DIY Sub Build, (2) SI 18 HT Ported, 1" MDF - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 04-19-2014, 11:05 AM - Thread Starter
DKAudio's Avatar
sooly1 likes this.
Samsung PN58C550
UMC-1
XPA-5
(2) AV123 Onix Rocket 760's
AV123 Onix Rocket RSC200 (Bigfoot)
(2) AV123 Onix Rocket RS250
(2) SI 18 HT D2 8ft^3 18hz Ported 1" MDF, Granite Tops
DKAudio is offline
Old 04-19-2014, 06:41 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
kevings is offline
Old 04-21-2014, 03:00 PM - Thread Starter
DKAudio's Avatar
drivers are mounted
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 04-21-2014, 09:19 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
Beastly!
Nice work DK.
How about you pull an all nighter and get those granite tops on there, my friend!  THAT pic will be some good looking speaker porn!
kevings is offline
Old 04-23-2014, 07:53 AM - Thread Starter
DKAudio's Avatar
They are all complete but I don't have pictures yet, will take some tonight. These things are so hard to move, even with two people! I still need to run a speaker cable through the floor, across my basement and back up to the other side of the living room for the second sub (I have one in each opposing corner of my living room). I hooked up one sub temporarily to my iNuke 3000DSP. I have not done any DSP adjustments and my processor out needs to be adjusted but WOW. The sub is barely moving and my living room was shaking during a movie not even known for bass.
Pictures tomorrow for sure!..
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 04-24-2014, 06:36 AM - Thread Starter
DKAudio's Avatar
gpmbc, BacHolz and Bombelman like this.
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 04-24-2014, 06:45 AM
djhamp's Avatar
Quoted: 24 Post(s)
Liked: 27
They look great! Do those feet have some kind of pad on the bottom? Wondering if they will try to "walk" around much.
djhamp is offline
Old 04-24-2014, 06:57 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
they look to have some sort of pad on them, and I agree those look really nice. I assume you just glued down the granite with some sort of silicone glue?
Sibuna is offline
Old 04-24-2014, 07:55 AM
BrutalBodyShots's Avatar
Quoted: 353 Post(s)
Liked: 85
Nice looking subs!
I bet those monsters wouldn't walk around at all @ over 200 lbs each thanks to those granite tops smile.gif
BrutalBodyShots is offline
Old 04-24-2014, 05:15 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
kevings is offline
Old 04-25-2014, 06:26 AM - Thread Starter
DKAudio's Avatar
Thanks for the all the positive feedback, these are definitely the beefiest and sturdiest enclosures I have ever come across. They don't walk at all, they came in at 240lbs each! The feet have a clear plastic/rubber pad on the bottom of each one, should protect the floor and makes it "stick" really well too.
Anyways, I actually played them yesterday and holy cow! They were barely moving and it was powerful and loud. I started messing the the DSP on the iNuke too, was pretty cool but have some questions, hopefully LTD will stop in. This is how I set it up...
-Dual Mono Mode
-Phase 0 on both channels, I tried changing them one at a time but thought 0 sounded best. The subs are in opposite corners of the room, one in front of my and one behind me so thought one might need 180 phase but guess not.
-HPF 20hz 12db Butterworth
-LPF 90hz 48db Butterworth
-Filter 1, -7db 20hz HS12 to lower for around a 13 hz HPF
I didn't mess with anything else, does everything look correct?
I also opened up the iNuke and the fan has no cowling or tunnel to direct air flow. There are some heatsinks attached though, look like Behringer redesigned it from other threads where people opened them up. The fan is 12V 80mm Bi-Sonic, I'm going to replace it with a quieter computer fan I have laying around, I'll try to match the CFM as close as I can.
One other thing, can the brightness of the orange be lowered? I see a contract section for the screen but no brightness. During a movie the lights are very distracting, especially the level LED's.
Here is a picture of the amp exactly how I opened it, nothing altered yet.
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 04-25-2014, 06:39 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
look into "light dims" they are basically stick on window tint for LEDs, you can also just paint them with black nail polish
you can place an O-ring around the knobs that helps with that orange as well
Sibuna is offline
Old 04-25-2014, 06:42 AM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
There is a thread where someone used black rubber washers around the knobs to block out the orange light.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
Old 04-25-2014, 08:00 AM
RexST's Avatar
Liked: 25
IIRC it was Cessna who employed the o-rings around the knobs. He got them from Home Depot I believe.
RexST is offline
Old 04-25-2014, 09:12 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
They look really nice DKAudio. Looking forward to hearing more about your impressions.
Do you know what the real tuning of the box is and how it relates to the model?
Have you noticed any chuffing when played loud?
I dont understand why you have a low pass filter. Your reciever should take care of that so its not needed.
splotten is offline
Old 04-25-2014, 09:51 AM - Thread Starter
DKAudio's Avatar
Tuning is modeled at 18hz, not sure how to discover actual. I want to get a mic and mess with REW, never done it before though.
Have not noticed any chuffing yet.
I did the LPF just for the heck of it, more or less messing around with the DSP. My UMC-1 is crossed at 80hz I believe.
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 04-25-2014, 10:03 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
OK. So did you go with the model in #55 or something similar? You can eyeball the actual tuning by playing a row of sinus test tones around the tuning frequency with the high pass turned off. (15, 16, 17, 18, 19, 20Hz) The tone that have the cone moving the -least- is the one closest to the actual tuning of the box. A mic is a great idea.
splotten is offline
Old 04-25-2014, 10:50 AM - Thread Starter
DKAudio's Avatar
Yeah, I did two slot ports 9.5" X 1.75" x 30", all ends have a round over edge done with a router. WinISD showed a 18.1hz tuning.
Interesting on the cone excursion, I will have to try some test tones and see. I have a iMM-6 mic but have not used it yet. Got info for the cables I need to make it work with REW from another member. I have not ordered the cables yet though.
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 04-26-2014, 05:36 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
BTW. You can also estimate the tuning with the mic. Just measure the the center of the cone really close (1") with the test tones. Again, its the tone that measures the lowest that is closest to the tuning point.
splotten is offline
Old 04-28-2014, 06:55 AM - Thread Starter
DKAudio's Avatar
Here is what I ended up doing with my iNuke 3000DSP’s fan. I already had a 80mm 12VDC fan laying around, it has the following specs…
• DF1208SM
• DC 12V, 0.20A
• Speed: 2600 RPM
• Air Flow: 27.94 CFM
• 30.10 dBA
The stock fan has these specs…
• BP802512HL-03-W
• DC 12V, 0.40A
• Speed: 4000 RPM
• Air Flow: 55.5 CFM
• 40 dBA
The noise level is very acceptable now, the iNuke has the fan spin at a low speed until it is pushed harder so at normal levels or during dialog I can’t hear the fan unless I go close to the unit.
Since this has about half the CFM as the stock fan I thought it would be a good idea to add some more heatsinks. I drilled through the metal stock heatsinks, used a thermal transfer pad and added some bigger aluminum finned heatsinks. After doing this the highest temp I have measures so far (not pushing the amp crazy hard but decently hard) was 96F with an ambient of 70F.
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 05-01-2014, 08:29 AM - Thread Starter
DKAudio's Avatar
I played some test tones, 16hz and 17hz definitely had the least amount of excursion. Couldn't hear anything but you could feel it and the house was rattling smile.gif WinISD came in at above 18hz tuning, wonder why it is that much lower? Once they break in will it change slightly?
10hz was the lowest freq I had and it was sure moving! I wonder if the iNuke 13hz HPF is working? I set it as I described in post # 101.
Also, anyone know how long the DSP settings in the iNuke will hold without power?
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 05-01-2014, 08:56 AM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
I had my inuke 1k DSP turned off but plugged in for months and it retained the settings i had put in. not sure if its totally unplugged
Sibuna is offline
Old 05-03-2014, 01:38 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
I has been reported a number of times that the tuning some times end up lower than modeled. Part of it might be the down fire port. If it is too close to the floor it will effectively lengthen the port and lower the tuning. If you have some dampening in there you can remove some of it. That will move the tuning up a little. Or vice versa.
Its normal that the excursion rises below the tuning point, but If the filter is not effective preventing bottoming the woofer you might want to move the HPF up a notch.
splotten is offline
Old 05-05-2014, 05:45 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
What was the purpose of the granite top again? Using this as an end table?
Blazar!
blazar is offline
Old 05-14-2014, 06:36 AM - Thread Starter
DKAudio's Avatar
Mostly just for looks, I can put items on there (including drinks) without worrying about anything getting damaged. Also makes it solid, 3cm granite does not flex smile.gif
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
Old 05-15-2014, 05:56 PM
Bombelman's Avatar
Quoted: 56 Post(s)
Liked: 52
nice build, great subs !!
Bombelman is offline
Old 05-16-2014, 09:05 PM
Electrodynamic's Avatar
Quoted: 381 Post(s)
Liked: 578
Electrodynamic is offline
