Finally ordered Fusion-12's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 50 Old 02-19-2014, 11:54 AM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Just ordered a pair of Fusion-12's. My room is small, so these are the definition of overkill. I'm so excited. biggrin.gif My "anticipation level" is through the roof. I've been drooling over these 12" waveguide kits for over a year.
I will be running these with a pair of UXL-18's, in 4cu ft flat packs.
Rebel975 is offline
post #2 of 50 Old 02-19-2014, 12:38 PM
Spiderm0n's Avatar
Rebel975 likes this.
My Gear: Sony VPL-HW40ES, 130" Spandex Screen, Onkyo TX-NR818, Fusion 12 Tempests (LCR), Axiom M3 & M2 Surrounds, Mach 5 UXL 18 Subwoofer
My theater: Escape from New York theater build
Spiderm0n is offline
post #3 of 50 Old 02-19-2014, 12:44 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
For sure the subs. The single is already enough to make me fear for the structural integrity of the walls/ceiling. I'm honestly surprised I haven't knocked a tile down, or broken a window yet. But, I ordered the second so I could smooth out the in room response. Besides, channel B on my CV5000 is feeling lonely. tongue.gif
cessna1466u and doublewing11 like this.
Rebel975 is offline
post #4 of 50 Old 02-19-2014, 05:02 PM
Dank1209's Avatar
Dank1209 is offline
post #5 of 50 Old 03-07-2014, 02:55 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
The speakers+flat packs have arrived. As always, EricH is a master packer. I haven't really had time to check the woofers, but everything appears to be in good shape.
Two things:
1) Are you sure I didn't get BA-750's instead? These compression drivers are huge!
2) EricH threw in a pair of free binding posts. I really wasn't expecting it, so it was a nice surprise. Thanks!
I have to go back to work now (was just home on my lunch break), but I'll upload more pics as I get going. smile.gif
Rebel975 is offline
post #6 of 50 Old 03-07-2014, 08:26 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Rebel975 is offline
post #7 of 50 Old 03-07-2014, 08:42 PM
BIG INJUN CHIEF's Avatar
Liked: 194
Congrats. I picked up three last week and have been toying with the flats packs.
BIG INJUN CHIEF is offline
post #8 of 50 Old 03-07-2014, 08:47 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Can someone link me to a diagram of the crossover? Pretty sure I didn't get instructions. I've double checked everything- including inside of the ports. smile.gif
Rebel975 is offline
post #9 of 50 Old 03-07-2014, 09:03 PM
post #10 of 50 Old 03-07-2014, 09:29 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Sorry, no. That doesn't show me where the connections are. It did help me design my layout, though. smile.gif
Rebel975 is offline
post #11 of 50 Old 03-08-2014, 05:23 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Congrats!
I've got my eyes on a pair myself. Anxious to see your final picks and subjective opinion on how they sound compared to other stuff you've heard.
Mfusick is offline
post #12 of 50 Old 03-08-2014, 06:33 AM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1774
I'll get you the crossover diagram. I had someone helping me layout all the crossover parts in sets of 10 and package them up in a small box. I thought he was putting the diagram inside the boxes before sealing them up, but he didn't on about 10 boxes.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #13 of 50 Old 03-08-2014, 10:37 AM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
^Thanks. I will try and get the crossovers completed tonight.
Rebel975 is offline
post #14 of 50 Old 03-08-2014, 11:35 AM
cessna1466u's Avatar
Quoted: 116 Post(s)
Liked: 201
Can I ask you guys that are running the fusion 12's what kind of amplifiers you are using or are you just running them using your receiver?
cessna1466u is offline
post #15 of 50 Old 03-08-2014, 12:16 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
I will be running mine off of an Emotiva UPA-500. I will need another amp so I can get 7.1 going though.
Rebel975 is offline
post #16 of 50 Old 03-08-2014, 12:22 PM
Quoted: 116 Post(s)
Liked: 201
Originally Posted by Rebel975 View Post
I will be running mine off of a Emotiva UPA-500. I will need another amp so I can get 7.1 going though.
What kind of wattage does the emotiva do? I have a Yamaha receiver and it states 110watts which is realistically more like 70 or 80.
post #17 of 50 Old 03-08-2014, 12:25 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Because the tempests are 98db sensative your avr should've fine.
If the speakers were 90db sensative then you would probably need an amp.
chalugadp is offline
post #18 of 50 Old 03-08-2014, 12:28 PM
Quoted: 116 Post(s)
Liked: 201
Thanks Donny,maybe I should look into the new inuke the 4 channel one. I can run the L/C/R and the 4th channel I can send outside to my Zone 2. biggrin.gif
post #19 of 50 Old 03-08-2014, 01:06 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Emotiva says:
120 watts / channel (4 ohms; all channels driven)
80 watts / channel (8 ohms; all channels driven)
cessna1466u likes this.
Rebel975 is offline
post #20 of 50 Old 03-08-2014, 03:42 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Rebel975 is offline
post #21 of 50 Old 03-08-2014, 07:26 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Big props to chalugadp for suggesting I buy a brad nailer. This is making assembly so freaking easy. biggrin.gif
I can still make mistakes though. Nothing a bit of sanding can't fix...
Rebel975 is offline
post #22 of 50 Old 03-08-2014, 08:00 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 938
So..........................
What you are saying to me......................use your engineering skills to reinforce my home?  Check please..................I'll take four! :cool:
doublewing11 is offline
post #23 of 50 Old 03-09-2014, 07:24 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I use a brad nailer too. I actually bought a cordless ryobi recently that works great for speaker boxes.
Mfusick is offline
post #24 of 50 Old 03-09-2014, 07:39 AM
The Teaza's Avatar
I've got that Ryobi nailer too, it is a fantastic tool indeed. Very convenient.
The Teaza is offline
post #25 of 50 Old 03-09-2014, 08:18 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
Rebel, Congrats on a great purchase.
Looking forward to hearing your impressions!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #26 of 50 Old 03-09-2014, 10:45 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Yup! biggrin.gif I had a full set of sizes of bradnailers for the air compressor but the noise of the compressor and the hassle of the cord was annoying. This thing is a dream come true. It works great. Even has that built in light that shines down on the area you are nailing. I'm happy.
For $129 it might not be in the reach for a speaker box project, but for someone looking for one for other reasons too I'd recommend.
We are pregnant with twins and I recently made some balloon boxes with it (which is what I bought it for) but it's basically the same process as a speaker box. I wish I had it when I built my subwoofer box.
I had a link and some pictures and talk about it in here: http://www.avsforum.com/t/1479556/how-much-did-you-spend-on-tools-to-build-your-theater/100_100#post_24296570
Mfusick is offline
post #27 of 50 Old 03-09-2014, 01:30 PM
The Teaza's Avatar
I actually just used mine today to hang masonite on the walls of my workshop after putting some R12 batting up, it's such a convenient tool, I reverted to the Ni Cads though because the darn Lio batts didn't impress me much, and I prefer to be able to rebuild them. With high Mah sub Cs.
I bought mine to help build my 12' x 12' shed/workshop last year, it was fantastic for putting the preprimed siding on with some full headed nails every couple feet for extra umph.
It's also the perfect tool for baseboards and corner moulding and the like.
post #28 of 50 Old 03-09-2014, 03:07 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Crossovers are nearly done too. I just spent 2 hours hot gluing, soldering, stripping wires, etc. My fingers hurt. tongue.gif
I set up a space heater in the garage to help the glue dry faster. It was so cold in there, that glue I used last night wasn't dry when I woke up this morning. eek.gif
Rebel975 is offline
post #29 of 50 Old 03-09-2014, 11:59 PM - Thread Starter
Rebel975's Avatar
Quoted: 12 Post(s)
Liked: 106
Just finished assembling the boxes. I'll let the glue dry overnight. I can then fill/sand/paint tomorrow. Barring any unforeseen catastrophes, I should be up and running Tuesday.
I finished the crossovers earlier as well.
Fatshaft and Mfusick like this.
Rebel975 is offline
post #30 of 50 Old 03-10-2014, 07:24 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Mfusick is offline
