Who wants to see the Inuke12000DSP tested? - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #391 of 445 Old 07-18-2014, 06:59 AM
Bassment's Avatar
Quoted: 904 Post(s)
Liked: 364
Originally Posted by splotten View Post
That is not how you calculate Vrms for a sine wave. Vrms = (Vp-p/2)/sqrt2 = Vp/sqrt2. It is not Vp-p/sqrt2
I know, but in a bridged amp there's two sine waves, 180 degrees shifted. So you get 2*Vp/sqrt(2).
I was talking about peak in my earlier post.
The orange graph and teal signals are the amplified positive and negative signals, and they're just on top of each other on the scope
For bridge 4 ohm, it's like each channels 2 ohm, so you get ((64/sqrt(2))^2)/2 = 1024 watts per channel, so two channels is 2048 watts RMS. Which is the same thing as ((2*Vp/sqrt(2))^2)/4 His RMS output is different as it's probably not exactly a 4 ohm load.
LTD02 likes this.
Bassment is offline
post #392 of 445 Old 07-18-2014, 07:33 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
OK I see what you mean. I know how a bridged amp work, but I didn't think about the possibility that he measured each "half" separately. It makes a lot more sense now. Thanks for pointing it out.
splotten is offline
post #393 of 445 Old 07-19-2014, 03:35 PM
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
The 10kQ outputs 105vRMS per channel at the onset of mild clipping and 116vRMS with heavy clipping, so I guess that's just slightly more than two 12kDSP's at limiters (assuming vRMS).
BassThatHz is offline
post #394 of 445 Old 07-19-2014, 04:33 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
"OK I see what you mean. I know how a bridged amp work, but I didn't think about the possibility that he measured each "half" separately. It makes a lot more sense now. Thanks for pointing it out."
+1 rms across bridged = 0 and that is what the 6000 is doing per channel.
Listen. It's All Good.
LTD02 is offline
post #395 of 445 Old 07-30-2014, 12:33 PM - Thread Starter
thebuckaman's Avatar
Quoted: 21 Post(s)
Liked: 80
Ok. Just got the amp back. Fired it up and logged in. Went to set limiters and......now I can set limiter to 165Vp. Interesting.
Also, they did re tighten the front end so its back to normal with that. They also double boxed it as my original box is not fairing so well with the several trips to Nevada and Cali.
Name:	ScreenHunter_18 Jul. 30 13.24.jpg
Getting things ready for a new theater room build at the new house.
Equipment so far- (8) SI HT18 mini martys, speakerpower SP2-12000, Denon 4311ci (will replace), MINIDSP 10x10HD, Crown CT8150, Oppo BDP-103D, (8)JBL 8320 , (3) EV EKX12 , Crestron CP3N control system, iso clips/Roxul
TBD- Projector, AT Screen, in room acoustics,
thebuckaman is offline
post #396 of 445 Old 07-30-2014, 01:01 PM
dtsdig's Avatar
Quoted: 828 Post(s)
Liked: 914
That is very interesting! It's as if they did something different this time.
dtsdig is online now
post #397 of 445 Old 07-30-2014, 03:07 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
I hooked it up to a multimeter and could only get 103 volts during some sine sweeps.
post #398 of 445 Old 07-30-2014, 10:06 PM
noah katz's Avatar
Quoted: 879 Post(s)
Liked: 304
Not surprising since these aren't designed for continuous high level output, so limiting is invoked.
Any way to do bursts of a second or less?
Noah
noah katz is online now
post #399 of 445 Old 08-01-2014, 05:58 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
I did various test tone bursts under a second. Slight increase of a volt or two
post #400 of 445 Old 08-01-2014, 06:00 PM
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1980
Are you measuring this with a voltmeter or something else?
notnyt is offline
post #401 of 445 Old 08-01-2014, 07:23 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
voltmeter
post #402 of 445 Old 08-01-2014, 07:30 PM
LTD02's Avatar
Liked: 2574
so unloaded and measured with a voltmeter, with limiter set to 165 volts, you get what just before clipping?
and you have sufficient gain to get to clipping?
just curious. :-)
Garidy likes this.
LTD02 is offline
post #403 of 445 Old 08-01-2014, 08:00 PM
Quoted: 311 Post(s)
Liked: 115
Originally Posted by notnyt View Post
Quote:Originally Posted by Scott Simonian
Oh sweet, thanks!
crap vid but you get the idea
Sounds like, I don't know; 'not so good / promising, maybe'... Just pointing out the obvious.
Garidy is offline
post #404 of 445 Old 08-01-2014, 08:03 PM
notnyt's Avatar
Liked: 1980
voltmeter
voltmeter measures rms voltage, but the limiter lists peak. If you're measuring 101 volts with a meter, peak voltage is higher, divide by .707
notnyt is offline
post #405 of 445 Old 08-01-2014, 10:31 PM
LTD02's Avatar
Liked: 2574
"I hooked it up to a multimeter and could only get 103 volts during some sine sweeps."
if the amp is bridged per channel, then 103 volts is +103 on one leg and -103 on the other leg. so the total swing is 206 volts, no?
206 volts rms is 206^2/4 = 5300 watts per channel into 4 ohms. the amp is spec'd for 3400 watts into 4 ohms, so the limitation would seem to be on the current side, not the voltage side.
LTD02 is offline
post #406 of 445 Old 08-01-2014, 11:07 PM
notnyt's Avatar
Liked: 1980
that was bridged? damn thought it was one channel.
notnyt is offline
post #407 of 445 Old 08-02-2014, 02:34 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
You are over complicating it. If 103Vrms was measured at the terminals then that is what the woofer "sees". That is ~2650W measured (assuming a 4ohm load). The limiter can now go to 165Vp = 116.7Vrms. That equates to 3400W into a 4Ohm load. Looks like the 12000 cant swing that much voltage into a 4 ohm load if testing with sine tones or sweeps, but it might do it into a 8 ohm load.
splotten is offline
post #408 of 445 Old 08-02-2014, 02:42 AM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
I'm sure it was one channel. LTD is referring to the way some of these amps are constructed internally. They are essentially 4 amp channels bridged two and two into a 2 channel amplifier.
splotten is offline
post #409 of 445 Old 08-02-2014, 11:05 AM
LTD02's Avatar
Liked: 2574
ok, i thought each leg was being measured relative to ground.
"Power rails measure at +/-84V"
http://forum.speakerplans.com/behrin...opic69202.html
so across the terminals would be a theoretical 168 volt difference. with the limiter at 165 volts peak, that as you show, would give a theoretical 3402 watts into a 4 ohm load per channel and that is right on their spec. for how long it can hold that voltage under varying conditions, how relevant that is to various users, and how that compares to other amps are of course the big questions.
http://www.behringer.com/EN/Products/NU12000DSP.aspx
not, each side of the amp is itself already bridged (this means the channels can't be bridged further), which may be why there was some confusion in how to measure the amp and calculate its power.
LTD02 is offline
post #410 of 445 Old 09-06-2014, 09:57 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 348
My gut feeling still tells me the performance of the non-dsp Inuke 12000 will be much better than this. Anyone have plans to pick up a non-dsp Inuke 12000? I want to get one but Im waiting for AmericanMusicalSupply to get them in stock.
Swolephile is offline
post #411 of 445 Old 09-07-2014, 01:43 AM
LTD02's Avatar
Liked: 2574
is the second picture 'twice the amp' as the first picture?
btw, the caps are 2200 x ? and 3300 x ? (from another picture). the 6000 employs 4x 2200x220v 4x3300x100v, so probably the same caps, but also 8x1000x100v that disappeared from the 12000?
Name:	6000 internal.jpg
ID:	250826   Click image for larger version
Name:	12000 internal.jpg
LTD02 is offline
post #412 of 445 Old 09-26-2014, 04:05 PM
subbass's Avatar
Quoted: 66 Post(s)
Liked: 29
These result are not that bad in my opinion.
Or did you guys really expect it could deliver 12000W for 1 hour
The current limiter just has to kick in.
How does it perform on a music signal ?
subbass is offline
post #413 of 445 Old 09-26-2014, 04:15 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5282 Post(s)
Liked: 4165
I was hoping for ~4-5kw burst output. Something along the line of double the iNuke6000. Reasonable expectation, imo.
Scott Simonian is online now
post #414 of 445 Old 09-26-2014, 04:27 PM
lukeamdman's Avatar
Quoted: 1072 Post(s)
Liked: 1190
In another thread, he compared the inuk12k to the ipr2 7500 and the 7500 was more powerful...
Nothing 12k about this thing.
lukeamdman is offline
post #415 of 445 Old 09-26-2014, 06:41 PM
Starquester's Avatar
I personally expected the amp to perform on par with the other inuke offerings. 3000=2000wrms, 6000=4000wrms etc... I expected the 12000 model to deliver 8000wrms.
As it stands now, and please someone correct me if I'm wrong, it makes more sense financially to just use two inuke6k's instead of the 12000. Unless someone absolutely only has room for one amp I suppose.
Starquester is offline
post #416 of 445 Old 09-26-2014, 07:54 PM
BassThatHz's Avatar
Liked: 1547
The 12k is 2-ohm stable, the 6k isn't.
How many volts does a ipr2 7500 output?
post #417 of 445 Old 09-26-2014, 08:58 PM
lukeamdman's Avatar
Liked: 1190
Originally Posted by bassthathz View Post
the 12k is 2-ohm stable, the 6k isn't.
124?
post #418 of 445 Old 09-26-2014, 10:34 PM
BassThatHz's Avatar
Liked: 1547
In order to meet it's spec of 1250 @ 8, the 7500 it only needs 100vRMS.
sqrt(1250w * 8ohm) = 100v
sqrt(2022w * 4ohm) = 90v
sqrt(3750w * 2ohm) = 87v
Assuming the power supply could provide the amperes needed.
For the 12k:
sqrt(1700w * 8ohm) = 117v
sqrt(3400w * 4ohm) = 117v
sqrt(6000w * 2ohm) = 110v
So the 12k needs to reach 117v, otherwise it ain't to spec.
The Crown iTech 8000:
sqrt(2100w * 8ohm) = 130v
sqrt(4000w * 4ohm) = 127v
sqrt(3500w * 2ohm) = 87v
What I actually measured from it was 148v, so it has enough voltage to exceed it's spec. It was independently tested as being able to do somewhere around 9-10kW.
If the iTech 8000 had a slightly better SMPS with a less aggressive limiter it would actually beat the PowerSoft K10; and for the first 2 seconds at dual 4-ohms it actually does beat it as-is by 2000watts total.
As far as bursting goes the iTech 8000 is a monster, and for bridging into a 4ohm load the K10 is a monster (12-15kW for 1 second).
At 8-ohms for the first 80seconds the iTech beats the K10 by about 800watts total.
On Average both of them can do about ~5-6kW for about ~1minute, give or take. Which is a lot of power for a coil to heat up with.
LTD02 likes this.
post #419 of 445 Old 09-26-2014, 10:44 PM
splotten's Avatar
Quoted: 268 Post(s)
Liked: 108
Originally Posted by lukeamdman View Post
124?
The max output voltage on the IPR2 7500 is highly load and frequency dependent. The prolite 7.5 which is similar, but not a lesser amp, says 124V max in the spec sheet. However It also says:
"Rated Watts 2ch x 2 ohms 4800 watts 20ms repetitive burst / 3790 watts 1% THD both channels driven @ 1kHz."
3790W into 2 ohm is 87V. Note that it takes 50ms to complete one cycle at 20 Hz. Therefore the 4800w, 20ms burst rating is of no value (IMO).
"20Hz - 20kHz, 2ch x 2 ohms, <0.5%, @ 3390 watts 20Hz to 4kHz, decreasing to 3100 watts @ 20kHz, both channels driven."
3390W into to 2 ohm is 82.3V. IMO this is the value that is relevant regarding 2 ohm subs.
http://www.peaveycommercialaudio.com...es/ProLITE-7.5
splotten is offline
post #420 of 445 Old 09-26-2014, 10:57 PM
BassThatHz's Avatar
Liked: 1547
Well... it has value if: you are driving a kickbin, midrange or tweeter array 50hz-20kHz and need a high burst of power. A drum snap with cymbal at a concert. So not totally useless.
A quick 50-120hz thump in a HT action movie perhaps.
