MFW-15 - Dual Opposed or Marty Cube style - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-06-2014, 08:59 AM - Thread Starter
Big Stogie's Avatar
I recently got some more of these from a friend and want to build a couple cabinets. I know that Dual Opposed has been done with good success before but I used WinISD and they look pretty good in a 7Cube slot ported box as singles now I am sort of torn, any feedback or thoughts? I know this is a blast from the past but I just ran into more of these.
BigStogie
Big Stogie is online now
post #2 of 14 Old 03-06-2014, 02:50 PM
desertdome's Avatar
Quoted: 1125 Post(s)
Liked: 1227
I'll be interested in what you decide. I still have two more MFW-15 drivers and am trying to decide what I'll do with them. So far I've done two Lilmike Cinema F20's and four dual opposed.
High Impact AV
desertdome is online now
post #3 of 14 Old 03-06-2014, 04:37 PM
steve nn's Avatar
Liked: 433
Cool! What size room are you in and is it open? Can you post your sim in 7cf?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 14 Old 03-06-2014, 11:08 PM
maxcooper's Avatar
Quoted: 13 Post(s)
I've got two mfw-15 drivers collecting dust, too. 😀 I look forward to seeing what you choose and build.
-Max
maxcooper is offline
post #5 of 14 Old 03-07-2014, 04:50 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I have two MFW-15 drivers as well, one of them is still in the stock MFW-15 cabinet from AV123, but, it has a blown amp. I wonder what kind of output and extension could be had out of two separate, large, low tuned, ported enclosures?
Martycool007 is offline
post #6 of 14 Old 03-07-2014, 08:53 AM
robotbunny's Avatar
Stogie, depends on your room, but I'd go two LLT's or a pair of F20's. The sim I ran (two drivers ported in 7ft^3 ea., 15Hz tuning, 300 watts ea., 24hz highpass, slot port 15x3x30.25) get's you ~6dB more output over two sealed at 4ft^3 ea. before room gain.
I'm running mine sealed now for space and WAF...really want to build the F20's tho. They pressurize my room pretty good.
There are obviously better drivers out there, but that's what was so cool about the MFW-15's...price/output. I paid $80 ea. for mine. cool.gif
-Nate
robotbunny is offline
post #7 of 14 Old 03-07-2014, 09:00 AM
robotbunny's Avatar
Cool man. Well, as you know, you'd have to double your drivers to gain 6dB. So adding two more into the mix won't gain you much, perhaps a db or two. You may just wanna go with a pair of sealed to improve FR (if you need to improve it that is). Those must sound awesome btw. smile.gif
-Nate
post #8 of 14 Old 03-07-2014, 09:16 AM
desertdome's Avatar
Liked: 1227
-Nate
The four dual opposed are at WOOlly's Copper Fields Cinema and the F20's are now owned by stormwind13 and recently participated in the Armageddon-Subwoofer GTG Aug 24th 2013, Burnsville MN. I'm just building out another sub either for another room in the house (my son wants it in his bedroom) or for my parents house.
High Impact AV
post #9 of 14 Old 03-07-2014, 09:27 AM
robotbunny's Avatar
^ Coo, thanks for the links...looks like they went to good homes. I'd still say LLT or F20 for these drivers, unless the room is good for a pair of sealed. They sound pretty sweet sealed...you know.
-Nate
post #10 of 14 Old 03-07-2014, 10:25 AM - Thread Starter
Big Stogie's Avatar
I am going to do 7CU/FT tuned to 20HZ 2" X 17.25" port they are going to to be pretty big but they are going in my basement which is pretty large I can fit them. If they are not enough I will build 2 more eek.gif
post #11 of 14 Old 03-08-2014, 06:56 AM
Quoted: 280 Post(s)
Liked: 176
So wrt to the MFW-15 drivers, what would be the best enclosure type & size if you wanted them to focus on the 30hz to 80hz region? The reason I ask, is because I have two MartySubs that cover the sub-20hz stuff great, and being that I have a few of these MFW-15's lying around, I might as well do something useful with them!
post #12 of 14 Old 03-08-2014, 03:40 PM
thucker's Avatar
Quoted: 65 Post(s)
Liked: 24
I have a pair of MFW-15s sitting round too. I am going to be building end table subwoofers with them in a 3cuft sealed box/table. They'll be placed on each side of the couch / back corners of the theater room to provide backup support for my two sealed SI-18s in the front.
It's probably overkill for my 14x20 room, but...... biggrin.gif:D:D:D
thucker is offline
post #13 of 14 Old 03-09-2014, 06:06 AM
Quoted: 280 Post(s)
Liked: 176
What would be a good enclosure size for a single, large, low tuned MFW-15 cabinet?
I have two of these drivers and a spare Crown XLI2500 that I have been wanting to do something with. They would have to play nice with my other MartySubs that utilize the Dayton HO18's in the original MartySub. That might be an issue. I am powering my MartySubs with a regular non-dsp version of an iNuke3000. So I might have to pick up a balanced MiniDsp 2 by 4 with the advanced plugin.
Is it possible to build a ported enclosure that would get more output, and/or extension than the stock enclosure for the MFW-15? If so, what would be the optimal enclosure specs?
post #14 of 14 Old 06-21-2014, 08:25 PM
jkkwaz's Avatar
Quoted: 63 Post(s)
Liked: 32
Hey guys,
I am helping out a friend and replacing the amp that went out on his MFW-15 in the stock AV123 enclosure. I'd like to set up a HPF to keep the driver from reaching excursion limits with the Crown XTi 1000 that I'll be using. What should I use? HP Butterworth 24 db/oct? Set at 22Hz? He is a VERY casual listener and I'd like to set it up to be as bulletproof as possible for him. Thanks!
jkkwaz is offline
