Infinite Baffle in 1100 cubic foot room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-03-2014, 07:55 AM - Thread Starter
armystud0911's Avatar
I am going to start building my first HT, a micro mini room of 10.5' x 16' x 7' and I wanted some input on an infinite baffle here. Personally, this represents two firsts for me, I have never used subs in an enclosed room anywhere near this small before and I also have never tried an IB either. I have never made a sub before that goes deeper than 10Hz and those that have, haven't had much output down there. I am curious what kind of gain I can expect from a room this small, where will it start and what how much will it chip in down around 5 Hz or so?
My second question is whether or not 2 Ficar IB318's will be enough for this room, I don't think I have ever seen someone build an IB with only 2 drivers before so I have my doubts about this. I can go up to 4x if I have to but two would be preferable from a cost standpoint if it is at all possible. Now, I have never done a system before as much total displacement as 2x IB318's so even though I am sure it has the ability to be very loud. However, with it being an IB, I won't be able to push the drivers as much as I am used to in the audible frequencies.
armystud0911 is offline
post #2 of 12 Old 03-03-2014, 08:11 AM
bass addict's Avatar
Quoted: 441 Post(s)
Liked: 507
This would be my first concern. I've never seen a two driver IB either as this design requires multiple drivers to prevent over excursion. That being said, I've never seen an IB in this size room either.
Out of curiosity; what is the driving force behind going with an IB as opposed to a ported setup. I'm assuming space constraints?
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #3 of 12 Old 03-03-2014, 08:20 AM
Bill Fitzmaurice's Avatar
Liked: 5687
You'll get cabin gain below 35Hz, 8-10dB/octave, so i don't see the need for a huge IB, a couple of sealed boxes with an f3 of 35Hz should do fine.
Bill Fitzmaurice is offline
post #4 of 12 Old 03-03-2014, 08:21 AM - Thread Starter
There are a number of reasons, space really isn't one of them, I can fit all the subs I want behind the AT screen. I have a number of reasons for trying it,
1. Sound quality
2. Extension into single digits
3. Cost
4. Ease of construction
5. I have always wanted to but was never able to
6. Such a small room seems like the ideal place for one
post #5 of 12 Old 03-03-2014, 08:25 AM
MKtheater's Avatar
Quoted: 1756 Post(s)
Liked: 1349
How loud do you listen? Proper location of drivers for smooth response is very important.
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is offline
post #6 of 12 Old 03-03-2014, 08:27 AM - Thread Starter
I have seen this generalization about gain before, does it hold true as you keep going deeper? I mean, from 35Hz to 17.5Hz, there's one octave, from 17.5Hz to ~9hz, there's two, from 9Hz to 4.5Hz, there's three, from 4.5Hz to 2.25Hz, that's four, if that were true, I could expect between 32 and 40db of gain at 2.25Hz?
post #7 of 12 Old 03-03-2014, 08:29 AM - Thread Starter
Typically about 5-10db below reference but I do enjoy watching things occasionally at full reference when the wife isn't with me, and possibly over reference for a little wow demonstration if the system could handle it.
post #8 of 12 Old 03-03-2014, 08:42 AM
MKtheater's Avatar
Liked: 1349
Yes it is true, except as you get lower your signal chain rolls off so you see people dropping off at 3-10hz depending on equipment.
Marantz 7704
2 Outlaw 7140s
post #9 of 12 Old 03-03-2014, 08:46 AM
MKtheater's Avatar
Liked: 1349
Well, you don't want me to help then as I always go over board. I have a 1510 cubic foot room with 8 of the IB3's. Adding 4 more. Why? Smooth out the response so no EQ is needed and use only a LT boost which all will need. As soon as I get my new Mic I will start posting sweeps again. You need enough drivers to keep clean at reference from 10hz and below. I am at about 1.5% THD at 10hz with a 115 dB sweep if the mic was accurate. The levels are accurate though.
Marantz 7704
2 Outlaw 7140s
post #10 of 12 Old 03-03-2014, 08:48 AM
Mike Garrett's Avatar
Quoted: 7063 Post(s)
Liked: 4772
Two driver IB's are done all the time. In fact, if I was going to do an IB, I would probably do two of them with two drivers each. Of course dual opposed for both of them. Look here and you should find several 2 driver IB's.
http://ibsubwoofers.proboards.com/board/13/builders-gallery
mjgarrett100@gmail.com
Mike Garrett is offline
post #11 of 12 Old 03-03-2014, 08:57 AM
MKtheater's Avatar
Liked: 1349
I just plugged your room into the ULF score calculator and you would be at 4.5 stars from 10-20hz. Meaning reference level ability. So it all depends on what you want.
Marantz 7704
2 Outlaw 7140s
post #12 of 12 Old 03-03-2014, 09:18 AM
Quoted: 441 Post(s)
Liked: 507
I figured only running 2 drivers you would have excursion issues. If room isn't an issue I'd prefer a multiple sealed setup, seeing as he references single digit extension.
