Who wants to see the Inuke12000DSP tested? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
Old 03-10-2014, 11:22 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1554
I really think I should change my name to John Smith, watcha' think? wink.gif
nobody will notice
BassThatHz is offline
Old 03-11-2014, 01:16 AM
BassThatHz's Avatar
Liked: 1554
Solution.
BassThatHz shall buy every amplifier that is to be tested.
Honestly it makes the most sense....
Absolutely Scott.
Sky's the limit, right?
https://www.cirquedusoleil.com/en/api/cpvs/phoenix/verification.aspx?targetitem=E4B159F6-E535-4024-8FC7-711BAFDBB6F3&partneritem=BD85462A-2625-432B-8C12-90F8C323DCBA&lang=en
Old 03-11-2014, 07:27 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Lol @ that picture of the PC with cigs and beer cans. Just lol.
Mfusick is offline
Old 03-11-2014, 08:30 AM - Thread Starter
thebuckaman's Avatar
Quoted: 21 Post(s)
Liked: 80
So....as we expected...nobody local to test the amplifier. Do you guys think we can raise $300 for shipping alone to send the amp to bassthathz?
Getting things ready for a new theater room build at the new house.
Equipment so far- (8) SI HT18 mini martys, speakerpower SP2-12000, Denon 4311ci (will replace), MINIDSP 10x10HD, Crown CT8150, Oppo BDP-103D, (8)JBL 8320 , (3) EV EKX12 , Crestron CP3N control system, iso clips/Roxul
TBD- Projector, AT Screen, in room acoustics,
thebuckaman is offline
Old 03-11-2014, 12:51 PM
djarchow's Avatar
Liked: 27
Maybe you could get Brian Oppegaard from Speakerpower to test it. He has done comparative testing on a number of amps. He certainly has the equipment and knowledge, though I doubt has much spare time.
http://www.speakerpower.net/comparative-performance.html
djarchow is offline
Old 03-11-2014, 01:29 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
Originally Posted by paskal9 View Post
care to explain what is a spec-an?
Spectrum analyser.
and also, i find it hard to believe that a soundcard will give less distortion than a signal generator.
Believe whatever you want. I have quite a bit of experience in measuring analog signals, and my experience tells me different. Most signal generators theses days, such as those in an Audio Precision are digital and there are many good soundcards out there such as the MAudio 24/192 and the EMU1212 that better any analog generator I've seen available at a similar price. Much, much more flexible too.
A9X-308 is offline
Old 03-11-2014, 01:42 PM
notnyt's Avatar
Quoted: 2155 Post(s)
Liked: 1982
notnyt is offline
Old 03-11-2014, 08:09 PM
paskal9's Avatar
Liked: 24
Originally Posted by A9X-308 View Post
Spectrum analyser.
i still have an EMU0404 from my hifi days. which i stored in some box somewhere.
speaking of which, i also have a spectrum analyser.
if measurement precision is the utmost priority, then it's gonna be too expensive for the average person to carry out these tests.
furthermore, it's audio. it makes no difference 0.1% THD and 0.000000001% THD. the human ear can't differentiate that small. the speaker driver and room will add a lot more distortion to it.
it's nice to throw around numbers. but at -120db?
that's 2 microvolt-something. do an average person have access to measure something that low? i do. do you?
paskal9 is offline
Old 03-11-2014, 10:06 PM
A9X-308's Avatar
Liked: 951
My point was that it takes a decent soundcard and appropriate software to do audio <50kHz BW to high precision.
The point is to have the measurement gear enough better than the lowest level signal you need to detect reliably. The point of this test is to see how an amplifier performs so doing it with poor test gear defeats the purpose. You also need the test gear to be quiet to do good SNR tests.
Yes, easily.
Yes. And yes.
A9X-308 is offline
Old 03-11-2014, 11:27 PM
thylantyr's Avatar
Have the camera rolling to capture any smoke if it manifests.
Scott Simonian and jpmst3 like this.
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
Old 03-11-2014, 11:53 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5284 Post(s)
Liked: 4168
It was only a matter of time...
Scott Simonian is offline
Old 03-12-2014, 03:53 AM
paskal9's Avatar
Liked: 24
Yes, easily.
Yes. And yes.
then i rest my case.
good luck.
paskal9 is offline
Old 03-12-2014, 06:50 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 03-12-2014, 11:44 AM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
... it makes no difference 0.1% THD and 0.000000001% THD. the human ear can't differentiate that small.
That may not be as safe as assertion as it seems; IIRC .1% can be audible depending on the fundamental and which harmonic, i.e. 20 Hz and its 6th harmonic at 1280 Hz.
Noah
noah katz is offline
Old 03-12-2014, 11:50 AM
Bass Enabler
Liked: 4168
I think he was overemphasizing the circumstances but you are right too. wink.gif
Old 03-12-2014, 09:09 PM
paskal9's Avatar
Liked: 24
the thread focusses on measuring an amp for sub duties.
which affectively limit the range to about 5hz - 200hz.
sure, a 500mhz scope, or a spectrum analyzer, or a signal source precise to a single microvolt, or a high end audio precision equipment is nice, and increase the measurement accuracy;
but you don't need to go high end since the bandwidth is low.
realistically speaking, it's gonna be hard to find someone with all that high end measurement gear to do these measurement for free.
0.1% thd vs 0.01% thd doesn't mean a thing when audio is concerned. more so with subs. check the distortion tab in rew.
paskal9 is offline
Old 03-12-2014, 10:10 PM
A9X-308's Avatar
Liked: 951
^^ There are already a number of amp tests on this site, so why not measure the 12k to the same standards and then let the results be comparable?
And as I've already stated, there is likely very little gear the OP needs beyond s/c and something to interface to get signals within the range of the s/c. Pete Millett has a kit, but it's a bit of overkill.
A9X-308 is offline
Old 03-13-2014, 02:13 AM
Bass Enabler
Liked: 4168
Originally Posted by jpmst3 View Post
I love it when I am fortunate enough to witness a Thy sighting. Him an his 2ohm, multi-kilowatt arrays.
Old 03-13-2014, 03:49 AM
chrapladm's Avatar
Quoted: 824 Post(s)
Liked: 286
I remember him saying he tested the tweeters at 1ohm also. LOL Tonnes of knowledge he has. biggrin.gif
chrapladm is offline
Old 03-13-2014, 04:17 AM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Anyone contact Steve Meade from www.stevemeadedesigns.com/‎ to test the amp? Easiest way to measure the amp would to use one of his amp dyno's. http://www.wccaraudio.com/smd-amp-dyno-ad-1.html
Manic1! is offline
Old 03-13-2014, 01:39 PM
BassThatHz's Avatar
Liked: 1554
You likely won't be able to compare my results with that of others.
1) My scope is entirely different (so it "might" be like comparing apples to oranges).
2) My DAC is entirely different. (Although -130db and flat to at least 3hz +-0db, maybe even 1hz... we will find out soon enough.)
3) Some were holding the voltage steady using variacs.
4) Different heater elements / resistance / thermal handling, blaa blaa
5) Temperature, humidity and altitude. I live over 1000ft above sea-level and humidity can fluctuate between 0% and 100% here.
That said; testing my EP4000 will establish a base-line from which to compare to the other online tests (so not all is lost).
My meter will be here in just a few more days.
Old 03-14-2014, 05:29 PM
BassThatHz's Avatar
Liked: 1554
Originally Posted by Manic1! View Post
Anyone contact Steve Meade from www.stevemeadedesigns.com/? to test the amp? Easiest way to measure the amp would to use one of his amp dyno's. http://www.wccaraudio.com/smd-amp-dyno-ad-1.html
for $2800?
HELL no, I wouldn't buy that unless I had to:
Water Heater elements = $40-70
Garbage Pale = $10-20
Water = Free
The only expensive part is the measuring device.
Besides, the SMD Dyno doesn't tell you the THD or PF or show the waveform (volts and current) etc; and you have no control over the goings on of things.
and it only measures burst power in RMS.
If it sold for $250 and without the load bank, and that the load bank was externally attached B.Y.O. , then it would be a good deal (for something quick and dirty).
Old 03-14-2014, 06:08 PM
SpeakerPower's Avatar
Quoted: 46 Post(s)
Liked: 95
Somebody mention my name? There are 1 or fewer people with my name in the U.S.A.
So glad I found this thread! Looks like fun! Can I play too? I have gear:
Audio Precision System 22 with burst generator
Audio Precision AUX-000025 Switching Amplifier Measurement Filter
Valhalla 2301 Digital Power Analyzer
Tektronix 2465B scope
8 x 1500W 8 ohm non inductive load resistors
Powerstat 50A variac
Topaz 5KVA ultra-isolating transformer
50A 120/208VAC mains
And I just created an Audio Precision test that does the 40Hz sine wave versus time sweep like in the new CAF (Common Amplifier Format) http://www.prosoundweb.com/article/apples_vs_apples_introducing_the_common_amplifier_format_caf/
PM me with where to send the UPS call tag and I will test the beast and post the results.
Brian
BrickTop, notnyt, blah450 and 1 others like this.
SpeakerPower is offline
Old 03-14-2014, 06:29 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 03-14-2014, 06:48 PM
notnyt's Avatar
Liked: 1982
Brian
You win this thread.
notnyt is offline
Old 03-14-2014, 07:40 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 80
Brian
Oh my gosh. Our dreams have come true! I will pm you Brian. You are awesome sir! Awesome! biggrin.gif
Old 03-14-2014, 08:06 PM
steve nn's Avatar
Liked: 433
Throw that thing on the bench! now we’re movein.. way to go Brian.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 03-14-2014, 08:54 PM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
If you'd like to toss an IPR7500 into the mix I'd be willing to contribute one as well.
tsloms is offline
Old 03-14-2014, 10:34 PM
BassThatHz's Avatar
Liked: 1554
Brian
Brian your meter has a lot of nice capabilities.
But why then, with all that nice gear, in this test here you didn't show any of that?
Just the output wattage, for seemingly-random amounts of non-comparative time at mostly-unknown frequencies?
Why not post the FULL details here on AVS? the FR, THD, SNR and all that. (If you saved them, that would be awesome.)
Ok, maybe your target audience on your website is meant for the average-joe who would otherwise be confused and overloaded by all the metrics thrown at them. (Fair enough, I could understand that.)
However, when I conduct my tests here on AVS, I will hold nothing back, all will be revealed, good or bad; and it will be fully documented to the maximum detail possible.
Also since we are back on this topic, I don't think you ever did answer my question when I originally asked you why you thought the iTech12k was too "powerful" for the 50amp circuit to seemingly "handle" on the dual 2-ohm test,
does it deliver the juice or doesn't it? Doesn't matter what the efficiency is. So it costs $100 per year more to operate, no biggie, just fully document all the abilities of all the amps wink.gif
No offence but, I can't help but think that you will tend to bias the tests in favor of your SpeakerPower brand amps. (and as you should, being the CEO\CTO of the company and all wink.gifbiggrin.gif)
With all that nice gear, we will all be expecting a test equal-to or better-than the detail provided in the existing AVS measurment-thread of 7 years ago: http://www.avsforum.com/t/855865/measuring-amplifiers
Old 03-14-2014, 10:56 PM
Manic1!'s Avatar
Quoted: 172 Post(s)
Liked: 73
Originally Posted by BassThatHz View Post
for $2800?
Water = Free
He does amp test Tuesdays on his site where people can sent in amps to get tested.
Manic1! is offline
