Best Material to Reduce Box Volume? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-28-2014, 08:18 PM - Thread Starter
invain's Avatar
I made the box for my sub on the large side on purpose if I ever decide to go ported. I need to reduce the volume by about 1 cf. I have a bunch of books in there right now but the way I have the bracing set-up I really need to custom fit something. I know most people just use 2x4s cut and glued/screwed but I'm curious if there's anything lighter I could use. With the box + sub + amp this thing already weighs around 100 lbs.
Some people have mentioned foam sheet insulation but I question whether this is dense enough. Is there anything any of you have used/would recommend that would effectively reduce volume while being lighter than wood?
invain is offline
post #2 of 7 Old 02-28-2014, 08:23 PM
wassub's Avatar
Closed cell foam insulation.
wassub is offline
post #3 of 7 Old 02-28-2014, 08:48 PM - Thread Starter
invain's Avatar
Are you talking about the sheets? Something like this: http://www.lowes.com/pd_15358-1278-3/4X48X96+R-TECH_4294858106__?productId=50100630&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=
I should notice no difference using this as opposed to wood, right?
invain is offline
post #4 of 7 Old 02-28-2014, 09:42 PM
wassub's Avatar
Yes and correct.
wassub is offline
post #5 of 7 Old 02-28-2014, 11:43 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1141
Why even bother? It's just going to change the Q slightly and room effects and EQ (if any used) will completely smother the difference.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #6 of 7 Old 03-01-2014, 12:10 AM
steve nn's Avatar
Liked: 433
Oh yeah, especially if it's used for HT. Just leave it as it is imo.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #7 of 7 Old 03-01-2014, 07:12 AM - Thread Starter
invain's Avatar
The sub I'm using calls for a 2.4 cf box with a qts of .7. It also has an FS of 15 hz so there is bottom end for days. Like I said I added a bunch of books to reduce volume by .6 - .7 cf and it made a pretty huge difference.
I'm also using the top end of the sub's power handling and I was hitting max extension way too easy at low frequencies when I first tested it out with an effective box volume of around 4 cf.
invain is offline
