
They're the same, if you look again, there's four coils in series, in both images. But, actually the 12v calc one is a bit unconventional, hitting one coil in the next adjacent driver, then coming back thru the other side. It's unconventional, but visually maybe it's simpler because lines don't cross.
Doing so is unorthodox IMO, typically you config the two coils on the same former prior to leaving that driver ... you don't leave the driver then come back thru the other side ... weird. Typically you do it as I showed in both mine and as John showed.
FOH is offline
Old 03-01-2014, 02:30 PM - Thread Starter
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
My drawing. This is each of the terminal blocks that wire to each individual VC inside the box. Glad I did it this way after all this wiring stuff smile.gif I would have had to pull all the drivers after getting this all sorted. I have a fundraiser this evening and have no idea how late it will go, but might have time to start wiring this evening. If not, then itll be tomorrow first thing for SURE!
beastaudio is offline
Old 03-01-2014, 02:59 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Looks good
Your fundraiser, is this a trip down to that über busy intersection, ... standing there soliciting cash with a sign reading "will work for new drivers", is that your idea of a fundraiser?
Dude, just ask man, we'll all help you out.
FOH is offline
Old 03-01-2014, 08:17 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
I tried that sign, people kept asking me who I was chauffeuring around town, or if I was starting a taxi service biggrin.gif Haha. Just got home from the fundraiser for "Housing assistance." And no, it's not my own assistance. Too tired to wire up stuff tonight, especially finishing loading the last box up last night/morning around 4 am. Time for some rest and I will hit the ground running tomorrow biggrin.gif
Old 03-02-2014, 05:21 AM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Originally Posted by FOH View Post
Great
FOH...this means power going to each driver would be one channel of beast's amp rated at 2 ohm single channel divided by eight?
blah450 is offline
Old 03-02-2014, 06:18 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
That's the config he's striving for.
~456w/driver
Then he can use the other channel for the monster band-pass sub in the rear of the room.
FOH is offline
Old 03-02-2014, 06:42 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
"John, on your drawing, it has the positive and negative from the amp coming into opposite drivers, at each end of the circuit, but on the 12 volt calc, it has the positive and negative coming into the same driver, different VC's and series-ing the coils from there to a loop from + to - on the final two VC's of the second driver. Any reason one works better than the other? Like this:"
the car stereo diagram has the 2 VOICE COILS wired in PARALLEL, 2 ohms per coil, gives 1 ohm net per driver.
then it has the 4 DRIVERS, 1 ohm net per driver, wired in SERIES to produce a net of 4 ohms total.
other method:
my picture had the 2 VOICE COILS wired in SERIES, 2 ohms per coil, gives 4 ohm net per driver.
the it has 2 DRIVERS wired in SERIES, 4 ohms per driver, to produce 8 ohms per PAIR
then it has the 2 PAIRS, 8 ohm net per PAIR, wired in PARALLEL to produce a net of 4 ohms total to the amp.
there are reasons why my suggested plan will be better, at least in theory. from a practical perspective, the only way to know would be to test.
Listen. It's All Good.
LTD02 is offline
Old 03-02-2014, 10:01 AM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Yours and Kevin's drawings, and mine actually all align at this point smile.gif I am about ready to finish up the wiring shortly smile.gif Then I need to recruit some buds that take payment in buds and tuna steaks to help me lift them up onto the danley's.
Old 03-02-2014, 12:52 PM
H8TWRK's Avatar
Dude I wish I was in Ashvegas this weekend, but I'm sick as he!! and laying at home trying to survive the freakin flu. I hope to come see the Corinthians soon though. I'm sure i'll be up in the next mont or so.I'm overdue refreshments from the Wedge, Asheville Brew, and Frog Level biggrin.gif
H8TWRK is offline
Old 03-02-2014, 03:08 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
You missed a very fun, but interesting Mardi Gras parade that we just attended. Pisgah Pale in hand, we had a pretty good time with our whole kickball team, "Pitches Be Crazy."
Old 03-02-2014, 04:01 PM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
lol
chrapladm is offline
Old 03-03-2014, 06:21 AM
H8TWRK's Avatar
Oh man , I think I may live through this after all! I wanted to come up this past week, but sickness doesn't follow your schedule, you follow it. Its always Hmm, interesting downtown. Thats why i love it so. Maybe in about five we can be neighbors. If not then, after retirement for sure.
BTW, the snow Throne is da bomb!!
NITRO STOUT FOR ME PLS!
H8TWRK is offline
Old 03-03-2014, 09:18 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Man I am late to the party but finally joining in.
Gorilla83 is offline
Old 03-03-2014, 06:27 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Welp, I have all 8 running. It is intense to say the least. I have just been playing them by themselves for a little while, and I can get things moving all over the entire house. I don't even have the other two boxes mounted on top yet, they are just sitting in front of the bottom two. Getting them up top should clean up the response obviously a little better in the time domain, but man......I have already put the peavey into protection a couple times just seeing what one channel is capable of. I still wish I could run 4 per channel at 2 ohm as the drivers are still just loafing when I am running into the limits of the amp, but at that point, I am at reference with the subs almost 10dB hot, so I can't complain too much there.....AND I don't have the shadow OR the 2242's running. Right now I have the DCX out of loop too so there is no EQ. I need to get that back in the mix and start dividing up the FR with the Shadow and SI's taking care of the low end and the 2242's handling something like 40-50hz up to the XO point which is currently set at 100 or 120hz. Just playing right now until I pop the boxes up top, but having a WHOLE lot of fun wink.gif
Old 03-03-2014, 06:52 PM
LTD02's Avatar
Liked: 2576
nice work. cabs look REALLY good under the danleys with the matching width. the top subs are just going to be insane.
LTD02 is offline
Old 03-03-2014, 09:18 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Thanks man!
My nice view as I close out the listening for the night. Man I like this sight! Seeing a few of the woofers is a whole lot of fun, but I can't get the screen back up until they are stacked biggrin.gif
Old 03-03-2014, 11:44 PM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
I dont know why but I really like the look of the JBL cabinet. Something about it.
Old 03-04-2014, 04:45 AM
ChopShop1's Avatar
Quoted: 293 Post(s)
Liked: 289
Still can't get over how the cabinets look dude..fantastic! Great plan, great execution and more great results to follow I'm sure. What's the deal though dude, why didn't you just throw those cabs up top last night?? tongue.gif
beastaudio likes this.
ChopShop1 is offline
Old 03-04-2014, 05:42 AM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
I need some muscle biggrin.gif I ain't lifting these behemoths on my own smile.gif Move aside Submersives, the Corinthians are in town!!!
Just get Megan and a bunch of her friends to do the heavy lifting for you...
C'mon man...think outside of the box. Like this guy...
beastaudio and Gorilla83 like this.
popalock is offline
Old 03-04-2014, 06:55 AM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Haha, they sounded fine where they were sitting smile.gif Those things are not light!
If they are wanting to get over here Monday evening for the Bachelor finale, they might have to end up doing it themselves. Now that would be a sight.
Old 03-04-2014, 07:10 AM
LTD02's Avatar
Liked: 2576
"I dont know why but I really like the look of the JBL cabinet. Something about it."
maybe it is the light. maybe it is the proportion. its baffle proportion is close to the golden ratio. the woofer location is close to the golden ratio. who knows.
LTD02 is offline
Old 03-04-2014, 05:39 PM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
I think it is all the above. Lighting ratio and all.
Old 03-05-2014, 03:06 PM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
So, I don't want to bust up Jbrown's thread with any more questions, but I have sourced some Linacoustic or the like that I want to pop on my front wall and up to the screen on the sides. I have found 1.5 inch and 2 inch locally for a decent price but no 1 inch.
I have also gotten the suggestion to do 1 inch, with 3mm "poly" which I assume is short for polyester?!?! and then another layer of 1 inch Linacoustic on top of that.
I felt like just tacking some 1.5" on there and calling it a day would be fine. I also think that the 5 2x4x2 inch panels of the front wall are probably close to being efficient enough on their own hand. Anyways. What do yall think? Get the 1.5" linacoustic and make a nice reflection-free space back there and call it a day?
Old 03-05-2014, 04:35 PM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
Luke Kamp is offline
Old 03-06-2014, 08:38 AM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
beast....3mm poly is 3 mil thick polyethelene plastic...someone mentioned earlier some good places to look...comes in rolls or folded...also Home Depot or Lowes paint departments is a good place to look...both like to have the material there to be used as drop cloths.
blah450 is offline
Old 03-06-2014, 09:16 AM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Yep, found some smile.gif I need to decide now if I can manage two layers of 1.5" thick, or if I should stick with 1" and 1". I can get the 1.5" today and start work on it tonight if so. If not, it will be next week before I could get going and that won't make the lady too happy with all her girls coming over to watch the Bachelor finale Monday night :/
Old 03-06-2014, 09:19 AM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Who is a good room treatment guru around here to get a quick answer from? I have talked a little with the GIK dudes, but the 1" ply 1" approach is an erskine design, and I really can't see how an extra inch of absorption would really affect anything that negatively. How are guys attaching the duct liner to the walls also?
Old 03-06-2014, 10:23 AM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
The extra inch of thickness is only an improvement in this context, IMO.
HopefulFred is offline
Old 03-06-2014, 10:51 AM - Thread Starter
Point Source
beastaudio's Avatar
Liked: 2826
Yep, my thinking too. I can't see any detriment other than taking up more space, and costing a bit more $$
