AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   DIY Speakers and Subs (http://www.avsforum.com/forum/155-diy-speakers-subs/)
-   -   Give me the FULL Marty! (http://www.avsforum.com/forum/155-diy-speakers-subs/1522587-give-me-full-marty.html)
sooly1 03-14-2014 05:36 PM
The build has started! I have never built a thing in my life. Thankfully a couple buddies are handy.
Full Marty
Si 18 D2
Inuke 3000dsp
8 2x4 Handy panels of 3/4 MDF
Following the one cut directions.
Tightbond 2, brad nails, screws.
I have all the wood cut and items above have been delivered.
Pictures of the progress are on my phone. I'll upload after dinner.
Couple questions.
The sub fits great but we used a jigsaw. Should I throw a bead of silicon down just as a precaution?
Should I put some wood around the baffle so the screws have something more to bite into?
How far do I push the double front baffle in from the front, or is pushing it in mainly to put a grill on flush with the front
Do I HAVE do flush mount the driver?
The 3 inch slot supports are truly 3 inches tall and 47 inches long? Or does the length not matter as long as they are at least the length of the port?
You all are incredible....I don't think anyone else but you guys understand why I am doing this... my buddies were trying to understand why something like the 2 8 inch subs in a bandpass box that was in his daughters jeep wouldn't be enough... or why would you need more than the HTIB Onkyo 10 I currently have (80 watts). They will understand when we are done lol
chalugadp 03-14-2014 06:02 PM
13 Attachment(s)
You don't have to flush mount. Much easier to surface mount. Do not use silicone to hold down sub. Mount the baffle flush with the front if you don't use a grill.
Good luck !
tential 03-14-2014 06:03 PM
Why I need more......
The short answer:
You can't get what you REALLY want unless you do it yourself sometimes lol.
sooly1 03-14-2014 06:11 PM
Thanks Chaluga, your info has been amazing. I was so close to getting the flat from you. but I also wanted to do this to prove I can... may sound odd, but its going to be worth it.
Yes if you want it done right... you have to copy a design from this forum tongue.gif I can't stress how thankful I am for all the information.
Chaluga if I have air leaking, what should I use.... or recut?
kevings 03-14-2014 06:18 PM
Sooly1,
Best of luck on your build! I'm looking forward to watching your progress. Im also a Marty sub fan ( im just about to finish my full size marty, and i finished my marty cube about a week ago ). ps- perhaps i missed it, but how are planning on finishing the sub?
sooly1 03-14-2014 06:39 PM
Kevings, indeed, I have been hawking these forums and reading every update since you started your build lol. My wife and I left for Jamaica THE DAY my 3000dsp arrived, (the final piece). I spent an incredible week at the Jewel in Ocho Rios...I had to forget I had this build waiting for me when I got home.
There are a few options I have seen for finish. My buddy owns a flooring store and we kicked around the idea of tile. That may make the marty WAY WAY to heavy and matching tile to my room may prove difficult. Another idea was flat black paint..but people will be drinking in my theater room sooooo that was tossed. That Duratex stuff looks great as well. Short story long, I havn't decided haha.
Just to give you all an idea, here is a glimpse of the room before it was done. At this point, about a year later, the screen has warped, I'm not happy with my monoprice in wall speakers, my HTIB 10 sub was letting me down the more movies we watched,my HTIB Onkyo receiver doesn't do HDMI audio or 3d, BUT, I still love the projector. W1070.
chalugadp 03-14-2014 06:50 PM
13 Attachment(s)
No problem doing it yourself .. I know the proud feeling your going to have. Depends on how big and where. If your joints are tight then just put a bead of dap silicone on the inside seams . If its a 1/8" gap then pl construction adhesive. Use speaker gasket tape underneath the sub. Take a picture if you run into a problem. Tonnes of folks here will help. wink.gif
kevings 03-14-2014 06:58 PM
A week in Jamaica, and now the fun of building a marty sub.....life is treating you well right now! : )
an idea that may help you out....google "custom hometheater subs" or something like that and look through all the different images....you'll see plenty of different finishes and perhaps ID something you really like. If you hot for tile, you could always use it, but just not cover the sub from top to bottom with it, to keep the weight down. In the future, ill be building a ported box, for a 12 inch sub that i have, and im planning on using some glass tile ribbon ( avail at home depot ) along the perimeter of the enclosure. Should make for a pretty unique little sub. Also, check out some of the veneers to that are out there. They cost some money, but your gonna have this sub for who knows how long..so whats a few bucks if it's gonna make you happy every time you look at it.
Regarding duratex...it's a pretty killer finish. Some dont like it and think it looks a little to pro audio / not sophisticated enough, but i disagree. You can control the amount of texture, to get the look you want, and it's rock hard once dry, which will be good if one of your drinking buddies happens to wack the sub accidentally.
Regarding your room.....do you have a pic of how it's currently looking? I always love checking out other peoples setups.
sooly1 03-14-2014 07:01 PM
I'll have more as we finish it up.
We mocked it up and found that the vent supports were to long, so I need to trim them back. Other than that it was all square. Ready to be brad nailed, glued, clamped, braced, and woofed
By the way, the subwoofer cut out that you see is the BACK. not the side that will fit on the sub. It is not a very good cut as you can see lol.
sooly1 03-14-2014 07:22 PM
This is the room, as of right now sitting in that ratty old chair by the laptop lol. There is so much to be done yet, like a ceiling, and that HUGE black wall is my brick basement foundation coated to death with black paint and waterproofing paint. All of my seats are third row seats from SUVs or minivans. My neighbor welded bases on them. The carpet on the wall was from a casino bingo place my buddies carpet store installed and they had it left over. Kids toys up front in the seats, This entire room was a terrible basement with cracking cement floor that we refinished, then put up the walls, ect. A Horrible amount of work went into getting to the point that we could even wire it. Now, looking back on it all, after the countless parties, movie nights, Sporting events, and on and on, I wouldn't have a house without it. It's the new living room.
sooly1 03-14-2014 09:21 PM
Another question. The D4s were out of stock by the time I ordered. The d2 and inuke 3000dsp will be great BUT, if I split the lfe out from the receiver into both channels of the inuke and wire each coil on its own channel, will that be ok for the sub? If so what should I limit power output to?
If that wiring option will work I will have a speak on for each coil.
I was a mobile dj for 10 years for weddings. I had a few speakon cables and connectors left over from that. I'll just use speaker wire inside the box and solder them to +1 and -1 for dual 2ohm connection on the outside of the box. Sunday can't get here soon enough. I should have more progress to report Sunday evening.
chalugadp 03-14-2014 09:26 PM
13 Attachment(s)
Power output in the 1100-1200 watts area. I would double check with a pro if that wiring will work , not me:sly:
LTD02 03-15-2014 06:24 AM
awesome...another marty to the party!
with a single d2 driver and a 3000 amp, no need to do anything other than wire the coils in series for 4 ohms and put it on the amp in bridged mode. then set the limiter to about 1100 watts at 4 ohms.
technically you could wire each coil to a channel, but that just sounds like a recipe for possible mistakes and blowups.
chalugadp 03-15-2014 07:18 AM
13 Attachment(s)
For those with two d2 subs and a single inuke3000dsp the most they can get is 600 watts per sub ?
steve nn 03-15-2014 07:32 AM
I dunno chal.. The way I took it was 1100w with the limiter engaged?
chalugadp 03-15-2014 07:56 AM
13 Attachment(s)
Its just if sooly decides to get another 18" single coil sub then does he lose the option of bridge mode ?
LTD02 03-15-2014 08:09 AM
at 4 ohms per channel, the 3000 will output about 650 watts per channel.
steve nn 03-15-2014 08:21 AM
I was trying to find a work around but it's just not there from what I can see and limited knowledge. If there was you would know. Kinda seems if the budget is there going the 6000 with employing the limiter is the way to go if a guy wants to get the full potential out of his sub with the possibility of adding another down the road.
Oh! Didn't someone sort of mention that the other day with a single driver except not explain with a single 3000 bridged. cool.gif
sooly1 03-15-2014 04:37 PM
Ahh man LTD02 posted in my marty thread.... pressure is on. Thanks for the tips guys. Bridge for now. Well. I'm 34 years old BLASTING Lateralus and building a speaker with glue all over my hands... poor touch screen. Pics later. biggrin.gif
kevings 03-15-2014 06:14 PM
Sooly1,
hows it coming over there buddy?
hey, i just finished up my tall marty, and posted some pics in my thread. take a peek later wink.gif
sooly1 03-15-2014 06:33 PM
Sides, back, ports, done. Miscut the double baffle by a nose hair so I need to shave some off. Clamp, glue, brad nail repeat! My wife keeps checking to make sure all my fingers are still attached. Rofl good times in my basement.
sooly1 03-16-2014 09:04 PM
Bracing is the worst part so far but it's getting there.
Going with a window type brace. So here is whats left.
1. Finish bracing
2. Mount driver to mark holes, remove driver, drill holes
3. Cut out speakon hole, place speakon plate. make sure it's air tight
4. Put the top on,stuff with polyfill in the middle, seal it up (not in that order lol)
5. TEST.
6. Decide what I'm going to do to finish it.
I used some misc wood I had at the house and put it on the back of the double baffle. I'm hoping that gives the screws something to bite into.
Sorry for the lack of pics. I'll have a couple soon but once I got going, I didn't stop. The build Process is perfectly documented with pics so no need to document my terrible craftsmanship!
chalugadp 03-16-2014 09:06 PM
13 Attachment(s)
Like I say to my woodworking students , its not the quantity , its always about the quality !
kevings 03-16-2014 09:09 PM
1. Finish bracing
5. TEST.
sounds like your making good progress / moving right along. I just got both of mine into my room tonight and setup....
YOU ARE GOING TO LIKE WHAT YOU HEAR......you'll see!
what kinds of questions are you wrestling with as far as the finish goes, or is it more of a "i just havent made up my mind yet" sort of thing?
sooly1 03-16-2014 10:33 PM
More of a not made up my mind. I really think with my sons friends and the parties we have I should just tile the top and sides so my piece of mind is there. ill have my buddy that owns a flooring store look for some dark tile tmrw.
sooly1 03-17-2014 06:20 PM
Update. Tile may not be the best idea. I would need to cement board the entire thing. Then I could tile. To much work lol.
kevings 03-17-2014 09:08 PM
yeah, i was wondering about how you were gonna do that. I think duratex is an option for you if you want easy, and durable. Some find the look boring though or maybe to pro audio. Another idea could be a nice dark stain, and then if your really worried about people bumping into the sub, maybe thos pro audio corner guard pieces might help. Im thinking they might blend in pretty good if the stain is dark enough.
Sooly, I got ask you though....when you have people over at your place....just how wild does it get? Are we talking animal house crazy? You dont think people would be careful in your HT room just knowing you worked hard on it, and spend $$$ in there to set it up?
( just basic manners sort of stuff, i guess )
sooly1 03-18-2014 08:26 AM
Well, it doesn't get real crazy....most of the time. However, overkill never hertz.....(see what I did there ;p).
I've put building on hold till Thursday when I'm off again. I did get the sub holes drilled last night though!
The good news is, with the sub in and the top just set on, it looks great!
sooly1 03-18-2014 06:25 PM
never mind. cant wait till thurs. guys coming over tonight to finish!
kevings 03-18-2014 06:38 PM
lol.....i remember feeling this way just a week ago or so!
Subwoofers seriously turn us into little kids on xmas morning.
take some pics for us.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
