Who wants to see the Inuke12000DSP tested? - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #331 of 445 Old 06-15-2014, 07:51 AM - Thread Starter
thebuckaman's Avatar
Quoted: 21 Post(s)
Liked: 80
Nuno... Thanks
thebuckaman is offline
post #332 of 445 Old 06-24-2014, 09:28 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
Ok. Amp is going out today. Sorry for the delay, I was at Infocomm all last week in Vegas.
Getting things ready for a new theater room build at the new house.
Equipment so far- (8) SI HT18 mini martys, speakerpower SP2-12000, Denon 4311ci (will replace), MINIDSP 10x10HD, Crown CT8150, Oppo BDP-103D, (8)JBL 8320 , (3) EV EKX12 , Crestron CP3N control system, iso clips/Roxul
TBD- Projector, AT Screen, in room acoustics,
post #333 of 445 Old 06-24-2014, 09:39 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5282 Post(s)
Liked: 4166
No worries. Thanks for the update. Look forward to the new new results!
Scott Simonian is online now
post #334 of 445 Old 06-30-2014, 02:11 PM
Nuno C's Avatar
Quoted: 29 Post(s)
Did the amp's arrive okay..???
Any juicy little teaser info you can share....???
Nuno C is offline
post #335 of 445 Old 07-01-2014, 03:30 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
Im sure Brian is busy running a business, but he said that tests should be revealing pretty quick. Amp arrived yesterday.
post #336 of 445 Old 07-02-2014, 11:04 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
Prepare to be underwhelmed........
From Brian:
Here is what I found.
1. Same 100V limit on output
2. When checking the DSP settings, noticed the display, buttons knobs etc were all loose. The mounting screws are not tight.
3. Confirmed limit was set all the way up (100%)
4. Power tests all the same as before. about 2700W/2 at 50Hz. Nowhere near 6000W.
post #337 of 445 Old 07-02-2014, 11:23 AM
95bat's Avatar
Quoted: 24 Post(s)
That seems odd... how is it even legal to advertise a 12,000 watt amp that produces less than 1/2 of that? I can understand putting out 75-80% of rated power, but 45% of rated power?
95bat is offline
post #338 of 445 Old 07-02-2014, 11:25 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
From Brian:
Is something wrong?
That's some serious BS to advertise as such!!!
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #339 of 445 Old 07-02-2014, 11:31 AM
Bass Enabler
Liked: 4166
That doesn't sound right. Like it wasn't even updated or fixed at all. Same results.
post #340 of 445 Old 07-02-2014, 11:38 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
I am writing an email to the CARE department at Behringer outlining all of this information. Stay tuned....
post #341 of 445 Old 07-02-2014, 11:38 AM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Nowwwwww...would be the time for that Behringer rep from earlier in the thread to make an appearance...
martinq likes this.
blah450 is offline
post #342 of 445 Old 07-02-2014, 11:51 AM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
Can someone remind me of the real output for the iNuke6000?
JohnDean is online now
post #343 of 445 Old 07-02-2014, 11:58 AM
Bass Enabler
Liked: 4166
~2kw @4ohm per channel, ~1.3kw @8ohm per channel.
Pretty much two bridged ep4k's in one 14lb 2RU case.
post #344 of 445 Old 07-02-2014, 11:58 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
Behringer:
1.37kW into 8 Ohms, 2.05kW into 4 Ohms for full-range or mid-top duty
1.16kW into 8 Ohms, 1.80kW into 4 Ohms for Bass duty
http://forum.speakerplans.com/behrin...opic69202.html
splotten is offline
post #345 of 445 Old 07-02-2014, 12:08 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
From Brian:
So its limited to 100Vrms or is it 100Vpeak?
splotten is offline
post #346 of 445 Old 07-02-2014, 12:14 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
100VRMS according to Brian.
post #347 of 445 Old 07-02-2014, 12:20 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
OK. Thanks.
splotten is offline
post #348 of 445 Old 07-02-2014, 12:37 PM
JohnDean's Avatar
Quoted: 430 Post(s)
Liked: 183
Originally Posted by splotten View Post
Behringer:
Unless I'm missing something, it seems like twice the power of the 6000. I'm not saying I like it, but it seems like par for the course for Behringer....and one of the reasons I'm really looking for an alternative to the nu4-6000
post #349 of 445 Old 07-02-2014, 01:07 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
Trouble is if it is limited to 100Vrms then it can deliver no more than 2500W into 4 ohms and half that into 8 Ohms. To me it sounds like a defective unit or a firmware bug.
splotten is offline
post #350 of 445 Old 07-02-2014, 01:10 PM
Archaea's Avatar
Quoted: 2839 Post(s)
Liked: 2416
twice as powerful?
2700Watt / 2 @ 2ohm on the iNuke 12000
or 1,800Watt / 2 @ 4ohm on the iNuke 6000
Seems about like the same amp - just actually capable of 2ohm.
Archaea is online now
post #351 of 445 Old 07-02-2014, 01:14 PM
Bass Enabler
Liked: 4166
Yup.
Now where it gets interesting is comparing the 12k to the IPR27500 and it's stated power output as they are a similar price.
post #352 of 445 Old 07-02-2014, 01:42 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
From Brian:
For reference. Please confirm that it is 2700W into 2 ohm and not 2700W into two channels of unknown impedance?
splotten is offline
post #353 of 445 Old 07-02-2014, 04:40 PM
Nuno C's Avatar
Quoted: 29 Post(s)
Angry Bad Berry Bad
 I will be boxing the 12000 and 7500 up this week and coordinating with Brian.
Two things...
1 - Please confirm Brian also received the IPR 7500 - at least hoping for good news from those tests.
2 - Register and create a post about this debacle over at https://soundforums.net/forum.php
I had issues with my iNuke 6k and posted in one of the threads there. It is common to see Behringer execs post including the CEO Uli Behringer himself.
Had someone assist in a few days after running into a brick wall for almost two weeks trying to get unit serviced.
A lot of pro audio guys there so bad press can and will hurt sales.
All in all rather sad series of events...
Nuno C is offline
post #354 of 445 Old 07-02-2014, 08:22 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Originally Posted by Nuno C View Post
Two things...
7500 went too, right??
blah450 is offline
post #355 of 445 Old 07-02-2014, 10:25 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
Only raised $50. Was only able to cover shipping for the 12k. Couldn't float the $50 for the round trip for the 7500.
I am checking on the power rating. Whether it was 2 ohm or two channels....
post #356 of 445 Old 07-02-2014, 11:06 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
splotten is offline
post #357 of 445 Old 07-03-2014, 02:13 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
Brian confirmed that the ratings were exactly the same as before
post #358 of 445 Old 07-03-2014, 02:46 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
Can you please point to the before ratings? I have no idea where to look for them.
splotten is offline
post #359 of 445 Old 07-03-2014, 02:48 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Yeow!
Time for a SpeakerPower group buy?
Seems like a great product, just priced out of the range (especially since price increase a while back) of most of the DIY community that has other alternatives that aren't too far off performance-wise?
blah450 is offline
post #360 of 445 Old 07-03-2014, 02:50 PM
lukeamdman's Avatar
Quoted: 1074 Post(s)
Liked: 1190
lukeamdman is offline
