Stereo Integrity HT-18-D4... Infinite Baffle...How Much "Safe" Power Per Driver ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 80 Old 03-10-2014, 03:39 PM - Thread Starter
TinnEars's Avatar
Liked: 74
Per the title...
I have four Stereo Integrity HT 18 D4 for IB install via two manifolds. How much RMS power can each driver "safely" handle (using both voice coils)? Estimates are okay!
OR... What is an acceptable rule-of-thumb regarding "rated specs" (which are probably assuming enclosed) vs. IB? 25 percent, 50 percent, 75 percent? Estimates okay!
TinnEars is offline
post #2 of 80 Old 03-10-2014, 03:42 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5837 Post(s)
Liked: 4837
Keep it within RMS ratings (600w) per driver. No need for more.
How large of an area is your HT space?
Scott Simonian is online now
post #3 of 80 Old 03-10-2014, 05:16 PM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
As per above, keep within rated specs and you should be safe.
WinISD can model excursion for an effectively IB design (just model as a massive sealed box) to give you more confidence.
MemX is offline
post #4 of 80 Old 03-10-2014, 05:37 PM - Thread Starter
TinnEars's Avatar
Liked: 74
The listening space is 16x24x9. So I can safely power each subwoofer with 600w RMS? I don't have WinISD and honestly am losing my ability to function so I'd rather not try. I'm just trying to enjoy my time for now.smile.gif
TinnEars is offline
post #5 of 80 Old 03-10-2014, 10:08 PM
Kriszilla's Avatar
Running in IB you may not even need all 600 watts to drive them to xmax. You could always test them free-air so that you can dial in the gain to set your max threshold.
Kriszilla is offline
post #6 of 80 Old 03-11-2014, 04:47 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 180
So does the SI 18HT D4/D2 make for a decent IB driver? What about the SI 15HT D4/D2 or a set of Dayton HO18's?
Martycool007 is offline
post #7 of 80 Old 03-11-2014, 06:47 AM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
Modeling in Winisd in an infinite baffle, 600 watts total (150 watts per driver) puts them at xmax at 10Hz, never exceeding the xmech. 200 watts per driver is the limit to stay safely within the mechanical limits of the driver without a high pass filter. 600 watts per driver is overkill, pushing them to xmax at 23 Hz and beyond Xmech at about 12 Hz.
gworrel is offline
post #8 of 80 Old 03-11-2014, 07:41 AM
Thomas-W's Avatar
Quoted: 22 Post(s)
Originally Posted by gworrel View Post
200 watts per driver is the limit to stay safely within the mechanical limits of the driver without a high pass filter..
Were it only that simple....
The OP is attempting to create a situation where regardless of how the system is driven the drivers can't be damaged.
That's problematic; if he stays to the 200 watts/driver and a signal comes to the amp that causes it to go into hard clipping, (due to insufficient power) that has the potential to do as much damage as does exceeding Xmech with a higher powered amp.
The 'best' solution in this instance is probably to use an amp with a bit more power combined with a high-pass filter. That way there's adequte power for large transients, but the drivers have protection via the high-pass filter.
Scott Simonian likes this.
Thomas-W is offline
post #9 of 80 Old 03-11-2014, 08:25 AM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
Wouldn't it also be possible to set the gain structure so the amp will not go into clipping at maximum volume? Or use an Inuke amp with dsp and set the maximum output there? You're right though, it is not as simple as I stated.
gworrel is offline
post #10 of 80 Old 03-11-2014, 08:58 AM
Thomas-W's Avatar
Quoted: 22 Post(s)
One would need a system that 'clamped' the input voltage to a set max. Easy to talk about probably not as easy to implement
Sorry, I'm not familiar with the DSP capabilities of those amps
Thomas-W is offline
post #11 of 80 Old 03-11-2014, 11:40 AM - Thread Starter
TinnEars's Avatar
Liked: 74
Okay, so 200-300 watts amp power per driver is more than enough and I need to implement some way of avoiding more than 150-200 watts to each. This avoids both amp clipping and reaching driver Xmech. Good to know. Anyone know how to limit amp output... maybe some sort of compressor/limiter? Or maybe low power breakers of fuses at the amp outputs?
TinnEars is offline
post #12 of 80 Old 03-11-2014, 12:05 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
The iNuke DSP models have voltage limiting as a DSP feature.
moosifee is offline
post #13 of 80 Old 03-11-2014, 12:20 PM - Thread Starter
TinnEars's Avatar
Liked: 74
I'd like to try and avoid class D amps. Will a DCX2496 or DEQ2496 perform the same function?
TinnEars is offline
post #14 of 80 Old 03-11-2014, 12:43 PM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
Why?
No.
moosifee is offline
post #15 of 80 Old 03-11-2014, 12:58 PM - Thread Starter
TinnEars's Avatar
Liked: 74
Why?
No.
I'm not convinced that class D has reached true hi-fi capability. For instance, the Behringer iNuke amps I've looked at have damping factors of about 140. Yes, I know folks will argue this isn't important but in my experience high current amps with high damping factors seem to produce more articulate bass... the older big Adcoms to mind.
TinnEars is offline
post #16 of 80 Old 03-11-2014, 01:15 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1139
For sub amps? Good grief. Driver non linearity will vastly outweigh any distortion that the amp produces, irrespective of class.
As for class D not being high fidelity, you need to look at Hypex for wide band units.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #17 of 80 Old 03-11-2014, 01:19 PM - Thread Starter
TinnEars's Avatar
Liked: 74
No, it's not distortion characteristics nor even poorly filtered high frequency switching (not that either are issues with iNuke amps). It's the low damping factor. I realize some class D amps are advertised as having 400+ damping but I've read that this can be misleading in class D amps. I wish I had a way to audition some without wasting a retailer's time but I don't. Is there no other way to set up a limiter other than going with iNuke amps?
TinnEars is offline
post #18 of 80 Old 03-11-2014, 01:27 PM
A9X-308's Avatar
Liked: 1139
Which is irrelevant. What is the DF at the end of 10m of cable, i.e. actually at the drivers where it's relevant? Run the numbers using DF of 140 and 400 and whatever gauge of cable you use and get back to me.
A9X-308 is offline
post #19 of 80 Old 03-11-2014, 02:40 PM - Thread Starter
TinnEars's Avatar
Liked: 74
I don't know how to do that and can no longer learn new things. All I know is what my ears tell me. Like I stated, I wish I could audition some class D amps but I can't. I'm very open minded provided I can be shown (can hear) the facts. Maybe my best bet is to buy an amp, test it, and sell it if I don't like it. But finding amps I like could take months and lots of lost revenue.
TinnEars is offline
post #20 of 80 Old 03-11-2014, 02:46 PM
Bass Enabler
Liked: 4837
Or you could take our word for it since you are here asking us. Just a thought. wink.gif Obviously you are free to make your own decisions.
There is no reason to believe that the iNuke amps or similar would not provide excellent SQ, especially for this application. Something like the iNuke3000 would be great for this. Just pick the one with DSP built in or not.
post #21 of 80 Old 03-11-2014, 02:53 PM - Thread Starter
TinnEars's Avatar
Liked: 74
Hmm... "trust". if you knew me then you'd know how much you're asking. biggrin.gif
Okay, I'll try the iNuke amps. I stated that I have two pairs of SI HT 18 D4 drivers and that's true but I also have a third pair of subs with very similar T-S parameters. I'll need three amps capable of delivering 200-300 watts to each driver into 4 or 16 ohms bridged. I prefer the safer/lighter load but don't want to (can't afford to) waste funds. Which would you do... larger amps bridged at 16 ohms or smaller amps at 4 ohms?
TinnEars is offline
post #22 of 80 Old 03-11-2014, 02:56 PM
Bass Enabler
Liked: 4837
If you feel like something more 'old-fashioned' would do the trick. wink.gif Then really take a look at the Behringer ep4000. That's your guy. biggrin.gif I figured you had alluded to a more ... "advanced age" to put it delicately, so I thought you might appreciate the lightweight chassis of the inukes. I love the old school amps too but these new inukes are the real deal it seems.
One or the other, really, you'll be more than fine. If you want something good and cheap, get the ep4k but if you want to save some weight too then try out the inuke's.
post #23 of 80 Old 03-11-2014, 02:59 PM - Thread Starter
TinnEars's Avatar
Liked: 74
Weight isn't an issue since this is for home audio and home theater... once installed they won't be moved. My concern is best sound quality for the money spent. I do care about efficiency but far less than sound quality.
Two things that bother me: 1. Flabby bass, 2. Gritty mids and highs.
TinnEars is offline
post #24 of 80 Old 03-11-2014, 03:07 PM
Bass Enabler
Liked: 4837
If it helps, I'm using both amps in both midbass and subwoofer use and I can't tell a difference in SQ at all. I'm still using class A/B for mids/highs though.
post #25 of 80 Old 03-11-2014, 03:17 PM - Thread Starter
TinnEars's Avatar
Liked: 74
Which would you folks choose: (1) a single iNuke NU6000DSP bridged into six ohms to feed all six subwoofers, or (2) three iNuke NU3000DSP bridged at 4 ohms into three pairs? For now let's not consider cost.
TinnEars is offline
post #26 of 80 Old 03-11-2014, 03:38 PM
Bass Enabler
Liked: 4837
Trick question.
Wait. What? You have four d4 18's don't you? That's simple. Just a single 3000 or 6000 would be more than adequate for the job.
post #27 of 80 Old 03-11-2014, 03:45 PM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
If the sub drivers are not all matching then you don't want to run them off of a single amp channel. Actually, using one NU3000dsp in stereo might be sufficient. Run the 4 SI18s off one channel in 2 ohms, run the second pair off the second channel as a 4 ohm load. Adjust levels and voltage appropriately for each channel.
To answer one of your earlier questions: While the DCX2496 does not have a voltage limiting function, it would allow you to set a high pass filter which would be another way of avoiding ruining your drivers, as Thomas pointed out. I like the iNuke dsp option better.
gworrel is offline
post #28 of 80 Old 03-11-2014, 03:49 PM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
Scott, you missed: "but I also have a third pair of subs with very similar T-S parameters."
gworrel is offline
post #29 of 80 Old 03-11-2014, 03:56 PM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
The NU3000dsp puts out 1000 watts/ per channel into 2 ohms. 600 watts per channel into 4 ohms. So using one channel to power 4 drivers gives you 250 watts/ driver. The other channel into 4 ohms gives you 300 watts per driver. I am not sure how much trouble it would be to balance the output. Someone else might have a better idea. The dsp gives you a lot of flexibility to tailor the output so this should certainly work.
Independent measurements of the NU3000dsp here: http://www.diyaudio.com/forums/class-d/213071-behringer-inuke-nu3000-measurements.html
gworrel is offline
post #30 of 80 Old 03-11-2014, 03:59 PM
Bass Enabler
Liked: 4837
*screeching tires*
Noooooo... I did not.
Hmm.. Similar T/S?
Tinn.... what are these other drivers?
