UXL-18 Quadinator Build - Page 6 - AVS Forum
 7Likes
post #151 of 178 Old 04-13-2014, 08:26 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 145 Post(s)
Liked: 639
That's awesome. Sounds like you have it under control then. biggrin.gif Just a temporary setback. wink.gif
My Dual 18" LLT subs 120dB down to 10hz
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is offline
post #152 of 178 Old 04-13-2014, 08:28 PM - Thread Starter
doublewing11's Avatar
Quoted: 38 Post(s)
Liked: 202
Or course............................I'm fabulous!  :p
doublewing11 is offline
post #153 of 178 Old 04-14-2014, 12:24 AM
jbrown15's Avatar
Quoted: 311 Post(s)
Liked: 734
Originally Posted by doublewing11 View Post
My Gear:
JTR Noesis 228HT (LCR)
Axiom Audio QS8 surrounds
Sherbourn PA 7-350
Pioneer VSX-21TXH
JVC RS45
Falcon Screens FVHD105
Dual PSA XS30's (gone but not forgotten)
jbrown15 is online now
post #154 of 178 Old 04-14-2014, 10:18 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
Originally Posted by jbrown15 View Post
Two drivers are ready........received one today and will have fourth Thursday. Getting closer to firing them up......
post #155 of 178 Old 05-24-2014, 01:29 AM
SXRDISBEST's Avatar
Quoted: 21 Post(s)
Liked: 34
All four must have arrived by now! ???
SXRDISBEST is online now
post #156 of 178 Old 05-24-2014, 10:34 AM
jbrown15's Avatar
Quoted: 311 Post(s)
Liked: 734
Doublewing received the last two a few weeks ago, just check out his home theater build thread. He's had great results powering all four from a single IPR2 7500 amp, I think he's flat all the way down to 8hz too.
My Gear:
Sherbourn PA 7-350
Pioneer VSX-21TXH
JVC RS45
post #157 of 178 Old 05-24-2014, 01:10 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
Time flies when you're having fun........
As JB mentioned.........close to flat down to 8 Hz at 115 db's. Very impressed so far with performance on a single Peavey ipr2 7500. I tried to push amp as hard as I could.......hit 124 db's at MLP but just could take it any more! Not once have I clipped amp! eek.gif
post #158 of 178 Old 05-27-2014, 07:40 AM
Pure-Evil's Avatar
Liked: 139
ok so I don't know anything about that amplifier, but how did you run 4 subs with one amp? Just split the outputs? Sorry, again I'm trying to learn. Also, are these just 4 kits from PartsExpress? you said "knock down kits" so that' swhat I figured they are. I didn't think there were 18" kits...unless these are from somewhere else? Great work btw...i'm definitely jealous
Pure-Evil is offline
post #159 of 178 Old 05-27-2014, 09:05 AM
Bass Enabler
Quoted: 145 Post(s)
Liked: 639
Hell yeah. Where is this dude?!?!
F**kin' aye, bubba.
Goodtimes, man. Was this all in time to impress your daughter for her visit? redface.gif
post #160 of 178 Old 05-27-2014, 09:06 AM
Bass Enabler
Quoted: 145 Post(s)
Liked: 639
Yup. It is 2ohm stable and these drivers are all rated 4ohm (actually run slightly higher than usual) so it's a reasonable load on this amplifier to power four of such.
post #161 of 178 Old 05-27-2014, 09:18 AM
jbrown15's Avatar
Quoted: 311 Post(s)
Liked: 734
Scott, I always seem to get this mixed up...lol
So because they're 4ohm drivers and the amp is 2ohm stable you would just run two drivers per channel parallel right? or was it in series?...lol
My Gear:
Sherbourn PA 7-350
Pioneer VSX-21TXH
JVC RS45
post #162 of 178 Old 05-27-2014, 09:21 AM
Bass Enabler
Quoted: 145 Post(s)
Liked: 639
Yup. You got it!
Parallel two 4ohm drivers for a 2ohm net.
Series two 4ohm drivers for an 8ohm net.
post #163 of 178 Old 05-27-2014, 05:09 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
Yup......all done and I'm quite impressed!
post #164 of 178 Old 05-27-2014, 05:30 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
F**kin' aye, bubba.
Hey Scotty!
Yeah, I was hoping to have all set up for my Daughter's visit from Germany but subs arrived too late.
I had a small issue with my MiniDSP Open DRC-an and had to replace unit..........MiniDSP handled situation very well.
I have 30 inches of 12 AWG wire coming out of Peavey amp and then attached 4 conductor in-wall 12 AWG wire to each side essentially wiring front and back on separate channels in parallel..........reason being with 50 ft runs, resistance would be less by wiring near amp and because it I ordered another Peavey, it would be simple to re-wiring to run each UXL off each channel.
I don't think I'll need another amp since I'm almost flat to 8Hz at reference! Yes, you heard that right.....off just one Peavey, I'm hitting 115 db's at 8Hz at O on my Marantz 8801! eek.gif I've had output at scary volumes for me and have never clipped amp once!!!!!!
Didn't think I could do that on one Peavey, but I can! Now I don't listen at those levels........but I can if I want!
Here is a graph with MiniDSP Open in chain along with XT32 engaged with dynamic eq and volume off!
BTW, I'm not hiding from you...........you are a quality guy and have been most helpful.........and of course, "Fabulous!" tongue.gif
Well, I've been busy preparing for my coffered ceilings in Knotty Alder! They should look like this when I'm done! I have all Summer to complete.......wink.gif
What do you think?
post #165 of 178 Old 05-27-2014, 05:49 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
Four DIYSoundgroup flat packs which have cut-out for SI-18 driver. I like the looks of the rim gasket so the OD of this flat pack is better for me.........
I was actually thinking of ordering four more until I actually got them hooked up..........well, four is enough!!!!! eek.gif
See prior post on hooking up four UXL's on a single Peavey ipr2 7500.
post #166 of 178 Old 06-26-2014, 06:09 AM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
Did I actually say this?
I'm stacking the front..........thanks to Atmos round two! Like the Phoenix, Quadinator becomes Octo-inator!
Scott Simonian and LTD02 like this.
post #167 of 178 Old 06-26-2014, 07:23 AM
Mfusick's Avatar
Quoted: 79 Post(s)
Liked: 683
Get 4 more!
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #168 of 178 Old 06-26-2014, 07:57 AM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
Get 4 more!
That is what I'm thinking..........I have anther 20 amp circuit which was planned for running a Peavey with two UXL's. Since one 7500 handles 4 UXL's easily, adding another four would allow system to run effortlessly. I'm really thinking Octo-inator may be born out of the ashes!
Mfusick and jbrown15 like this.
post #169 of 178 Old 06-26-2014, 09:47 AM
Bass Enabler
Quoted: 145 Post(s)
Liked: 639
Hell yes.
Mfusick likes this.
post #170 of 178 Old 06-26-2014, 05:02 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
Hell yes.
No freaking Flat packs for me this time........
I'm going full DIY!!
post #171 of 178 Old 06-26-2014, 05:12 PM
LTD02's Avatar
Quoted: 135 Post(s)
Liked: 853
awesome.
Listen. It's All Good.
LTD02 is online now
post #172 of 178 Old 06-26-2014, 06:13 PM
Mfusick's Avatar
Quoted: 79 Post(s)
Liked: 683
FULL DIY ! I like it. That is the only way I will roll too. I like the CNC cut baffles though.. I admit those are nicer than I do with a router.
post #173 of 178 Old 06-26-2014, 06:17 PM
corradizo's Avatar
Insane in the membrane.
corradizo is online now
post #174 of 178 Old 06-26-2014, 06:28 PM
chalugadp's Avatar
Quoted: 433 Post(s)
Liked: 753
So you can already hit 130dbs plus and you want more. Time for SA.
Subwoofers anonymous
chalugadp is online now
post #175 of 178 Old 06-26-2014, 07:35 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
No, no, no.,........
I want system to cruise......and have lots of headroom. Besides, I'm old......bored, and need something to do!
Naaaaa........the real reason is I can't let Jbrown15 out do me!
post #176 of 178 Old 06-26-2014, 07:51 PM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 142 Post(s)
Liked: 350
Four is nice, but 8 will be just right. When I am done, I will have six 18's and two 12's.
Mike Garrett, AV Science Sales
Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI & many more.
Klipsch, RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is online now
post #177 of 178 Old 06-26-2014, 10:35 PM
SpinMonster's Avatar
Liked: 32
Hammer insert nuts are done........just need to line left two with Linacoutic RC and wait unti Thusday when I'll have all four drivers.
What size screen is that?
SpinMonster is offline
post #178 of 178 Old 06-27-2014, 06:08 AM - Thread Starter
Quoted: 38 Post(s)
Liked: 202
12 ft wide 2.37 Seymour-SE Enlightor 4k
User Tag List
