The Legend of El Pipe-O - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-15-2014, 05:46 PM - Thread Starter
Bob7145's Avatar
Liked: 36
Only for people with High ceilings, haha.
Just scroll down to Page 8
http://www.firstwatt.com/pdf/art_elpipeo.pdf
Bob7145 is offline
post #2 of 17 Old 02-15-2014, 05:47 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Interesting design for sure. I will have to peruse the doc more thoroughly.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #3 of 17 Old 02-15-2014, 06:08 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2572
what would something like this offer compared with a ported enclosure of the same tune?
jack bouska runs them (or at least he did in his supersystem).
http://www.audioheritage.org/vbulletin/showthread.php?12126-DIY-Axially-symmetric-oblate-spheroid-CD-waveguides-in-solid-Oak&p=123614&viewfull=1#post123614
Listen. It's All Good.
LTD02 is offline
post #4 of 17 Old 02-15-2014, 06:14 PM - Thread Starter
Bob7145's Avatar
Liked: 36
Later on the article says that it works almost as good without the manifold and just 1 driver in each "Pipe"
Bob7145 is offline
post #5 of 17 Old 02-15-2014, 06:17 PM - Thread Starter
Bob7145's Avatar
Liked: 36
El PIPE-O is just a straight tube with out the Folded Horn, sortofa simple Sonotube really.
Bob7145 is offline
post #6 of 17 Old 02-15-2014, 06:34 PM - Thread Starter
Bob7145's Avatar
Liked: 36
He picked 12ft tube for a reason. I have room to mount 1 or 2 horizontally haha. Who'll be the first?
Bob7145 is offline
post #7 of 17 Old 02-15-2014, 06:34 PM
LTD02's Avatar
Liked: 2572
so to investigate this, i looked at the 2242 driver in a ported cab. this response:
then i created a quick pipe-o and got this schlock:
then seeing some potential here, i modified it to create this:
so it looks like the pipe-o can pick up a little sensitivity vs a ported cab, but you have to do it right.
LTD02 is offline
post #8 of 17 Old 02-15-2014, 06:42 PM
LTD02's Avatar
Liked: 2572
oops, driver was pointed wrong way. here is pipe-o
LTD02 is offline
post #9 of 17 Old 02-15-2014, 06:47 PM
LTD02's Avatar
Liked: 2572
and a pipe-o with a flare starting at 1/2 sd and ending at 2x sd
that doesn't look too bad actually.
Bob7145 likes this.
LTD02 is offline
post #10 of 17 Old 02-15-2014, 07:21 PM - Thread Starter
Bob7145's Avatar
Liked: 36
After rereading, always important for forgetful me, they started talking about 14' being quarter wave of 20Hz BUT they ended up using 12' sections of Sonotube...
Then modified the design for 1 speaker and a 10' section (cut 2' off the end in the box) which they were happy with but was not the ideal design.
Then suggested (last page of article) making 2 six footers from a 12' section of eight inch sonotube and using 8' woofers with a 40Hz resonant Freq.
So there were 3 design experiments. The 8" six footers should go great next to the big boys huh?
I think I can handle the dual eights as I have a loose pair that are currently "between boxes" haha.
Edit: Nope, I have wrong ones but these Fenders may work,
These are not exactly high powered speakers but... http://www.parts-express.com/fender-8-full-range-speaker-8-ohm--299-079
Bob7145 is offline
post #11 of 17 Old 02-16-2014, 08:47 PM
diy speaker guy's Avatar
Quoted: 393 Post(s)
Liked: 309
That's terminus output alone. You have to do combined response to see actual response.
BUT with these sonotube transmission lines that have the driver and port so far apart the actual response at any given position could be anywhere between the combined response with 0 path length difference (which only applies if you measure from a spot equidistant from both ends) or the response on the terminus end (as you showed) or the response at the driver end (which is significantly different than both) depending on where you are in relation to the sub. The room will even it out to some degree but it's still a mess.
These long straight (constant csa) transmission lines with driver and terminus so far apart are just a bad idea (IMO). Adding a bit of taper to the line (like your example, although it's also shown as terminus output only) and doing a simple single fold to put the driver and terminus closer together is much better (again IMO). Do that and throw in a bit of stuffing and you can get almost ruler flat response over a much wider bandwith no matter where you stand in relation to the sub, unlike El Pipe-o.
diy speaker guy is offline
post #12 of 17 Old 02-16-2014, 09:11 PM
Quoted: 393 Post(s)
Liked: 309
Just to be more clear, here's a few pics.
Graph 1 - combined response +300 cm
Graph 2 - combined response 0 cm
Graph 3 - combined response -300 cm
So if you built this, laid it out flat on the ground and measured from different locations in relation to the sub, this is what you would get from the terminus end, the middle and the driver end. As you walk around the sub you would get VERY different response due to the driver and terminus being so far apart. Put it in a room and the room will even this mess out to some degree (and add it's own wild influence to the mix) but it's still a mess and a bad idea (IMO).
post #13 of 17 Old 02-16-2014, 09:30 PM
LTD02's Avatar
Liked: 2572
ah, i see. thanks for clearing that all up.
nice work.
LTD02 is offline
post #14 of 17 Old 02-17-2014, 01:21 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
I'm failing to see the attraction in it except perhaps the massive size to impress people.
You can do far more in much less volume.
A9X-308 is offline
post #15 of 17 Old 02-17-2014, 02:12 AM - Thread Starter
Bob7145's Avatar
Liked: 36
Did you read the article? It was just an experiment for fun about 12 years ago.
Bob7145 is offline
post #16 of 17 Old 02-17-2014, 03:58 AM
A9X-308's Avatar
Liked: 951
I read it when it first came out, and it wasn't particularly impressive then. And since then the world has moved on with better drivers, EQ and amplifiers.
A9X-308 is offline
post #17 of 17 Old 02-17-2014, 06:45 AM
Bill Fitzmaurice's Avatar
Liked: 4628
I read it, and if it had been my experiment I would have chalked it up to experience and moved on. Nellie's as good as they get with amplifier design, but where speakers are concerned he's as much a hacker as I am playing golf. That doesn't mean I'll ever give up playing golf, but I'll never make a living doing it either.
Bill Fitzmaurice is online now
