Limited Run of 4cuft Flat Packs for the Stereo Integrity 18" Subwoofer - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #151 of 170 Old 04-11-2014, 04:13 PM
Kpilk's Avatar
Liked: 24
'Anybody have a dual 2 ohm SI 18 they no longer need? I like one more.
Kpilk is offline
post #152 of 170 Old 04-11-2014, 04:19 PM
scotsman8's Avatar
Quoted: 12 Post(s)
Originally Posted by btinindy View Post
Yes, much easier to nail it than clamp it. I used a pin nailer and also did not need to fill any holes.
yea i'll be using a pin nailer when I build volt boxes and whenever the alpha mtm comes out.
scotsman8 is offline
post #153 of 170 Old 04-11-2014, 04:43 PM
Kpilk's Avatar
Liked: 24
I built a couple of these with 6 clamps...8 would be better but if you don't try to do all at once you can get by with as few as 4. Tightbond II all around and used it to seal the inside seams (even though it wasn't necessary). Used just a bit of filler for the baffles as they can be slightly big for the box by a MM or 2. Filler and sanding is much easier than trying to just sand down the seams if you looking to hide all the seams. Really nice fitting boxes and dead solid.
Kpilk is offline
post #154 of 170 Old 04-14-2014, 02:14 PM
Bob7145's Avatar
Liked: 36
Brad Nailers - How much air pressure are you using and what length of 18ga nails??? Someone loaned me a brad nailer and supply of various ammo. Rather not experiment on the boxes. Do you absolutely have to use a certain length? The store was out of 1 and a half inch. I've used sanders and sprayers with air so I have a valve and gauge close to the end of my hose.
Bob7145 is offline
post #155 of 170 Old 04-14-2014, 02:56 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
Use some scraps for experiment. Typically 80-90 psi works for me but my nailer also has depth adjustment.
You want at least 1/4 inch of nail into the material just to hold while the glue dries.
Bob7145 likes this.
btinindy is offline
post #156 of 170 Old 04-14-2014, 05:10 PM
Bob7145's Avatar
Liked: 36
Thank you sir!
Tank pressure is 100 so it won't be a problem with a low volume tool like a nailer.
Depth adjustment - Haha, I didn't get any instructions verbal or otherwise with the tool. It's a Craftsman. I'll look it up 1st. No MDF scraps unless they came with the flatpacks smile.gif I just didn't want to sink the heads too far but can always tap it in flush the old fashion way.
Thanks again!
Bob7145 is offline
post #157 of 170 Old 04-15-2014, 01:51 PM
Kpilk's Avatar
Liked: 24
Erich...if you see this, I had reserved two flat packs, ordered one because I could only find on D2 SI 18" sub. Now I see they've posted on facebook that they're going to offer the sub again, available in 3 months or so. If my second is available still I'd like to order...please advise. Thanks.
Kpilk is offline
post #158 of 170 Old 04-15-2014, 03:17 PM - Thread Starter
Erich H's Avatar
Quoted: 1493 Post(s)
Liked: 1902
Go for it. I'm going to count up what's left over in a day or so and then let anyone else order them.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #159 of 170 Old 04-15-2014, 03:32 PM
Rhino11's Avatar
Rhino11 is offline
post #160 of 170 Old 04-23-2014, 12:35 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
Hey Erich, have you had a chance to see how many you have left over? I'm still needing one.
JWagstaff is offline
post #161 of 170 Old 04-23-2014, 03:12 PM - Thread Starter
Erich H's Avatar
Liked: 1902
Well I guess there's 5 left over because I don't think anyone asked me to hold them any longer than now. So they are up for grabs at this point.
Erich H is offline
post #162 of 170 Old 04-23-2014, 03:15 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
how do we order them? Off the group buy one?
post #163 of 170 Old 04-23-2014, 04:15 PM - Thread Starter
Erich H's Avatar
Liked: 1902
That is correct. Don't wait too long.
Erich H is offline
post #164 of 170 Old 02-28-2015, 08:29 PM
eggyhustles's Avatar
Quoted: 14 Post(s)
Are these coming back?
eggyhustles is offline
post #165 of 170 Old 03-01-2015, 02:14 AM
niktak11's Avatar
Quoted: 92 Post(s)
Liked: 45
http://www.diysoundgroup.com/sealed-...flat-pack.html
niktak11 is offline
post #166 of 170 Old 03-01-2015, 03:05 AM
saginawjuggalo's Avatar
Quoted: 47 Post(s)
Liked: 51
I'm positive they'll be back. If not I'll be disappointed if I ever make it to twelve 18" SIs.
Originally Posted by niktak11 View Post
He's asking because of the "Availability: Out of stock."
eggyhustles likes this.
JVC DLA-RS40 w/003 lamp,DIY False-wall 125" acoustically transparent screen,Darbee Darblet,Sanyo PLV-Z2000 (gaming),7.1 DIYSoundGroup 1099 x3 LCR & Slanted Volt 6 rears x4,Onkyo TX-NR818,Emotiva LPA-1,Behringer EP4000 (x2),Sealed Stereo Integrity HT18"s (x8),Balanced MiniDSP,Cross·Spectrum UMIK-1,DIY Acoustic Treatments,PS3,Sony BDP-S590,Seiki SR4KP1 Region Free BDP,Toshiba HD-A1,Roku,Outdoor Antenna,APC H15 power conditioner,Harmony Smart Control,Rebuilding*HTPC,Leather Theater seating etc.
saginawjuggalo is offline
post #167 of 170 Old 03-01-2015, 06:47 AM - Thread Starter
Erich H's Avatar
Liked: 1902
I'll be getting more in about 2 weeks.
MemX likes this.
Erich H is offline
post #168 of 170 Old 03-01-2015, 09:18 AM
vitod's Avatar
Quoted: 278 Post(s)
Liked: 153
Good to know, Erich! :-)
Panasonic AE-8000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #169 of 170 Old 03-01-2015, 12:14 PM
Quoted: 14 Post(s)
Out of stock my friend.
post #170 of 170 Old 03-01-2015, 07:03 PM
andyc56's Avatar
Quoted: 17 Post(s)
Liked: 406
Will any of this batch be for the Dayton RSS460HO 18" or am I stuck getting them from PE? I can wait a bit, as painting with Restore 4x requires that the temperature not drop below 50 deg F during the drying process.
Or do they end up being about the same price when shipping is taken into account?
andyc56 is offline
