Fatshaft’s Tux 1099 build… - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #721 of 734 Old 07-29-2014, 12:18 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
I was comparing the specs of the raw compact drivers - not with crossover's applied to them.
Bassment is offline
post #722 of 734 Old 07-29-2014, 12:37 PM
frankie2075's Avatar
Quoted: 458 Post(s)
Liked: 110
Originally Posted by gpmbc View Post
They have there place but most rely on subs from a theater standpoint to reproduce the bass. One thing that makes full range less desirable is that the deep bass may not sound as good as the rest of the spectrum in the desired location now you're stuck with limited placement options. Full range can definitely work but it's more of a balancing act.
i would deff use subs with them...no doubt about that just thought from imax point of view cause all there speakers in the real imax theaters are full range
frankie2075 is offline
post #723 of 734 Old 07-29-2014, 12:51 PM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
they're run full range, that doesn't mean they DO full range. There's just no crossover applied.
Bassment is offline
post #724 of 734 Old 03-17-2015, 02:26 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
Full range means the speaker has to act like a sub, or at least 10dB lower: 105dB ref level at 20Hz is the sort of thing 12" woofers and 400w and a big box are used for. Sure looks like a sub.
So I say if you want each channel to act like a sub, be prepared to spend 2x on drivers, wood, more complicated crossover, and buy more external amps.
Eyleron is offline
post #725 of 734 Old 12-22-2015, 05:06 AM
nezff's Avatar
Quoted: 156 Post(s)
Liked: 76
Originally Posted by Fatshaft View Post
I thought I'd post my finished 1099's.
This is how it will finally play out.
I've placed them on my former surrounds to lift them a little off the front stage floor.
The CD is a little over ear height when I'm sitting and they sound AWESOME!
I've also raised my screen by approx. 8" and so I raised my center by that same amount too and it made a pretty decent difference in my center channel sound.
I had a major dip in the 100-200HZ region which helped tremendously.
I am now experimenting how to finish the front.
I am now considering covering all the front wall with insulation and building a screen of Spandex (white) for my screen.
All fun so I'll see what it gives.
What subs are those? Nice build
nezff is offline
post #726 of 734 Old 12-22-2015, 08:00 AM
mlah384's Avatar
Quoted: 485 Post(s)
Liked: 207
mlah384 is offline
post #727 of 734 Old 12-22-2015, 09:45 AM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
Those are SI HT18's (discontinued)
My front stage has changed since then...I now have the 21's in the front...looks like this
Quality of pic not great but you have a good idea
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #728 of 734 Old 12-22-2015, 11:54 AM
brian6751's Avatar
Quoted: 1172 Post(s)
Liked: 1143
@Fatshaft do you notice any difference having the 1099's flipped the other way like that?
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #729 of 734 Old 12-22-2015, 12:01 PM
JBL49q's Avatar
Real nice work.
Fatshaft likes this.
JBL49q is offline
post #730 of 734 Old 12-22-2015, 12:08 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
Not really except when I'm fully reclined then yes cause in the reclined position the cd is more than 18" above my ears.
Also when watching movies I can't really tell the difference that much.
I ONLY recline my seat when watching movies...I never recline the seat when listening to music.
I've done so many tests (several 1000's) with a mic and REW that what I've learned is not to take measurement to seriously.
It amazes me how much moving the mic one inch (left, right up or down) affects the higher frequencies so much!
So for that reason I rely more on my ears.
Measurements for low Frequencies I do rely on measurements as that stays VERY consistent whether moving the mic an inch (left, right up or down)
brian6751 likes this.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #731 of 734 Old 12-23-2015, 06:24 PM
brian6751's Avatar
Liked: 1143
Thanks. Great setup. Thats a lot of good ole' Canadian designed and built power up front!!
Rivers Edge Theater
post #732 of 734 Old 12-23-2015, 08:57 PM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
Yup
Canadian in the front and American in the back
Oh and thanks
Fatshaft is offline
post #733 of 734 Old 12-23-2015, 11:07 PM
kingpin111's Avatar
Quoted: 290 Post(s)
Liked: 283
Fatshaft for prime minister!
kingpin111 is offline
post #734 of 734 Old 12-24-2015, 06:39 AM - Thread Starter
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
lol
My Build Thread
Equipment Speakers:
Fatshaft is offline
